Hi there,
Here it goes:
$ rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
$systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Fri 2022-09-02 09:28:27 -03; 2h 20min ago
Docs: man:bluetoothd(8)
Main PID: 5680 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 57459)
Memory: 1.0M
CPU: 100ms
CGroup: /system.slice/bluetooth.service
└─5680 /usr/lib/bluetooth/bluetoothd
set 02 09:28:27 manjaro2am bluetoothd[5680]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSource/sbc
set 02 09:28:27 manjaro2am bluetoothd[5680]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSink/sbc_xq_453
set 02 09:28:27 manjaro2am bluetoothd[5680]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSource/sbc_xq_453
set 02 09:28:27 manjaro2am bluetoothd[5680]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSink/sbc_xq_512
set 02 09:28:27 manjaro2am bluetoothd[5680]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSource/sbc_xq_512
set 02 09:28:27 manjaro2am bluetoothd[5680]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSink/sbc_xq_552
set 02 09:28:27 manjaro2am bluetoothd[5680]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSource/sbc_xq_552
set 02 09:28:27 manjaro2am bluetoothd[5680]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
set 02 09:28:29 manjaro2am bluetoothd[5680]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
set 02 09:28:48 manjaro2am bluetoothd[5680]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
$ sudo dmesg -l err,warn,emerg,alert,crit
[ 0.254014] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.778778] hpet_acpi_add: no address or irqs in _CRS
[ 1.109825] ata5.00: supports DRM functions and may not be fully accessible
[ 1.113048] ata5.00: supports DRM functions and may not be fully accessible
[ 1.364486] usb: port power management may be unreliable
[ 1.373426] nvme nvme1: missing or invalid SUBNQN field.
[ 1.922765] vfs_monitor: loading out-of-tree module taints kernel.
[ 1.923130] mydriver driver is init ok!
[ 1.975363] VBoxNetAdp: Successfully started.
[ 1.978895] VBoxNetFlt: Successfully started.
[ 2.293728] acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
[ 2.517119] r8168 Copyright (C) 2022 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 2.540080] iwlwifi 0000:00:14.3: WRT: Overriding region id 0
[ 2.540082] iwlwifi 0000:00:14.3: WRT: Overriding region id 1
[ 2.540084] iwlwifi 0000:00:14.3: WRT: Overriding region id 2
[ 2.540084] iwlwifi 0000:00:14.3: WRT: Overriding region id 3
[ 2.540085] iwlwifi 0000:00:14.3: WRT: Overriding region id 4
[ 2.540086] iwlwifi 0000:00:14.3: WRT: Overriding region id 6
[ 2.540086] iwlwifi 0000:00:14.3: WRT: Overriding region id 8
[ 2.540087] iwlwifi 0000:00:14.3: WRT: Overriding region id 9
[ 2.540088] iwlwifi 0000:00:14.3: WRT: Overriding region id 10
[ 2.540088] iwlwifi 0000:00:14.3: WRT: Overriding region id 11
[ 2.540089] iwlwifi 0000:00:14.3: WRT: Overriding region id 15
[ 2.540090] iwlwifi 0000:00:14.3: WRT: Overriding region id 16
[ 2.540090] iwlwifi 0000:00:14.3: WRT: Overriding region id 18
[ 2.540091] iwlwifi 0000:00:14.3: WRT: Overriding region id 19
[ 2.540092] iwlwifi 0000:00:14.3: WRT: Overriding region id 20
[ 2.540093] iwlwifi 0000:00:14.3: WRT: Overriding region id 21
[ 2.540093] iwlwifi 0000:00:14.3: WRT: Overriding region id 28
[ 2.907795] nvidia: module license 'NVIDIA' taints kernel.
[ 2.907799] Disabling lock debugging due to kernel taint
[ 3.200256] thermal thermal_zone2: failed to read out thermal zone (-61)
[ 3.303827] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.65.01 Wed Jul 20 14:00:58 UTC 2022
[ 4.624282] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 5.332526] kauditd_printk_skb: 83 callbacks suppressed
[ 7.419867] ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20211217/nsarguments-61)
[ 10.946679] kauditd_printk_skb: 3 callbacks suppressed
[ 97.600475] kauditd_printk_skb: 24 callbacks suppressed
[ 103.424567] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 103.424568] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 103.424570] pcieport 0000:00:1c.0: [12] Timeout
[ 129.025696] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 129.025698] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 129.025699] pcieport 0000:00:1c.0: [12] Timeout
[ 318.890566] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 318.890567] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 318.890568] pcieport 0000:00:1c.0: [12] Timeout
[ 705.014145] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 705.014146] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 705.014148] pcieport 0000:00:1c.0: [12] Timeout
[ 1197.809496] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1197.809497] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 1197.809498] pcieport 0000:00:1c.0: [12] Timeout
[ 1389.810016] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1389.810017] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 1389.810019] pcieport 0000:00:1c.0: [12] Timeout
[ 1746.072894] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1746.072895] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 1746.072896] pcieport 0000:00:1c.0: [12] Timeout
[ 1989.268349] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 1989.268350] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 1989.268352] pcieport 0000:00:1c.0: [12] Timeout
[ 2102.333473] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 2102.333475] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 2102.333476] pcieport 0000:00:1c.0: [12] Timeout
[ 2174.866782] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 2174.866783] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 2174.866784] pcieport 0000:00:1c.0: [12] Timeout
[ 2295.105214] SUPR0GipMap: fGetGipCpu=0x1b
[ 2295.871557] vboxdrv: 0000000025afdb1d VMMR0.r0
[ 2296.007897] vboxdrv: 00000000207354e9 VBoxDDR0.r0
[ 2296.074339] VBoxNetFlt: attached to 'enp3s0f1' / 80:fa:5b:a6:34:fa
[ 2296.079023] vboxdrv: 00000000c805f963 VBoxEhciR0.r0
[ 2296.080103] VMMR0InitVM: eflags=246 fKernelFeatures=0x0 (SUPKERNELFEATURES_SMAP=0)
[ 2693.261516] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 2693.261517] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 2693.261518] pcieport 0000:00:1c.0: [12] Timeout
[ 2735.928018] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 2735.928019] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 2735.928020] pcieport 0000:00:1c.0: [12] Timeout
[ 2797.794161] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 2797.794162] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 2797.794163] pcieport 0000:00:1c.0: [12] Timeout
[ 3151.922453] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 3151.922454] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 3151.922455] pcieport 0000:00:1c.0: [12] Timeout
[ 3282.053641] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 3282.053642] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 3282.053643] pcieport 0000:00:1c.0: [12] Timeout
[ 3484.716828] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 3484.716830] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 3484.716831] pcieport 0000:00:1c.0: [12] Timeout
[ 3531.649888] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 3531.649889] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 3531.649890] pcieport 0000:00:1c.0: [12] Timeout
[ 3548.716369] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 3548.716370] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 3548.716371] pcieport 0000:00:1c.0: [12] Timeout
[ 3604.553975] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 3604.553976] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 3604.553978] pcieport 0000:00:1c.0: [12] Timeout
[ 3610.584411] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 3610.584412] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 3610.584414] pcieport 0000:00:1c.0: [12] Timeout
[ 3838.848649] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 3838.848651] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 3838.848652] pcieport 0000:00:1c.0: [12] Timeout
[ 3945.028748] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 3945.028749] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 3945.028751] pcieport 0000:00:1c.0: [12] Timeout
