Bluetooth suddenly quit working
Good day,
I left my computer alone for a day connected to a headset and when I came back, it just stopped working. The remembered devices are gone as well. I’ve rebooted, tried using a live environment, and tried kernel 6.1 and 6.8, to no avail. Here’s my system information:
  Kernel: 6.6.25-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.6-x86_64
    root=UUID=4b0de9a1-f76b-4599-9ca5-7b90c9d3a620 rw rootflags=subvol=@
    quiet
    cryptdevice=UUID=fe6bdc85-0dc2-4c0a-a8d8-5e90f50b416f:luks-fe6bdc85-0dc2-4c0a-a8d8-5e90f50b416f
    root=/dev/mapper/luks-fe6bdc85-0dc2-4c0a-a8d8-5e90f50b416f splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
    v: 5.115.0 wm: kwin_x11 vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop System: Dell product: OptiPlex 3010 v: 01
    serial: <superuser required> Chassis: type: 6 serial: <superuser required>
  Mobo: Dell model: 042P49 v: A01 serial: <superuser required>
    part-nu: OptiPlex 3010 uuid: <superuser required> UEFI: Dell v: A22
    date: 11/29/2018
  System RAM: total: 16 GiB available: 15.59 GiB used: 2.1 GiB (13.5%)
  Array-1: capacity: 16 GiB note: est. slots: 2 modules: 2 EC: None
  Device-1: DIMM1 type: DDR3 detail: synchronous size: 8 GiB
    speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Micron part-no: 16JTF1G64AZ-1G6E1 serial: <filter>
  Device-2: DIMM2 type: DDR3 detail: synchronous size: 8 GiB
  Info: model: Intel Core i5-3470 bits: 64 type: MCP arch: Ivy Bridge
    gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
    model-id: 0x3A (58) stepping: 9 microcode: 0x21
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
    desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB
    desc: 1x6 MiB
  Speed (MHz): avg: 1596 high: 1597 min/max: 1600/3200 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1597 2: 1597 3: 1596
    4: 1596 bogomips: 25555
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
    ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
    lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae
    pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
    rdrand rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
    stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
    x2apic xsave xsaveopt xtopology xtpr
    disabled
    STIBP: disabled, RSB filling, PBRSB-eIBRS: Not affected
  Type: srbds status: Vulnerable: No microcode
  Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
    vendor: PC Partner / Sapphire driver: amdgpu v: kernel arch: GCN-4
    code: Arctic Islands process: GF 14nm built: 2016-20 pcie: gen: 3
    speed: 8 GT/s lanes: 16 ports: active: DP-2 empty: DP-1, DVI-D-1,
    HDMI-A-1, HDMI-A-2 bus-ID: 01:00.0 chip-ID: 1002:67df class-ID: 0300
    temp: 49.0 C
  Display: x11 server: X.Org v: 21.1.12 with: Xwayland v: 23.2.6
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: DP-2 mapped: DisplayPort-1 model: Viewteck GFV24C built: 2019
    res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2 size: 530x280mm (20.87x11.02")
    diag: 599mm (23.6") modes: max: 1920x1080 min: 720x400
    device: 1 drv: swrast surfaceless: drv: radeonsi x11: drv: radeonsi
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.2-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 470 Graphics
    (radeonsi polaris10 LLVM 16.0.6 DRM 3.54 6.6.25-1-MANJARO)
    device-ID: 1002:67df memory: 3.91 GiB unified: no
  API: Vulkan v: 1.3.279 layers: 4 device: 0 type: discrete-gpu name: AMD
    Radeon RX 470 Graphics (RADV POLARIS10) driver: mesa radv
    v: 24.0.2-manjaro1.1 device-ID: 1002:67df surfaces: xcb,xlib
    vendor: Dell 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:1c20 class-ID: 0403
  Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    vendor: PC Partner / Sapphire driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aaf0 class-ID: 0403
  Device-3: C-Media TONOR TC-777 Audio Device
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-1.3:4 chip-ID: 0d8c:0134 class-ID: 0300
  API: ALSA v: k6.6.25-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
    vendor: Dell RTL8111/8168/8411 driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  Info: services: NetworkManager
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.2:3 chip-ID: 0bda:8771
  Device-1: luks-0db4202a-0a00-4bac-84fb-39bef6ca327e maj-min: 254:1
    type: LUKS dm: dm-1 size: 93.13 GiB
  Components:
  p-1: sda1 maj-min: 8:1 size: 93.13 GiB
  Device-2: luks-fe6bdc85-0dc2-4c0a-a8d8-5e90f50b416f maj-min: 254:0
    type: LUKS dm: dm-0 size: 130.14 GiB
  Components:
  p-1: sda3 maj-min: 8:3 size: 130.14 GiB
  Supported mdraid levels: raid0
  Device-1: md126 maj-min: 9:126 type: mdraid level: raid-0 status: active
  Info: report: N/A blocks: 976224256 chunk-size: 64k
  Components: Online:
  0: sdb maj-min: 8:16 size: 931.51 GiB
  Device-2: md127 maj-min: 9:127 type: mdraid level: N/A status: inactive
  Info: report: N/A blocks: 538328 chunk-size: N/A
  Components: Online: N/A Spare:
  0: sdb maj-min: 8:16 size: 931.51 GiB state: S
  Local Storage: total: raw: 2.04 TiB usable: 1.13 TiB used: 26.8 GiB (2.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: PNY model: CS900 240GB SSD
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 0BB3 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Hitachi model: HUA722010CLA330
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: A3EA
  ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: Portable
    size: 931.51 GiB block-size: physical: 4096 B logical: 512 B type: USB
    rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter>
    fw-rev: 0712 scheme: MBR
  Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVD+-RW GHA2N rev: A103
    dev-links: cdrom
  Features: speed: 125 multisession: yes audio: yes dvd: yes
  ID-1: / raw-size: 130.14 GiB size: 130.14 GiB (100.00%)
    used: 19.51 GiB (15.0%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-fe6bdc85-0dc2-4c0a-a8d8-5e90f50b416f label: system
    uuid: 4b0de9a1-f76b-4599-9ca5-7b90c9d3a620
    used: 728 KiB (0.2%) fs: vfat dev: /dev/sda2 maj-min: 8:2 label: BOOT
    uuid: E233-C8B4
  ID-3: /home raw-size: 93.13 GiB size: 93.13 GiB (100.00%)
    used: 7.29 GiB (7.8%) fs: btrfs dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-0db4202a-0a00-4bac-84fb-39bef6ca327e label: home
    uuid: 9a8b50aa-3186-458f-a6c9-b1400b9d9a37
  ID-4: /var/cache raw-size: 130.14 GiB size: 130.14 GiB (100.00%)
  ID-5: /var/log raw-size: 130.14 GiB size: 130.14 GiB (100.00%)
  ID-1: /dev/md126p1 maj-min: 259:0 size: 931 GiB fs: ext4 label: N/A
    uuid: 7c1fa927-7b20-4c59-878a-9bc1bc64e298
  ID-2: /dev/sdc1 maj-min: 8:33 size: 3.65 GiB fs: iso9660
  ID-3: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: B5B6-A7FC
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
  Device-1: 1-1.2:3 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
  Device-2: 1-1.3:4 info: C-Media TONOR TC-777 Audio Device type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 3 rev: 1.1
  Device-3: 1-1.4:5 info: Razer USA DeathAdder Essential
    type: mouse,keyboard driver: hid-generic,usbhid interfaces: 3 rev: 2.0
    chip-ID: 1532:0098 class-ID: 0300
  Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Device-1: 2-1.4:3 info: Seagate RSS LLC Portable type: mass storage
    driver: uas interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 0bc2:2344 class-ID: 0806 serial: <filter>
  Device-2: 2-1.5:4 info: China Resource Semico USB Keyboard
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 500mA
    chip-ID: 1a2c:4b81 class-ID: 0301
  System Temperatures: cpu: 42.0 C mobo: N/A gpu: amdgpu temp: 49.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 1677
  Processes: 258 Power: uptime: 5m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.21 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: 1202 pm: pacman pkgs: 1197 libs: 370 tools: pamac,yay
    pm: flatpak pkgs: 5 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9
    default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.33
Here’s logs about bluetooth:
sudo systemctl status bluetooth
● bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
     Active: active (running) since Wed 2024-04-10 19:05:51 CDT; 24h ago
       Docs: man:bluetoothd(8)
   Main PID: 525 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 19090)
     Memory: 2.3M (peak: 2.5M)
        CPU: 31ms
     CGroup: /system.slice/bluetooth.service
             └─525 /usr/lib/bluetooth/bluetoothd
Apr 10 19:05:51 dylan-optiplex3010 systemd[1]: Started Bluetooth service.
