VlaMa
January 27, 2023, 10:13pm
1
Latest stable version of Manjaro
When I have night light feature enabled then while scrolling I can see blurry (a bit reddish) text. This can be seen on every screen (browser, settings, etc.).
When I disabled night light then this blurry effect is gone.
Is this expected?
Hanzel
January 27, 2023, 11:06pm
2
No I think this should not be expected. I use this feature and my experience is that the white and blue are less bright. This might have something to do with resolution but that is a guess.
Ah I do notice that setting the slider to the max the image is less clear and could be the behavior you describe. Does changing the temperature change the amount of blur?
VlaMa
January 28, 2023, 12:13pm
4
I would say yes. The colder the temperature is, the better experience.
Now while in daylight setting the problem is not present at all. I will do more test this/tomorrow night.
VlaMa
January 28, 2023, 12:16pm
5
I’m sorry I did not post my system information. I just wanted to know what it’s expected behavior.
My system info:
Kernel: 6.1.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=91c4d4a3-96db-40a7-953d-22670ba42974 rw quiet
cryptdevice=UUID=5f3a73ec-379b-4d7e-8f84-99bed74ea123:luks-5f3a73ec-379b-4d7e-8f84-99bed74ea123
root=/dev/mapper/luks-5f3a73ec-379b-4d7e-8f84-99bed74ea123 splash
apparmor=1 security=apparmor
resume=/dev/mapper/luks-7c057540-93fa-4657-9ccb-10ad57454ccb
udev.log_priority=3
Desktop: GNOME v: 43.2 tk: GTK v: 3.24.36 wm: gnome-shell dm: GDM v: 43.0
Type: Laptop System: LENOVO product: 21AHCTO1WW v: ThinkPad T14 Gen 3
Mobo: LENOVO model: 21AHCTO1WW serial: <superuser required> UEFI: LENOVO
v: N3MET11W (1.10 ) date: 12/07/2022
ID-1: BAT0 charge: 30.5 Wh (58.1%) condition: 52.5/52.5 Wh (100.0%)
volts: 15.5 min: 15.5 model: SMP 5B10W51864 type: Li-poly serial: <filter>
status: discharging
RAM: total: 31.06 GiB used: 3.69 GiB (11.9%)
Info: model: 12th Gen Intel Core i7-1260P bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
microcode: 0x424
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB L2: 9 MiB
desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 1918 high: 2500 min/max: 400/4700:3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 1006 2: 2500 3: 1195
4: 2500 5: 2500 6: 2500 7: 1143 8: 2500 9: 887 10: 785 11: 2500 12: 681
13: 2500 14: 2500 15: 2500 16: 2500 bogomips: 79888
de ds_cpl dtes64 dtherm dts epb erms est f16c flush_l1d fma fpu fsgsbase
fsrm fxsr gfni hfi ht hwp hwp_act_window hwp_epp hwp_notify hwp_pkg_req
ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid invpcid_single lahf_lm lm
mca mce md_clear mmx monitor movbe movdir64b movdiri msr mtrr nonstop_tsc
nopl nx ospke pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni
popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good sdbg sep
serialize sha_ni smap smep smx split_lock_detect ss ssbd sse sse2 sse4_1
sse4_2 ssse3 stibp syscall tm tm2 tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip vaes vme vpclmulqdq waitpkg x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB
filling, PBRSB-eIBRS: SW sequence
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Lenovo driver: i915
v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Device-2: Acer Integrated RGB Camera type: USB driver: uvcvideo
bus-ID: 3-4:2 chip-ID: 5986:2142 class-ID: fe01 serial: <filter>
Display: wayland server: X.org v: 1.21.1.6 with: Xwayland v: 22.1.7
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0xd291 built: 2020 res: 1920x1200
dpi: 162 gamma: 1.2 size: 301x188mm (11.85x7.4") diag: 355mm (14")
ratio: 16:10 modes: 1920x1200
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: Mesa Intel Graphics (ADL GT2)
direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 00:1f.3
chip-ID: 8086:51c8 class-ID: 0403
Sound API: ALSA v: k6.1.7-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.64 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-2: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:1a1f class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:3
chip-ID: 8087:0033 class-ID: e001
Device-1: luks-5f3a73ec-379b-4d7e-8f84-99bed74ea123 maj-min: 254:0
type: LUKS dm: dm-0 size: 919.4 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 919.4 GiB
Device-2: luks-7c057540-93fa-4657-9ccb-10ad57454ccb maj-min: 254:1
type: LUKS dm: dm-1 size: 34.17 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 34.17 GiB
Local Storage: total: 953.87 GiB used: 23.61 GiB (2.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVL21T0HCLR-00BL7
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 type: SSD serial: <filter> rev: CL2QGXA7 temp: 38.9 C scheme: GPT
ID-1: / raw-size: 919.4 GiB size: 903.89 GiB (98.31%) used: 23.61 GiB (2.6%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-5f3a73ec-379b-4d7e-8f84-99bed74ea123 label: N/A
uuid: 91c4d4a3-96db-40a7-953d-22670ba42974
used: 472 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: FC21-11C4
ID-1: swap-1 type: partition size: 34.17 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-7c057540-93fa-4657-9ccb-10ad57454ccb label: swap
uuid: b65e8ad6-a1bc-4e36-a9e9-750b2f0bfee0
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 3 rev: 3.1 speed: 20 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-4:2 info: Acer Integrated RGB Camera type: Video
driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s power: 500mA
Device-2: 3-10:3 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0033 class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 46.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 0
Processes: 374 Uptime: 1h 6m wakeups: 3413 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: 1223 pm: pacman pkgs: 1218 libs: 314 tools: gnome-software,pamac
pm: flatpak pkgs: 5 Shell: Bash v: 5.1.16 running-in: gnome-terminal
inxi: 3.3.24
VlaMa
January 30, 2023, 8:19pm
6
I tried to play with that a bit and the warmer temperature is set the more intense reddish blurring is visible. On the other hand it might be just personal feeling. For sure, if I switched off night mode then this problem is gone.