[ 3968.976559] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 3968.976560] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 3968.976562] pcieport 0000:00:1c.0: [12] Timeout
[ 3975.379811] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 3975.379812] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 3975.379813] pcieport 0000:00:1c.0: [12] Timeout
[ 4086.307705] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 4086.307706] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 4086.307707] pcieport 0000:00:1c.0: [12] Timeout
[ 4103.374794] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 4103.374795] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 4103.374796] pcieport 0000:00:1c.0: [12] Timeout
[ 4297.507815] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 4297.507817] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 4297.507818] pcieport 0000:00:1c.0: [12] Timeout
[ 4568.440264] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 4568.440266] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 4568.440267] pcieport 0000:00:1c.0: [12] Timeout
[ 4826.571050] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 4826.571051] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 4826.571052] pcieport 0000:00:1c.0: [12] Timeout
[ 5265.390865] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 5265.390867] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 5265.390868] pcieport 0000:00:1c.0: [12] Timeout
[ 5487.897763] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 5487.897764] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 5487.897765] pcieport 0000:00:1c.0: [12] Timeout
[ 5682.027528] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 5682.027530] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 5682.027531] pcieport 0000:00:1c.0: [12] Timeout
[ 5728.960589] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 5728.960590] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 5728.960591] pcieport 0000:00:1c.0: [12] Timeout
[ 5767.998517] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 5767.998518] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 5767.998519] pcieport 0000:00:1c.0: [12] Timeout
[ 5890.610250] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 5890.610251] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 5890.610252] pcieport 0000:00:1c.0: [12] Timeout
[ 5929.491309] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 5929.491310] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 5929.491311] pcieport 0000:00:1c.0: [12] Timeout
[ 5965.757490] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 5965.757491] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 5965.757492] pcieport 0000:00:1c.0: [12] Timeout
[ 6130.021944] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 6130.021945] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 6130.021946] pcieport 0000:00:1c.0: [12] Timeout
[ 6307.089098] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 6307.089099] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 6307.089100] pcieport 0000:00:1c.0: [12] Timeout
[ 6548.154767] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 6548.154768] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 6548.154769] pcieport 0000:00:1c.0: [12] Timeout
[ 7216.006057] nvme 0000:02:00.0: PCIe Bus Error: severity=Corrected, type=Physical Layer, (Receiver ID)
[ 7216.006058] nvme 0000:02:00.0: device [15b7:5011] error status/mask=00000001/0000e000
[ 7216.006059] nvme 0000:02:00.0: [ 0] RxErr (First)
[ 7374.120378] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 7374.120379] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 7374.120380] pcieport 0000:00:1c.0: [12] Timeout
[ 7576.413260] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 7576.413262] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 7576.413263] pcieport 0000:00:1c.0: [12] Timeout
[ 7834.543958] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 7834.543959] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 7834.543961] pcieport 0000:00:1c.0: [12] Timeout
[ 8171.607561] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 8171.607562] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 8171.607563] pcieport 0000:00:1c.0: [12] Timeout
[ 8192.940137] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 8192.940139] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 8192.940140] pcieport 0000:00:1c.0: [12] Timeout
[ 8212.140432] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 8212.140433] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 8212.140434] pcieport 0000:00:1c.0: [12] Timeout
[ 8268.885202] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 8268.885203] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 8268.885205] pcieport 0000:00:1c.0: [12] Timeout
[ 8837.202838] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 8837.202852] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 8837.202853] pcieport 0000:00:1c.0: [12] Timeout
[ 8841.412631] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 8841.412632] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 8841.412634] pcieport 0000:00:1c.0: [12] Timeout
[ 9109.944012] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 9109.944028] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 9109.944030] pcieport 0000:00:1c.0: [12] Timeout
[ 9423.862028] pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
[ 9423.862030] pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
[ 9423.862031] pcieport 0000:00:1c.0: [12] Timeout
$ journalctl -b0 -p4 --no-pager
set 02 09:12:58 manjaro2am kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
set 02 09:12:58 manjaro2am kernel: hpet_acpi_add: no address or irqs in _CRS
set 02 09:12:58 manjaro2am kernel: ata5.00: supports DRM functions and may not be fully accessible
set 02 09:12:58 manjaro2am kernel: usb: port power management may be unreliable
set 02 09:12:58 manjaro2am kernel: nvme nvme1: missing or invalid SUBNQN field.
set 02 09:12:58 manjaro2am kernel: vfs_monitor: loading out-of-tree module taints kernel.
set 02 09:12:58 manjaro2am kernel: mydriver driver is init ok!
set 02 09:12:58 manjaro2am kernel: VBoxNetAdp: Successfully started.
set 02 09:12:58 manjaro2am systemd-modules-load[279]: Failed to find module 'clevo-xsm-wmi'
set 02 09:12:58 manjaro2am kernel: VBoxNetFlt: Successfully started.
set 02 09:12:59 manjaro2am kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:02)
set 02 09:12:59 manjaro2am kernel: r8168 Copyright (C) 2022 Realtek NIC software team <nicfae@realtek.com>
set 02 09:12:59 manjaro2am kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 0
set 02 09:12:59 manjaro2am kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 1
set 02 09:12:59 manjaro2am kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 2
set 02 09:12:59 manjaro2am kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 3
set 02 09:12:59 manjaro2am kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 4
set 02 09:12:59 manjaro2am kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 6
set 02 09:12:59 manjaro2am kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 8
set 02 09:12:59 manjaro2am kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 9
set 02 09:12:59 manjaro2am kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 10
set 02 09:12:59 manjaro2am kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 11
set 02 09:12:59 manjaro2am kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 15
set 02 09:12:59 manjaro2am kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 16
set 02 09:12:59 manjaro2am kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 18
set 02 09:12:59 manjaro2am kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 19
set 02 09:12:59 manjaro2am kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 20
set 02 09:12:59 manjaro2am kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 21
set 02 09:12:59 manjaro2am kernel: iwlwifi 0000:00:14.3: WRT: Overriding region id 28
set 02 09:12:59 manjaro2am kernel: nvidia: module license 'NVIDIA' taints kernel.
