Regarding the parameters acpi_osi=Linux acpi_backlight=vendor I want to clarify that I haven’t changed anything in these parameters. I followed the instructions you provided and implemented the changes as you suggested.
~ journalctl -b0 -p4 --no-pager 1 ✘ 3s
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: x86/cpu: SGX disabled by BIOS.
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: MMIO Stale Data CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/processor_mmio_stale_data.html for more details.
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: #5 #6 #7
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.LPCB.HEC], AE_NOT_FOUND (20230331/dswload2-162)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20230331/psobject-220)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.BAT1], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230331/psobject-220)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_TZ.ETMD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.GPLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.TPLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.GUPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.TUPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS01._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS02._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS03._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS04._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS05._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS05._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS06._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS07._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS08._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS08._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS09._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS09._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS10._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS10._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS11._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS11._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS12._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS12._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS13._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS13._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS14._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.HS14._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR1._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR1._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR2._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.USR2._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS01._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS02._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS03._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS04._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS05._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS05._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS06._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS06._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS07._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS07._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS08._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS08._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS09._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS09._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS10._UPC], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.XHC.RHUB.SS10._PLD], AE_ALREADY_EXISTS (20230331/dswload2-326)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI Error: AE_NOT_FOUND, While resolving a named reference package element - \_SB_.PCI0.LPCB.H_EC.TFN1 (20230331/dspkginit-438)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: hpet_acpi_add: no address or irqs in _CRS
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: nvidia: loading out-of-tree module taints kernel.
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: nvidia: module license 'NVIDIA' taints kernel.
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: Disabling lock debugging due to kernel taint
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: nvidia: module license taints kernel.
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 535.98 Tue Aug 1 21:42:05 UTC 2023
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: usb: port power management may be unreliable
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: memfd_create() without MFD_EXEC nor MFD_NOEXEC_SEAL, pid=1 'systemd'
Aug 24 20:57:45 romka-asustufgamingf15fx506lhfx506lh systemd-vconsole-setup[251]: Failed to import credentials, ignoring: Нет такого файла или каталога
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh (udev-worker)[282]: nvidia: Process '/usr/bin/bash -c '/usr/bin/mknod -Z -m 666 /dev/nvidiactl c $(grep nvidia-frontend /proc/devices | cut -d \ -f 1) 255'' failed with exit code 1.
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI Warning: \_SB.IETM._ART: Found unexpected NULL package element (20230331/nsrepair-187)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI Warning: \_SB.IETM._ART: Missing expected return value (20230331/nsrepair-203)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI Warning: \_SB.IETM._ART: Expected return object of type Reference (20230331/nspredef-249)
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: _ART package 0 is invalid, ignored
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: _ART package 1 is invalid, ignored
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: _ART package 2 is invalid, ignored
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh (udev-worker)[282]: nvidia: Process '/usr/bin/bash -c 'for i in $(cat /proc/driver/nvidia/gpus/*/information | grep Minor | cut -d \ -f 4); do /usr/bin/mknod -Z -m 666 /dev/nvidia${i} c $(grep nvidia-frontend /proc/devices | cut -d \ -f 1) ${i}; done'' failed with exit code 1.
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh (udev-worker)[287]: cfg80211: Process '/usr/bin/set-wireless-regdom' failed with exit code 1.
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: r8169 0000:04:00.0: can't disable ASPM; OS doesn't have ASPM control
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: asus_wmi: fan_curve_get_factory_default (0x00110024) failed: -19
Aug 24 20:57:46 romka-asustufgamingf15fx506lhfx506lh kernel: asus_wmi: fan_curve_get_factory_default (0x00110025) failed: -19
Aug 24 20:57:47 romka-asustufgamingf15fx506lhfx506lh bluetoothd[1094]: src/plugin.c:plugin_init() System does not support csip plugin
Aug 24 20:57:47 romka-asustufgamingf15fx506lhfx506lh bluetoothd[1094]: src/plugin.c:plugin_init() System does not support vcp plugin
Aug 24 20:57:47 romka-asustufgamingf15fx506lhfx506lh bluetoothd[1094]: src/plugin.c:plugin_init() System does not support mcp plugin
Aug 24 20:57:47 romka-asustufgamingf15fx506lhfx506lh bluetoothd[1094]: src/plugin.c:plugin_init() System does not support bass plugin
Aug 24 20:57:47 romka-asustufgamingf15fx506lhfx506lh bluetoothd[1094]: src/plugin.c:plugin_init() System does not support bap plugin
Aug 24 20:57:47 romka-asustufgamingf15fx506lhfx506lh systemd-xdg-autostart-generator[1177]: /home/romka/.config/autostart/manjaro-starter.desktop: not generating unit, error parsing Exec= line: No such file or directory
Aug 24 20:57:47 romka-asustufgamingf15fx506lhfx506lh systemd-xdg-autostart-generator[1177]: /home/romka/.config/autostart/manjaro-app-folder-settings.desktop: not generating unit, error parsing Exec= line: No such file or directory
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh gdm-autologin][1165]: gkr-pam: couldn't unlock the login keyring.
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) Log file renamed from "/var/log/Xorg.pid-1192.log" to "/var/log/Xorg.0.log"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: X.Org X Server 1.21.1.8
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: X Protocol Version 11, Revision 0
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: Current Operating System: Linux romka-asustufgamingf15fx506lhfx506lh 6.4.9-1-MANJARO #1 SMP PREEMPT_DYNAMIC Wed Aug 9 08:32:12 UTC 2023 x86_64
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.4-x86_64 root=UUID=b9c159f5-3ae0-44de-83c9-87e7f9fc6fdb rw acpi_osi=Linux acpi_backlight=vendor i915.enable_psr=0
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: Current version of pixman: 0.42.2
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: Before reporting problems, check http://wiki.x.org
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: to make sure that you have the latest version.
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: Markers: (--) probed, (**) from config file, (==) default setting,
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (++) from command line, (!!) notice, (II) informational,
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) Log file: "/var/log/Xorg.0.log", Time: Thu Aug 24 20:57:48 2023
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) Using system config directory "/usr/share/X11/xorg.conf.d"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) ServerLayout "layout"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) No screen section available. Using defaults.
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) |-->Screen "Default Screen Section" (0)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) | |-->Monitor "<default monitor>"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) No monitor specified for screen "Default Screen Section".
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: Using a default monitor configuration.
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) Automatically adding devices
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) Automatically enabling devices
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) Automatically adding GPU devices
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) Automatically binding GPU devices
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) Max clients allowed: 256, resource mask: 0x1fffff
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (WW) The directory "/usr/share/fonts/misc" does not exist.
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: Entry deleted from font path.
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (Run 'mkfontdir' on "/usr/share/fonts/TTF").
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (WW) The directory "/usr/share/fonts/OTF" does not exist.
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (WW) The directory "/usr/share/fonts/Type1" does not exist.
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (WW) The directory "/usr/share/fonts/100dpi" does not exist.
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (WW) The directory "/usr/share/fonts/75dpi" does not exist.
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) FontPath set to:
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) ModulePath set to "/usr/lib/xorg/modules"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) The server relies on udev to provide the list of input devices.
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: If no devices become available, reconfigure udev or disable AutoAddDevices.
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Module ABI versions:
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: X.Org ANSI C Emulation: 0.4
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: X.Org Video Driver: 25.2
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: X.Org XInput driver : 24.4
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: X.Org Server Extension : 10.0
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (++) using VT number 2
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) xfree86: Adding drm device (/dev/dri/card1)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card1
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got fd for /dev/dri/card1 226:1 fd 14 paused 0
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) xfree86: Adding drm device (/dev/dri/card0)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card0
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 15 paused 0
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) PCI:*(0@0:2:0) 8086:9bc4:1043:177f rev 5, Mem @ 0xc3000000/16777216, 0xa0000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) PCI: (1@0:0:0) 10de:1f99:1043:177f rev 161, Mem @ 0xc4000000/16777216, 0xb0000000/268435456, 0xc0000000/33554432, I/O @ 0x00004000/128, BIOS @ 0x????????/524288
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) LoadModule: "glx"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Module glx: vendor="X.Org Foundation"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: compiled for 1.21.1.8, module version = 1.0.0
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: ABI class: X.Org Server Extension, version 10.0
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Applying OutputClass "intel" to /dev/dri/card0
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: loading driver: modesetting
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Applying OutputClass "nvidia" to /dev/dri/card1
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: loading driver: nvidia
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) Matched modesetting as autoconfigured driver 0
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) Matched nvidia as autoconfigured driver 1
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) Matched nouveau as autoconfigured driver 2
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) Matched nv as autoconfigured driver 3
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) Matched fbdev as autoconfigured driver 4
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) Matched vesa as autoconfigured driver 5
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) Assigned the driver to the xf86ConfigLayout
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) LoadModule: "modesetting"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Module modesetting: vendor="X.Org Foundation"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: compiled for 1.21.1.8, module version = 1.21.1
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: Module class: X.Org Video Driver
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: ABI class: X.Org Video Driver, version 25.2
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) LoadModule: "nvidia"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Module nvidia: vendor="NVIDIA Corporation"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: compiled for 1.6.99.901, module version = 1.0.0
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) LoadModule: "nouveau"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (WW) Warning, couldn't open module nouveau
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (EE) Failed to load module "nouveau" (module does not exist, 0)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) LoadModule: "nv"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (WW) Warning, couldn't open module nv
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (EE) Failed to load module "nv" (module does not exist, 0)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) LoadModule: "fbdev"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (WW) Warning, couldn't open module fbdev
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (EE) Failed to load module "fbdev" (module does not exist, 0)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) LoadModule: "vesa"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (WW) Warning, couldn't open module vesa
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (EE) Failed to load module "vesa" (module does not exist, 0)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modesetting: Driver for Modesetting Kernel Drivers: kms
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA dlloader X Driver 535.98 Tue Aug 1 21:44:52 UTC 2023
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): using drv /dev/dri/card0
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: releasing fd for 226:1
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Loading sub module "fb"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) LoadModule: "fb"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Module "fb" already built-in
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Loading sub module "wfb"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) LoadModule: "wfb"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Loading /usr/lib/xorg/modules/libwfb.so
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Module wfb: vendor="X.Org Foundation"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: ABI class: X.Org ANSI C Emulation, version 0.4
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Creating default Display subsection in Screen section
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: "Default Screen Section" for depth/fbbpp 24/32
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) modeset(0): Depth 24, (==) framebuffer bpp 32
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) modeset(0): RGB weight 888
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) modeset(0): Default visual is TrueColor
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Loading sub module "glamoregl"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) LoadModule: "glamoregl"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Loading /usr/lib/xorg/modules/libglamoregl.so
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Module glamoregl: vendor="X.Org Foundation"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: compiled for 1.21.1.8, module version = 1.0.1
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh kernel: ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230331/nsarguments-61)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) UHD Graphics (CML GT2)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): glamor initialized
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) modeset(0): VariableRefresh: disabled
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) modeset(0): AsyncFlipSecondaries: disabled
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Output eDP-1 has no monitor section
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): EDID for output eDP-1
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Manufacturer: NCP Model: 4d Serial#: 0
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Year: 2019 Week: 51
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): EDID Version: 1.4
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Digital Display Input
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): 8 bits per channel
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Digital interface is DisplayPort
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Max Image Size [cm]: horiz.: 34 vert.: 19
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Gamma: 2.20
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): No DPMS capabilities specified
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Supported color encodings: RGB 4:4:4
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): First detailed timing is preferred mode
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Preferred mode is native pixel format and refresh rate
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Display is continuous-frequency
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): redX: 0.595 redY: 0.361 greenX: 0.346 greenY: 0.555
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): blueX: 0.157 blueY: 0.106 whiteX: 0.312 whiteY: 0.328
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Manufacturer's mask: 0
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Supported detailed timing:
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): clock: 354.7 MHz Image Size: 344 x 194 mm
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): h_active: 1920 h_sync: 1968 h_sync_end 2000 h_blank_end 2180 h_border: 0
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): v_active: 1080 v_sync: 1083 v_sync_end 1088 v_blanking: 1130 v_border: 0
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): clock: 147.8 MHz Image Size: 344 x 194 mm
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Ranges: V min: 48 V max: 144 Hz, H min: 154 H max: 154 kHz, PixClock max 355 MHz
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): LM156LF-2F01
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): EDID (in hex):
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): 00ffffffffffff0038704d0000000000
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): 331d0104a5221378036850985c588e28
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): 1b505400000001010101010101010101
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): 010101010101918a8004713832403020
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): 350058c21000001abd39800471383240
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): 3020350058c21000001a000000fd0030
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): 909a9a23010a202020202020000000fe
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): 004c4d3135364c462d324630310a0049
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Printing probed modes for output eDP-1
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1920x1080"x144.0 354.73 1920 1968 2000 2180 1080 1083 1088 1130 +hsync -vsync (162.7 kHz eP)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1920x1080"x60.0 356.38 1920 2080 2288 2656 1080 1081 1084 1118 doublescan -hsync +vsync (134.2 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1920x1080"x60.0 266.50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1920x1080"x60.0 147.81 1920 1968 2000 2180 1080 1083 1088 1130 +hsync -vsync (67.8 kHz e)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1400x1050"x74.8 155.80 1400 1464 1784 1912 1050 1052 1064 1090 +hsync +vsync (81.5 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1600x900"x60.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1600x900"x59.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1280x1024"x85.0 157.50 1280 1344 1504 1728 1024 1025 1028 1072 +hsync +vsync (91.1 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1280x960"x85.0 148.50 1280 1344 1504 1728 960 961 964 1011 +hsync +vsync (85.9 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1440x810"x60.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1440x810"x60.0 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1280x800"x60.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1280x800"x60.0 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1280x720"x60.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1280x720"x60.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1024x768"x85.0 194.02 1024 1108 1220 1416 768 768 770 806 doublescan -hsync +vsync (137.0 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1024x768"x75.0 170.24 1024 1108 1220 1416 768 768 770 801 doublescan -hsync +vsync (120.2 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1024x768"x60.0 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1024x768"x85.0 94.50 1024 1072 1168 1376 768 769 772 808 +hsync +vsync (68.7 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1024x768i"x87.0 44.90 1024 1032 1208 1264 768 768 776 817 interlace +hsync +vsync (35.5 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "960x720"x85.0 170.68 960 1036 1144 1328 720 720 722 756 doublescan -hsync +vsync (128.5 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "960x720"x75.0 148.50 960 1032 1144 1320 720 720 722 750 doublescan -hsync +vsync (112.5 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "960x720"x60.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "928x696"x75.0 144.00 928 992 1104 1280 696 696 698 750 doublescan -hsync +vsync (112.5 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "928x696"x60.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "896x672"x75.0 130.50 896 944 1052 1228 672 672 674 708 doublescan -hsync +vsync (106.3 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "896x672"x60.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1024x576"x60.0 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1024x576"x60.0 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "960x600"x59.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "960x600"x60.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "832x624"x74.6 57.28 832 864 928 1152 624 625 628 667 -hsync -vsync (49.7 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "960x540"x60.0 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "960x540"x60.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "800x600"x85.0 114.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (106.2 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "800x600"x75.0 101.25 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (93.8 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "800x600"x70.0 94.50 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (87.5 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "800x600"x65.0 87.75 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (81.2 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "800x600"x60.