Apr 10 19:05:51 dylan-optiplex3010 bluetoothd[525]: Starting SDP server
Apr 10 19:05:51 dylan-optiplex3010 bluetoothd[525]: src/plugin.c:plugin_init() System does not support csip plugin
Apr 10 19:05:51 dylan-optiplex3010 bluetoothd[525]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Apr 10 19:05:51 dylan-optiplex3010 bluetoothd[525]: src/plugin.c:plugin_init() System does not support micp plugin
Apr 10 19:05:51 dylan-optiplex3010 bluetoothd[525]: src/plugin.c:plugin_init() System does not support vcp plugin
Apr 10 19:05:51 dylan-optiplex3010 bluetoothd[525]: src/plugin.c:plugin_init() System does not support mcp plugin
Apr 10 19:05:51 dylan-optiplex3010 bluetoothd[525]: src/plugin.c:plugin_init() System does not support bass plugin
Apr 10 19:05:51 dylan-optiplex3010 bluetoothd[525]: src/plugin.c:plugin_init() System does not support bap plugin
Apr 10 19:05:51 dylan-optiplex3010 bluetoothd[525]: Bluetooth management interface 1.22 initialized
sudo dmesg | grep -i bluetooth
[    1.080116] usb 1-1.2: Product: Bluetooth Radio
[   11.593886] Bluetooth: Core ver 2.22
[   11.593906] NET: Registered PF_BLUETOOTH protocol family
[   11.593908] Bluetooth: HCI device and connection manager initialized
[   11.593911] Bluetooth: HCI socket layer initialized
[   11.593913] Bluetooth: L2CAP socket layer initialized
[   11.593917] Bluetooth: SCO socket layer initialized
[   13.816934] Bluetooth: hci0: command 0xfc61 tx timeout
[   13.816942] Bluetooth: hci0: RTL: Failed to generate devcoredump
[   13.816958] Bluetooth: hci0: RTL: RTL: Read reg16 failed (-110)
[   16.188977] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   16.188982] Bluetooth: BNEP filters: protocol multicast
[   16.188986] Bluetooth: BNEP socket layer initialized
[ 1372.111585] Bluetooth: hci0: command 0xfc61 tx timeout
[ 1372.111611] Bluetooth: hci0: RTL: RTL: Read reg16 failed (-110)
[ 1372.111615] Bluetooth: hci0: RTL: Failed to generate devcoredump
It looks to me like a hardware failure at first glance, but the inxi dump reports a Bluetooth controller? Weird stuff happening here. Any help would be greatly appreciated.
Thanks in advance.
Just to be clear, which is it - your computer or headset - that just stopped working? (I’ll assume it was the latter).
It very well might be. These potential issues may have contributed.
This suggests you have no battery. Are you running it from mains power? :point_down:
Having no Swap partition or Swap file (as an alternative) is never a good thing (even if it’s barely used) :point_down:
If the machine attempted to hibernate during your extended absence, that could cause issues when not actually having Swap space to hibernate to.
Typically, many devices are turned off in preparation to hibernate. Perhaps this gives a direction to investigate further.
Good luck.
My computer is the one that just stopped working.
It’s a desktop computer. It’s running from the wall.
I prefer having my swap file on a separate internal hard drive (/dev/sdb),which I have done before, but less than a week ago I reinstalled for separate reasons, and when I select swap to file in the installer, in puts in on the root drive. I just forgot about it. I’ll fix it soon.
I’ve never explicitly made my computer hibernate, but the power button has been blinking, with the display not getting any input and the lights on keyboard and mouse when I leave it on the login screen for a while. Is that hibernation or sleep?
Thank you, for both your assistance and words. I appreciate it greatly.
Ah, so it is.
It’s possibly defaulting to hibernation. Whether its a swap partition or file, your INXI output shows neither is working.
Considering you don’t have swap correctly configured, any attempt to hibernate should fail. And yes, the blinking is typically an indication of a sleep states prior to hibernating.
If you want hibernation, you’ll (technically) need enough space to hold as much as your RAM (for example if you have 32G of RAM, then 32G of Swap should be available to hibernate). Whatever data is held in RAM must have somewhere to go when the machine hibernates (it can’t stay in RAM) and the Swap space is the destination. As you were previously using a separate partition for Swap, you should probably reconfigure it to do the same as before. Of course, if you don’t wish to use hibernation at all, you can likely allocate less Swap.
I suggest to focus on configuring your Swap and then your power saving options. Try a few different settings and see whichever suits.
Cheers.
Swap is now on.
swapon -show
Filename                                Type            Size            Used            Priority
/data/secondary/swapfile                file            16777212        0               -2
Obviously, Bluetooth still isn’t working; I didn’t expect it to after adding swap. However, hibernate now shows up on the superkey menu.
That’s a step in the right direction, at least. I can’t help with blutooth configuration, etc (I use desktops on a LAN and have no need of it), but no doubt someone else will chime in if you post a few logs etc.
Cheers.
@Warp
If you have a Bluetooth-stick, may try to unplug and reconnect it.
If it still dont work, may remove and reinstall anything Bluetooth-related.
You can do that by looking ie at octopi for blue and reinstall anything, what you can see bluetooth-related.
And search at octopi, since a packet search at pamac dont work proper anymore, at least at my system.
I had the same problems a few times, that suddenly my bluetooth connected device like headset or phones did not work proper anymore.
Sometimes it was enough to remove the devices from the list and let them search new at bluetooth-manager, sometimes i had to complete reinstall it.
I assume, its a problem from address assignment since it gets new addresses after updates, but its my guess.
Thanks for your advice. I’ll be on a business trip till Thursday so I’ll get back to you then. Again, thank you.
I’m back. It was working for a few minutes, then stopped working again. I reinstalled the following packages that seemed to be related to bluetooth to no avail:
bluez bluez-libs pipewire-pulse bluez-utils bluez-qt5 fwupd pipewire-audio
Here’s the complete kernel buffer, starting from the first mention of Bluetooth:
[    1.544948] usb 2-1.6: Product: Bluetooth Radio
[    1.544950] usb 2-1.6: Manufacturer: Realtek
[    1.544951] usb 2-1.6: SerialNumber: 00E04C239987
[    1.585375] wmi_bus wmi_bus-PNP0C14:00: WQBC data block query control method not found
[    1.606326] usbcore: registered new interface driver usb-storage
[    1.611870] sr 1:0:0:0: [sr0] scsi3-mmc drive: 125x/125x writer dvd-ram cd/rw xa/form2 cdda tray
[    1.611875] cdrom: Uniform CD-ROM driver Revision: 3.20
[    1.612659] scsi host5: uas
[    1.612733] usbcore: registered new interface driver uas
[    1.613280] scsi 5:0:0:0: Direct-Access     Seagate  Portable         0712 PQ: 0 ANSI: 6
[    1.614909] cryptd: max_cpu_qlen set to 1000
[    1.619907] sd 5:0:0:0: [sdc] 1953525167 512-byte logical blocks: (1.00 TB/932 GiB)
[    1.619911] sd 5:0:0:0: [sdc] 4096-byte physical blocks
[    1.620079] usbcore: registered new interface driver usbhid
[    1.620081] usbhid: USB HID core driver
[    1.620147] sd 5:0:0:0: [sdc] Write Protect is off
[    1.620150] sd 5:0:0:0: [sdc] Mode Sense: 53 00 00 08
[    1.620760] sd 5:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.620899] sd 5:0:0:0: [sdc] Preferred minimum I/O size 4096 bytes
[    1.620902] sd 5:0:0:0: [sdc] Optimal transfer size 33553920 bytes not a multiple of preferred minimum block size (4096 bytes)
[    1.623156]  sdc: sdc1 sdc2
[    1.623235] sd 5:0:0:0: [sdc] Attached SCSI disk
[    1.632097] hid-generic 0003:0D8C:0134.0001: No inputs registered, leaving
[    1.633289] hid-generic 0003:0D8C:0134.0001: hidraw0: USB HID v1.11 Device [C-Media Electronics Inc. TONOR TC-777 Audio Device] on usb-0000:00:1a.0-1.3/input2
[    1.633411] input: Razer Razer DeathAdder Essential as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:1532:0098.0002/input/input3
[    1.633754] hid-generic 0003:1532:0098.0002: input,hidraw1: USB HID v1.11 Mouse [Razer Razer DeathAdder Essential] on usb-0000:00:1a.0-1.4/input0
[    1.633977] input: Razer Razer DeathAdder Essential Keyboard as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:1532:0098.0003/input/input4
[    1.635899] AVX version of gcm_enc/dec engaged.
[    1.635923] AES CTR mode by8 optimization enabled
[    1.690427] input: Razer Razer DeathAdder Essential as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:1532:0098.0003/input/input5
[    1.690594] hid-generic 0003:1532:0098.0003: input,hidraw2: USB HID v1.11 Keyboard [Razer Razer DeathAdder Essential] on usb-0000:00:1a.0-1.4/input1
[    1.690733] input: Razer Razer DeathAdder Essential as /devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.4/1-1.4:1.2/0003:1532:0098.0004/input/input6
[    1.747234] hid-generic 0003:1532:0098.0004: input,hidraw3: USB HID v1.11 Keyboard [Razer Razer DeathAdder Essential] on usb-0000:00:1a.0-1.4/input2
[    1.747410] input: SEMICO USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.0/0003:1A2C:4B81.0005/input/input7
[    1.773506] sr 1:0:0:0: Attached scsi CD-ROM sr0
[    1.803890] hid-generic 0003:1A2C:4B81.0005: input,hidraw4: USB HID v1.10 Keyboard [SEMICO USB Keyboard] on usb-0000:00:1d.0-1.5/input0
[    1.804160] input: SEMICO USB Keyboard Consumer Control as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.1/0003:1A2C:4B81.0006/input/input8
[    1.860371] input: SEMICO USB Keyboard System Control as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.1/0003:1A2C:4B81.0006/input/input9
[    1.860447] input: SEMICO USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.1/0003:1A2C:4B81.0006/input/input11
[    1.860612] hid-generic 0003:1A2C:4B81.0006: input,hiddev96,hidraw5: USB HID v1.10 Keyboard [SEMICO USB Keyboard] on usb-0000:00:1d.0-1.5/input1
[    4.622951] [drm] amdgpu kernel modesetting enabled.
[    4.623098] amdgpu: Virtual CRAT table created for CPU
[    4.623113] amdgpu: Topology: Add CPU node
[    4.623279] [drm] initializing kernel modesetting (POLARIS10 0x1002:0x67DF 0x174B:0xE353 0xCF).
[    4.623290] [drm] register mmio base: 0xF7E00000
[    4.623291] [drm] register mmio size: 262144
[    4.623336] [drm] add ip block number 0 <vi_common>
[    4.623338] [drm] add ip block number 1 <gmc_v8_0>
[    4.623339] [drm] add ip block number 2 <tonga_ih>
[    4.623339] [drm] add ip block number 3 <gfx_v8_0>
[    4.623340] [drm] add ip block number 4 <sdma_v3_0>
[    4.623341] [drm] add ip block number 5 <powerplay>
[    4.623342] [drm] add ip block number 6 <dm>
[    4.623343] [drm] add ip block number 7 <uvd_v6_0>
[    4.623344] [drm] add ip block number 8 <vce_v3_0>
[    4.623516] resource: resource sanity check: requesting [mem 0x00000000000c0000-0x00000000000dffff], which spans more than PCI Bus 0000:00 [mem 0x000d8000-0x000dffff window]
[    4.623520] caller pci_map_rom+0x69/0x1b0 mapping multiple BARs
[    4.623526] amdgpu 0000:01:00.0: Invalid PCI ROM data signature: expecting 0x52494350, got 0xe808aa55
[    4.623543] amdgpu 0000:01:00.0: amdgpu: Fetched VBIOS from ROM BAR
[    4.623545] amdgpu: ATOM BIOS: 113-2E353AU.O4D
[    4.623718] [drm] UVD is enabled in VM mode
[    4.623720] [drm] UVD ENC is enabled in VM mode
[    4.623721] [drm] VCE enabled in VM mode
[    4.683873] amdgpu 0000:01:00.0: vgaarb: deactivate vga console
[    4.683877] amdgpu 0000:01:00.0: amdgpu: Trusted Memory Zone (TMZ) feature not supported
[    4.683879] amdgpu 0000:01:00.0: amdgpu: PCIE atomic ops is not supported
[    4.683900] [drm] vm size is 64 GB, 2 levels, block size is 10-bit, fragment size is 9-bit
[    4.684057] amdgpu 0000:01:00.0: amdgpu: VRAM: 4096M 0x000000F400000000 - 0x000000F4FFFFFFFF (4096M used)
[    4.684060] amdgpu 0000:01:00.0: amdgpu: GART: 256M 0x000000FF00000000 - 0x000000FF0FFFFFFF
[    4.684066] [drm] Detected VRAM RAM=4096M, BAR=256M
[    4.684067] [drm] RAM width 256bits GDDR5
[    4.684215] [drm] amdgpu: 4096M of VRAM memory ready
[    4.684218] [drm] amdgpu: 7983M of GTT memory ready.
[    4.684238] [drm] GART: num cpu pages 65536, num gpu pages 65536
[    4.684659] [drm] PCIE GART of 256M enabled (table at 0x000000F400300000).
[    4.685176] [drm] Chained IB support enabled!
[    4.687717] amdgpu: hwmgr_sw_init smu backed is polaris10_smu
[    4.689166] [drm] Found UVD firmware Version: 1.130 Family ID: 16
[    4.690327] [drm] Found VCE firmware Version: 53.26 Binary ID: 3
[    4.752001] [drm] Display Core v3.2.266 initialized on DCE 11.2
[    4.904756] [drm] UVD and UVD ENC initialized successfully.
[    5.005705] [drm] VCE initialized successfully.
[    5.005742] kfd kfd: amdgpu: skipped device 1002:67df, PCI rejects atomics 730<0
[    5.005753] amdgpu 0000:01:00.0: amdgpu: SE 4, SH per SE 1, CU per SH 9, active_cu_number 32
[    5.008358] amdgpu 0000:01:00.0: amdgpu: Using BACO for runtime pm
[    5.008991] [drm] Initialized amdgpu 3.57.0 20150101 for 0000:01:00.0 on minor 1
[    5.027757] fbcon: amdgpudrmfb (fb0) is primary device
[    5.027763] fbcon: Deferring console take-over
[    5.027768] amdgpu 0000:01:00.0: [drm] fb0: amdgpudrmfb frame buffer device
[    5.195143] device-mapper: uevent: version 1.0.3
[    5.195234] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-devel@redhat.com
[    5.355156] Key type encrypted registered
[    9.616206] raid6: skipped pq benchmark and selected sse2x4
[    9.616209] raid6: using ssse3x2 recovery algorithm
[    9.620770] xor: automatically using best checksumming function   avx
[    9.757290] Btrfs loaded, zoned=yes, fsverity=yes
[    9.786129] BTRFS: device label system devid 1 transid 3700 /dev/mapper/luks-fe6bdc85-0dc2-4c0a-a8d8-5e90f50b416f scanned by mount (212)
[    9.786648] BTRFS info (device dm-0): first mount of filesystem 4b0de9a1-f76b-4599-9ca5-7b90c9d3a620
[    9.786661] BTRFS info (device dm-0): using crc32c (crc32c-intel) checksum algorithm
[    9.786667] BTRFS info (device dm-0): using free-space-tree
[   10.109257] systemd[1]: systemd 255.4-1-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[   10.109265] systemd[1]: Detected architecture x86-64.
[   10.110177] systemd[1]: Hostname set to <dylan-optiplex3010>.
[   10.643724] systemd[1]: bpf-lsm: LSM BPF program attached
[   11.101410] systemd[1]: Queued start job for default target Graphical Interface.
[   11.131473] systemd[1]: Created slice Slice /system/dirmngr.
[   11.131811] systemd[1]: Created slice Slice /system/getty.
[   11.132101] systemd[1]: Created slice Slice /system/gpg-agent.
[   11.132390] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[   11.132676] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[   11.132966] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[   11.133251] systemd[1]: Created slice Slice /system/keyboxd.
[   11.133533] systemd[1]: Created slice Slice /system/modprobe.
[   11.133844] systemd[1]: Created slice Encrypted Volume Units Service Slice.
[   11.134138] systemd[1]: Created slice Slice /system/systemd-fsck.
[   11.134357] systemd[1]: Created slice User and Session Slice.
[   11.134426] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   11.134608] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   11.134632] systemd[1]: Expecting device /dev/disk/by-uuid/0db4202a-0a00-4bac-84fb-39bef6ca327e...
[   11.134640] systemd[1]: Expecting device /dev/disk/by-uuid/7c1fa927-7b20-4c59-878a-9bc1bc64e298...
[   11.134648] systemd[1]: Expecting device /dev/disk/by-uuid/E233-C8B4...
[   11.134656] systemd[1]: Expecting device /dev/disk/by-uuid/fe6bdc85-0dc2-4c0a-a8d8-5e90f50b416f...
[   11.134663] systemd[1]: Expecting device /dev/mapper/luks-0db4202a-0a00-4bac-84fb-39bef6ca327e...
[   11.134667] systemd[1]: Expecting device /dev/mapper/luks-fe6bdc85-0dc2-4c0a-a8d8-5e90f50b416f...
[   11.134685] systemd[1]: Reached target Login Prompts.
[   11.134698] systemd[1]: Reached target Local Integrity Protected Volumes.
[   11.134720] systemd[1]: Reached target Remote File Systems.
[   11.134732] systemd[1]: Reached target Slice Units.
[   11.134754] systemd[1]: Reached target Local Verity Protected Volumes.
[   11.134826] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[   11.135998] systemd[1]: Listening on LVM2 poll daemon socket.
[   11.137144] systemd[1]: Listening on Process Core Dump Socket.
[   11.137274] systemd[1]: Listening on Journal Socket (/dev/log).
[   11.137393] systemd[1]: Listening on Journal Socket.
[   11.137430] systemd[1]: TPM2 PCR Extension (Varlink) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   11.138061] systemd[1]: Listening on udev Control Socket.
[   11.138161] systemd[1]: Listening on udev Kernel Socket.
[   11.138266] systemd[1]: Listening on User Database Manager Socket.
[   11.139527] systemd[1]: Mounting Huge Pages File System...
[   11.140171] systemd[1]: Mounting POSIX Message Queue File System...
[   11.140869] systemd[1]: Mounting Kernel Debug File System...
[   11.143290] systemd[1]: Mounting Kernel Trace File System...
[   11.145587] systemd[1]: Starting Create List of Static Device Nodes...
[   11.148554] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[   11.149477] systemd[1]: Starting Load Kernel Module configfs...
[   11.150899] systemd[1]: Starting Load Kernel Module dm_mod...
[   11.152532] systemd[1]: Starting Load Kernel Module drm...
[   11.155425] systemd[1]: Starting Load Kernel Module fuse...
[   11.156341] systemd[1]: Starting Load Kernel Module loop...
[   11.157899] systemd[1]: Starting Journal Service...
[   11.160453] systemd[1]: Starting Load Kernel Modules...
[   11.160477] systemd[1]: TPM2 PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   11.163901] systemd[1]: Starting Remount Root and Kernel File Systems...
[   11.163947] systemd[1]: TPM2 SRK Setup (Early) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   11.164792] systemd[1]: Starting Coldplug All udev Devices...
[   11.166366] systemd[1]: Starting Virtual Console Setup...
[   11.167990] systemd[1]: Mounted Huge Pages File System.
[   11.168116] systemd[1]: Mounted POSIX Message Queue File System.
[   11.168207] systemd[1]: Mounted Kernel Debug File System.
[   11.168298] systemd[1]: Mounted Kernel Trace File System.
[   11.168987] systemd[1]: Finished Create List of Static Device Nodes.
[   11.169345] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   11.169481] systemd[1]: Finished Load Kernel Module configfs.
[   11.169741] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[   11.169862] systemd[1]: Finished Load Kernel Module dm_mod.