set 02 09:12:59 manjaro2am kernel: Disabling lock debugging due to kernel taint
set 02 09:12:59 manjaro2am kernel: thermal thermal_zone2: failed to read out thermal zone (-61)
set 02 09:13:00 manjaro2am kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 515.65.01 Wed Jul 20 14:00:58 UTC 2022
set 02 09:13:01 manjaro2am kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
set 02 09:13:01 manjaro2am systemd[954]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
set 02 09:13:02 manjaro2am kernel: kauditd_printk_skb: 83 callbacks suppressed
set 02 09:13:02 manjaro2am NetworkManager[1019]: <warn> [1662120782.0850] device (wlo1): wifi-scan: active scanning for networks due to profiles with wifi.hidden=yes. This makes you trackable
set 02 09:13:04 manjaro2am kernel: ACPI Warning: \_SB.PCI0.PEG0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20211217/nsarguments-61)
set 02 09:13:05 manjaro2am systemd-xdg-autostart-generator[1202]: /etc/xdg/autostart/deepin-system-monitor-plugin-popup.desktop:4: Unknown key name 'NoShowIn' in section 'Desktop Entry', ignoring.
set 02 09:13:07 manjaro2am kernel: kauditd_printk_skb: 3 callbacks suppressed
set 02 09:13:07 manjaro2am nmbd[1262]: [2022/09/02 09:13:07.754862, 0] ../../source3/nmbd/nmbd.c:901(main)
set 02 09:13:07 manjaro2am nmbd[1262]: nmbd version 4.16.4 started.
set 02 09:13:07 manjaro2am nmbd[1262]: Copyright Andrew Tridgell and the Samba Team 1992-2022
set 02 09:13:07 manjaro2am smbd[1263]: [2022/09/02 09:13:07.792284, 0] ../../source3/smbd/server.c:1741(main)
set 02 09:13:07 manjaro2am smbd[1263]: smbd version 4.16.4 started.
set 02 09:13:07 manjaro2am smbd[1263]: Copyright Andrew Tridgell and the Samba Team 1992-2022
set 02 09:13:30 manjaro2am nmbd[1262]: [2022/09/02 09:13:30.814442, 0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
set 02 09:13:30 manjaro2am nmbd[1262]: *****
set 02 09:13:30 manjaro2am nmbd[1262]: Samba name server MANJARO2AM is now a local master browser for workgroup WORKGROUP on subnet 192.168.42.1
set 02 09:13:30 manjaro2am nmbd[1262]: [2022/09/02 09:13:30.822837, 0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
set 02 09:13:30 manjaro2am nmbd[1262]: Samba name server MANJARO2AM is now a local master browser for workgroup WORKGROUP on subnet 192.168.202.1
set 02 09:13:30 manjaro2am nmbd[1262]: [2022/09/02 09:13:30.823018, 0] ../../source3/nmbd/nmbd_become_lmb.c:398(become_local_master_stage2)
set 02 09:13:30 manjaro2am nmbd[1262]: Samba name server MANJARO2AM is now a local master browser for workgroup WORKGROUP on subnet 10.0.0.72
set 02 09:14:23 manjaro2am lightdm[1253]: gkr-pam: unable to locate daemon control file
set 02 09:14:23 manjaro2am systemd-xdg-autostart-generator[1437]: Configuration file /home/myara/.config/autostart/xfce-panel-workaround.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
set 02 09:14:23 manjaro2am systemd-xdg-autostart-generator[1437]: /home/myara/.config/autostart/xcape.desktop:9: Unknown key name 'RunHook' in section 'Desktop Entry', ignoring.
set 02 09:14:23 manjaro2am systemd-xdg-autostart-generator[1437]: Configuration file /home/myara/.config/autostart/xfce-pbw.sh is marked executable. Please remove executable permission bits. Proceeding anyway.
set 02 09:14:23 manjaro2am systemd-xdg-autostart-generator[1437]: /home/myara/.config/autostart/xfce-pbw.sh:2: Assignment outside of section. Ignoring.
set 02 09:14:23 manjaro2am systemd-xdg-autostart-generator[1437]: /home/myara/.config/autostart/xfce-pbw.sh:3: Assignment outside of section. Ignoring.
set 02 09:14:23 manjaro2am systemd-xdg-autostart-generator[1437]: /home/myara/.config/autostart/xfce-pbw.sh:4: Assignment outside of section. Ignoring.
set 02 09:14:23 manjaro2am systemd-xdg-autostart-generator[1437]: /home/myara/.config/autostart/xfce-pbw.sh:5: Assignment outside of section. Ignoring.
set 02 09:14:23 manjaro2am systemd-xdg-autostart-generator[1437]: /home/myara/.config/autostart/xfce-pbw.sh:6: Assignment outside of section. Ignoring.
set 02 09:14:23 manjaro2am systemd-xdg-autostart-generator[1437]: /home/myara/.config/autostart/xfce-pbw.sh:7: Assignment outside of section. Ignoring.
set 02 09:14:23 manjaro2am systemd-xdg-autostart-generator[1437]: Configuration file /home/myara/.config/autostart/overgrive-autostart.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
set 02 09:14:24 manjaro2am systemd-xdg-autostart-generator[1437]: /etc/xdg/autostart/deepin-system-monitor-plugin-popup.desktop:4: Unknown key name 'NoShowIn' in section 'Desktop Entry', ignoring.
set 02 09:14:25 manjaro2am pulseaudio[1527]: stat('/etc/pulse/default.pa.d'): Arquivo ou diretório inexistente
set 02 09:14:26 manjaro2am tumblerd[1605]: Failed to load plugin "tumbler-gepub-thumbnailer.so": libgepub-0.6.so.0: cannot open shared object file: No such file or directory
set 02 09:14:26 manjaro2am deepin-system-monitor-daemon[1680]: cpu total usage calc result equal 0 ! cpu stat [ QMap(("guest", 0)("guest_nice", 0)("hardqirq", 38)("idle", 69211)("iowait", 188)("nice", 2)("softirq", 36)("steal", 0)("sys", 873)("total", 71499)("user", 1151)) ]
set 02 09:14:26 manjaro2am zeitgeist-datah[1817]: zeitgeist-datahub.vala:224: Unable to get name "org.gnome.zeitgeist.datahub" on the bus!
set 02 09:14:26 manjaro2am daemon/dde-session-daemon[1912]: main.go:92: Name "com.deepin.SessionManager" does not exist
set 02 09:14:26 manjaro2am daemon/loader[1912]: dag_builder.go:42: disabled module(calltrace) is no existed
set 02 09:14:26 manjaro2am daemon/loader[1912]: dag_builder.go:42: disabled module(debug) is no existed
set 02 09:14:26 manjaro2am daemon/mime[1912]: manager.go:90: no such file or directory
set 02 09:14:26 manjaro2am daemon/launcher[1912]: manager.go:161: no such file or directory
set 02 09:14:26 manjaro2am daemon/launcher[1912]: manager.go:184: open /var/lib/lastore/desktop_package.json: no such file or directory
set 02 09:14:26 manjaro2am daemon/launcher[1912]: manager.go:189: open /var/lib/lastore/applications.json: no such file or directory
set 02 09:14:26 manjaro2am daemon/screensaver[1912]: module.go:56: ScreenSaver has been register, exit...