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "800x600"x85.1 56.30 800 832 896 1048 600 601 604 631 +hsync +vsync (53.7 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "840x525"x60.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "840x525"x59.9 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "700x525"x74.8 77.90 700 732 892 956 525 526 532 545 doublescan +hsync +vsync (81.5 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "700x525"x60.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "800x450"x59.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "800x450"x59.8 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "640x512"x85.0 78.75 640 672 752 864 512 512 514 536 doublescan +hsync +vsync (91.1 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "640x512"x75.0 67.50 640 648 720 844 512 512 514 533 doublescan +hsync +vsync (80.0 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "640x512"x60.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "700x450"x60.0 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "700x450"x59.9 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "640x480"x85.1 74.25 640 672 752 864 480 480 482 505 doublescan +hsync +vsync (85.9 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "640x480"x60.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "640x480"x85.0 36.00 640 696 752 832 480 481 484 509 -hsync -vsync (43.3 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "720x400"x85.0 35.50 720 756 828 936 400 401 404 446 -hsync +vsync (37.9 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "684x384"x59.9 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "684x384"x59.9 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "640x400"x59.9 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "640x400"x60.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "640x400"x85.1 31.50 640 672 736 832 400 401 404 445 -hsync +vsync (37.9 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "576x432"x75.0 54.00 576 608 672 800 432 432 434 450 doublescan +hsync +vsync (67.5 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "640x360"x59.9 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "640x360"x59.8 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "640x350"x85.1 31.50 640 672 736 832 350 382 385 445 +hsync -vsync (37.9 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "512x384"x85.0 47.25 512 536 584 688 384 384 386 404 doublescan +hsync +vsync (68.7 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "512x384"x75.0 39.38 512 520 568 656 384 384 386 400 doublescan +hsync +vsync (60.0 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "512x384"x70.1 37.50 512 524 592 664 384 385 388 403 doublescan -hsync -vsync (56.5 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "512x384"x60.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "512x384i"x87.1 22.45 512 516 604 632 384 384 388 408 interlace doublescan +hsync +vsync (35.5 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "512x288"x60.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "512x288"x59.9 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "416x312"x74.7 28.64 416 432 464 576 312 312 314 333 doublescan -hsync -vsync (49.7 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "480x270"x59.6 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "480x270"x59.8 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "400x300"x85.3 28.15 400 416 448 524 300 300 302 315 doublescan +hsync +vsync (53.7 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "400x300"x72.2 25.00 400 428 488 520 300 318 321 333 doublescan +hsync +vsync (48.1 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "400x300"x75.1 24.75 400 408 448 528 300 300 302 312 doublescan +hsync +vsync (46.9 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "400x300"x60.3 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "400x300"x56.3 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "432x243"x59.9 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "432x243"x59.6 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "320x240"x85.2 18.00 320 348 376 416 240 240 242 254 doublescan -hsync -vsync (43.3 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "320x240"x72.8 15.75 320 332 352 416 240 244 246 260 doublescan -hsync -vsync (37.9 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "320x240"x75.0 15.75 320 328 360 420 240 240 242 250 doublescan -hsync -vsync (37.5 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "320x240"x60.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "360x202"x59.5 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "360x202"x59.1 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "360x200"x85.0 17.75 360 378 414 468 200 200 202 223 doublescan -hsync +vsync (37.9 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "320x200"x85.3 15.75 320 336 368 416 200 200 202 222 doublescan -hsync +vsync (37.9 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "320x180"x59.8 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "320x180"x59.3 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "320x175"x85.3 15.75 320 336 368 416 175 191 192 222 doublescan +hsync -vsync (37.9 kHz d)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Output eDP-1 connected
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Using exact sizes for initial modes
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Output eDP-1 using initial mode 1920x1080 +0+0
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) modeset(0): DPI set to (96, 96)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) NVIDIA(G0): Depth 24, (==) framebuffer bpp 32
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) NVIDIA(G0): RGB weight 888
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) NVIDIA(G0): Default visual is TrueColor
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) NVIDIA(G0): Using gamma correction (1.0, 1.0, 1.0)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "AllowNVIDIAGpuScreens"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Applying OutputClass "nvidia" options to /dev/dri/card1
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) NVIDIA(G0): Option "AllowEmptyInitialConfiguration"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) NVIDIA(G0): Enabling 2D acceleration
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Loading sub module "glxserver_nvidia"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) LoadModule: "glxserver_nvidia"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: Module class: X.Org Server Extension
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA GLX Module 535.98 Tue Aug 1 21:49:22 UTC 2023
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA: The X server supports PRIME Render Offload.
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(0): DFP-0
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(0): DFP-1
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(0): DFP-2
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): NVIDIA GPU NVIDIA GeForce GTX 1650 (TU117-A) at PCI:1:0:0
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): (GPU-0)
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(G0): Memory: 4194304 kBytes
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(G0): VideoBIOS: 90.17.4b.00.22
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): Detected PCI Express Link width: 16X
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-0: disconnected
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-1: disconnected
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-1: 2660.0 MHz maximum pixel clock
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-2: disconnected
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): Validated MetaModes:
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): "NULL"
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): Virtual screen size determined to be 640 x 480
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (WW) NVIDIA(G0): Unable to get display device for DPI computation.
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) NVIDIA(G0): DPI set to (75, 75); computed from built-in default
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) modeset(0): Backing store enabled
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) modeset(0): Silken mouse enabled
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) modeset(0): DPMS enabled
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): [DRI2] Setup complete
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): [DRI2] DRI driver: iris
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): [DRI2] VDPAU driver: va_gl
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA: Reserving 24576.00 MB of virtual memory for indirect memory
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA: access.
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): ACPI: failed to connect to the ACPI event daemon; the daemon
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): may not be running or the "AcpidSocketPath" X
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): configuration option may not be set correctly. When the
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): ACPI event daemon is available, the NVIDIA X driver will
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): try to use it to receive ACPI event notifications. For
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): details, please see the "ConnectToAcpid" and
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): "AcpidSocketPath" X configuration options in Appendix B: X
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): Config Options in the README.
Aug 24 20:57:48 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): Setting mode "NULL"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) NVIDIA(G0): Disabling shared memory pixmaps
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) NVIDIA(G0): Backing store enabled
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) NVIDIA(G0): Silken mouse enabled
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (==) NVIDIA(G0): DPMS enabled
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Loading sub module "dri2"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) LoadModule: "dri2"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Module "dri2" already built-in
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): [DRI2] Setup complete
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): [DRI2] VDPAU driver: nvidia
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension Generic Event Extension
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension SHAPE
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension MIT-SHM
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension XInputExtension
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension XTEST
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension BIG-REQUESTS
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension SYNC
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension XKEYBOARD
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension XC-MISC
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension SECURITY
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension XFIXES
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension RENDER
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension RANDR
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension COMPOSITE
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension DAMAGE
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension MIT-SCREEN-SAVER
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension DOUBLE-BUFFER
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension RECORD
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension DPMS
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension Present
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension DRI3
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension X-Resource
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension XVideo
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension XVideo-MotionCompensation
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension GLX
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Indirect GLX disabled.
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) AIGLX: Loaded and initialized iris
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) GLX: Initialized DRI2 GL provider for screen 0
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension XFree86-VidModeExtension
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension XFree86-DGA
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension XFree86-DRI
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension DRI2
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension NV-GLX
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Initializing extension NV-CONTROL
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Damage tracking initialized
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Setting screen physical size to 508 x 285
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) config/udev: Adding input device Power Button (/dev/input/event3)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Power Button: Applying InputClass "libinput keyboard catchall"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Power Button: Applying InputClass "system-keyboard"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) LoadModule: "libinput"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Module libinput: vendor="X.Org Foundation"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: compiled for 1.21.1.8, module version = 1.3.0
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: Module class: X.Org XInput Driver
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: ABI class: X.Org XInput driver, version 24.4
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Using input driver 'libinput' for 'Power Button'
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got fd for /dev/input/event3 13:67 fd 48 paused 0
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Power Button: always reports core events
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "Device" "/dev/input/event3"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event3 - Power Button: is tagged by udev as: Keyboard
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event3 - Power Button: device is a keyboard
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event3 - Power Button: device removed
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "xkb_layout" "us"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) config/udev: Adding input device Asus Wireless Radio Control (/dev/input/event7)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Asus Wireless Radio Control: Applying InputClass "libinput keyboard catchall"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Asus Wireless Radio Control: Applying InputClass "system-keyboard"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Using input driver 'libinput' for 'Asus Wireless Radio Control'
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got fd for /dev/input/event7 13:71 fd 51 paused 0
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Asus Wireless Radio Control: always reports core events
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "Device" "/dev/input/event7"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event7 - Asus Wireless Radio Control: is tagged by udev as: Keyboard
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event7 - Asus Wireless Radio Control: device is a keyboard
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event7 - Asus Wireless Radio Control: device removed
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/ATK4002:00/input/input7/event7"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) XINPUT: Adding extended input device "Asus Wireless Radio Control" (type: KEYBOARD, id 7)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) config/udev: Adding input device Video Bus (/dev/input/event4)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Video Bus: Applying InputClass "libinput keyboard catchall"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Video Bus: Applying InputClass "system-keyboard"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Using input driver 'libinput' for 'Video Bus'
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got fd for /dev/input/event4 13:68 fd 52 paused 0
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Video Bus: always reports core events
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "Device" "/dev/input/event4"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event4 - Video Bus: is tagged by udev as: Keyboard
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event4 - Video Bus: device is a keyboard
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event4 - Video Bus: device removed
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input4/event4"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) config/udev: Adding input device Video Bus (/dev/input/event5)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got fd for /dev/input/event5 13:69 fd 53 paused 0
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "Device" "/dev/input/event5"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event5 - Video Bus: is tagged by udev as: Keyboard
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event5 - Video Bus: device is a keyboard
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event5 - Video Bus: device removed
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:13/LNXVIDEO:01/input/input5/event5"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 9)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) config/udev: Adding input device Power Button (/dev/input/event2)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got fd for /dev/input/event2 13:66 fd 54 paused 0
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "Device" "/dev/input/event2"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event2 - Power Button: is tagged by udev as: Keyboard
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event2 - Power Button: device is a keyboard
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event2 - Power Button: device removed
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2/event2"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 10)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) config/udev: Adding input device Lid Switch (/dev/input/event1)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) No input driver specified, ignoring this device.
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) This device may have been added with another device file.
