i’m trying to run a script called booksplit (https://github.com/LukeSmithxyz/voidrice/blob/master/.local/bin/booksplit
), that functions with another script called tag (https://github.com/LukeSmithxyz/voidrice/blob/master/.local/bin/tag
The script (booksplit) is meant to take an audio file, like an album or audiobook, and split it into smaller audiofiles, as tracks or chapters, based on timecodes provided as input in a text file.
I’ve made sure to have installed all the requirements and have mimicked and compared my results with what I see in the video made by the author of the script (https://www.youtube.com/watch?v=z_CcQhbwINU
When I run the script with the following command:
sh .local/bin/booksplit.sh *audiofile.m4a* *timecodes.txt*
It seems to split the tracks but not tag them. The result is only a directory with the album name and .opus files, each named after a track in the album. But these are not the audio files the script is supposed to output, the script seems to ignore the inputted audio file, making an incomplete execution.
This is my inxi
output
Kernel: 5.18.17-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.18-x86_64
root=UUID=34ad0c3f-417e-47b5-a595-c2f224c5ae7a rw quiet apparmor=1
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 20210 v: Lenovo IdeaPad P500
serial: <superuser required> Chassis: type: 10 v: Lenovo IdeaPad P500
Mobo: LENOVO model: INVALID v: 31900003WIN8 STD MLT
serial: <superuser required> UEFI: LENOVO v: 71CN44WW(V1.17)
date: 04/03/2013
ID-1: BAT1 charge: 37.8 Wh (100.0%) condition: 37.8/N/A Wh volts: 16.3
min: 14.4 model: LENOVO PABAS0241231 type: Li-ion serial: <filter>
status: full
RAM: total: 5.65 GiB used: 2.48 GiB (43.8%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i5-3230M bits: 64 type: MT MCP arch: Ivy Bridge
gen: core 3 level: v3 built: 2012-15 process: Intel 22nm family: 6
model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1208 high: 1243 min/max: 1200/3200 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1197 2: 1197 3: 1197
4: 1243 bogomips: 20759
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
erms est f16c flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida lahf_lm lm mca
mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tsc tsc_deadline_timer vme x2apic xsave xsaveopt xtopology xtpr
Type: itlb_multihit status: KVM: VMX unsupported
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
active: HDMI-A-1 off: LVDS-1 empty: DP-1,VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0166 class-ID: 0300
Device-2: IMC Networks Lenovo EasyCamera type: USB driver: uvcvideo
bus-ID: 3-4:3 chip-ID: 13d3:5170 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1600x1200 s-dpi: 96 s-size: 423x318mm (16.65x12.52")
s-diag: 529mm (20.83")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary model: Sharp HDMI
serial: <filter> built: 2009 res: 1600x1200 hz: 60 dpi: 64 gamma: 1.2
size: 640x360mm (25.2x14.17") diag: 734mm (28.9") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: LVDS-1 note: disabled pos: primary model: ChiMei InnoLux 0x15b6
built: 2012 res: 1600x1200 dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 1366x768
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Sound Server-1: ALSA v: k5.18.17-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.57 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 2000
bus-ID: 01:00.0 chip-ID: 10ec:8136 class-ID: 0200
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:0888
class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
Local Storage: total: 232.89 GiB used: 20.99 GiB (9.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT250MX200SSD1
size: 232.89 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: MU01 scheme: GPT
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GU70N rev: DE01
dev-links: cdrom
ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%) used: 20.99 GiB
(9.2%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 34ad0c3f-417e-47b5-a595-c2f224c5ae7a
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 0B98-F27A
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.4:4 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Microsoft Nano Transceiver v1.0 for Bluetooth
type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 045e:0745 class-ID: 0300
Device-2: 3-4:3 info: IMC Networks Lenovo EasyCamera type: Video
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 48.0 C mobo: N/A
Processes: 198 Uptime: 5d 3h 7m wakeups: 33 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1082 libs: 316 tools: pamac,yay pm: flatpak
pkgs: 0 Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.21
Why isn’t it working?
