I am in the middle of installation process of Manjaro Linux, and I got an error message when I click on both [Boot with open source drivers] and [Boot with proprietary drivers] that says:
[ 5.142988] Initramfs unpacking failed: XZ-compressed data is corrupt
Warning: /lib/modules/5.15.31-1-MANJARO/modules.devname not found - ignoring systemd-tmpfiles: error while loading shared libraries: libsystemd-shared-250.so: cannot open shared object file: No such file or directory
/init: line 6: usr/lib/systemd/systemd-udevd: not found
udevadm: error while loading shared libraries: libsystemd-shared-250.so: cannot open shared object file: No such file or directory
ERROR: ’ /dev/disk/by-label/MANJARO_KDE_2126’ device did not show up after 30 seconds. . .
Falling back to interactive prompt
You can try to fix the problem manually, log out when you are finished
sh: can’t access tty; job control turned off
[rootfs ]#
//I tried to type but it doesnt let me type anything
I already verified the iso image and downloaded it again but it doesn’t work. I’m performing a live boot from usb. How do I set up the booting process?
