Boot from sdxc (mmc_core mmc_block) issue after update
Hi,
I updated my laptop two days ago, and I have the issue described below.
Foreword
  • Manjaro is on a sdhc. sdhc boot is quicker then the hd on this old laptop
  • My 2014 lenovo (multiboot) has a sdcard reader, but for some reason I can’t boot directly from it in bios. Boot process is:
  • initial load of refind (EFI booting) from hd efi partition. I could not find a way to see the sdhc from refind (likely a lack of module…)
  • refind pass control to linux kernel, loaded from hd (/dev/sda3)
  • linux kernel launched with root=/dev/mmcblk0p2
  • from here normal boot process, with /dev/sda3 mounted in /boot
Issue
  • after update I could not boot anymore
  • doing nothing I was landing on an emergency shell
  • after some troubleshooting I found that if I insert the sdhc AFTER the kernel is loaded, boot is ok
  • instead if I leave the sdhc inserted and boot the /dev/mmcblk0 is not recognized and I land on the emergency shell
So the experience is that I need to manually trigger the module load to have the kernel to see the sdhc. The matter is the laptop is used as “family kiosk”, in a not easily reachable position. I do not know how to force the kernel to access the sdhc. For the moment the workaround is to root=/dev/sda4, a hd partition where I did a cp -a from the original sdhc root.
Suggestions? Many thanks!
inxi -zv8
  Kernel: 6.6.80-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    clocksource: tsc avail: acpi_pm parameters: root=/dev/sda4 rw quiet splash
    udev.log_priority=3 initrd=\initramfs-6.6-x86_64.img
  Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A info: frameworks v: 6.11.0
    wm: kwin_wayland vt: 4 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Laptop System: LENOVO product: 80L0 v: Lenovo G50-80
    serial: <superuser required> Chassis: type: 10 v: Lenovo G50-80
  Mobo: LENOVO model: Lenovo G50-80 v: 31900058 WIN
    part-nu: LENOVO_MT_80L0_BU_idea_FM_Lenovo G50-80
    uuid: <superuser required> UEFI: LENOVO v: B0CN72WW date: 01/27/2015
  ID-1: BAT0 charge: 22.4 Wh (99.6%) condition: 22.5/28.5 Wh (78.8%)
    power: 6.7 W volts: 16.4 min: 14.4 model: Lenovo IdeaPad type: Unknown
    serial: <filter> status: charging
  Device-1: hidpp_battery_0 model: Logitech Illuminated Living-Room
    Keyboard K830 serial: <filter> charge: 50% (should be ignored)
    rechargeable: yes status: discharging
  System RAM: total: 8 GiB available: 7.68 GiB used: 4.1 GiB (53.4%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
    speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Hynix/Hyundai part-no: HMT451S6BFR8A-PB serial: <filter>
  Device-2: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
  Info: model: Intel Core i3-4005U bits: 64 type: MT MCP arch: Haswell
    gen: core 4 level: v3 note: check built: 2013-15 process: Intel 22nm
    family: 6 model-id: 0x45 (69) stepping: 1 microcode: 0x17
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1597 min/max: 800/1600 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 1597 2: 1597 3: 1597 4: 1597 bogomips: 13574
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
    dtherm dts epb erms est f16c fma fpu fsgsbase fxsr ht invpcid lahf_lm lm
    mca mce mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
    pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
    rdtscp rep_good sdbg sep smep ss sse sse2 sse4_1 sse4_2 ssse3 syscall tm
    tm2 tsc tsc_adjust vme xsave xsaveopt xtopology xtpr
  Type: itlb_multihit status: KVM: VMX unsupported
  Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
    SMT vulnerable
  Type: spectre_v2 mitigation: Retpolines; STIBP: disabled; RSB filling;
  Type: srbds status: Vulnerable: No microcode
  Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo driver: i915
    v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
    active: HDMI-A-1 off: eDP-1 empty: DP-1,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:0a16 class-ID: 0300
  Device-2: Bison Lenovo EasyCamera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:4 chip-ID: 5986:0652
    alternate: fbdev,vesa dri: crocus gpu: i915 display-ID: 0
  Monitor-1: HDMI-A-1 model: Panasonic Panasonic-TV serial: <filter>
    built: 2011 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 70 gamma: 1.2
    chroma: red: x: 0.639 y: 0.345 green: x: 0.290 y: 0.635 blue: x: 0.161
    y: 0.090 white: x: 0.286 y: 0.294 size: 698x392mm (27.48x15.43")
    diag: 801mm (31.52") modes: 1920x1080, 1920x1080i, 1280x720, 720x576,
    720x576i, 720x480, 720x480i, 640x480
  Monitor-2: eDP-1 model: AU Optronics 0x40ec built: 2013 res: 1366x768
    dpi: 101 gamma: 1.2 chroma: red: x: 0.580 y: 0.333 green: x: 0.329 y: 0.565
