My Bluetooth just randomly stopped working, and I haven’t updated any packages.
I have tried rebooting and sudo systemctl restart bluetooth.service, but nothing is resolving my issue.
systemctl status bluetooth
○ bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: inactive (dead)
Docs: man:bluetoothd(8)
Oct 18 21:07:55 francois-hplaptop systemd[1]: Bluetooth service was skipped because of a failed condition check (ConditionPathIsDirectory=/sys/class/bluetooth).
rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
inxi --full --verbosity=7 --filter --no-host
Kernel: 5.15.74-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_wayland vt: 2
Type: Laptop System: HP product: HP Laptop 15s-eq2xxx v: N/A
Mobo: HP model: 887A v: 59.11 serial: <superuser required> UEFI: AMI
v: F.18 date: 11/26/2021
ID-1: BAT0 charge: 25.4 Wh (62.4%) condition: 40.7/40.7 Wh (100.0%)
volts: 11.6 min: 11.3 model: HP Primary type: Li-ion serial: <filter>
status: discharging
RAM: total: 14.96 GiB used: 3.43 GiB (22.9%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: 6-core model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64
type: MT MCP smt: enabled arch: Zen 2 rev: 1 cache: L1: 384 KiB L2: 3 MiB
L3: 8 MiB
Speed (MHz): avg: 1396 high: 1397 min/max: 1400/4056 boost: disabled
cores: 1: 1397 2: 1397 3: 1397 4: 1397 5: 1392 6: 1397 7: 1397 8: 1397
9: 1397 10: 1397 11: 1397 12: 1397 bogomips: 50329
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs
ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rapl rdpid
rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock
syscall tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xsaves
Device-1: AMD Lucienne vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN-5.1 pcie: speed: 8 GT/s lanes: 16 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c class-ID: 0300
temp: 37.0 C
Device-2: Chicony HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 04f2:b6f1 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0
Monitor-1: eDP-1 res: 1476x830 size: N/A modes: N/A
OpenGL: renderer: AMD RENOIR (LLVM 14.0.6 DRM 3.42 5.15.74-3-MANJARO)
v: 4.6 Mesa 22.1.7 direct render: Yes
Device-1: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel pcie: speed: 8 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: snd_rn_pci_acp3x v: kernel pcie: speed: 8 GT/s lanes: 16
bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound API: ALSA v: k5.15.74-3-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.58 running: yes
Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A pcie: speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 01:00.0 chip-ID: 10ec:c821 class-ID: 0280
Device-1: luks-9a915a82-f1ac-4fda-a713-befca1c3f997 type: LUKS dm: dm-0
Components: p-1: nvme0n1p2
Local Storage: total: 931.51 GiB used: 213.14 GiB (22.9%)
ID-1: /dev/nvme0n1 vendor: Samsung model: SSD 970 EVO Plus 1TB
size: 931.51 GiB speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 2B2QEXM7 temp: 39.9 C scheme: GPT
ID-1: / size: 931.21 GiB used: 213.14 GiB (22.9%) fs: btrfs dev: /dev/dm-0
mapped: luks-9a915a82-f1ac-4fda-a713-befca1c3f997 label: N/A
uuid: 4ee418e8-ca35-4a5f-9a96-1eb3cf16f3b0
ID-2: /boot/efi size: 299.4 MiB used: 752 KiB (0.2%) fs: vfat
dev: /dev/nvme0n1p1 label: NO_LABEL uuid: 90B7-5322
ID-3: /home size: 931.21 GiB used: 213.14 GiB (22.9%) fs: btrfs
dev: /dev/dm-0 mapped: luks-9a915a82-f1ac-4fda-a713-befca1c3f997 label: N/A
ID-4: /var/cache size: 931.21 GiB used: 213.14 GiB (22.9%) fs: btrfs
ID-5: /var/log size: 931.21 GiB used: 213.14 GiB (22.9%) fs: btrfs
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 1-3:2 info: Chicony HP TrueVision HD Camera type: Video
Hub-2: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 38.2 C mobo: N/A gpu: amdgpu temp: 38.0 C
Processes: 329 Uptime: 7m wakeups: 809 Init: systemd v: 251
default: graphical Compilers: gcc: 12.2.0 clang: 14.0.6 Packages:
pm: pacman pkgs: 1353 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.22
