First thanks for your reply!
I have no dual boot and no encrypted partition. Now, I’m in the stable branch, which has no problem.
inxi -cv8 gives:
Host: manjaro Kernel: 6.6.103-3-MANJARO arch: x86_64 bits: 64 compiler: gcc
v: 15.2.1 clocksource: tsc avail: hpet,acpi_pm
root=UUID=a37063d9-164e-40e8-aa78-511e3dadc5b1 rw
resume=UUID=677ae4e2-f3b6-482c-b895-12bb6c5af2fa
Desktop: LXQt v: 2.2.2 tk: Qt v: 6.9.2 wm: LabWC with: lxqt-panel,waybar
tools: swayidle vt: 1 dm: 1: LightDM v: 1.32.0 note: stopped 2: SDDM
note: stopped Distro: Manjaro base: Arch Linux
Type: Laptop System: LENOVO product: 80NV v: Lenovo ideapad Y700-15ISK
serial: <superuser required> Chassis: type: 10 v: Lenovo ideapad Y700-15ISK
Mobo: LENOVO model: Allsparks 5A v: NO DPK serial: <superuser required>
part-nu: LENOVO_MT_80NV_BU_idea_FM_Lenovo ideapad Y700-15ISK
uuid: <superuser required> UEFI: LENOVO v: CDCN53WW date: 09/19/2016
ID-1: BAT0 charge: 53.9 Wh (100%) condition: 53.9/60 Wh (89.8%) volts: 16.14
min: 14.8 model: SMP L14M4P23 type: Li-ion serial: 8577 charging:
status: full cycles: N/A
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K360
serial: 4b-5d-15-20 charge: 55% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 16 GiB available: 15.45 GiB used: 3.08 GiB (19.9%)
Array-1: capacity: 32 GiB slots: 4 modules: 2 EC: None
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
speed: 2133 MT/s volts: curr: 1 min: 1.25 max: 1.25 width (bits): data: 64
total: 64 manufacturer: 0467 part-no: RMSA3260MB78HAF2400 serial: 18195119
Device-2: ChannelA-DIMM1 type: no module installed
Device-3: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
speed: 2133 MT/s volts: curr: 1 min: 1.25 max: 2 width (bits): data: 64
Device-4: ChannelB-DIMM1 type: no module installed
Info: model: Intel Core i7-6700HQ bits: 64 type: MT MCP arch: Skylake-S
gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
model-id: 0x5E (94) stepping: 3 microcode: 0xF0
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 800 min/max: 800/3500 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 41621
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Type: gather_data_sampling status: Vulnerable: No microcode
vulnerable
Device-1: Intel HD Graphics 530 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:191b class-ID: 0300
Device-2: NVIDIA GM107M [GeForce GTX 960M] vendor: Lenovo driver: nvidia
v: 575.64.05 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-08; EOL~2026-12-xx) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-2019 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:139b
class-ID: 0302
Device-3: Bison Lenovo EasyCamera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:4 chip-ID: 5986:0672
class-ID: 0e02 serial: 200901010001
compositor: LabWC driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: LG Display 0x0533 built: 2016 res: mode: 1920x1080
hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red: x: 0.580 y: 0.349
green: x: 0.341 y: 0.561 blue: x: 0.153 y: 0.125 white: x: 0.314 y: 0.329
size: 340x190mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: 1920x1080
drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia wayland: drv: iris x11: drv: iris
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.2.1-arch1.4
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 530 (SKL GT2)
device-ID: 8086:191b memory: 15.09 GiB unified: yes display-ID: :0.0
API: Vulkan v: 1.4.321 layers: 2 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 960M driver: nvidia v: 575.64.05
device-ID: 10de:139b surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info,
wdisplays, wlr-randr x11: xdriinfo, xdpyinfo, xprop, xrandr
Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:a170 class-ID: 0403
API: ALSA v: k6.6.103-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
Device-1: Intel Wireless 8260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: 8086:24f3 class-ID: 0280
IF: wlp8s0 state: up mac: f0:d5:bf:bf:7d:40
IP v4: 192.168.1.4/24 type: dynamic noprefixroute scope: global
broadcast: 192.168.1.255
IP v6: fe80::d961:d80c:8a6e:7bfc/64 type: noprefixroute scope: link
vendor: Lenovo driver: r8168 v: 8.055.00-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 09:00.0 chip-ID: 10ec:8168
class-ID: 0200
IF: enp9s0 state: down mac: c8:5b:76:a0:10:dc
WAN IP: 151.238.6.1
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-11:5 chip-ID: 8087:0a2b
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: disabled
Local Storage: total: 1.03 TiB used: 174.97 GiB (16.7%)
model: MZVLW128HEGR-000L2 size: 119.24 GiB block-size: physical: 512 B
logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial: S35FNX0HA46846
fw-rev: 1L1QCXB7 temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
tech: HDD rpm: 5400 serial: WES30M3F fw-rev: LVM1 temp: 46.0 C scheme: GPT
ID-1: / raw-size: 118.74 GiB size: 116.32 GiB (97.96%)
used: 20.88 GiB (17.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: a37063d9-164e-40e8-aa78-511e3dadc5b1
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 4426-FF77
ID-3: /home raw-size: 97.66 GiB size: 95.56 GiB (97.86%)
used: 32.73 GiB (34.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 00c286f8-b8e9-496e-ad2f-fc2a7630cfad
ID-4: /media/sda3 raw-size: 97.66 GiB size: 95.56 GiB (97.86%)
used: 12.41 GiB (13.0%) fs: ext4 dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 61e92b37-6fef-450d-b5d7-8465c8587266
ID-5: /media/sda4 raw-size: 97.66 GiB size: 95.56 GiB (97.86%)
used: 18.2 GiB (19.0%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
uuid: bba4b14a-58a0-4c72-96ce-45d365ea2e6a
ID-6: /media/sda5 raw-size: 97.66 GiB size: 95.56 GiB (97.86%)
used: 15.81 GiB (16.5%) fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 087fad13-3140-41f3-beb5-d74f8ae2e9c2
ID-7: /media/sda7 raw-size: 476.43 GiB size: 467.88 GiB (98.21%)
used: 56.13 GiB (12.0%) fs: ext4 dev: /dev/sda7 maj-min: 8:7 label: N/A
uuid: 62db5230-9949-455e-a601-8fdc23dbd925
ID-8: /var raw-size: 48.83 GiB size: 47.76 GiB (97.81%)
used: 18.82 GiB (39.4%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: d4d5b1f8-ec8d-4600-a72b-229c511b80d5
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: partition size: 15.62 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: 677ae4e2-f3b6-482c-b895-12bb6c5af2fa
Device-1: 1-1:2 info: Logitech Nano Receiver type: keyboard,mouse
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c534 class-ID: 0301
Device-2: 1-3:3 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Device-3: 1-6:4 info: Bison Lenovo EasyCamera type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 5986:0672 class-ID: 0e02 serial: 200901010001
Device-4: 1-11:5 info: Intel Bluetooth wireless interface type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:0a2b class-ID: e001
Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.0
System Temperatures: cpu: 47.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 2138 libs: 508 tools: yay
1: http://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
2: http://manjaro.mirrors.lavatech.top/stable/$repo/$arch
3: http://mirrors.manjaro.org/repo/stable/$repo/$arch
Processes:
CPU top: 5 of 257
1: cpu: 18.5% command: qterminal pid: 13431 mem: 85.3 MiB (0.5%)
2: cpu: 8.3% command: firefox pid: 11551 mem: 656.4 MiB (4.1%)
3: cpu: 5.1% command: firefox pid: 11785 mem: 287.4 MiB (1.8%)
4: cpu: 4.1% command: labwc pid: 1143 mem: 179.0 MiB (1.1%)
5: cpu: 1.6% command: conky pid: 1489 mem: 31.4 MiB (0.1%)
Memory top: 5 of 257
1: mem: 656.4 MiB (4.1%) command: firefox pid: 11551 cpu: 8.3%
2: mem: 553.2 MiB (3.4%) command: thunderbird pid: 2455 cpu: 0.3%
3: mem: 287.4 MiB (1.8%) command: firefox pid: 11785 cpu: 5.1%
4: mem: 245.4 MiB (1.5%) command: firefox pid: 11799 cpu: 0.3%
5: mem: 193.9 MiB (1.2%) command: firefox pid: 11716 cpu: 0.4%
Processes: 257 Power: uptime: 3h 17m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 6.17 GiB services: upowerd Init: systemd
v: 257 default: graphical tool: systemctl
Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Bash v: 5.3.3
running-in: qterminal inxi: 3.3.39
Also be aware that after changing branch…
Yes, of course
My wild guess is that something may be wrong with one of the grub packages in testing and unstable (grub, install-grub, update-grub), because everything else is related to the system, while I couldn’t start to boot — as I said, there was nothing to boot into
The Lenovo logo stayed there forever without any activity when I was in testing/unstable branch.
Sorry that I can’t do more tests for a while, coding under Manjaro for LXQt…