    blue: x: 0.153 y: 0.137 white: x: 0.314 y: 0.329
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
    modes: 1366x768
  API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
    device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus wayland:
    drv: crocus x11: drv: crocus
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4400 (HSW
    GT2) device-ID: 8086:0a16 memory: 1.46 GiB unified: yes display-ID: :3.0
  Device-1: Intel Haswell-ULT HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
  Device-2: Intel 8 Series HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
  API: ALSA v: k6.6.80-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Intel Wireless 3160 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b4 class-ID: 0280
  IF-ID-1: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
  IP v4: <filter> scope: global
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:5 chip-ID: 8087:07dc
    class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
  Local Storage: total: 931.51 GiB used: 16.56 GiB (1.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: ST1000LM024 HN-M101MBB
    tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GUC0N rev: T.02
    dev-links: cdrom
  ID-1: / raw-size: 58.59 GiB size: 57.37 GiB (97.92%) used: 16.24 GiB (28.3%)
    fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
    uuid: 9b796aa6-db6b-4761-9d03-9df1634bffd9
  ID-2: /boot raw-size: 400 MiB size: 358.5 MiB (89.62%)
    used: 135.7 MiB (37.9%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
    label: LinuxBoot uuid: 9d1d5605-c7be-4b3a-935d-500cfc4566f5
  ID-3: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
    used: 194.1 MiB (75.8%) fs: vfat dev: /dev/sda2 maj-min: 8:2
    label: SYSTEM_DRV uuid: 9CAD-34EE
  ID-1: /dev/sda1 maj-min: 8:1 size: 1000 MiB fs: ntfs label: WINRE_DRV
    uuid: 7C08AB0B08AAC38C
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 8 rev: 2.0
  Device-1: 1-3:2 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c52b class-ID: 0300
  Device-2: 1-4:3 info: Realtek RTS5129 Card Reader Controller
    power: 500mA chip-ID: 0bda:0129 class-ID: ff00 serial: <filter>
  Device-3: 1-6:4 info: Bison Lenovo EasyCamera type: video driver: uvcvideo
    interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 500mA chip-ID: 5986:0652 class-ID: 0e02 serial: <filter>
  Device-4: 1-7:5 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:07dc class-ID: e001
  Hub-2: 2-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 42.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1206 libs: 324 tools: pamac pm: flatpak pkgs: 0
    1: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    2: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    3: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    4: https://mirror.init7.net/manjaro/stable/$repo/$arch
    5: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    6: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    7: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    8: https://mirrors.manjaro.org/repo/stable/$repo/$arch
Processes:
  CPU top: 5 of 255
  1: cpu: 17.4% command: firefox pid: 2778 mem: 439.7 MiB (5.5%)
  2: cpu: 7.8% command: firefox pid: 2901 mem: 258.3 MiB (3.2%)
  3: cpu: 5.2% command: konsole pid: 3297 mem: 205.1 MiB (2.6%)
  4: cpu: 4.5% command: kwin_wayland pid: 2079 mem: 221.3 MiB (2.8%)
  5: cpu: 4.3% command: firefox pid: 2863 mem: 145.0 MiB (1.8%)
  Memory top: 5 of 255
  1: mem: 439.7 MiB (5.5%) command: firefox pid: 2778 cpu: 17.4%
  2: mem: 423.2 MiB (5.3%) command: firefox pid: 1025 cpu: 2.5%
  3: mem: 384.0 MiB (4.8%) command: plasmashell pid: 2229 cpu: 2.9%
  4: mem: 308.0 MiB (3.9%) command: plasmashell pid: 879 cpu: 1.3%
  5: mem: 282.7 MiB (3.5%) command: kscreenlocker_greet pid: 1745 cpu: 1.2%
  Processes: 255 Power: uptime: 15m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 3.06 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: konsole
    inxi: 3.3.37
In your case I would buy a cheap sdd and install Manjaro on it instead of a sdhc. You have created a very special boot case which is most likely not considered by anyone maintaining packages affecting your boot situation in the future. With other words, even if you find a solution for now, further issues are highly likely to show up in the future, again.
Hi,
I looked at the card, it is a sdxc. Previously all was working fine, and because if I insert the card after kernel load I’m able to boot, I assume (possibly wrongly), that a module is missing in the (new) kernel?
I’ll try booting with an older kernel and report back here …
Do you have already
microcode
in the HOOKS=( line of your /etc/mkinitcpio.conf?
