Hello everyone
i have problem with my Bluetooth when i send a file from my phone (or my other pc) it will receive it normally but when i resend the same file it fails to receive the file, normally it would ask to overwrite the old file or it would suggest a new name to rename the incoming file.
I dont know what is happen …
If somebody can help i would be very appreciated…
Thanks a lot for your time…
Welcome to Manjaro!
Please read this:
and post some more information so we can see what’s really going on. Now we know the symptom of the disease, but we need some more probing to know where the origin lies…
An inxi --admin --verbosity=7 --filter --no-host --width would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
here is the output of the command inxi --admin --verbosity=7 --filter --no-host --width :
System: Kernel: 5.10.15-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1 Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2
info: cairo-dock wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Portable System: Dell product: Dell System XPS L502X v: N/A serial: <filter> Chassis: type: 8 v: 0.1
serial: <filter>
Mobo: Dell model: 0NJT03 v: A00 serial: <filter> UEFI [Legacy]: Dell v: A07 date: 10/20/2011
Battery: ID-1: BAT0 charge: 3.8 Wh condition: 3.8/73.3 Wh (5%) volts: 12.4/11.1 model: LGC Dell type: Li-ion
serial: <filter> status: Full
Device-1: hid-20:73:ab:01:07:17-battery model: Bluetooth Mouse serial: N/A charge: N/A status: Discharging
Memory: RAM: total: 7.67 GiB used: 2.22 GiB (28.9%)
Array-1: capacity: 8 GiB slots: 2 EC: None max module size: 4 GiB note: est.
Device-1: ChannelA-DIMM0 size: 4 GiB speed: 1333 MT/s type: DDR3 detail: synchronous bus width: 64 bits
total: 64 bits manufacturer: Hynix/Hyundai part-no: HMT351S6CFR8C-H9 serial: <filter>
Device-2: ChannelB-DIMM0 size: 4 GiB speed: 1333 MT/s type: DDR3 detail: synchronous bus width: 64 bits
CPU: Info: Quad Core model: Intel Core i7-2670QM bits: 64 type: MT MCP arch: Sandy Bridge rev: 7 L1 cache: 64 KiB
L2 cache: 6 MiB L3 cache: 5.9 MiB bogomips: 35135
Speed: 1238 MHz min/max: 800/3100 MHz volts: 1.2 V ext-clock: 100 MHz Core speeds (MHz): 1: 1238 2: 1194 3: 1427
4: 891 5: 1115 6: 999 7: 1724 8: 1048
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov constant_tsc cpuid cx16 cx8 de ds_cpl dtes64
dtherm dts epb ept est flexpriority flush_l1d fpu fxsr ht ibpb ibrs ida lahf_lm lm mca mce md_clear mmx monitor msr
mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp sep ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic xsave
xsaveopt xtopology xtpr
Graphics: Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics vendor: Dell driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:0116 class ID: 0300
Device-2: NVIDIA GF108M [GeForce GT 540M] driver: N/A bus ID: 01:00.0 chip ID: 10de:0df4 class ID: 0300
Device-3: Quanta Laptop_Integrated_Webcam_2HDM type: USB driver: uvcvideo bus ID: 1-1.4:3 chip ID: 0408:2fb1
class ID: 0e02
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: modesetting resolution: 1920x1080~60Hz
s-dpi: 96
OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2) v: 3.3 Mesa 20.3.4 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel 6 Series/C200 Series Family High Definition Audio vendor: Dell driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:1c20 class ID: 0403
Device-2: NVIDIA GF108 High Definition Audio driver: snd_hda_intel v: kernel bus ID: 01:00.1 chip ID: 10de:0bea
class ID: 0403
Device-3: Philips s SAA7231 vendor: Avermedia driver: N/A bus ID: 02:00.0 chip ID: 1131:7231 class ID: 0480
Sound Server: ALSA v: k5.10.15-1-MANJARO
Network: Device-1: Intel Centrino Wireless-N 1030 [Rainbow Peak] driver: iwlwifi v: kernel port: efa0 bus ID: 03:00.0
chip ID: 8086:008a class ID: 0280
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Dell driver: r8168 v: 8.048.03-NAPI
port: 2000 bus ID: 06:00.0 chip ID: 10ec:8168 class ID: 0200
IF: enp6s0 state: down mac: <filter>
Bluetooth: Device-1: Intel Centrino Advanced-N 6230 Bluetooth adapter type: USB driver: btusb v: 0.8 bus ID: 2-1.5:3
chip ID: 8086:0189 class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
RAID: Message: No RAID data was found.
