I have installed Manjaro KDE on RPI 4.
Under normal circumstances though, I would prefer it to not load into GUI.
Is there a way to make it boot into CLI by default?
Tried the b/m command, but did not work.
sudo systemctl set-default multi-user
Simply disable the display manager.
So for KDE edition, that would be:
sudo systemctl disable sddm
And then reboot. Should now boot to a CLI login screen.
Thanks. That worked.