set 02 09:14:26 manjaro2am daemon/trayicon[1912]: traymanager.go:120: Another System tray application is running
set 02 09:14:26 manjaro2am daemon/loader[1912]: loader.go:179: enable module clipboard failed: another clipboard manager is already running, owner: 12582915, cost 26.256376ms
-> asm_amd64.s:1571
set 02 09:14:26 manjaro2am deepin-system-monitor-plugin-popup[1695]: QWidget::setMinimumSize: (/QScrollArea) Negative sizes (0,-40) are not possible
set 02 09:14:26 manjaro2am deepin-system-monitor-plugin-popup[1695]: QWidget::setMaximumSize: (/QScrollArea) Negative sizes (16777215,-40) are not possible
set 02 09:14:26 manjaro2am kalendarac[1721]: Attribute Qt::AA_EnableHighDpiScaling must be set before QCoreApplication is created.
set 02 09:14:27 manjaro2am deepin-system-monitor-plugin-popup[1695]: QDBusArgument: read from a write-only object
set 02 09:14:27 manjaro2am daemon/dde-session-daemon[1989]: main.go:92: Name "com.deepin.SessionManager" does not exist
set 02 09:14:27 manjaro2am daemon/loader[1989]: dag_builder.go:42: disabled module(calltrace) is no existed
set 02 09:14:27 manjaro2am daemon/loader[1989]: dag_builder.go:42: disabled module(debug) is no existed
set 02 09:14:27 manjaro2am daemon/launcher[1989]: manager.go:161: no such file or directory
set 02 09:14:27 manjaro2am daemon/launcher[1989]: manager.go:184: open /var/lib/lastore/desktop_package.json: no such file or directory
set 02 09:14:27 manjaro2am daemon/launcher[1989]: manager.go:189: open /var/lib/lastore/applications.json: no such file or directory
set 02 09:14:27 manjaro2am daemon/mime[1989]: manager.go:90: no such file or directory
set 02 09:14:27 manjaro2am daemon/lastore[1989]: lastore.go:361: The name com.deepin.lastore was not provided by any .service files
set 02 09:14:27 manjaro2am deepin-system-monitor-plugin-popup[1695]: "Error: [2] Arquivo ou diretório inexistente, " "open /proc/2011/stat failed"
set 02 09:14:27 manjaro2am deepin-system-monitor-plugin-popup[1695]: "Error: [2] Arquivo ou diretório inexistente, " "open /proc/2011/schedstat failed"
set 02 09:14:27 manjaro2am daemon/trayicon[1989]: traymanager.go:120: Another System tray application is running
set 02 09:14:27 manjaro2am daemon/screensaver[1989]: module.go:56: ScreenSaver has been register, exit...
set 02 09:14:27 manjaro2am gesture[1989]: manager.go:148: The name org.desktopspec.ConfigManager was not provided by any .service files
set 02 09:14:27 manjaro2am gesture[1989]: manager.go:173: dbus: invalid message: invalid path name
set 02 09:14:27 manjaro2am daemon/loader[1989]: loader.go:179: enable module clipboard failed: another clipboard manager is already running, owner: 12582915, cost 36.251808ms
-> asm_amd64.s:1571
set 02 09:14:27 manjaro2am deepin-system-monitor-plugin-popup[1695]: QWidget::setMinimumSize: (/MainWindow) Negative sizes (300,-20) are not possible
set 02 09:14:27 manjaro2am akonadi_control[2012]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
set 02 09:14:27 manjaro2am daemon/dde-session-daemon[2040]: main.go:92: Name "com.deepin.SessionManager" does not exist
set 02 09:14:27 manjaro2am daemon/loader[2040]: dag_builder.go:42: disabled module(calltrace) is no existed
set 02 09:14:27 manjaro2am daemon/loader[2040]: dag_builder.go:42: disabled module(debug) is no existed
set 02 09:14:27 manjaro2am daemon/launcher[2040]: manager.go:161: no such file or directory
set 02 09:14:27 manjaro2am daemon/launcher[2040]: manager.go:184: open /var/lib/lastore/desktop_package.json: no such file or directory
set 02 09:14:27 manjaro2am daemon/launcher[2040]: manager.go:189: open /var/lib/lastore/applications.json: no such file or directory
set 02 09:14:27 manjaro2am daemon/mime[2040]: manager.go:90: no such file or directory
set 02 09:14:27 manjaro2am daemon/lastore[2040]: lastore.go:361: The name com.deepin.lastore was not provided by any .service files
set 02 09:14:27 manjaro2am gesture[2040]: manager.go:148: The name org.desktopspec.ConfigManager was not provided by any .service files
set 02 09:14:27 manjaro2am gesture[2040]: manager.go:173: dbus: invalid message: invalid path name
set 02 09:14:27 manjaro2am daemon/systeminfo[2040]: info.go:152: get systeminfo.CurrentSpeed err : The name com.deepin.system.SystemInfo was not provided by any .service files
set 02 09:14:27 manjaro2am daemon/screensaver[2040]: module.go:56: ScreenSaver has been register, exit...
set 02 09:14:27 manjaro2am daemon/network[2040]: manager.go:185: get sessionManager CurrentSessionPath failed: The name com.deepin.SessionManager was not provided by any .service files
set 02 09:14:27 manjaro2am daemon/network[2040]: manager.go:189: Failed to connect self session: path is invalid
-> module.go:77
-> module.go:132
-> module.go:76
-> module.go:92
-> loader.go:175
-> asm_amd64.s:1571
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2040]: panic: runtime error: invalid memory address or nil pointer dereference
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2040]: [signal SIGSEGV: segmentation violation code=0x1 addr=0x20 pc=0x563a5b326466]
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2040]: goroutine 67 [running]:
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2040]: github.com/linuxdeepin/dde-daemon/network.(*Manager).isSessionActive(0xc000452080?)
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2040]: github.com/linuxdeepin/dde-daemon/network/utils.go:247 +0x26
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2040]: github.com/linuxdeepin/dde-daemon/network.(*Manager).init(0xc000014700)
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2040]: github.com/linuxdeepin/dde-daemon/network/manager.go:226 +0x537
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2040]: github.com/linuxdeepin/dde-daemon/network.(*Module).start(0x563a5b421a00?)
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2040]: github.com/linuxdeepin/dde-daemon/network/module.go:77 +0x85
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2040]: github.com/linuxdeepin/dde-daemon/network.(*Module).Start(0xc0000903a8?)
