Hi all,
I have put together a new system, moving away from my almost decade old thinkpad, to a small desktop where I plan to have my Linux install alongside a Windows install which I need for Adobe software. I dd’d my Linux install over onto an M.2 drive and migrated to EFI while I was at it. I also dd’d my existing windows install over to a SATA SSD. Now this is where things get strange and I don’t really know which direction to go in (Google hasn’t turned up anything useful thus far).
With both drives connected, selecting Windows there are no boot issues which makes sense as the previous machine was also EFI. Disconnecting the windows drive and booting into Arch also gives no issues. Now if I connect both drives and attempt to boot into Arch I get the following.
mount: /new_root: wrong fs type, bad option, bad superblock on /dev/sda1, missing codepage or helper program, or other error.
and then I land in an emergency shell.
Now my intuition is telling me that somehow the boot process is at some point targeting the Windows drive given the /dev/sdX notation instead of the /dev/nvmeXX that I am used to seeing with M.2 drives.
I am stumped as to where to go, I installed grub using the following
sudo grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=manjaro --recheck
after mounting my efi partition to /boot/efi
I also tried following this up with sudo update-grub
but also to no avail.
Any points in the right direction would be greatly appreciated.
Cheers and happy holidays!
