Hello, I recently put Manjaro ARM on my new RPi400 (since Archlinuxarm uses a mainline linux kernel for 64bit support instead of the RPi foundation solution with arm_64bit). I opted for i3 mostly to conserve resources for the servers that I will also be running on it. I noticed a problem with it though.
The helptext on the desktop says “mod+ctrl+b” for bmenu:
However, bmenu doesnt exist. Hitting the shortcut does nothing and running bmenu in terminal says it doesnt exist:
$ bmenu zsh: command not found: bmenu
pacman -Ss bmenu:
I can only assume this is the intended program: https://github.com/bartobri/bmenu
Will it be included in the repos soon/at all?
Thanks in advance
Edit: changed code with image
Edit2: Apparently gksu is also missing:
