Hi all, I noticed a strange error in the bluez logs while debugging an unrelated problem. Does anyone know what this is?
[D][08941.634922][backend-native.c: 870 rfcomm_hfp_ag()] native: battery level: 80%
[E][08941.635952][ bluez5-dbus.c: 335 on_battery_provider_registered()] bluez5-monitor: Failed to register battery provider. Error: org.freedesktop.DBus.Error.UnknownMethod
[E][08941.635974][ bluez5-dbus.c: 336 on_battery_provider_registered()] bluez5-monitor: BlueZ Battery Provider is not available, won't retry to register it. Make sure you are running BlueZ 5.56+ with experimental features to use Battery Provider.
Thanks a lot, this works! Now the battery status of Bluetooth devices also show up in the battery indicator. Is there a reason Manjaro doesn’t enable this by default?
