Bluetooth turning off after wakeup
I noticed that sometimes after wakeup from sleep, the bluetooth turns off and can’t turn it back on until I completely shut down the laptop and turn it on again (restart doesn’t work). I trying running the command
systemctl restart bluetooth
but it doesn’t do anything. the GUI is unresponsive as well.
My system specs are:
  Kernel: 6.18.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    clocksource: hpet avail: acpi_pm
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64
    root=UUID=c0b7a99b-f9c9-49a0-9421-a744ae0f2d61 rw rootflags=subvol=@
    quiet splash udev.log_priority=3 gpio_ich.use_gpio=0
  Desktop: KDE Plasma v: 6.6.4 tk: Qt v: N/A info: frameworks v: 6.25.0
    wm: kwin_wayland with: Docker vt: 1 dm: SDDM Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: LENOVO product: 83LT v: Legion Pro 5 16ADR10
    serial: <superuser required> Chassis: type: 10 v: Legion Pro 5 16ADR10
  Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
    part-nu: LENOVO_MT_83LT_BU_idea_FM_Legion Pro 5 16ADR10
    uuid: <superuser required> Firmware: UEFI vendor: LENOVO v: RLCN32WW
    date: 11/25/2025
  ID-1: BAT0 charge: 30.7 Wh (37%) condition: 83/80 Wh (103.7%) power: 81.1 W
    volts: 16.01 min: 15.52 model: COSMX L24X4PC0 type: Li-poly serial: <filter>
    charging: status: charging type: standard avail: long_life,standard
    cycles: 11
  Device-1: apple_mfi_fastcharge_1-2 model: N/A serial: N/A charge: N/A
    status: N/A
  System RAM: total: 32 GiB available: 30.64 GiB used: 5.42 GiB (17.7%)
  Device-1: Channel-A DIMM 0 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 16 GiB speed: spec: 5600 MT/s actual: 5200 MT/s
    volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: Cxmt part-no: CXMR4E816S6AS-CN1C serial: <filter>
  Device-2: Channel-B DIMM 0 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 8745HX with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 4 gen: 4 level: v4 note: check built: 2022+ process: TSMC n5 (5nm)
    family: 0x19 (25) model-id: 0x61 (97) stepping: 2 microcode: 0xA60120C
    smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 1490 min/max: 404/5153 boost: enabled scaling:
    driver: amd-pstate-epp governor: performance cores: 1: 1490 2: 1490 3: 1490
    4: 1490 5: 1490 6: 1490 7: 1490 8: 1490 9: 1490 10: 1490 11: 1490 12: 1490
    13: 1490 14: 1490 15: 1490 16: 1490 bogomips: 114982
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
    avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
    clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid
    cpuid_fault cqm cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc
    cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
    flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt gfni ht
    hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf lahf_lm lbrv lm mba
    mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
    nopl npt nrip_save nx ospke osvw overflow_recov pae pat pausefilter
    pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb perfmon_v2
    pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed
    rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean vme
    vmmcall vnmi vpclmulqdq wbnoinvd wdt x2apic x2avic xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves xtopology
    conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: NVIDIA GB206M [GeForce RTX 5060 Max-Q / Mobile] vendor: Lenovo
    driver: nvidia v: 595.71.05 alternate: nouveau,nova_core,nvidia_drm
    non-free: 550-580.xx+ status: current (as of 2025-11) arch: Lovelace
    code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 1
    speed: 2.5 GT/s lanes: 8 link-max: gen: 5 speed: 32 GT/s lanes: 16 ports:
    active: none empty: DP-1, DP-2, HDMI-A-1, eDP-2 bus-ID: 01:00.0
    chip-ID: 10de:2d59 class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Lenovo
    driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
    empty: Writeback-1 bus-ID: 05:00.0 chip-ID: 1002:164e class-ID: 0300
    temp: 54.0 C
  Device-3: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2 chip-ID: 30c9:00f8
    compositor: kwin_wayland driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
    gpu: amdgpu display-ID: 0
  Monitor-1: eDP-1 model: Samsung ATNA60HS03-0 built: 2024 res:
    mode: 2560x1600 hz: 165 scale: 125% (1.25) to: 2048x1280 dpi: 191 gamma: 1.2
    chroma: red: x: 0.682 y: 0.318 green: x: 0.220 y: 0.725 blue: x: 0.141
    y: 0.039 white: x: 0.314 y: 0.329 size: 340x220mm (13.39x8.66")
    diag: 405mm (15.94") modes: 2560x1600, 1920x1200, 1920x1080, 1600x1200,
    1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768, 800x600,
    640x480
  EDID-Warnings: 1: parse_edid: unknown tag 112 2: parse_edid: unknown tag