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) config/udev: Adding input device Sleep Button (/dev/input/event0)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Sleep Button: Applying InputClass "system-keyboard"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Using input driver 'libinput' for 'Sleep Button'
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got fd for /dev/input/event0 13:64 fd 55 paused 0
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Sleep Button: always reports core events
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "Device" "/dev/input/event0"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event0 - Sleep Button: is tagged by udev as: Keyboard
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event0 - Sleep Button: device is a keyboard
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event0 - Sleep Button: device removed
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input0/event0"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 11)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=3 (/dev/input/event9)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=7 (/dev/input/event10)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=8 (/dev/input/event12)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) config/udev: Adding input device HDA NVidia HDMI/DP,pcm=9 (/dev/input/event13)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) config/udev: Adding input device ELAN1203:00 04F3:307A Mouse (/dev/input/event14)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) ELAN1203:00 04F3:307A Mouse: Applying InputClass "libinput pointer catchall"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Using input driver 'libinput' for 'ELAN1203:00 04F3:307A Mouse'
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got fd for /dev/input/event14 13:78 fd 56 paused 0
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) ELAN1203:00 04F3:307A Mouse: always reports core events
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "Device" "/dev/input/event14"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event14 - ELAN1203:00 04F3:307A Mouse: is tagged by udev as: Mouse Pointingstick
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event14 - ELAN1203:00 04F3:307A Mouse: device is a pointer
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event14 - ELAN1203:00 04F3:307A Mouse: device removed
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) libinput: ELAN1203:00 04F3:307A Mouse: Step value 0 was provided, libinput Fallback acceleration function is used.
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-6/i2c-ELAN1203:00/0018:04F3:307A.0001/input/input16/event14"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) XINPUT: Adding extended input device "ELAN1203:00 04F3:307A Mouse" (type: MOUSE, id 12)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "AccelerationScheme" "none"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) ELAN1203:00 04F3:307A Mouse: (accel) selected scheme none/0
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) ELAN1203:00 04F3:307A Mouse: (accel) acceleration factor: 2.000
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) ELAN1203:00 04F3:307A Mouse: (accel) acceleration threshold: 4
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) config/udev: Adding input device ELAN1203:00 04F3:307A Mouse (/dev/input/mouse0)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) config/udev: Adding input device ELAN1203:00 04F3:307A Touchpad (/dev/input/event15)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) ELAN1203:00 04F3:307A Touchpad: Applying InputClass "libinput touchpad catchall"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Using input driver 'libinput' for 'ELAN1203:00 04F3:307A Touchpad'
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got fd for /dev/input/event15 13:79 fd 57 paused 0
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) ELAN1203:00 04F3:307A Touchpad: always reports core events
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "Device" "/dev/input/event15"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event15 - ELAN1203:00 04F3:307A Touchpad: is tagged by udev as: Touchpad
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event15 - ELAN1203:00 04F3:307A Touchpad: device is a touchpad
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event15 - ELAN1203:00 04F3:307A Touchpad: device removed
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) libinput: ELAN1203:00 04F3:307A Touchpad: Step value 0 was provided, libinput Fallback acceleration function is used.
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:15.0/i2c_designware.0/i2c-6/i2c-ELAN1203:00/0018:04F3:307A.0001/input/input17/event15"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) XINPUT: Adding extended input device "ELAN1203:00 04F3:307A Touchpad" (type: TOUCHPAD, id 13)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) ELAN1203:00 04F3:307A Touchpad: (accel) selected scheme none/0
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) ELAN1203:00 04F3:307A Touchpad: (accel) acceleration factor: 2.000
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) ELAN1203:00 04F3:307A Touchpad: (accel) acceleration threshold: 4
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) config/udev: Adding input device ELAN1203:00 04F3:307A Touchpad (/dev/input/mouse1)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event16)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event17)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event18)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event19)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) config/udev: Adding input device Asus WMI hotkeys (/dev/input/event11)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Asus WMI hotkeys: Applying InputClass "libinput keyboard catchall"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Asus WMI hotkeys: Applying InputClass "system-keyboard"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Using input driver 'libinput' for 'Asus WMI hotkeys'
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got fd for /dev/input/event11 13:75 fd 58 paused 0
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Asus WMI hotkeys: always reports core events
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "Device" "/dev/input/event11"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event11 - Asus WMI hotkeys: is tagged by udev as: Keyboard
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event11 - Asus WMI hotkeys: device is a keyboard
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event11 - Asus WMI hotkeys: device removed
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "config_info" "udev:/sys/devices/platform/asus-nb-wmi/input/input11/event11"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) XINPUT: Adding extended input device "Asus WMI hotkeys" (type: KEYBOARD, id 14)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event6)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got fd for /dev/input/event6 13:70 fd 59 paused 0
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) AT Translated Set 2 keyboard: always reports core events
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "Device" "/dev/input/event6"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event6 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event6 - AT Translated Set 2 keyboard: device is a keyboard
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event6 - AT Translated Set 2 keyboard: device removed
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input6/event6"
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 15)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) config/udev: Adding input device PC Speaker (/dev/input/event8)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh kernel: Bluetooth: hci0: HCI Enhanced Setup Synchronous Connection command is advertised, but not supported.
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh bluetoothd[1094]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Failed (0x03)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh bluetoothd[1094]: Failed to clear UUIDs: Failed (0x03)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh bluetoothd[1094]: Failed to add UUID: Failed (0x03)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh bluetoothd[1094]: Failed to set mode: Failed (0x03)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh gnome-session-binary[1287]: WARNING: Desktop file /home/romka/.config/autostart/manjaro-starter.desktop for application manjaro-starter.desktop could not be parsed or references a missing TryExec binary
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh gnome-session-binary[1287]: WARNING: Desktop file /home/romka/.config/autostart/manjaro-app-folder-settings.desktop for application manjaro-app-folder-settings.desktop could not be parsed or references a missing TryExec binary
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh gnome-keyring-daemon[1303]: discover_other_daemon: 1
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh gnome-keyring-daemon[1304]: discover_other_daemon: 1
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh gnome-keyring-daemon[1305]: discover_other_daemon: 1
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh systemd[1171]: app-gnome-gnome\x2dkeyring\x2dpkcs11-1299.scope: Failed to add PIDs to scope's control group: No such process
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh systemd[1171]: app-gnome-gnome\x2dkeyring\x2dpkcs11-1299.scope: Failed with result 'resources'.
