When Manjaro wakes from the sleep mode or bluetooth just turned off an on, every BT device which was connected before reconnects automatically. Except BT speakers (paired and trusted), which require manual connection each time.
What may be the reason and how to repair?
Device-1: Realtek Bluetooth 4.2 Adapter driver: btusb type: USB
Report: btmgmt ID: hci0 state: up bt-v: 4.2
# lsusb -tv
|__ Port 010: Dev 005, If 0, Class=Wireless, Driver=btusb, 12M
ID 0bda:b00b Realtek Semiconductor Corp. Realtek Bluetooth 4.2 Adapter
|__ Port 010: Dev 005, If 1, Class=Wireless, Driver=btusb, 12M
# usb_modeswitch -R -v 0bda -p b00b
Look for default devices ...
Found devices in default mode (1)
Access device 005 on bus 001
Get the current device configuration ...
Current configuration number is 1
Use interface number 0
with class 224
Warning: no switching method given. See documentation
Reset USB device .
Device was reset
-> Run lsusb to note any changes. Bye!
After latest update I have the same problem with mouse. After sleep or reboot, need to manually forgot old connection and create new with device. Tried to add device as trusted with bluetoothctl. Doesn’t work