    112
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia wayland: drv: radeonsi x11: drv: radeonsi
    inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 26.0.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon 610M (radeonsi
    raphael_mendocino ACO DRM 3.64 6.18.26-1-MANJARO) device-ID: 1002:164e
    memory: 500 MiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.4.341 layers: 8 device: 0 type: integrated-gpu name: AMD
    Radeon 610M (RADV RAPHAEL_MENDOCINO) driver: mesa radv v: 26.0.6-arch1.1
    device-ID: 1002:164e surfaces: N/A device: 1 type: discrete-gpu
    name: NVIDIA GeForce RTX 5060 Laptop GPU driver: nvidia v: 595.71.05
    device-ID: 10de:2d59 surfaces: N/A
  Device-1: NVIDIA GB206 High Definition Audio driver: snd_hda_intel v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: gen: 5 speed: 32 GT/s
    lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22eb class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
    driver: snd_rpl_pci_acp6x v: kernel alternate: snd_pci_acp3x,
    snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
    snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio vendor: Lenovo
    bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.18.26-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.4 status: active with: 1: pipewire-pulse
That’s not the full inxi -zv8 output, it stops after the Audio section so we can’t see your Network & Bluetooth info. Please edit your post to include the full output.
I had this happen on my laptop too, and disabling Bluetooth power saving in TLP fixed it for me. Updating the kernel also helped since some suspend/wakeup Bluetooth bugs seem pretty hardware-specific.
@Yochanan
  Kernel: 6.18.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
    quiet splash udev.log_priority=3 mem_sleep_default=s2idle
  Desktop: KDE Plasma v: 6.6.5 tk: Qt v: N/A info: frameworks v: 6.26.0
    base: Arch Linux
    date: 11/25/2025
  ID-1: BAT0 charge: 61.4 Wh (74%) condition: 82.9/80 Wh (103.6%)
    power: 26.3 W volts: 16.24 min: 15.52 model: COSMX L24X4PC0 type: Li-poly
    serial: <filter> charging: status: discharging type: long_life
    avail: long_life,standard cycles: 36
  System RAM: total: 32 GiB available: 30.64 GiB used: 6.72 GiB (21.9%)
    driver: amd-pstate-epp governor: powersave cores: 1: 1490 2: 1490 3: 1490
    13: 1490 14: 1490 15: 1490 16: 1490 bogomips: 114984
    affected
    code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4
    speed: 16 GT/s lanes: 8 link-max: gen: 5 speed: 32 GT/s lanes: 16 ports:
    temp: 48.0 C
    640x480
    112
    inactive: device-1
    raphael_mendocino ACO DRM 3.64 6.18.32-1-MANJARO) device-ID: 1002:164e
  API: Vulkan v: 1.4.350 layers: 8 device: 0 type: integrated-gpu name: AMD
  API: ALSA v: k6.18.32-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.5 status: active with: 1: pipewire-pulse
  Device-1: MEDIATEK MT7925 802.11be 160MHz 2x2 PCIe Wireless Network Adapter
    [Filogic 360] vendor: Lenovo driver: mt7925e v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 14c3:7925 class-ID: 0280
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp4s0 state: down mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  Device-1: Foxconn / Hon Hai Wireless_Device driver: btusb v: 0.8 type: USB
    rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.3:3
    chip-ID: 0489:e111 class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 4 state: up address: <filter> bt-v: 5.4
    lmp-v: 13 status: discoverable: no pairing: no class-ID: 6c010c
  Local Storage: total: 953.87 GiB used: 729.25 GiB (76.5%)
    model: MZAL81T0HFLB-00BL2 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 5L1QKXF7 temp: 42.9 C scheme: GPT
  ID-1: / raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
    used: 729.22 GiB (76.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: c0b7a99b-f9c9-49a0-9421-a744ae0f2d61
    used: 32.7 MiB (10.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
    label: N/A uuid: 8070-76C3
  ID-3: /home raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
  ID-4: /var/cache raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
  ID-5: /var/log raw-size: 953.57 GiB size: 953.57 GiB (100.00%)
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-4: 3-2:2 info: Genesys Logic Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
  Device-1: 3-2.3:3 info: Foxconn / Hon Hai Wireless_Device type: bluetooth
    mode: 2.0 power: 100mA chip-ID: 0489:e111 class-ID: e001 serial: <filter>
  Device-2: 3-2.4:4 info: Integrated Express ITE Device(8258)
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 048d:c195 class-ID: 0300