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh systemd[1171]: Failed to start Application launched by gnome-session-binary.
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh systemd[1171]: app-gnome-gnome\x2dkeyring\x2dsecrets-1302.scope: Failed to add PIDs to scope's control group: No such process
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh systemd[1171]: app-gnome-gnome\x2dkeyring\x2dsecrets-1302.scope: Failed with result 'resources'.
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh systemd[1171]: app-gnome-gnome\x2dkeyring\x2dssh-1300.scope: Failed to add PIDs to scope's control group: No such process
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh systemd[1171]: app-gnome-gnome\x2dkeyring\x2dssh-1300.scope: Failed with result 'resources'.
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): EDID vendor "NCP", prod id 77
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Using EDID range info for horizontal sync
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Using EDID range info for vertical refresh
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Printing DDC gathered Modelines:
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1920x1080"x0.0 354.73 1920 1968 2000 2180 1080 1083 1088 1130 +hsync -vsync (162.7 kHz eP)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1920x1080"x0.0 147.81 1920 1968 2000 2180 1080 1083 1088 1130 +hsync -vsync (67.8 kHz e)
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Using hsync ranges from config file
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Using vrefresh ranges from config file
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-0: disconnected
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-1: disconnected
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-1: 2660.0 MHz maximum pixel clock
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-2: disconnected
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
Aug 24 20:57:49 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
Aug 24 20:57:50 romka-asustufgamingf15fx506lhfx506lh geoclue[1427]: Failed to connect to avahi service: Daemon not running
Aug 24 20:57:50 romka-asustufgamingf15fx506lhfx506lh systemd[1171]: app-gnome-user\x2ddirs\x2dupdate\x2dgtk-1584.scope: Failed to add PIDs to scope's control group: No such process
Aug 24 20:57:50 romka-asustufgamingf15fx506lhfx506lh systemd[1171]: app-gnome-user\x2ddirs\x2dupdate\x2dgtk-1584.scope: Failed with result 'resources'.
Aug 24 20:57:50 romka-asustufgamingf15fx506lhfx506lh systemd[1171]: Failed to start Application launched by gnome-session-binary.
Aug 24 20:57:50 romka-asustufgamingf15fx506lhfx506lh gsd-usb-protect[1574]: Failed to fetch USBGuard parameters: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.usbguard1 was not provided by any .service files
Aug 24 20:57:50 romka-asustufgamingf15fx506lhfx506lh pulseaudio[1426]: stat('/etc/pulse/default.pa.d'): Нет такого файла или каталога
Aug 24 20:57:50 romka-asustufgamingf15fx506lhfx506lh bluetoothd[1094]: Failed to add UUID: Failed (0x03)
Aug 24 20:57:51 romka-asustufgamingf15fx506lhfx506lh gsd-media-keys[1557]: Failed to grab accelerator for keybinding settings:playback-random
Aug 24 20:57:51 romka-asustufgamingf15fx506lhfx506lh gsd-media-keys[1557]: Failed to grab accelerator for keybinding settings:hibernate
Aug 24 20:57:51 romka-asustufgamingf15fx506lhfx506lh gsd-media-keys[1557]: Failed to grab accelerator for keybinding settings:playback-repeat
Aug 24 20:57:51 romka-asustufgamingf15fx506lhfx506lh gsd-media-keys[1557]: Failed to grab accelerator for keybinding settings:rotate-video-lock
Aug 24 20:57:51 romka-asustufgamingf15fx506lhfx506lh kernel: ucsi_acpi USBC000:00: error -ETIMEDOUT: PPM init failed
Aug 24 20:57:52 romka-asustufgamingf15fx506lhfx506lh systemd-coredump[1948]: [🡕] Process 1568 (python3) of user 1000 dumped core.
Stack trace of thread 1568:
#0 0x00007fdccd6a4070 n/a (n/a + 0x0)
Aug 24 20:57:52 romka-asustufgamingf15fx506lhfx506lh wpa_supplicant[1215]: bgscan simple: Failed to enable signal strength monitoring
Aug 24 21:04:07 romka-asustufgamingf15fx506lhfx506lh gnome-shell[1309]: Can't update stage views actor <unnamed>[<MetaWindowActorX11>:0x560ee7a44bb0] is on because it needs an allocation.
Aug 24 21:04:07 romka-asustufgamingf15fx506lhfx506lh gnome-shell[1309]: Can't update stage views actor <unnamed>[<MetaSurfaceActorX11>:0x560ee76224e0] is on because it needs an allocation.
