Bluetooth turns on automatically on start
I have currently installed Manjaro Gnome Edition on my laptop and am a beginner in linux. On every bootup I see that bluetooth is turned on automatically. Can anyone provide a solution for this?
Try to execute gsettings set org.blueman.plugins.powermanager auto-power-on false (is needed once).
You can also try to edit /etc/bluetooth/main.conf and make sure that AutoEnable=false is uncommented (without # in front).
sudo systemctl disable bluetooth.service
try this
The bluetooth radio itself will remain active indipendently from the bluetooth service.
This one didn’t work out for me. I uncommented the line but still the bluetooth kept turning itself on for every boot.
This one worked. Thank you so much. :slight_smile:
after doing sudo systemctl disable bluetooth.service
i got a pulseaudio error: pulseaudio[1005]: GetManagedObjects() failed:
org.freedesktop.DBus.Error.NoReply
which i fixed with this post instructions:
