I corrected the spurious # and changed the UUID to match that provided by BG405. Here’s step by step with restoring grub:
pacman -Syu grub
core is up to date
extra is up to date
multilib is up to date
warning: grub-2:2.12-3 is up to date -- reinstalling
resolving dependencies...
Packages (1) grub-2:2.12-3
Total Installed Size: 48.04 MiB
Net Upgrade Size: 0.00 MiB
:: Proceed with installation? [Y/n] Y
(1/1) checking keys in keyring [############] 100%
(1/1) checking package integrity [############] 100%
(1/1) loading package files [############] 100%
(1/1) checking for file conflicts [############] 100%
(1/1) checking available disk space [############] 100%
(1/1) Creating Timeshift snapshot before upgrade...
==> skipping timeshift-autosnap due skipRsyncAutosnap in /etc/timeshift-autosnap.conf set to TRUE.
(1/1) reinstalling grub [############] 100%
:: To use the new features provided in this GRUB update, it is recommended
to install it to the MBR or UEFI. Due to potential configuration
incompatibilities, it is advised to run both, installation and generation
of configuration:
# UEFI: https://wiki.archlinux.org/title/GRUB#Installation
# BIOS: https://wiki.archlinux.org/title/GRUB#Installation_2
(1/3) Arming ConditionNeedsUpdate...
(2/3) Refreshing PackageKit...
Error connecting: Could not connect: No such file or directory
error: command failed to execute correctly
(3/3) Updating the info directory file...
I note the “error connecting” message above, but as grub was seemingly already installed and up to date, I proceeded:
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
Installing for x86_64-efi platform.
Installation finished. No error reported.
There are errors and warnings in the next step:
grub-mkconfig -o /boot/grub/grub.cfg
Found linux image: /boot/vmlinuz-6.12-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.12-x86_64.
Found initrd fallback image: /boot/initramfs-6.12-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.6-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.6-x86_64.i
mg
Found initrd fallback image: /boot/initramfs-6.6-x86_64-fallback.img
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-6.1-x86_64.i
mg
Found initrd fallback image: /boot/initramfs-6.1-x86_64-fallback.img
Warning: os-prober will be executed to detect other bootable partition
s.
Its output will be used to detect bootable binaries on them and create
new boot entries.
ERROR: mkdir /var/lock/dmraid
Root filesystem isn't btrfs
If you think an error has occurred, please file a bug report at "https
://github.com/Antynea/grub-btrfs"
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
Found memtest86+ EFI image: /boot/memtest86+/memtest.efi
done
An “unknown device type nvme0n1” appears in this next step:
mg
mg
s.
new boot entries.
done
The “verify the existence of efi” step. It is not explained what one should look for, but it does not seem to verify much.
lsblk -o PATH,PTTYPE,PARTTYPE,FSTYPE,PARTTYPENAME
PATH PTTYPE PARTTYPE FSTYPE PARTTYPENAME
/dev/loop0
/dev/loop1
/dev/loop2
/dev/loop3
/dev/sr0
/dev/nvme0n1
/dev/nvme0n1p1
/dev/nvme0n1p2
/dev/nvme0n1p3
The “verify efi filesystem step.”
ls /sys/firmware/efi
config_table esrt fw_vendor runtime-map
efivars fw_platform_size runtime systab
Now one is asked to “try loading the efi system.” This does not look like it worked.
modprobe efivarfs
modprobe: FATAL: Module efivarfs not found in directory /lib/modules/6.12.4-1-MANJARO
Next, mounting the efi filesystem. This did not return anything.
Finally, “verify that the efi system is loaded:”
Finally, the last statement probably should say “If NOT successful”?
If successfull re-run above installation commands
Also, here’s lsblk -f:
lsblk -f ✔
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
loop0 squash 4.0 0 100% /run/miso/sfs/livefs
loop1 squash 4.0 0 100% /run/miso/sfs/mhwdfs
loop2 squash 4.0 0 100% /run/miso/sfs/desktopfs
loop3 squash 4.0 0 100% /run/miso/sfs/rootfs
sr0 iso966 Jolie MANJARO_KDE_2421 2024-12-16-11-21-39-00 0 100% /run/miso/bootmnt
nvme0n1
├─nvme0n1p1
│ vfat FAT32 ADE6-11AF 299.1M 0% /mnt/boot/efi
├─nvme0n1p2
│ ext4 1.0 fc3e655b-f7ce-407a-8107-00d3073125af 129.2G 88% /mnt
│ /run/media/manjaro/fc3e655b-f7ce-407a-8107-00d3073125af
└─nvme0n1p3
swap 1 swap 8867e950-c703-4a9f-822b-7dc231f8b99f
I’ll wait for any feedback before doing more. (But again, the extra disk was NOT a clone, it was a fresh install from a fresh ISO.)
Thank you.