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2040]: github.com/linuxdeepin/dde-daemon/network/module.go:132 +0x5b
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2040]: github.com/linuxdeepin/dde-daemon/loader.(*ModuleBase).doEnable(0xc0004520c0, 0x1)
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2040]: github.com/linuxdeepin/dde-daemon/loader/module.go:76 +0x9f
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2040]: github.com/linuxdeepin/dde-daemon/loader.(*ModuleBase).Enable(0xc000044480?, 0x5?)
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2040]: github.com/linuxdeepin/dde-daemon/loader/module.go:92 +0x6d
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2040]: github.com/linuxdeepin/dde-daemon/loader.(*Loader).EnableModules.func1()
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2040]: github.com/linuxdeepin/dde-daemon/loader/loader.go:175 +0x20b
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2040]: created by github.com/linuxdeepin/dde-daemon/loader.(*Loader).EnableModules
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2040]: github.com/linuxdeepin/dde-daemon/loader/loader.go:165 +0x47e
set 02 09:14:27 manjaro2am daemon/dde-system-daemon[2081]: main.go:93: No PATH found, manual special
set 02 09:14:27 manjaro2am com.deepin.daemon.Daemon[2081]: libtc-api.so: cannot open shared object file: No such file or directory
set 02 09:14:27 manjaro2am com.deepin.daemon.Daemon[2081]: TC_Start come to nothing 1
set 02 09:14:27 manjaro2am daemon/system/powermanager[2081]: manager.go:50: exit status 1
set 02 09:14:27 manjaro2am daemon/fprintd[2081]: manager.go:242: Failed to get fprint devices: The name net.reactivated.Fprint was not provided by any .service files
set 02 09:14:27 manjaro2am daemon/dde-session-daemon[2098]: main.go:92: Name "com.deepin.SessionManager" does not exist
set 02 09:14:27 manjaro2am bluetoothd[954]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
set 02 09:14:27 manjaro2am daemon/system/power[2081]: battery_display.go:34: v is not exported
set 02 09:14:27 manjaro2am daemon/system/power[2081]: manager.go:230: open /sys/devices/system/cpu/cpufreq/boost: no such file or directory
set 02 09:14:27 manjaro2am daemon/loader[2098]: dag_builder.go:42: disabled module(calltrace) is no existed
set 02 09:14:27 manjaro2am daemon/loader[2098]: dag_builder.go:42: disabled module(debug) is no existed
set 02 09:14:27 manjaro2am daemon/launcher[2098]: manager.go:161: no such file or directory
set 02 09:14:27 manjaro2am daemon/launcher[2098]: manager.go:184: open /var/lib/lastore/desktop_package.json: no such file or directory
set 02 09:14:27 manjaro2am daemon/launcher[2098]: manager.go:189: open /var/lib/lastore/applications.json: no such file or directory
set 02 09:14:27 manjaro2am daemon/screensaver[2098]: module.go:56: ScreenSaver has been register, exit...
set 02 09:14:27 manjaro2am daemon/mime[2098]: manager.go:90: no such file or directory
set 02 09:14:27 manjaro2am daemon/trayicon[2098]: traymanager.go:120: Another System tray application is running
set 02 09:14:27 manjaro2am daemon/loader[2098]: loader.go:179: enable module clipboard failed: another clipboard manager is already running, owner: 12582915, cost 29.490323ms
-> asm_amd64.s:1571
set 02 09:14:27 manjaro2am python[1683]: backintime (myara/1): ERROR: Back In Time is not configured!
set 02 09:14:27 manjaro2am net.launchpad.backintime.serviceHelper[2157]: which: no su in ((null))
set 02 09:14:27 manjaro2am net.launchpad.backintime.serviceHelper[2163]: which: no backintime in ((null))
set 02 09:14:27 manjaro2am net.launchpad.backintime.serviceHelper[2166]: which: no nice in ((null))
set 02 09:14:27 manjaro2am net.launchpad.backintime.serviceHelper[2171]: which: no ionice in ((null))
set 02 09:14:27 manjaro2am daemon/dde-session-daemon[2165]: main.go:92: Name "com.deepin.SessionManager" does not exist
set 02 09:14:27 manjaro2am daemon/loader[2165]: dag_builder.go:42: disabled module(calltrace) is no existed
set 02 09:14:27 manjaro2am daemon/loader[2165]: dag_builder.go:42: disabled module(debug) is no existed
set 02 09:14:27 manjaro2am daemon/mime[2165]: manager.go:90: no such file or directory
set 02 09:14:27 manjaro2am daemon/launcher[2165]: manager.go:161: no such file or directory
set 02 09:14:27 manjaro2am daemon/launcher[2165]: manager.go:184: open /var/lib/lastore/desktop_package.json: no such file or directory
set 02 09:14:27 manjaro2am daemon/launcher[2165]: manager.go:189: open /var/lib/lastore/applications.json: no such file or directory
set 02 09:14:27 manjaro2am daemon/trayicon[2165]: traymanager.go:120: Another System tray application is running
set 02 09:14:27 manjaro2am daemon/lastore[2165]: lastore.go:361: The name com.deepin.lastore was not provided by any .service files
set 02 09:14:27 manjaro2am daemon/screensaver[2165]: module.go:56: ScreenSaver has been register, exit...
set 02 09:14:27 manjaro2am daemon/appearance[2165]: scale.go:33: failed to get scale factor: Name "com.deepin.SessionManager" does not exist
set 02 09:14:27 manjaro2am gesture[2165]: manager.go:148: The name org.desktopspec.ConfigManager was not provided by any .service files
set 02 09:14:27 manjaro2am gesture[2165]: manager.go:173: dbus: invalid message: invalid path name
set 02 09:14:27 manjaro2am daemon/loader[2165]: loader.go:179: enable module clipboard failed: another clipboard manager is already running, owner: 12582915, cost 29.952444ms
-> asm_amd64.s:1571
set 02 09:14:27 manjaro2am daemon/dde-session-daemon[2242]: main.go:92: Name "com.deepin.SessionManager" does not exist
set 02 09:14:27 manjaro2am daemon/loader[2242]: dag_builder.go:42: disabled module(calltrace) is no existed
set 02 09:14:27 manjaro2am daemon/loader[2242]: dag_builder.go:42: disabled module(debug) is no existed
set 02 09:14:27 manjaro2am daemon/mime[2242]: manager.go:90: no such file or directory
set 02 09:14:27 manjaro2am daemon/screensaver[2242]: module.go:56: ScreenSaver has been register, exit...
set 02 09:14:27 manjaro2am gesture[2242]: manager.go:148: The name org.desktopspec.ConfigManager was not provided by any .service files
set 02 09:14:27 manjaro2am gesture[2242]: manager.go:173: dbus: invalid message: invalid path name
set 02 09:14:27 manjaro2am daemon/network[2242]: manager.go:185: get sessionManager CurrentSessionPath failed: The name com.deepin.SessionManager was not provided by any .service files
set 02 09:14:27 manjaro2am daemon/network[2242]: manager.go:189: Failed to connect self session: path is invalid
-> module.go:77
-> module.go:132
-> module.go:76
-> module.go:92
-> loader.go:175
-> asm_amd64.s:1571
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2242]: panic: runtime error: invalid memory address or nil pointer dereference
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2242]: [signal SIGSEGV: segmentation violation code=0x1 addr=0x20 pc=0x55ae165ef466]
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2242]: goroutine 97 [running]:
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2242]: github.com/linuxdeepin/dde-daemon/network.(*Manager).isSessionActive(0xc0000440c0?)
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2242]: github.com/linuxdeepin/dde-daemon/network/utils.go:247 +0x26
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2242]: github.com/linuxdeepin/dde-daemon/network.(*Manager).init(0xc00080e000)
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2242]: github.com/linuxdeepin/dde-daemon/network/manager.go:226 +0x537
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2242]: github.com/linuxdeepin/dde-daemon/network.(*Module).start(0x55ae166eaa00?)
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2242]: github.com/linuxdeepin/dde-daemon/network/module.go:77 +0x85
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2242]: github.com/linuxdeepin/dde-daemon/network.(*Module).Start(0xc000130348?)
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2242]: github.com/linuxdeepin/dde-daemon/network/module.go:132 +0x5b
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2242]: github.com/linuxdeepin/dde-daemon/loader.(*ModuleBase).doEnable(0xc000044100, 0x1)
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2242]: github.com/linuxdeepin/dde-daemon/loader/module.go:76 +0x9f
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2242]: github.com/linuxdeepin/dde-daemon/loader.(*ModuleBase).Enable(0xc000178400?, 0x5?)
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2242]: github.com/linuxdeepin/dde-daemon/loader/module.go:92 +0x6d
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2242]: github.com/linuxdeepin/dde-daemon/loader.(*Loader).EnableModules.func1()
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2242]: github.com/linuxdeepin/dde-daemon/loader/loader.go:175 +0x20b
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2242]: created by github.com/linuxdeepin/dde-daemon/loader.(*Loader).EnableModules
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2242]: github.com/linuxdeepin/dde-daemon/loader/loader.go:165 +0x47e
set 02 09:14:27 manjaro2am daemon/dde-session-daemon[2275]: main.go:92: Name "com.deepin.SessionManager" does not exist
set 02 09:14:27 manjaro2am daemon/loader[2275]: dag_builder.go:42: disabled module(calltrace) is no existed
set 02 09:14:27 manjaro2am daemon/loader[2275]: dag_builder.go:42: disabled module(debug) is no existed
set 02 09:14:27 manjaro2am daemon/mime[2275]: manager.go:90: no such file or directory
set 02 09:14:27 manjaro2am daemon/launcher[2275]: manager.go:161: no such file or directory
set 02 09:14:27 manjaro2am daemon/launcher[2275]: manager.go:184: open /var/lib/lastore/desktop_package.json: no such file or directory
set 02 09:14:27 manjaro2am daemon/launcher[2275]: manager.go:189: open /var/lib/lastore/applications.json: no such file or directory
set 02 09:14:27 manjaro2am gesture[2275]: manager.go:148: The name org.desktopspec.ConfigManager was not provided by any .service files
set 02 09:14:27 manjaro2am gesture[2275]: manager.go:173: dbus: invalid message: invalid path name
set 02 09:14:27 manjaro2am daemon/screensaver[2275]: module.go:56: ScreenSaver has been register, exit...
set 02 09:14:27 manjaro2am daemon/lastore[2275]: lastore.go:361: The name com.deepin.lastore was not provided by any .service files
set 02 09:14:27 manjaro2am x-event-monitor[2275]: manager.go:714: UnregisterArea id "Process com.deepin.api.XEventMonitor exited with status 2" pid 1695 failed: the areas has not been registered yet
set 02 09:14:27 manjaro2am daemon/dde-system-daemon[2311]: main.go:87: name "com.deepin.daemon.Daemon" already has the owner
set 02 09:14:27 manjaro2am systemd[1]: deepin-accounts-daemon.service: Failed with result 'exit-code'.
set 02 09:14:27 manjaro2am systemd[1]: Failed to start Accounts Service.
set 02 09:14:27 manjaro2am com.deepin.daemon.Daemon[2081]: libinput error: client bug: Invalid event type LIBINPUT_EVENT_POINTER_MOTION (400) passed to libinput_event_pointer_get_axis_source()
set 02 09:14:27 manjaro2am com.deepin.daemon.Daemon[2081]: libinput error: client bug: Invalid event type LIBINPUT_EVENT_POINTER_MOTION (400) passed to libinput_event_pointer_get_axis_value()
this one is reeeeally long and keeps repeating those 2 last errors… So I’m skipping those repetitions and pasting below only different messages…
set 02 09:14:27 manjaro2am gesture[2275]: manager.go:209: Path '' is invalid
set 02 09:14:27 manjaro2am daemon/trayicon[2275]: traymanager.go:120: Another System tray application is running
set 02 09:14:27 manjaro2am daemon/loader[2275]: loader.go:179: enable module clipboard failed: another clipboard manager is already running, owner: 12582915, cost 82.282002ms
-> asm_amd64.s:1571
set 02 09:14:27 manjaro2am daemon/dde-session-daemon[2335]: main.go:92: Name "com.deepin.SessionManager" does not exist
set 02 09:14:27 manjaro2am daemon/loader[2335]: dag_builder.go:42: disabled module(calltrace) is no existed
set 02 09:14:27 manjaro2am daemon/loader[2335]: dag_builder.go:42: disabled module(debug) is no existed
set 02 09:14:27 manjaro2am daemon/mime[2335]: manager.go:90: no such file or directory
set 02 09:14:27 manjaro2am daemon/launcher[2335]: manager.go:161: no such file or directory
set 02 09:14:27 manjaro2am daemon/launcher[2335]: manager.go:184: open /var/lib/lastore/desktop_package.json: no such file or directory
set 02 09:14:27 manjaro2am daemon/launcher[2335]: manager.go:189: open /var/lib/lastore/applications.json: no such file or directory
set 02 09:14:27 manjaro2am daemon/screensaver[2335]: module.go:56: ScreenSaver has been register, exit...
set 02 09:14:27 manjaro2am gesture[2335]: manager.go:148: The name org.desktopspec.ConfigManager was not provided by any .service files
set 02 09:14:27 manjaro2am gesture[2335]: manager.go:173: dbus: invalid message: invalid path name
set 02 09:14:27 manjaro2am daemon/lastore[2335]: lastore.go:361: The name com.deepin.lastore was not provided by any .service files
set 02 09:14:27 manjaro2am daemon/network[2335]: manager.go:185: get sessionManager CurrentSessionPath failed: The name com.deepin.SessionManager was not provided by any .service files
set 02 09:14:27 manjaro2am daemon/network[2335]: manager.go:189: Failed to connect self session: path is invalid
-> module.go:77
-> module.go:132
-> module.go:76
-> module.go:92
-> loader.go:175
-> asm_amd64.s:1571
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2335]: panic: runtime error: invalid memory address or nil pointer dereference
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2335]: [signal SIGSEGV: segmentation violation code=0x1 addr=0x20 pc=0x5653d06c4466]
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2335]: goroutine 54 [running]:
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2335]: github.com/linuxdeepin/dde-daemon/network.(*Manager).isSessionActive(0xc000452040?)
