After startup, matray
system tray icon is a bit bigger and blurred.
After I quit matray
and then open it again, the icon is fine.
What is the issue here?
After I quit matray
matray
is using hardoced icon AFAIK. @moson would know more about, but i guess is starting quicker than some panel elements, hence the render gets fuzzy. Add a delay to the start of matray
and see if that helps.
I don’t think matray uses hardcoded icons. I’ve seen this happen with Solaar and Remmina too, despite that they’re using icons provided by the current icon theme. Unfortunately, I don’t have any screenshots that show exactly that. My best guess is this is a bug with the Plasma desktop itself.
Best practice to find something out is to check the code
I did, but I don’t see any hints pointing out that matray’s icons are hardcoded, or maybe I don’t understand Vala
In computer programming or text markup, to hardcode is to use an explicit rather than a symbolic name. Icons for matray are defined in https://github.com/moson-mo/matray/blob/master/resources/ui.gresource.xml
file and placed in /usr/share/icons/hicolor/
upon install, but regardless.
There was a similar issue with the pamac tray in plasma some time ago, and it needed a delay to start to not become funky (as a workaround), later there was a proper fix for it in the code.
That delay setting is only for the notification messages.
You’d need to edit the autostart file in ~/.config/autostart/
The line with Exec...
to something like:
Exec=bash -c "sleep 10 && matray"
Actually there is already a hardcoded of 5 seconds due that stupid KDE issue, but it does not seem to be long enough on your machine…
Mine is a 3 year old HDD.
