BlueZ 5.79 to 5.80
Hello everyone,
My name is Alexander, and I’m new here. I first gained experience with Linux using OpenSUSE, Ubuntu, and Debian. After spending a long time with macOS, I’ve been back on Linux for the past four months because I want to better understand what my system is doing in the background. I now use Manjaro as my sole production system—and I’m completely satisfied with it.
Now to my problem:
Since updating from BlueZ 5.79 to 5.80, my MX Master 3 and MX Keys no longer work. After downgrading to 5.79, everything functions smoothly again. However, I would like to update to the latest version.
I have already found a potential solution:
:link: GitHub – Commit with relevant changes
However, I’m unsure where exactly to apply these changes. That’s why I’m reaching out here in the hope of getting some guidance.
Best regards,
Alex
The rebuild is caused by adding a dependency
 $ mbn info bluez -q
Branch         : archlinux
Version        : 5.80-2
Repository     : extra
Build Date     : Thu 27 Mar 2025 06:34:45
Packager       : Andreas Radke <andyrtr@archlinux.org>
Branch         : unstable
Version        : 5.80-2
Repository     : extra
Branch         : testing
Version        : 5.80-2
Repository     : extra
Branch         : stable
Version        : 5.80-1
Repository     : extra
Build Date     : Mon 17 Mar 2025 15:52:18
You would have to create a patch file and apply it in the source PKGBUILD
I have already tried the testing branch, but unfortunately without success.
The issue seems to be known, but I can’t figure out the solution because I can’t find where the changes need to be made.
Here is the full post:
:link: GitHub – BlueZ Issue #1138
I figured that much when I found the commit on Arch prompting the rebuild.
You would have to clone the repo mentioned in your link - then patch the file mentioned with the code mention in the rightmost pane.
Another approach is to clone the Arch PKGBUILD
  • first use makepkg -os to fetch and unpack the sources
  • then manually patch the file before you run makepkg -i
But it is likely better to wait on the next release of the bluez source code.
Fixing it myself didn’t work, so I guess I’ll have to wait.
This version (bluez 5.82-1) works
https://archlinux.org/packages/extra/x86_64/bluez/
Mod edit: added the relevant bluez version number to the post