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2335]: github.com/linuxdeepin/dde-daemon/network/utils.go:247 +0x26
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2335]: github.com/linuxdeepin/dde-daemon/network.(*Manager).init(0xc000844380)
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2335]: github.com/linuxdeepin/dde-daemon/network/manager.go:226 +0x537
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2335]: github.com/linuxdeepin/dde-daemon/network.(*Module).start(0x5653d07bfa00?)
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2335]: github.com/linuxdeepin/dde-daemon/network/module.go:77 +0x85
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2335]: github.com/linuxdeepin/dde-daemon/network.(*Module).Start(0xc0000903a8?)
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2335]: github.com/linuxdeepin/dde-daemon/network/module.go:132 +0x5b
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2335]: github.com/linuxdeepin/dde-daemon/loader.(*ModuleBase).doEnable(0xc000452080, 0x1)
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2335]: github.com/linuxdeepin/dde-daemon/loader/module.go:76 +0x9f
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2335]: github.com/linuxdeepin/dde-daemon/loader.(*ModuleBase).Enable(0xc000044480?, 0x5?)
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2335]: github.com/linuxdeepin/dde-daemon/loader/module.go:92 +0x6d
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2335]: github.com/linuxdeepin/dde-daemon/loader.(*Loader).EnableModules.func1()
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2335]: github.com/linuxdeepin/dde-daemon/loader/loader.go:175 +0x20b
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2335]: created by github.com/linuxdeepin/dde-daemon/loader.(*Loader).EnableModules
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2335]: github.com/linuxdeepin/dde-daemon/loader/loader.go:165 +0x47e
set 02 09:14:27 manjaro2am daemon/dde-session-daemon[2397]: main.go:92: Name "com.deepin.SessionManager" does not exist
set 02 09:14:27 manjaro2am gnome-keyring-daemon[1441]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
set 02 09:14:27 manjaro2am gnome-keyring-d[1441]: asked to register item /org/freedesktop/secrets/collection/login/1, but it's already registered
set 02 09:14:27 manjaro2am daemon/loader[2397]: dag_builder.go:42: disabled module(calltrace) is no existed
set 02 09:14:27 manjaro2am daemon/loader[2397]: dag_builder.go:42: disabled module(debug) is no existed
set 02 09:14:27 manjaro2am daemon/mime[2397]: manager.go:90: no such file or directory
set 02 09:14:27 manjaro2am daemon/launcher[2397]: manager.go:161: no such file or directory
set 02 09:14:27 manjaro2am daemon/launcher[2397]: manager.go:184: open /var/lib/lastore/desktop_package.json: no such file or directory
set 02 09:14:27 manjaro2am daemon/launcher[2397]: manager.go:189: open /var/lib/lastore/applications.json: no such file or directory
set 02 09:14:27 manjaro2am daemon/screensaver[2397]: module.go:56: ScreenSaver has been register, exit...
set 02 09:14:27 manjaro2am gesture[2397]: manager.go:148: The name org.desktopspec.ConfigManager was not provided by any .service files
set 02 09:14:27 manjaro2am gesture[2397]: manager.go:173: dbus: invalid message: invalid path name
set 02 09:14:27 manjaro2am daemon/lastore[2397]: lastore.go:361: The name com.deepin.lastore was not provided by any .service files
set 02 09:14:27 manjaro2am daemon/network[2397]: manager.go:185: get sessionManager CurrentSessionPath failed: The name com.deepin.SessionManager was not provided by any .service files
set 02 09:14:27 manjaro2am daemon/network[2397]: manager.go:189: Failed to connect self session: path is invalid
-> module.go:77
-> module.go:132
-> module.go:76
-> module.go:92
-> loader.go:175
-> asm_amd64.s:1571
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2397]: panic: runtime error: invalid memory address or nil pointer dereference
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2397]: [signal SIGSEGV: segmentation violation code=0x1 addr=0x20 pc=0x55efaa231466]
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2397]: goroutine 137 [running]:
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2397]: github.com/linuxdeepin/dde-daemon/network.(*Manager).isSessionActive(0xc0000440c0?)
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2397]: github.com/linuxdeepin/dde-daemon/network/utils.go:247 +0x26
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2397]: github.com/linuxdeepin/dde-daemon/network.(*Manager).init(0xc0004ee1c0)
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2397]: github.com/linuxdeepin/dde-daemon/network/manager.go:226 +0x537
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2397]: github.com/linuxdeepin/dde-daemon/network.(*Module).start(0x55efaa32ca00?)
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2397]: github.com/linuxdeepin/dde-daemon/network/module.go:77 +0x85
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2397]: github.com/linuxdeepin/dde-daemon/network.(*Module).Start(0xc000130348?)
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2397]: github.com/linuxdeepin/dde-daemon/network/module.go:132 +0x5b
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2397]: github.com/linuxdeepin/dde-daemon/loader.(*ModuleBase).doEnable(0xc000044100, 0x1)
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2397]: github.com/linuxdeepin/dde-daemon/loader/module.go:76 +0x9f
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2397]: github.com/linuxdeepin/dde-daemon/loader.(*ModuleBase).Enable(0xc000178400?, 0x5?)
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2397]: github.com/linuxdeepin/dde-daemon/loader/module.go:92 +0x6d
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2397]: github.com/linuxdeepin/dde-daemon/loader.(*Loader).EnableModules.func1()
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2397]: github.com/linuxdeepin/dde-daemon/loader/loader.go:175 +0x20b
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2397]: created by github.com/linuxdeepin/dde-daemon/loader.(*Loader).EnableModules
set 02 09:14:27 manjaro2am com.deepin.api.XEventMonitor[2397]: github.com/linuxdeepin/dde-daemon/loader/loader.go:165 +0x47e
set 02 09:14:28 manjaro2am systemd[1]: dev-disk-by\x2duuid-fa7921f4\x2dab61\x2d4561\x2d9ec7\x2d5473512ce3a8.device: Job dev-disk-by\x2duuid-fa7921f4\x2dab61\x2d4561\x2d9ec7\x2d5473512ce3a8.device/start timed out.
set 02 09:14:28 manjaro2am systemd[1]: Timed out waiting for device /dev/disk/by-uuid/fa7921f4-ab61-4561-9ec7-5473512ce3a8.