Aug 24 21:05:32 romka-asustufgamingf15fx506lhfx506lh gnome-shell[1309]: JS ERROR: TypeError: this.actor is null
_syncEnabled@resource:///org/gnome/shell/ui/windowManager.js:139:25
onStopped@resource:///org/gnome/shell/ui/windowManager.js:151:35
_makeEaseCallback/<@resource:///org/gnome/shell/ui/environment.js:151:22
_easeActorProperty/<@resource:///org/gnome/shell/ui/environment.js:317:60
_destroyWindowDone@resource:///org/gnome/shell/ui/windowManager.js:1596:21
onStopped@resource:///org/gnome/shell/ui/windowManager.js:1564:39
_easeActor/<@resource:///org/gnome/shell/ui/environment.js:240:64
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "fd" "48"
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event3 - Power Button: device removed
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "fd" "51"
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event7 - Asus Wireless Radio Control: device removed
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "fd" "52"
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event4 - Video Bus: device removed
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "fd" "53"
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event5 - Video Bus: device removed
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "fd" "54"
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event2 - Power Button: device removed
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "fd" "55"
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event0 - Sleep Button: device removed
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "fd" "56"
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event14 - ELAN1203:00 04F3:307A Mouse: device removed
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "fd" "57"
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event15 - ELAN1203:00 04F3:307A Touchpad: device removed
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "fd" "58"
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event11 - Asus WMI hotkeys: device removed
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (**) Option "fd" "59"
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event6 - AT Translated Set 2 keyboard: device removed
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) AIGLX: Suspending AIGLX clients for VT switch
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got pause for 13:78
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got pause for 13:71
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got pause for 13:79
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got pause for 13:66
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got pause for 13:67
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got pause for 13:64
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got pause for 13:68
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got pause for 13:75
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got pause for 13:70
Aug 24 21:45:24 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got pause for 13:69
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh kernel: queueing ieee80211 work while going to suspend
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got resume for 13:78
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got resume for 13:71
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got resume for 13:79
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got resume for 13:66
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got resume for 13:67
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got resume for 13:64
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got resume for 13:68
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got resume for 13:75
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got resume for 226:0
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) AIGLX: Resuming AIGLX clients after VT switch
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): EDID vendor "NCP", prod id 77
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Using hsync ranges from config file
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Using vrefresh ranges from config file
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Printing DDC gathered Modelines:
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1920x1080"x0.0 354.73 1920 1968 2000 2180 1080 1083 1088 1130 +hsync -vsync (162.7 kHz eP)
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) modeset(0): Modeline "1920x1080"x0.0 147.81 1920 1968 2000 2180 1080 1083 1088 1130 +hsync -vsync (67.8 kHz e)
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-0: disconnected
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-1: disconnected
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-1: Internal DisplayPort
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-1: 2660.0 MHz maximum pixel clock
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-2: disconnected
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): Setting mode "NULL"
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): ACPI: failed to connect to the ACPI event daemon; the daemon
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): may not be running or the "AcpidSocketPath" X
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): configuration option may not be set correctly. When the
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): ACPI event daemon is available, the NVIDIA X driver will
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): try to use it to receive ACPI event notifications. For
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): details, please see the "ConnectToAcpid" and
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): "AcpidSocketPath" X configuration options in Appendix B: X
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) NVIDIA(G0): Config Options in the README.
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event3 - Power Button: is tagged by udev as: Keyboard
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event3 - Power Button: device is a keyboard
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event7 - Asus Wireless Radio Control: is tagged by udev as: Keyboard
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event7 - Asus Wireless Radio Control: device is a keyboard
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event4 - Video Bus: is tagged by udev as: Keyboard
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event4 - Video Bus: device is a keyboard
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event2 - Power Button: is tagged by udev as: Keyboard
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event2 - Power Button: device is a keyboard
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event0 - Sleep Button: is tagged by udev as: Keyboard
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event0 - Sleep Button: device is a keyboard
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event14 - ELAN1203:00 04F3:307A Mouse: is tagged by udev as: Mouse Pointingstick
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event14 - ELAN1203:00 04F3:307A Mouse: device is a pointer
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event15 - ELAN1203:00 04F3:307A Touchpad: is tagged by udev as: Touchpad
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event15 - ELAN1203:00 04F3:307A Touchpad: device is a touchpad
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event11 - Asus WMI hotkeys: is tagged by udev as: Keyboard
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event11 - Asus WMI hotkeys: device is a keyboard
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got resume for 13:70
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event6 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event6 - AT Translated Set 2 keyboard: device is a keyboard
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) systemd-logind: got resume for 13:69
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event5 - Video Bus: is tagged by udev as: Keyboard
Aug 24 21:51:04 romka-asustufgamingf15fx506lhfx506lh /usr/lib/gdm-x-session[1192]: (II) event5 - Video Bus: device is a keyboard
Aug 24 21:51:09 romka-asustufgamingf15fx506lhfx506lh wpa_supplicant[1215]: bgscan simple: Failed to enable signal strength monitoring
~ ls /etc/modprobe.d ✔
mhwd-gpu.conf
~ find /etc/X11/ -name "*.conf" ✔
/etc/X11/mhwd.d/nvidia.conf
/etc/X11/xorg.conf.d/00-keyboard.conf
/etc/X11/xorg.conf.d/90-mhwd.conf
For the sake of simplification, I’m considering trying a fresh installation of Manjaro full edition. It’s possible that the issue might be related to the minimal version I’m currently using. Before delving too deep into troubleshooting, I’d like to rule out any potential installation-related problems.
I greatly appreciate your guidance and support in this matter. Thank you for taking the time to provide advice. Your assistance has been immensely valuable to me.