If not, add it after autodetect and run
sudo mkinitcpio -P
sudo update-grub
and reboot.
Hi,
so I tried with a 6.1 kernel, and I also tried the above microcode in mkinitcpio.conf. Both not solving the issue. I tried the following, and it revolvs around the mmc_block module.
  • after succesfull boot from sda4 at command prompt as root with sdxc inserted since power on: mount /dev/mmcblk0p1 /mnt fails and a blkid does not list /dev/mmcblk0
  • I then manually extract and insert back the sdxc. Now blkid shows it and mount succeed
  • I also tried to boot from the sdxc with a kernel line option root=/dev/mmcblk0p2 no splash. At one point I see a line “Waiting for /dev/mmcblk0p2” repeated a few times, the attempt from kernel to mount /. As said above if at that moment I insert the sdxc, boot progress nicely. If I do nothing boot fails and a emergency shell is prompted
So my conclusion is that the kernel has the module mmc_block “at hand”, and that the manual insert triggers the creation of the block device /dev/mmcblk0. So question is how may I force it?
Hi
I refer to the other thread, for inxi and “preface” (Boot from sdxc (mmc_core mmc_block) issue after update - #5 by rednose). I’m löooking at hint who/how the /dev/mmcblk0 device file gets created. I did the following check, with the sdxc already inserted before power on:
  1. I boot from a live-cd. At a prompt I do a lsblk or blkid, and /dev/mmcblk0 is shown
  2. I tried also to boot from a “recovery usb” like clonezilla. same as above the sdxc is found
  3. If I boot from my newly update Manjaro, the only way to have it sensed is manually extract and reinsert the sdxc
How can I force/trigger manjaro to “see” the sdxc?
Many thanks!
To try to clarify:
  • the card is already inserted when you boot
  • all the other distros see it
  • your Manjaro does not see it unless you eject it and insert it again
Correct?
I can’t offer any solution - I just wanted to clarify whether this is the issue or whether I misunderstood.
Correct!
The only thing I can think of right now is:
partprobe (in a terminal)
perhaps the command needs sudo (admin) privileges
It’s what, for instance, gparted does when you tell it to re-discover devices
I can’t test this - I do have SD cards, but I don’t run Manjaro on my machine
I am thinking - does your firmware has a setting called something Fast Boot?
The setting - if enabled - skips scanning for devices that is not required for starting the system.
The fact your sdcard is not recognized on boot - but if you eject and insert - then it is recognized, this makes me think if Fast Boot is enabled.
partprobe … no effects
fast boot: yes, it is present in the bios, but it is disabled.
About initial post: when I say live-cd, I meant I installed a live-cd on a usb stick, and that I can boot from it. laptop is a lenovo g50-80. It was never able to boot from bios directly to sd, nor I was able to “see” the sd from grub or refind. That is why I was loading the kernel from a small hd partition, then having manjaro “/” on the sdxc. Everithing was working nicely since last update, meaning manjaro was able to see the sdxc when inserted before power on.
I tried to boot with different kernels 6.1 and now 6.12, but I think something the way the kernel is built (hooks/mkinitcpio) lead to the issue
That is why I’m even able to boot from the sdxc, if during boot when kernel says “waiting 10 sec for /dev/mmcblk0p2” I insert the sdxc …
I have tested three (3) different systems - all three have a card reader - all three of them recognize the sd-card present before starting the system.
What ever it is - it must be something specific to your system - I cannot say what it is - what I can say - I am not able to reproduce the issue.
  1. cheap yepo plastic laptop - Linux 6.12.4
  2. Tuxedo Infinitibook Pro 14 gen.8 - Linux 6.12.13
  3. Lenovo ThinkStation P620 - Linux 6.12.18
Not much consolation - I know …
thanks for giving it a try!
I’m downloading now manjaro kde minimal, I’ll install on the usb stick. If after booting from it the sd-drive is seen, I’ll reinstall. Then in principle I should do a diff of partitions, between the currently booting on hd and the one on sd-disc to understand what the hell occurred … :frowning:
OK so there is definetively a bug in the last manjaro kde update. That is why:
  1. I downloaded manjaro kde minimal and installed on a usb
  2. booted from usb and installed on the sdxc (erasing partition option in installer)
  3. rebooted as before (i.e. efi from hd, kernel from hd, root from sdxc
    all was working fine and as before then
  4. updated system + reboot
    same situation, sdxc no more visible … something in the kernel build during update (mkinitcpio/hooks) is wrong …
The threads have now been merged considering they are closely related. Note that it’s usually better for those wishing to help for inxi output to be added to a new thread, regardless of how often you might have posted it in other topics.