set 02 09:14:28 manjaro2am systemd[1]: Dependency failed for /mnt/MintHD.
set 02 09:14:28 manjaro2am systemd[1]: dev-disk-by\x2did-usb\x2dSeagate_Backup\x2b_Hub_BK_NA9R3Q8T\x2d0:0\x2dpart2.device: Job dev-disk-by\x2did-usb\x2dSeagate_Backup\x2b_Hub_BK_NA9R3Q8T\x2d0:0\x2dpart2.device/start timed out.
set 02 09:14:28 manjaro2am systemd[1]: Timed out waiting for device /dev/disk/by-id/usb-Seagate_Backup+_Hub_BK_NA9R3Q8T-0:0-part2.
set 02 09:14:28 manjaro2am systemd[1]: Dependency failed for /mnt/MacBackupHD.
set 02 09:14:28 manjaro2am systemd[1]: dev-disk-by\x2did-wwn\x2d0x5000c5007d5a2bdb\x2dpart2.device: Job dev-disk-by\x2did-wwn\x2d0x5000c5007d5a2bdb\x2dpart2.device/start timed out.
set 02 09:14:28 manjaro2am systemd[1]: Timed out waiting for device /dev/disk/by-id/wwn-0x5000c5007d5a2bdb-part2.
set 02 09:14:28 manjaro2am systemd[1]: Dependency failed for /mnt/StorageDisk.
set 02 09:14:28 manjaro2am systemd[1]: dev-disk-by\x2did-wwn\x2d0x5000c500d0315eae\x2dpart1.device: Job dev-disk-by\x2did-wwn\x2d0x5000c500d0315eae\x2dpart1.device/start timed out.
set 02 09:14:28 manjaro2am systemd[1]: Timed out waiting for device /dev/disk/by-id/wwn-0x5000c500d0315eae-part1.
set 02 09:14:28 manjaro2am systemd[1]: Dependency failed for /mnt/BackupHD.
set 02 09:14:28 manjaro2am systemd[1]: dev-disk-by\x2duuid-6addfe70\x2d51d5\x2d4616\x2d9678\x2d2bef0c108755.device: Job dev-disk-by\x2duuid-6addfe70\x2d51d5\x2d4616\x2d9678\x2d2bef0c108755.device/start timed out.
set 02 09:14:28 manjaro2am systemd[1]: Timed out waiting for device /dev/disk/by-uuid/6addfe70-51d5-4616-9678-2bef0c108755.
set 02 09:14:28 manjaro2am systemd[1]: Dependency failed for /mnt/6addfe70-51d5-4616-9678-2bef0c108755.
set 02 09:14:28 manjaro2am systemd[1]: dev-disk-by\x2did-wwn\x2d0x5000c5007d5a2bdb\x2dpart1.device: Job dev-disk-by\x2did-wwn\x2d0x5000c5007d5a2bdb\x2dpart1.device/start timed out.
set 02 09:14:28 manjaro2am systemd[1]: Timed out waiting for device /dev/disk/by-id/wwn-0x5000c5007d5a2bdb-part1.
set 02 09:14:28 manjaro2am systemd[1]: Dependency failed for /mnt/StorageHD.
set 02 09:14:28 manjaro2am systemd[1]: dev-disk-by\x2did-usb\x2dUSB3.0_USB_Device_DB9876543211167\x2d0:0\x2dpart1.device: Job dev-disk-by\x2did-usb\x2dUSB3.0_USB_Device_DB9876543211167\x2d0:0\x2dpart1.device/start timed out.
set 02 09:14:28 manjaro2am systemd[1]: Timed out waiting for device /dev/disk/by-id/usb-USB3.0_USB_Device_DB9876543211167-0:0-part1.
set 02 09:14:28 manjaro2am systemd[1]: Dependency failed for /mnt/MobileHD.
set 02 09:14:28 manjaro2am com.deepin.daemon.Daemon[2081]: libinput error: client bug: Invalid event type LIBINPUT_EVENT_POINTER_MOTION (400) passed to libinput_event_pointer_get_axis_source()
set 02 09:14:28 manjaro2am com.deepin.daemon.Daemon[2081]: libinput error: client bug: Invalid event type LIBINPUT_EVENT_POINTER_MOTION (400) passed to libinput_event_pointer_get_axis_value()
set 02 09:14:28 manjaro2am deepin-system-monitor-plugin-popup[1695]: QDBusArgument: read from a write-only object
set 02 09:14:28 manjaro2am deepin-system-monitor-plugin-popup[1695]: "Error: [2] Arquivo ou diretório inexistente, " "open /proc/2669/stat failed"
set 02 09:14:28 manjaro2am deepin-system-monitor-plugin-popup[1695]: "Error: [2] Arquivo ou diretório inexistente, " "open /proc/2669/schedstat failed"
set 02 09:14:28 manjaro2am bluetoothd[954]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
set 02 09:14:29 manjaro2am com.deepin.daemon.Daemon[2081]: libinput error: client bug: Invalid event type LIBINPUT_EVENT_POINTER_MOTION (400) passed to libinput_event_pointer_get_axis_source()
set 02 09:14:29 manjaro2am com.deepin.daemon.Daemon[2081]: libinput error: client bug: Invalid event type LIBINPUT_EVENT_POINTER_MOTION (400) passed to libinput_event_pointer_get_axis_value()
set 02 09:31:04 manjaro2am deepin-system-monitor-plugin-popup[1695]: QDBusArgument: read from a write-only object
set 02 09:31:04 manjaro2am com.deepin.daemon.Daemon[2081]: libinput error: client bug: value requested for unset axis
set 02 09:31:05 manjaro2am com.deepin.daemon.Daemon[2081]: libinput error: client bug: value requested for unset axis
set 02 09:31:05 manjaro2am com.deepin.daemon.Daemon[2081]: libinput error: client bug: Invalid event type LIBINPUT_EVENT_POINTER_MOTION (400) passed to libinput_event_pointer_get_axis_source()
set 02 09:31:05 manjaro2am com.deepin.daemon.Daemon[2081]: libinput error: client bug: Invalid event type LIBINPUT_EVENT_POINTER_MOTION (400) passed to libinput_event_pointer_get_axis_value()
set 02 09:42:00 manjaro2am deepin-system-monitor-plugin-popup[1695]: QDBusArgument: read from a write-only object
set 02 09:42:02 manjaro2am kernel: pcieport 0000:00:1c.0: PCIe Bus Error: severity=Corrected, type=Data Link Layer, (Transmitter ID)
set 02 09:42:02 manjaro2am kernel: pcieport 0000:00:1c.0: device [8086:a33c] error status/mask=00001000/00002000
set 02 09:42:02 manjaro2am kernel: pcieport 0000:00:1c.0: [12] Timeout
set 02 09:42:02 manjaro2am deepin-system-monitor-plugin-popup[1695]: QDBusArgument: read from a write-only object
