drbb
1 November 2023 13:36
1
This morning I received a few updates. This is the pacman log:
[2023-11-01T10:37:51+0100] [ALPM] upgraded nvidia-settings (535.113.01-1 -> 535.129.03-1)
[2023-11-01T10:37:51+0100] [ALPM] upgraded mhwd-nvidia (535.113.01-2 -> 535.129.03-1)
[2023-11-01T10:37:51+0100] [ALPM] upgraded mhwd-nvidia-470xx (470.199.02-4 -> 470.223.02-1)
[2023-11-01T10:37:46+0100] [ALPM] upgraded linux65-nvidia (535.113.01-2 -> 535.129.03-1)
[2023-11-01T10:37:42+0100] [ALPM] upgraded linux61-nvidia (535.113.01-2 -> 535.129.03-1)
[2023-11-01T10:37:42+0100] [ALPM] upgraded libxnvctrl (535.113.01-1 -> 535.129.03-1)
[2023-11-01T10:37:42+0100] [ALPM] upgraded lib32-nvidia-utils (535.113.01-1 -> 535.129.03-1)
[2023-11-01T10:37:41+0100] [ALPM] upgraded discord (0.0.32-1 -> 0.0.33-1)
[2023-11-01T10:37:39+0100] [ALPM] upgraded nvidia-utils (535.113.01-2 -> 535.129.03-1)
[2023-11-01T10:33:34+0100] [ALPM] upgraded archlinux-keyring (20230918-1 -> 20231026-1)
Kernels got recompiled. Kernel 6.5.5-1 boots just fine, but the 6.1.55-1 LTS doesn’t. This is what I get:
I’d like to stick with the LTS one because the other one behaves oddly with multiple displays.
Any idea?
Hi @drbb ,
My idea: I think you updated prematurely, I think there’s a stable update due any time now, with an incomplete sync.
I think this, because I see you are on the stable and I am too. But there hasn’t been an update today. Yet there is packages available for update:
$ pamac checkupdates
12 available updates:
archlinux-keyring 20230918-1 -> 20231026-1 core
chromium 118.0.5993.54-1 -> 118.0.5993.117-1 extra
lib32-nvidia-utils 535.113.01-1 -> 535.129.03-1 multilib
libxnvctrl 535.113.01-1 -> 535.129.03-1 extra
linux515-nvidia 535.113.01-2 -> 535.129.03-1 extra
linux61-nvidia 535.113.01-2 -> 535.129.03-1 extra
mhwd-nvidia 535.113.01-2 -> 535.129.03-1 extra
mhwd-nvidia-470xx 470.199.02-4 -> 470.223.02-1 extra
nvidia-settings 535.113.01-1 -> 535.129.03-1 extra
nvidia-utils 535.113.01-2 -> 535.129.03-1 extra
opencl-nvidia 535.113.01-2 -> 535.129.03-1 extra
vivaldi 6.2.3105.58-1 -> 6.4.3160.34-1 extra
So you can do 1 of two things, IMHO:
Wait for the sync to complete, since you have a booting kernel; or
use the working kernel to install an older LTS to use and test.
Hope this helps!
drbb
2 November 2023 10:01
3
Hi, thanks for the reply. This is a very odd situation: this “premature update” thing never happened before. I think I’ll stick with the current booting kernel for now and wait for the next stable update to hopefully fix things up.
Xephon
2 November 2023 10:34
4
drbb:
No they didn’t. There were no new kernel versions, look at your log. Only mkinitcpio
got updated.
I had the same update yesterday and kernel 6.1 boots without issues.
Boot 6.5 and reinstall 6.1.
drbb
2 November 2023 13:40
5
Yeah, sorry wrong term, I meant that the local ramdisk images were refreshed. Well, reinstalling kernel 6.1.55 solved the issue. I wonder what went wrong. Thanks.
system
Closed
5 November 2023 03:41
6
