My bluetooth speaker is connected, paired and works as intended. That is until I disconnect it, suspend or shutdown. When I log back or start it up, it won’t automatically reconnect. I try to reconnect and nothing happens. I’ve tried unpairing the device and pairing it again. It pairs but I can’t select the bluetooth speaker as an audio device. The only thing I can consistently do to make it work again is unpair the device and restart the service then pair it again. It works afterwards. But I have to do it every time disconnect the speaker, suspend or shutdown the system.
Has anyone experienced and fixed this?
#################### lsusb -vt ########################
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 10000M
ID 1d6b:0003 Linux Foundation 3.0 root hub
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/2p, 5000M
ID 05e3:0620 Genesys Logic, Inc.
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 480M
ID 1d6b:0002 Linux Foundation 2.0 root hub
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/2p, 480M
ID 05e3:0610 Genesys Logic, Inc. Hub
|__ Port 1: Dev 4, If 0, Class=Hub, Driver=hub/4p, 480M
ID 1a40:0101 Terminus Technology Inc. Hub
|__ Port 3: Dev 7, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
ID 1a2c:2124 China Resource Semico Co., Ltd Keyboard
|__ Port 3: Dev 7, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 2: Dev 6, If 0, Class=Human Interface Device, Driver=usbhid, 12M
ID 17ef:60e4 Lenovo
|__ Port 2: Dev 6, If 1, Class=Human Interface Device, Driver=usbhid, 12M
ID 17ef:60e4 Lenovo
|__ Port 2: Dev 6, If 2, Class=Human Interface Device, Driver=usbhid, 12M
ID 17ef:60e4 Lenovo
|__ Port 3: Dev 3, If 0, Class=Wireless, Driver=btusb, 12M
ID 8087:0029 Intel Corp. AX200 Bluetooth
|__ Port 3: Dev 3, If 1, Class=Wireless, Driver=btusb, 12M
|__ Port 4: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 12M
ID 048d:c100 Integrated Technology Express, Inc.
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/2p, 10000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 480M
|__ Port 3: Dev 2, If 0, Class=Video, Driver=uvcvideo, 480M
ID 04f2:b6c2 Chicony Electronics Co., Ltd
|__ Port 3: Dev 2, If 1, Class=Video, Driver=uvcvideo, 480M
#################### inxi -Fxzc0 ########################
System: Kernel: 5.8.3-2-MANJARO x86_64 bits: 64 compiler: N/A Desktop: GNOME 3.36.5
Distro: Manjaro Linux
Machine: Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05 serial: <filter>
Mobo: LENOVO model: LNVNB161216 v: SDK0J40688 WIN serial: <filter>
UEFI [Legacy]: LENOVO v: EUCN19WW date: 05/12/2020
Battery: ID-1: BAT0 charge: 50.2 Wh condition: 62.0/60.0 Wh (103%) model: Celxpert L19C4PC0
status: Discharging
CPU: Topology: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen rev: 1 L2 cache: 4096 KiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 92662
Speed: 3940 MHz min/max: 1400/2900 MHz Core speeds (MHz): 1: 3936 2: 3939 3: 1754
4: 1752 5: 3939 6: 3942 7: 3939 8: 3942 9: 1752 10: 2096 11: 3936 12: 3943 13: 1752
14: 1752 15: 1753 16: 1752
Graphics: Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo driver: nvidia
v: 450.66 bus ID: 01:00.0
Device-2: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel bus ID: 05:00.0
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo bus ID: 1-3:2
Display: x11 server: X.org 1.20.8 driver: amdgpu,nvidia resolution: <xdpyinfo missing>
OpenGL: renderer: AMD RENOIR (DRM 3.38.0 5.8.3-2-MANJARO LLVM 10.0.1)
v: 4.6 Mesa 20.1.6 direct render: Yes
Audio: Device-1: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel bus ID: 01:00.1
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Lenovo
driver: snd_rn_pci_acp3x v: kernel bus ID: 05:00.5
Device-3: AMD Family 17h HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus ID: 05:00.6
Sound Server: ALSA v: k5.8.3-2-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo
driver: r8169 v: kernel port: 2000 bus ID: 03:00.0
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: 2000 bus ID: 04:00.0
IF: wlp4s0 state: up mac: <filter>
Drives: Local Storage: total: 476.94 GiB used: 92.72 GiB (19.4%)
ID-1: /dev/nvme0n1 vendor: Samsung model: MZVLB512HBJQ-000L2 size: 476.94 GiB
Partition: ID-1: / size: 459.79 GiB used: 92.68 GiB (20.2%) fs: ext4 dev: /dev/nvme0n1p1
Swap: ID-1: swap-1 type: partition size: 8.80 GiB used: 31.8 MiB (0.4%) dev: /dev/nvme0n1p2
Sensors: System Temperatures: cpu: 54.2 C mobo: N/A gpu: amdgpu temp: 44 C
Info: Processes: 406 Uptime: 31m Memory: 7.22 GiB used: 4.16 GiB (57.6%) Init: systemd
Compilers: gcc: 10.2.0 Packages: 1270 Client: shell wrapper v: 5.0.18-release
inxi: 3.1.05