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-6: 4-2:2 info: Genesys Logic GL3523 Hub ports: 2 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
  Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 5-1:2 info: Luxvisions Innotech Integrated Camera type: video
    driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 30c9:00f8 class-ID: fe01
    serial: <filter>
  System Temperatures: cpu: 57.1 C mobo: 43.0 C gpu: amdgpu temp: 49.0 C
  Fan Speeds (rpm): N/A
  Packages: 1511 pm: pacman pkgs: 1502 libs: 402 tools: pamac,yay pm: flatpak
    pkgs: 9
    1: https://manjaro.ynh.ovh/stable/$repo/$arch
    2: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    3: https://mirror.23m.com/manjaro/stable/$repo/$arch
    4: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    6: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
    8: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    9: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    10: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    11: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    12: https://mirror.fcix.net/manjaro/stable/$repo/$arch
    13: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    14: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    15: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    16: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    17: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    18: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    19: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    20: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    21: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    22: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    23: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    24: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    25: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    26: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    27: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    28: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    29: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    30: https://mirrors2.manjaro.org/stable/$repo/$arch
    31: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    32: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    33: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
    34: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    35: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    36: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    37: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    38: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    39: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    40: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    41: https://mirror.init7.net/manjaro/stable/$repo/$arch
    42: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    43: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    44: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    45: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    46: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    47: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    48: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    49: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 414
  1: cpu: 9.9% command: vivaldi-bin pid: 7889 mem: 297.8 MiB (0.9%)
  2: cpu: 6.9% command: vivaldi-bin pid: 10659 mem: 303.1 MiB (0.9%)
  3: cpu: 3.4% command: konsole pid: 11058 mem: 359.8 MiB (1.1%)
  4: cpu: 2.2% command: vivaldi-bin pid: 4290 mem: 419.7 MiB (1.3%)
  5: cpu: 1.8% command: zsh pid: 11085 mem: 10.3 MiB (0.0%)
  Memory top: 5 of 414
  1: mem: 735.7 MiB (2.3%) command: vivaldi-bin pid: 4213 cpu: 1.6%
  2: mem: 583.2 MiB (1.8%) command: plasmashell pid: 1538 cpu: 0.1%
  3: mem: 425.7 MiB (1.3%) command: kwin_wayland pid: 1318 cpu: 0.4%
  4: mem: 419.7 MiB (1.3%) command: vivaldi-bin pid: 4290 cpu: 2.2%
  5: mem: 380.4 MiB (1.2%) command: vivaldi-bin pid: 6871 cpu: 0.6%
  Processes: 414 Power: uptime: 2h 47m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 1 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.13 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 260 default: graphical
    tool: systemctl
  Compilers: gcc: 16.1.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.40
@ErinHong
I don’t have TLP installed. Also I think I have the latest kernel, since this is a relatively new laptop, but will recheck
Mod edit: Consecutive posts merged. Please edit your previous post(s) instead to add further information.
There are various reports on multiple distros with that chipset. You might try what worked for this user after boot:
sudo modprobe -r btusb mt7925e && sudo modprobe mt7925e && sudo modprobe btusb