[   11.171125] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   11.171264] systemd[1]: Finished Load Kernel Module drm.
[   11.174410] loop: module loaded
[   11.175759] systemd[1]: Mounting Kernel Configuration File System...
[   11.181347] systemd[1]: Starting Create Static Device Nodes in /dev gracefully...
[   11.182741] fuse: init (API version 7.39)
[   11.183155] systemd[1]: modprobe@loop.service: Deactivated successfully.
[   11.184157] systemd[1]: Finished Load Kernel Module loop.
[   11.184748] systemd[1]: Mounted Kernel Configuration File System.
[   11.184947] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[   11.187535] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   11.187687] systemd[1]: Finished Load Kernel Module fuse.
[   11.188541] systemd[1]: Mounting FUSE Control File System...
[   11.194382] systemd[1]: Mounted FUSE Control File System.
[   11.209213] systemd-journald[267]: Collecting audit messages is disabled.
[   11.229874] i2c_dev: i2c /dev entries driver
[   11.233615] systemd[1]: Finished Load Kernel Modules.
[   11.253808] systemd[1]: Starting Apply Kernel Variables...
[   11.255935] systemd[1]: Starting User Database Manager...
[   11.256028] systemd[1]: Started Journal Service.
[   11.370846] BTRFS info (device dm-0: state M): turning on async discard
[   11.686765] BTRFS info: devid 1 device path /dev/mapper/luks-fe6bdc85-0dc2-4c0a-a8d8-5e90f50b416f changed to /dev/dm-0 scanned by (udev-worker) (342)
[   11.691637] BTRFS info: devid 1 device path /dev/dm-0 changed to /dev/mapper/luks-fe6bdc85-0dc2-4c0a-a8d8-5e90f50b416f scanned by (udev-worker) (342)
[   11.749413] mousedev: PS/2 mouse device common for all mice
[   11.782626] EDAC ie31200: No ECC support
[   11.785763] EDAC ie31200: No ECC support
[   11.839339] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20230628/utaddress-204)
[   11.839347] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[   11.839350] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20230628/utaddress-204)
[   11.839352] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[   11.839353] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20230628/utaddress-204)
[   11.839356] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[   11.839357] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20230628/utaddress-204)
[   11.839359] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[   11.839359] lpc_ich: Resource conflict(s) found affecting gpio_ich
[   11.919803] systemd-journald[267]: Received client request to flush runtime journal.
[   11.921358] systemd-journald[267]: File /var/log/journal/63ce1e011e0c43e0b61d02d19f6a44a5/system.journal corrupted or uncleanly shut down, renaming and replacing.
[   11.945795] Bluetooth: Core ver 2.22
[   11.945816] NET: Registered PF_BLUETOOTH protocol family
[   11.945817] Bluetooth: HCI device and connection manager initialized
[   11.945821] Bluetooth: HCI socket layer initialized
[   11.945823] Bluetooth: L2CAP socket layer initialized
[   11.945826] Bluetooth: SCO socket layer initialized
[   11.950991] input: PC Speaker as /devices/platform/pcspkr/input/input12
[   11.962269] r8169 0000:03:00.0: can't disable ASPM; OS doesn't have ASPM control
[   11.969879] i801_smbus 0000:00:1f.3: SMBus using PCI interrupt
[   11.971174] i2c i2c-7: 2/2 memory slots populated (from DMI)
[   11.971746] i2c i2c-7: Successfully instantiated SPD at 0x50
[   11.973329] r8169 0000:03:00.0 eth0: RTL8168evl/8111evl, a4:1f:72:67:fe:8b, XID 2c9, IRQ 29
[   11.973334] r8169 0000:03:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko]
[   11.981492] mc: Linux media interface: v0.10
[   12.018770] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.4)
[   12.051102] RAPL PMU: API unit is 2^-32 Joules, 2 fixed counters, 163840 ms ovfl timer
[   12.051106] RAPL PMU: hw unit of domain pp0-core 2^-16 Joules
[   12.051107] RAPL PMU: hw unit of domain package 2^-16 Joules
[   12.067663] usbcore: registered new interface driver btusb
[   12.071210] Bluetooth: hci0: RTL: examining hci_ver=0a hci_rev=000b lmp_ver=0a lmp_subver=8761
[   12.072212] Bluetooth: hci0: RTL: rom_version status=0 version=1
[   12.072215] Bluetooth: hci0: RTL: loading rtl_bt/rtl8761bu_fw.bin
[   12.076705] Bluetooth: hci0: RTL: loading rtl_bt/rtl8761bu_config.bin
[   12.076766] Bluetooth: hci0: RTL: cfg_sz 6, total sz 30210
[   12.083166] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[   12.083286] snd_hda_intel 0000:01:00.1: Force to non-snoop mode
[   12.107287] snd_hda_intel 0000:01:00.1: bound 0000:01:00.0 (ops amdgpu_dm_audio_component_bind_ops [amdgpu])
[   12.108241] input: Dell WMI hotkeys as /devices/platform/PNP0C14:00/wmi_bus/wmi_bus-PNP0C14:00/9DBB5994-A997-11DA-B012-B622A1EF5492/input/input19
[   12.199759] snd_hda_codec_conexant hdaudioC0D2: CX20641: BIOS auto-probing.
[   12.199814] iTCO_vendor_support: vendor-support=0
[   12.200048] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input13
[   12.200673] input: HDA ATI HDMI HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input14
[   12.200801] snd_hda_codec_conexant hdaudioC0D2: autoconfig for CX20641: line_outs=1 (0x1c/0x0/0x0/0x0/0x0) type:line
[   12.200806] snd_hda_codec_conexant hdaudioC0D2:    speaker_outs=1 (0x1f/0x0/0x0/0x0/0x0)
[   12.200808] snd_hda_codec_conexant hdaudioC0D2:    hp_outs=1 (0x19/0x0/0x0/0x0/0x0)
[   12.200810] snd_hda_codec_conexant hdaudioC0D2:    mono: mono_out=0x0
[   12.200811] snd_hda_codec_conexant hdaudioC0D2:    inputs:
[   12.200812] snd_hda_codec_conexant hdaudioC0D2:      Rear Mic=0x1b
[   12.200814] snd_hda_codec_conexant hdaudioC0D2:      Front Mic=0x1a
[   12.200815] snd_hda_codec_conexant hdaudioC0D2:      Line=0x1d
[   12.206999] input: HDA ATI HDMI HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input15
[   12.207067] input: HDA ATI HDMI HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input16
[   12.207121] input: HDA ATI HDMI HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input17
[   12.207167] input: HDA ATI HDMI HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1/input18
[   12.210707] i8042: PNP: No PS/2 controller found.
[   12.210709] i8042: Probing ports directly.
[   12.215008] serio: i8042 KBD port at 0x60,0x64 irq 1
[   12.215022] serio: i8042 AUX port at 0x60,0x64 irq 12
[   12.219759] iTCO_wdt iTCO_wdt.1.auto: Found a Cougar Point TCO device (Version=2, TCOBASE=0x0460)
[   12.219772] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input20
[   12.221533] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input21
[   12.222340] iTCO_wdt iTCO_wdt.1.auto: initialized. heartbeat=30 sec (nowayout=0)
[   12.224592] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input22
[   12.226291] usbcore: registered new interface driver snd-usb-audio
[   12.232784] r8169 0000:03:00.0 enp3s0: renamed from eth0
[   12.236206] Bluetooth: hci0: RTL: fw version 0xdfc6d922
[   12.237315] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input23
[   12.238420] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input24
[   12.248501] at24 7-0050: supply vcc not found, using dummy regulator
[   12.266587] at24 7-0050: 256 byte spd EEPROM, read-only
[   12.336858] intel_rapl_common: Found RAPL domain package
[   12.336863] intel_rapl_common: Found RAPL domain core
[   12.336869] intel_rapl_common: package-0:package:long_term locked by BIOS
[   12.336871] intel_rapl_common: package-0:package:short_term locked by BIOS
[   12.466325] md126: detected capacity change from 0 to 1952448512
[   12.469889]  md126: p1
[   12.469897] md126: p1 size 1953519616 extends beyond EOD, truncated
[   12.791067] EXT4-fs (md126p1): recovery complete
[   12.809694] EXT4-fs (md126p1): mounted filesystem 7c1fa927-7b20-4c59-878a-9bc1bc64e298 r/w with ordered data mode. Quota mode: none.
[   12.895073] Adding 16777212k swap on /data/secondary/swapfile.  Priority:-2 extents:176 across:947560444k
[   16.155425] BTRFS: device label home devid 1 transid 6503 /dev/mapper/luks-0db4202a-0a00-4bac-84fb-39bef6ca327e scanned by mount (496)
[   16.156178] BTRFS info (device dm-1): first mount of filesystem 9a8b50aa-3186-458f-a6c9-b1400b9d9a37
[   16.156195] BTRFS info (device dm-1): using crc32c (crc32c-intel) checksum algorithm
[   16.156201] BTRFS info (device dm-1): using free-space-tree
[   16.162390] BTRFS info (device dm-1): start tree-log replay
[   16.286337] BTRFS info (device dm-1): checking UUID tree
[   16.889062] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   16.889065] Bluetooth: BNEP filters: protocol multicast
[   16.889069] Bluetooth: BNEP socket layer initialized
[   16.891413] Bluetooth: MGMT ver 1.22
[   16.903290] NET: Registered PF_ALG protocol family
[   17.065072] RTL8211E Gigabit Ethernet r8169-0-300:00: attached PHY driver (mii_bus:phy_addr=r8169-0-300:00, irq=MAC)
[   17.079355] NET: Registered PF_QIPCRTR protocol family
[   17.299069] r8169 0000:03:00.0 enp3s0: Link is Down
[   20.527904] r8169 0000:03:00.0 enp3s0: Link is Up - 1Gbps/Full - flow control off
[  109.205225] systemd-journald[267]: /var/log/journal/63ce1e011e0c43e0b61d02d19f6a44a5/user-1000.journal: Journal file uses a different sequence number ID, rotating.
[  111.749308] Bluetooth: RFCOMM TTY layer initialized
[  111.749317] Bluetooth: RFCOMM socket layer initialized
[  111.749321] Bluetooth: RFCOMM ver 1.11
[  113.870269] Bluetooth: hci0: command 0x0c24 tx timeout
[  113.870286] Bluetooth: hci0: Opcode 0x0c24 failed: -110
[  116.003582] Bluetooth: hci0: command 0x0c24 tx timeout
[  116.003582] Bluetooth: hci0: Opcode 0x0c24 failed: -110
[  228.539830] SGI XFS with ACLs, security attributes, realtime, scrub, repair, quota, no debug enabled
[  228.565139] JFS: nTxBlock = 8192, nTxLock = 65536
[  228.929280] sr 1:0:0:0: [sr0] tag#15 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=0s
[  228.929287] sr 1:0:0:0: [sr0] tag#15 Sense Key : Illegal Request [current]
[  228.929289] sr 1:0:0:0: [sr0] tag#15 Add. Sense: Logical block address out of range
[  228.929292] sr 1:0:0:0: [sr0] tag#15 CDB: Read(10) 28 00 00 00 00 00 00 00 01 00
[  228.929293] I/O error, dev sr0, sector 0 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
[  361.763544] Bluetooth: hci0: command tx timeout
[  374.290301] input: SteelSeries Arctis 9X Headset (AVRCP) as /devices/virtual/input/input28
[ 1768.483124] Bluetooth: hci0: command tx timeout
[ 1779.576450] Bluetooth: hci0: command 0x0c03 tx timeout
[ 1779.576462] Bluetooth: hci0: Resetting usb device.
[ 1779.576464] Bluetooth: hci0: HCI reset during shutdown failed
[ 1779.581465] Bluetooth: hci0: urb 0000000043485621 failed to resubmit (2)
[ 1779.686477] usb 2-1.6: reset full-speed USB device number 5 using ehci-pci
[ 1781.923116] Bluetooth: hci1: command 0xfc61 tx timeout
[ 1781.923126] Bluetooth: hci1: RTL: Failed to generate devcoredump
[ 1781.923132] Bluetooth: hci1: RTL: RTL: Read reg16 failed (-110)
[ 2014.516207] usbcore: deregistering interface driver btusb
[ 2026.936859] usbcore: registered new interface driver btusb
[ 2028.963064] Bluetooth: hci1: command 0xfc61 tx timeout
[ 2028.963072] Bluetooth: hci1: RTL: Failed to generate devcoredump
[ 2028.963103] Bluetooth: hci1: RTL: RTL: Read reg16 failed (-110)
[ 2419.323756] BTRFS info: devid 1 device path /dev/mapper/luks-0db4202a-0a00-4bac-84fb-39bef6ca327e changed to /dev/dm-1 scanned by (udev-worker) (10285)
[ 2419.327772] BTRFS info: devid 1 device path /dev/mapper/luks-fe6bdc85-0dc2-4c0a-a8d8-5e90f50b416f changed to /dev/dm-0 scanned by (udev-worker) (10308)
[ 2419.334428] BTRFS info: devid 1 device path /dev/dm-0 changed to /dev/mapper/luks-fe6bdc85-0dc2-4c0a-a8d8-5e90f50b416f scanned by (udev-worker) (10308)
[ 2419.340850] BTRFS info: devid 1 device path /dev/dm-1 changed to /dev/mapper/luks-0db4202a-0a00-4bac-84fb-39bef6ca327e scanned by (udev-worker) (10285)
[ 2509.622531] usb 2-1.5: USB disconnect, device number 4
[ 2510.276267] usb 2-1.5: new low-speed USB device number 6 using ehci-pci
[ 2510.379156] usb 2-1.5: New USB device found, idVendor=1a2c, idProduct=4b81, bcdDevice= 1.10
[ 2510.379167] usb 2-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2510.379170] usb 2-1.5: Product: USB Keyboard
[ 2510.379173] usb 2-1.5: Manufacturer: SEMICO
[ 2510.383169] input: SEMICO USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.0/0003:1A2C:4B81.0007/input/input29
[ 2510.439816] hid-generic 0003:1A2C:4B81.0007: input,hidraw4: USB HID v1.10 Keyboard [SEMICO USB Keyboard] on usb-0000:00:1d.0-1.5/input0
[ 2510.446332] input: SEMICO USB Keyboard Consumer Control as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.1/0003:1A2C:4B81.0008/input/input30
[ 2510.503051] input: SEMICO USB Keyboard System Control as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.1/0003:1A2C:4B81.0008/input/input31
[ 2510.503104] input: SEMICO USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.1/0003:1A2C:4B81.0008/input/input33
[ 2510.503187] hid-generic 0003:1A2C:4B81.0008: input,hiddev96,hidraw5: USB HID v1.10 Keyboard [SEMICO USB Keyboard] on usb-0000:00:1d.0-1.5/input1
[ 2510.646481] usb 2-1.5: USB disconnect, device number 6
[ 2511.272915] usb 2-1.5: new low-speed USB device number 7 using ehci-pci
[ 2511.385619] usb 2-1.5: New USB device found, idVendor=1a2c, idProduct=4b81, bcdDevice= 1.10
[ 2511.385626] usb 2-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2511.385628] usb 2-1.5: Product: USB Keyboard
[ 2511.385629] usb 2-1.5: Manufacturer: SEMICO
[ 2511.389095] input: SEMICO USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.0/0003:1A2C:4B81.0009/input/input34
[ 2511.443373] hid-generic 0003:1A2C:4B81.0009: input,hidraw4: USB HID v1.10 Keyboard [SEMICO USB Keyboard] on usb-0000:00:1d.0-1.5/input0
[ 2511.449875] input: SEMICO USB Keyboard Consumer Control as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.1/0003:1A2C:4B81.000A/input/input35
[ 2511.506507] input: SEMICO USB Keyboard System Control as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.1/0003:1A2C:4B81.000A/input/input36
[ 2511.506712] input: SEMICO USB Keyboard as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.5/2-1.5:1.1/0003:1A2C:4B81.000A/input/input38
[ 2511.507190] hid-generic 0003:1A2C:4B81.000A: input,hiddev96,hidraw5: USB HID v1.10 Keyboard [SEMICO USB Keyboard] on usb-0000:00:1d.0-1.5/input1
[ 2511.507485] usb 2-1.6: USB disconnect, device number 5
[ 2522.876277] usb 1-1.2: new full-speed USB device number 5 using ehci-pci
[ 2522.978098] usb 1-1.2: New USB device found, idVendor=0bda, idProduct=8771, bcdDevice= 2.00
[ 2522.978108] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2522.978111] usb 1-1.2: Product: Bluetooth Radio
[ 2522.978113] usb 1-1.2: Manufacturer: Realtek
[ 2522.978115] usb 1-1.2: SerialNumber: 00E04C239987
[ 2523.502986] usb 2-1.5: reset low-speed USB device number 7 using ehci-pci
[ 2525.176287] Bluetooth: hci0: command 0xfc61 tx timeout
[ 2525.176314] Bluetooth: hci0: RTL: RTL: Read reg16 failed (-110)
[ 2525.176335] Bluetooth: hci0: RTL: Failed to generate devcoredump
[ 2526.506282] usb 2-1.5: reset low-speed USB device number 7 using ehci-pci
And here’s the kernel buffer with just mentions of Bluetooth:
I unplugged the Bluetooth device into other ports after it stopped working but nothing changed.
When the Bluetooth started working again, the previously connected to devices were back. It worked flawlessly up until I stopped getting audio in my headphones. I tried to restart the Bluetooth daemon but after doing so it was back to the previously stated situation.
So it worked straight after starting the pc then stopped working?
When your headset is connected, you can rightclick at the at the speaker symbol, then look at the bottom, where it says ‘mixer’.
A new window will pop up, and right side is configuration, where your Headset should be listed.
There is a pull down menu, where you can choose a profile. May try both of them, also right hand the codec, if it will connect proper.
For the installed packages, i additional got manjaro-bluetooth pulseaudio-bluetooth,
but looks like you dont use pulseaudio, but pipewire. So maybe you try to add manjaro-bluetooth.
Once i used only pipewire too, but bluetooth did not really work with it, so i installed pulseaudio,
even it seems its not really supported anymore, but at least, my bluetooth worked with it.
After hibernating for an hour or two, it worked again. All the profiles I tried worked. I installed manjaro-bluetooth after it started working again. I do use pipewire, so I didn’t bother installing pulseaudio-bluetooth. However, after about 15 minutes of use, it stopped working again. I have yet to reboot. Here are the logs:
Kernel buffer, again:
sudo dmesg | grep -i Bluetooth
[    1.101942] usb 1-1.2: Product: Bluetooth Radio
[   11.999460] Bluetooth: Core ver 2.22
[   11.999477] NET: Registered PF_BLUETOOTH protocol family
[   11.999479] Bluetooth: HCI device and connection manager initialized
[   11.999482] Bluetooth: HCI socket layer initialized
[   11.999485] Bluetooth: L2CAP socket layer initialized
[   11.999488] Bluetooth: SCO socket layer initialized
[   12.210545] Bluetooth: hci0: RTL: Failed to generate devcoredump
[   13.376533] Bluetooth: hci0: RTL: Failed to generate devcoredump
[   14.243619] Bluetooth: hci0: command 0xfc61 tx timeout
[   14.243637] Bluetooth: hci0: RTL: Failed to generate devcoredump
[   14.243649] Bluetooth: hci0: RTL: RTL: Read reg16 failed (-110)
[   16.688855] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   16.688859] Bluetooth: BNEP filters: protocol multicast
[   16.689006] Bluetooth: BNEP socket layer initialized
[  215.682094] usb 2-1.6: Product: Bluetooth Radio
[  217.766917] Bluetooth: hci0: command 0xfc61 tx timeout
[  217.766928] Bluetooth: hci0: RTL: Failed to generate devcoredump
[  217.766930] Bluetooth: hci0: RTL: RTL: Read reg16 failed (-110)
[ 2246.670233] Bluetooth: hci0: RTL: examining hci_ver=0a hci_rev=000b lmp_ver=0a lmp_subver=8761
[ 2246.671235] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ 2246.671238] Bluetooth: hci0: RTL: loading rtl_bt/rtl8761bu_fw.bin
[ 2246.673140] Bluetooth: hci0: RTL: loading rtl_bt/rtl8761bu_config.bin
[ 2246.673195] Bluetooth: hci0: RTL: cfg_sz 6, total sz 30210
[ 2246.830376] Bluetooth: hci0: RTL: fw version 0xdfc6d922
[ 2246.899562] Bluetooth: MGMT ver 1.22
[ 2246.941736] Bluetooth: RFCOMM TTY layer initialized
[ 2246.941745] Bluetooth: RFCOMM socket layer initialized
[ 2246.941749] Bluetooth: RFCOMM ver 1.11
[ 2474.404862] Bluetooth: hci0: command tx timeout
[ 2647.974939] Bluetooth: hci0: SCO packet for unknown connection handle 3
[ 2653.574909] Bluetooth: hci0: SCO packet for unknown connection handle 4
[ 2804.438236] Bluetooth: hci0: SCO packet for unknown connection handle 6
[ 3312.011555] Bluetooth: hci0: link tx timeout
[ 3312.011566] Bluetooth: hci0: killing stalled connection 28:9a:4b:86:40:8f
[ 3380.858063] Bluetooth: hci0: command tx timeout
[ 3422.031420] Bluetooth: hci0: command 0x0408 tx timeout
[ 3426.084726] Bluetooth: hci0: command 0x0408 tx timeout
[ 3525.071373] Bluetooth: hci0: command tx timeout
[ 3525.071385] Bluetooth: hci0: Resetting usb device.
[ 3525.076897] Bluetooth: hci0: urb 00000000b9d18bb2 failed to resubmit (2)
[ 3527.418054] Bluetooth: hci1: command 0xfc61 tx timeout
[ 3527.418069] Bluetooth: hci1: RTL: Failed to generate devcoredump
[ 3527.418079] Bluetooth: hci1: RTL: RTL: Read reg16 failed (-110)
Bluetooth status log:
Apr 18 18:25:45 dylan-optiplex3010 bluetoothd[540]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSource/faststream_duplex
Apr 18 18:25:45 dylan-optiplex3010 bluetoothd[540]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSink/opus_05
Apr 18 18:25:45 dylan-optiplex3010 bluetoothd[540]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSource/opus_05
Apr 18 18:25:45 dylan-optiplex3010 bluetoothd[540]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Apr 18 18:25:45 dylan-optiplex3010 bluetoothd[540]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSource/opus_05_duplex
Apr 18 18:30:00 dylan-optiplex3010 bluetoothd[540]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Software caused connection abort
Apr 18 18:31:26 dylan-optiplex3010 bluetoothd[540]: /org/bluez/hci0/dev_28_9A_4B_86_40_8F/sep1/fd0: fd(30) ready
Apr 18 18:33:08 dylan-optiplex3010 bluetoothd[540]: /org/bluez/hci0/dev_28_9A_4B_86_40_8F/sep1/fd1: fd(30) ready
Apr 18 18:35:27 dylan-optiplex3010 bluetoothd[540]: /org/bluez/hci0/dev_28_9A_4B_86_40_8F/sep1/fd2: fd(30) ready
Apr 18 18:43:20 dylan-optiplex3010 bluetoothd[540]: profiles/audio/avdtp.c:cancel_request() Suspend: Connection timed out (110)
Journal logs:
journalctl --boot=0 --priority=3 --catalog --no-pager
Apr 18 15:03:59 dylan-optiplex3010 kernel: hid-generic 0003:0D8C:0134.0001: No inputs registered, leaving
Apr 18 15:04:00 dylan-optiplex3010 kernel: Bluetooth: hci0: RTL: Failed to generate devcoredump
Apr 18 15:04:01 dylan-optiplex3010 kernel: Bluetooth: hci0: RTL: Failed to generate devcoredump
Apr 18 15:04:02 dylan-optiplex3010 kernel: Bluetooth: hci0: command 0xfc61 tx timeout
Apr 18 15:04:02 dylan-optiplex3010 kernel: Bluetooth: hci0: RTL: Failed to generate devcoredump
Apr 18 15:04:02 dylan-optiplex3010 kernel: Bluetooth: hci0: RTL: RTL: Read reg16 failed (-110)
Apr 18 15:07:25 dylan-optiplex3010 kernel: Bluetooth: hci0: command 0xfc61 tx timeout
Apr 18 15:07:25 dylan-optiplex3010 kernel: Bluetooth: hci0: RTL: Failed to generate devcoredump
Apr 18 15:07:25 dylan-optiplex3010 kernel: Bluetooth: hci0: RTL: RTL: Read reg16 failed (-110)
Apr 18 18:25:44 dylan-optiplex3010 kernel: amdgpu 0000:01:00.0: [drm:amdgpu_ring_test_helper [amdgpu]] *ERROR* ring comp_1.3.0 test failed (-110)
Apr 18 18:29:32 dylan-optiplex3010 kernel: Bluetooth: hci0: command tx timeout
Apr 18 18:32:31 dylan-optiplex3010 kernel: Bluetooth: hci0: SCO packet for unknown connection handle 3
Apr 18 18:32:57 dylan-optiplex3010 kernel: Bluetooth: hci0: SCO packet for unknown connection handle 4
Apr 18 18:34:09 dylan-optiplex3010 sudo[4081]: pam_unix(sudo:auth): conversation failed
Apr 18 18:34:09 dylan-optiplex3010 sudo[4081]: pam_unix(sudo:auth): auth could not identify password for [dylanm]
Apr 18 18:35:16 dylan-optiplex3010 kernel: Bluetooth: hci0: SCO packet for unknown connection handle 6
Apr 18 18:43:30 dylan-optiplex3010 bluetoothd[540]: profiles/audio/avdtp.c:cancel_request() Suspend: Connection timed out (110)
Apr 18 18:43:30 dylan-optiplex3010 bluetoothd[540]: src/profile.c:ext_io_disconnected() Unable to get io data for Hands-Free Voice gateway: getpeername: Transport endpoint is not connected (107)
Apr 18 18:43:30 dylan-optiplex3010 kernel: Bluetooth: hci0: link tx timeout
Apr 18 18:43:30 dylan-optiplex3010 kernel: Bluetooth: hci0: killing stalled connection 28:9a:4b:86:40:8f
Apr 18 18:44:39 dylan-optiplex3010 kernel: Bluetooth: hci0: command tx timeout
Apr 18 18:45:18 dylan-optiplex3010 bluetoothd[540]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Connection timed out
Apr 18 18:45:20 dylan-optiplex3010 bluetoothd[540]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to 28:9A:4B:86:40:8F: Connection reset by peer (104)
Apr 18 18:45:20 dylan-optiplex3010 kernel: Bluetooth: hci0: command 0x0408 tx timeout
Apr 18 18:45:24 dylan-optiplex3010 kernel: Bluetooth: hci0: command 0x0408 tx timeout
Apr 18 18:46:02 dylan-optiplex3010 bluetoothd[540]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to 28:9A:4B:86:40:8F: Connection refused (111)
Apr 18 18:47:03 dylan-optiplex3010 kernel: Bluetooth: hci0: command tx timeout
Apr 18 18:47:03 dylan-optiplex3010 kernel: Bluetooth: hci0: Resetting usb device.
Apr 18 18:47:03 dylan-optiplex3010 bluetoothd[540]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Software caused connection abort
Apr 18 18:47:03 dylan-optiplex3010 kernel: Bluetooth: hci0: urb 00000000b9d18bb2 failed to resubmit (2)
Apr 18 18:47:05 dylan-optiplex3010 kernel: Bluetooth: hci1: command 0xfc61 tx timeout
Apr 18 18:47:05 dylan-optiplex3010 kernel: Bluetooth: hci1: RTL: Failed to generate devcoredump
Apr 18 18:47:05 dylan-optiplex3010 kernel: Bluetooth: hci1: RTL: RTL: Read reg16 failed (-110)
Ok. Lets see if you have any pulseaudo packages left, what are in conflict with pipewire.
Look if you have anything installed from what he mentions and install the packages.
There is a topic already about the same symptoms like yours.
Else, what i have found on the net, its maybe a linux-firmware related problem.
Edit: Another thing what i observed today is interference with other devices.
I managed it, to disconnect my headphones today with an electrical toothbrush.
Mobiles and Wlan work on the same frequency ranges from about 2,4Ghz.
I found an article where it says, to avoide channel 14.
But i could figure, that other devices can interfere with the headphones or receiver too.
Or an dying battery can cause disconnecting too.
It was a hardware problem, I just ended up getting a new Bluetooth adapter and now everything works fine.
