Hey there!
I want to revive an old Laptop and I am really excited about Manjaro XFCE. I succesfully installed it on a quite fast USB3.0 drive (BIOS Legacy Installation), but when I tried to boot from it, I figured out that for some reason my Laptop does not support its USB3.0 port during BIOS/Boot phase. The drive does not show up in BIOS, and there is no options in there regarding USB. I can boot Manjaro when I plug it into an USB 2.0 port though.
What I have tried:
Running sudo update-grub on my HDD installation of Ubuntu, so that it recognizes Manjaro on the USB stick. It adds an entry, but Grub is unable to boot if I select the entry, not finding the drive. The “ls” command in grubs command line only shows me the hard drive.
Maybe a bit stupid: Plugging the drive from USB2.0 to 3.0 when Manjaro is fully started, hoping that it would just run from RAM enough to recognize its file system was only offline temporarily. Obviously, it did not work.
What do you think? Is there a solution how I can use Manjaro from USB3.0? I wonder if there is a way to feed grub the necessary drivers, or even let it boot a kernel on my hard drive that then continues to boot from my USB3.0 drive. I would also be okay with a quick and dirty solution that allows me to unplug and replug the drive without Manjaro crashing.
Thx!