Drives: Local Storage: total: 698.65 GiB used: 671.35 GiB (96.1%)
ID-1: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB speed: 6.0 Gb/s rotation: SSD
serial: <filter> rev: 2B6Q scheme: MBR
ID-2: /dev/sdb vendor: Hitachi model: HTS727550A9E364 size: 465.76 GiB speed: 3.0 Gb/s rotation: 7200 rpm
serial: <filter> rev: A0D0 scheme: MBR
Partition: ID-1: / size: 105.84 GiB used: 98.33 GiB (92.9%) fs: ext4 dev: /dev/sda6 label: N/A
uuid: 6a905820-7cb4-45f6-841c-d2ded91ae9ea
ID-2: /mnt/40CA7197CA7189C4 size: 270.35 GiB used: 267.54 GiB (99.0%) fs: ntfs dev: /dev/sdb4 label: N/A
uuid: 40CA7197CA7189C4
ID-3: /mnt/AABCC3A7BCC36BFF size: 97.66 GiB used: 92.46 GiB (94.7%) fs: ntfs dev: /dev/sdb2 label: N/A
uuid: AABCC3A7BCC36BFF
ID-4: /mnt/B2B67561B675274F size: 116.65 GiB used: 116.36 GiB (99.8%) fs: ntfs dev: /dev/sda2 label: N/A
uuid: B2B67561B675274F
ID-5: /mnt/none size: 97.66 GiB used: 96.63 GiB (99.0%) fs: ntfs dev: /dev/sdb5 label: none uuid: 32EEBCFBEEBCB905
ID-6: /run/media/beams/\xce\x94\xce\xb5\xcf\x83\xce\xbc\xce\xb5\xcf\x85\xce\xbc\xce\xad\xce\xbd\xce\xbf
\xce\xb1\xcf\x80\xcf\x8c \xcf\x84\xce\xbf \xcf\x83\xcf\x8d\xcf\x83\xcf\x84\xce\xb7\xce\xbc\xce\xb1
raw size: 100 MiB size: N/A (hidden?) used: N/A (hidden?) fs: ntfs dev: /dev/sda1 label: \xce\x94\xce\xb5\xcf\x83\xce\xbc\xce\xb5\xcf\x85\xce\xbc\xce\xad\xce\xbd\xce\xbf
uuid: 7CECEAC2ECEA7634
ID-7: /run/media/beams/Δεσμευμένο από το σύστημα size: 100 MiB used: 28.4 MiB (28.4%)
Swap: ID-1: swap-1 type: partition size: 7.66 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda5 label: N/A
uuid: 265a80b0-93f8-4970-9e3e-cf3ef74b795d
Unmounted: ID-1: /dev/sda3 size: 450 MiB fs: ntfs label: N/A uuid: D0BE5F33BE5F10F8
ID-2: /dev/sda4 size: 1 KiB fs: N/A label: N/A uuid: N/A
ID-3: /dev/sdb1 size: 100 MiB fs: ntfs label: System Reserved uuid: C274A42B74A4245F
ID-4: /dev/sdb3 size: 1 KiB fs: N/A label: N/A uuid: N/A
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0 speed: 480 Mb/s chip ID: 8087:0024
class ID: 0900
Device-1: 1-1.4:3 info: Quanta Laptop_Integrated_Webcam_2HDM type: Video driver: uvcvideo interfaces: 3 rev: 2.0
speed: 480 Mb/s chip ID: 0408:2fb1 class ID: 0e02
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0 speed: 480 Mb/s chip ID: 8087:0024
class ID: 0900
Device-1: 2-1.5:3 info: Intel Centrino Advanced-N 6230 Bluetooth adapter type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8086:0189 class ID: e001
Hub-5: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Hub-6: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003 class ID: 0900
Sensors: System Temperatures: cpu: 57.0 C mobo: 50.0 C
Fan Speeds (RPM): cpu: 2807
Info: Processes: 249 Uptime: 48m wakeups: 2 Init: systemd v: 247 Compilers: gcc: 10.2.0 clang: 11.0.1 Packages: 1738
pacman: 1720 flatpak: 5 snap: 13 Shell: Bash (su) v: 5.1.0 running in: konsole inxi: 3.3.01
I hope i posted it correct this time and provide the infos.
Thanks a lot
In the future, when providing code/output, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text so that the output looks like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.instead of like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.`
(as that makes both our lives much easier)
No need to do anything right now as I’m an editor here on this site and have fixed it for you already. However, in the future I might not see your post so review my edits by pushing the orange pencil above the post I just fixed.
Everything looks normal, so I’ve edited your title and added the #bluetooth and #kde tags to attract smarter people than me!
Thanks a lot for your help and guidance…
… why would it?
as I understood it
you are sending the same file (by name)
but actually a different file (by content)
the difference should be detected and
one should only overwrite the other after confirmation
If it is the same file name and the same content …
why should the “old” be overwritten with the “new”
(it’s the same … it’s already there …)
… this might be my problem understanding yours …
What happens when it:
Hello my friend
Actually it is the same spreadsheet with different content every time . this problem exists about 10 days. before it was asking me to overwrite or to rename with a suggestion. Now it fails to receive…
Thanks for your time
now now I can begin to understand your issue
… it fails to receive?
or it fails to ask to overwrite ?
the same file, same name, different content
From the sender the transfer is ok .but my laptop fails to receive when in the destination folder is a file with the same name. If I delete the file from my folder I receive the file normal…
… it fails to receive (unlikely)
or
it fails to overwrite
the same file name with different content
(that is what I understood)
but you say:
it fails to receive …
How do you know the difference?
Hello Nachlese
Ive made a test :I have a photo in the destination folder with name “a.jpg” and i send from my mobile a different photo but with the same name “a.jpg” and it fails to receive (i will upload a screenshot of the fail message) .But when i delete or move the photo from the destination folder and send it again it will receive the photo normally without any problem.
10 days ago was the last transfer that i made and i had the same situation but it prompted me to take an action (as always it do) “overwrite or rename or suggest a name or cancel” . Now it doesn’t prompt me to take an action.
Thanks a lot
and have a nice day…
Hello my friend
i’ve been thinking could it be maybe i say a permission error?
So that it cant modify the file in the destination folder (with the same name)?
thanks for your time…
