Having a problem where bluetooth connects then immediately disconnects my keyboard and controller. keyboard is a Keychron K2 V2 and controller is a Sony Dualsense and motherboard is a gigabyte B650 Aorus Elite AX Rev 1.0. I have Bluez and all of its dependencies installed along with blueman and the issue persists. I’ve also tried disabling ertm to no avail
Hello and welcome to the Manjaro Community!
It will help if you provide system information (see [HowTo] Request support) but to start with:
Enter
inxi -zv8
… in a Terminal, copy all the text, paste here;
highlight it and click the </> button at the top of the reply window to format it correctly for this Forum.
Note: The
z
part of that command filters out personally identifiable information such as MAC addresses, etc.
Please do the same for other information you will be asked for.
Cheers!
Kernel: 6.12.12-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=d1006fcd-0474-4368-bbe2-12d20a326eb5 rw quiet splash
udev.log_priority=3
Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.10.0
Type: Desktop Mobo: Gigabyte model: B650 AORUS ELITE AX v: x.x
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: F33a date: 02/07/2025
System RAM: total: 32 GiB available: 30.47 GiB used: 6.08 GiB (20.0%)
Device-1: Channel-A DIMM 0 type: no module installed
Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
(unregistered) size: 16 GiB speed: 6000 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.SKILL
part-no: F5-6000J3636F16G serial: <filter>
Device-3: Channel-B DIMM 0 type: no module installed
Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
Info: model: AMD Ryzen 7 7700X bits: 64 type: MT MCP arch: Zen 4 gen: 4
level: v4 note: check built: 2022+ process: TSMC n5 (5nm) family: 0x19 (25)
model-id: 0x61 (97) stepping: 2 microcode: 0xA60120C
smt: enabled cache: L1: 512 KiB desc: d-8x32 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3209 min/max: 545/5573 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3209 2: 3209 3: 3209
4: 3209 5: 3209 6: 3209 7: 3209 8: 3209 9: 3209 10: 3209 11: 3209 12: 3209
13: 3209 14: 3209 15: 3209 16: 3209 bogomips: 143806
apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f
avx512ifma avx512vbmi avx512vl bmi1 bmi2 bpext cat_l3 cdp_l3 clflush
clflushopt clwb clzero cmov cmp_legacy constant_tsc cpb cppc cpuid cqm
cqm_llc cqm_mbm_local cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de
decodeassists erms extapic extd_apicid f16c flush_l1d flushbyasid fma fpu
fsgsbase fsrm fxsr fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse
pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
succor svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk
v_spec_ctrl vaes vgif vmcb_clean vme vmmcall vnmi vpclmulqdq wbnoinvd wdt
x2avic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
conditional; STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected;
BHI: Not affected
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ZOTAC driver: nvidia
v: 550.144.03 alternate: nouveau,nvidia_drm non-free: 550/565.xx+
status: current (as of 2025-01; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2484 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael vendor: Gigabyte
driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-1, DP-2, DP-3, HDMI-A-1, Writeback-1 bus-ID: 11:00.0
chip-ID: 1002:164e class-ID: 0300 temp: 40.0 C
Device-3: Logitech CrystalCam driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-1.2:4
chip-ID: 046d:0894 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.5
compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia
gpu: nvidia,amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 109 s-size: 802x333mm (31.57x13.11")
s-diag: 868mm (34.19")
Monitor-1: Unknown-1 mapped: DP-4 res: N/A size: 800x330mm (31.5x12.99")
modes: 3440x1440
API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia v: 550.144.03 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.4.303 layers: 10 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3070 driver: N/A device-ID: 10de:2484
surfaces: xcb,xlib device: 1 type: integrated-gpu name: AMD Radeon
Graphics (RADV RAPHAEL_MENDOCINO) driver: N/A device-ID: 1002:164e
surfaces: xcb,xlib
Device-1: NVIDIA GA104 High Definition Audio vendor: ZOTAC
bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High
Definition Audio driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 11:00.1 chip-ID: 1002:1640 class-ID: 0403
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 11:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Corsair HS80 RGB Wireless Gaming Receiver
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 5-1:2 chip-ID: 1b1c:0a6b class-ID: 0300
serial: <filter>
Device-5: Roland KATANA driver: snd-usb-audio type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2:3 chip-ID: 0582:01d8
class-ID: ff00
Device-6: Logitech CrystalCam driver: snd-usb-audio,uvcvideo type: USB
API: ALSA v: k6.12.12-2-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0c:00.0
IF: enp12s0 state: down mac: <filter>
Device-2: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 0d:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp13s0 state: up mac: <filter>
Device-1: MediaTek Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-9:5 chip-ID: 0e8d:0616
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.2
lmp-v: 11 status: discoverable: yes pairing: yes class-ID: 6c0104
Local Storage: total: 2.8 TiB used: 26.52 GiB (0.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup model: TM8FP6002T
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: SN13126 temp: 41.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Western Digital
model: WD BLACK SN770 1TB size: 931.51 GiB block-size: physical: 512 B
fw-rev: 731120WD temp: 38.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 model: General USB Flash Disk size: 28.92 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: SSD serial: <filter> fw-rev: 1.00 scheme: MBR
ID-1: / raw-size: 488.28 GiB size: 479.55 GiB (98.21%)
used: 21.91 GiB (4.6%) fs: ext4 dev: /dev/nvme1n1p5 maj-min: 259:7
label: N/A uuid: d1006fcd-0474-4368-bbe2-12d20a326eb5
used: 30.9 MiB (32.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
label: N/A uuid: 7C64-9182
ID-3: /mnt/game raw-size: 1.86 TiB size: 1.83 TiB (98.38%)
used: 4.58 GiB (0.2%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 6184f269-9ba2-4b05-ac4f-ff8792956be3
ID-1: /dev/nvme1n1p2 maj-min: 259:4 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme1n1p3 maj-min: 259:5 size: 442.49 GiB fs: bitlocker
ID-3: /dev/nvme1n1p4 maj-min: 259:6 size: 641 MiB fs: ntfs label: N/A
uuid: 38A242CEA2429074
ID-4: /dev/sda1 maj-min: 8:1 size: 4.03 GiB fs: iso9660
ID-5: /dev/sda2 maj-min: 8:2 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 97A3-D79B
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-2:2 info: Apple Aluminium Keyboard (ANSI) type: keyboard,mouse
driver: apple,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 05ac:024f class-ID: 0301
Hub-2: 1-3:3 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
chip-ID: 0bda:5411 class-ID: 0900
Device-1: 1-6:4 info: Integrated Express RGB LED Controller type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
Device-2: 1-9:5 info: MediaTek Wireless_Device type: bluetooth
mode: 2.0 power: 100mA chip-ID: 0e8d:0616 class-ID: e001 serial: <filter>
Hub-3: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
Hub-4: 2-3:2 info: Realtek Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 96mA
chip-ID: 0bda:0411 class-ID: 0900
Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 5-1:2 info: Corsair HS80 RGB Wireless Gaming Receiver
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 5
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 500mA
chip-ID: 1b1c:0a6b class-ID: 0300 serial: <filter>
Device-2: 5-2:3 info: Roland KATANA type: <vendor specific>
driver: snd-usb-audio interfaces: 4 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 chip-ID: 0582:01d8 class-ID: ff00
Hub-8: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-9: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Hub-10: 7-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 7-1.1:3 info: Razer USA Viper V2 Pro type: mouse,keyboard
lanes: 1 mode: 1.1 power: 100mA chip-ID: 1532:00a6 class-ID: 0301
serial: <filter>
Device-2: 7-1.2:4 info: Logitech CrystalCam type: video,audio
Device-3: 7-1.3:5 info: General USB Flash Disk type: mass storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
lanes: 1 mode: 2.0 power: 100mA chip-ID: 9129:1583 class-ID: 0806
serial: <filter>
Hub-11: 8-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
System Temperatures: cpu: 51.8 C mobo: 42.0 C
Fan Speeds (rpm): N/A
GPU: device: nvidia screen: :0.0 temp: 57 C fan: 0% device: amdgpu
temp: 39.0 C
Packages: pm: pacman pkgs: 1455 libs: 474 tools: pamac pm: flatpak pkgs: 0
1: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
2: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
3: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 389
1: cpu: 137% command: Discord pid: 1358 mem: 643.4 MiB (2.0%)
2: cpu: 27.6% command: Xorg pid: 781 mem: 191.0 MiB (0.6%)
3: cpu: 9.1% command: brave pid: 5027 mem: 284.5 MiB (0.9%)
4: cpu: 8.4% command: konsole pid: 5089 mem: 176.1 MiB (0.5%)
5: cpu: 2.6% command: zsh pid: 5099 mem: 9.39 MiB (0.0%)
Memory top: 5 of 389
1: mem: 1432.2 MiB (4.5%) command: pamac-manager pid: 3680 cpu: 0.6%
2: mem: 643.4 MiB (2.0%) command: Discord pid: 1358 cpu: 137%
3: mem: 586.6 MiB (1.8%) command: plasmashell pid: 931 cpu: 0.8%
4: mem: 457.5 MiB (1.4%) command: steamwebhelper pid: 3669 cpu: 0.8%
5: mem: 428.3 MiB (1.3%) command: brave pid: 4086 cpu: 1.1%
Processes: 389 Power: uptime: 27m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.15 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
running-in: konsole inxi: 3.3.37
Hi all together !
I just installed my PC with a fresh Manjaro system using KDE Plasma 6 desktop and I have the same problem with Bluetooth connecting for 1 - 2 s then it disconnects (same Hardware and Gnome desktop no issues at all … with Bluetooth).
I have a different Bluetooth chip, but also an AMD system.
In dmesg I have the following entries:
[ 8.206961] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 8.206964] Bluetooth: BNEP filters: protocol multicast
[ 8.206966] Bluetooth: BNEP socket layer initialized
[ 8.207400] Bluetooth: MGMT ver 1.23
[ 8.210958] NET: Registered PF_ALG protocol family
[ 8.248753] NET: Registered PF_QIPCRTR protocol family
[ 6247.862701] snd_hda_codec_hdmi hdaudioC0D0: HDMI: Unknown ELD version 0
[ 6248.599992] Bluetooth: RFCOMM TTY layer initialized
[ 6248.599998] Bluetooth: RFCOMM socket layer initialized
[ 6248.600000] Bluetooth: RFCOMM ver 1.11
[ 9324.450640] Bluetooth: hci0: ACL packet for unknown connection handle 69
[ 9324.833903] Bluetooth: hci0: unexpected SMP command 0x0b from 16:cb:19:98:fb:2d
[ 9386.986124] Bluetooth: hci0: unexpected SMP command 0x0b from 16:cb:19:98:fb:2d
I am no expert in Bluetooth, maybe someone has some ideas what’s wrong here?
Update:
I let dmesg -w run an tried out activating / deactivating the USB Bluetooth device … reboot no change. Since it is an USB stick removing and reconnecting it was possible and resulted in a proper entry. Afterwards the Bluetooth connecting to a JBL speakter could be established and is running stable - as long as I don’t reboot.
regards,
Marcus
My specs:
inxi -zv8
Kernel: 6.12.17-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=40e8b027-d3ee-4c7a-a17a-b4fa5459f2d0 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A info: frameworks v: 6.11.0
wm: kwin_x11 with: krunner vt: 2 dm: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop Mobo: ASRock model: X670E PG Lightning
Megatrends LLC. v: 2.08.AS01 date: 01/31/2024
System RAM: total: 32 GiB available: 30.47 GiB used: 8.18 GiB (26.8%)
(unregistered) size: 16 GiB speed: spec: 4800 MT/s actual: 6000 MT/s
volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: N/A part-no: F5-6000J3038F16G serial: N/A
Info: model: AMD Ryzen 7 7800X3D bits: 64 type: MT MCP arch: Zen 4 gen: 4
model-id: 0x61 (97) stepping: 2 microcode: 0xA601209
desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3453 min/max: 400/5050 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 3453 2: 3453 3: 3453
4: 3453 5: 3453 6: 3453 7: 3453 8: 3453 9: 3453 10: 3453 11: 3453 12: 3453
13: 3453 14: 3453 15: 3453 16: 3453 bogomips: 134201
BHI: Not affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
XTX/7900 GRE/7900M] vendor: Sapphire PULSE driver: amdgpu v: kernel
arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-2 empty: DP-1,
HDMI-A-1, HDMI-A-2, Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:744c
class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raphael driver: amdgpu
v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm) built: 2020-22
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-3,
DP-4, DP-5, HDMI-A-3, Writeback-2 bus-ID: 1a:00.0 chip-ID: 1002:164e
class-ID: 0300 temp: 36.0 C
Device-3: Generalplus GENERAL WEBCAM driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-10:3
chip-ID: 1b3f:2247 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: DP-2 mapped: DisplayPort-1 model: Samsung LC34G55T
serial: <filter> built: 2023 res: N/A dpi: 109 gamma: 1.2 chroma: red:
x: 0.651 y: 0.337 green: x: 0.310 y: 0.624 blue: x: 0.153 y: 0.067 white:
x: 0.306 y: 0.329 size: 798x334mm (31.42x13.15") diag: 869mm (34.2")
modes: 3440x1440, 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768,
832x624, 800x600, 720x576, 720x480, 640x480, 720x400
EDID-Warnings: 1: parse_edid: unknown tag 112
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7900 XT (radeonsi
navi31 LLVM 19.1.7 DRM 3.61 6.12.17-1-MANJARO) device-ID: 1002:744c
memory: 19.53 GiB unified: no
API: Vulkan v: 1.4.304 layers: N/A device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XT (RADV NAVI31) driver: N/A device-ID: 1002:744c
surfaces: xcb,xlib
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
speed: 16 GT/s lanes: 16 bus-ID: 1a:00.1 chip-ID: 1002:1640 class-ID: 0403
vendor: ASRock driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 1a:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Generalplus GENERAL WEBCAM driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.12.17-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
Device-1: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 10:00.0
IF: enp16s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:2
chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 6.37 TiB used: 2.24 TiB (35.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 36.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 4TB
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: SSK model: Portable SSD 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: SSD serial: <filter>
fw-rev: 1000 scheme: MBR
ID-1: / raw-size: 930.93 GiB size: 930.93 GiB (100.00%)
used: 139.56 GiB (15.0%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 40e8b027-d3ee-4c7a-a17a-b4fa5459f2d0
ID-2: /boot/efi raw-size: 600 MiB size: 598.8 MiB (99.80%)
used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 60C7-1768
ID-3: /home raw-size: 930.93 GiB size: 930.93 GiB (100.00%)
ID-4: /home/<filter>/Daten raw-size: 3.64 TiB size: 3.64 TiB (100.00%)
used: 958.09 GiB (25.7%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
label: Daten-SSD uuid: b7420cbc-63cf-494a-9529-f4a44a0dc4f2
ID-5: /run/media/marcus/My_Backup_2024 raw-size: 1.82 TiB
size: 1.79 TiB (98.37%) used: 1.17 TiB (65.2%) fs: ext4 dev: /dev/sdb1
maj-min: 8:17 label: My_Backup_2024
uuid: fc863637-065f-4e2e-bbce-a1a71262845e
ID-6: /swap raw-size: 930.93 GiB size: 930.93 GiB (100.00%)
ID-7: /var/cache raw-size: 930.93 GiB size: 930.93 GiB (100.00%)
ID-8: /var/log raw-size: 930.93 GiB size: 930.93 GiB (100.00%)
ID-1: swap-1 type: file size: 512 MiB used: 72.2 MiB (14.1%) priority: -2
file: /swap/swapfile
Device-1: 1-5:2 info: Canon CanoScan 8800F type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 2mA chip-ID: 04a9:1901 class-ID: 0000
Hub-2: 2-0:1 info: super-speed hub ports: 5 rev: 3.1
Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-2:2 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Device-2: 3-10:3 info: Generalplus GENERAL WEBCAM type: video,audio
Device-3: 3-12:4 info: Logitech Illuminated Keyboard type: keyboard,mouse
lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c318 class-ID: 0300
Hub-4: 4-0:1 info: super-speed hub ports: 5 rev: 3.1
Device-1: 4-1:2 info: Silicon Motion - Taiwan (formerly Feiya ) Portable
SSD type: mass storage driver: uas interfaces: 1 rev: 3.2
speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 power: 896mA
chip-ID: 090c:2320 class-ID: 0806 serial: <filter>
Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Hub-6: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
Device-1: 7-2:2 info: Logitech Logi Bolt Receiver type: keyboard,mouse,HID
lanes: 1 mode: 1.1 power: 98mA chip-ID: 046d:c548 class-ID: 0300
Hub-8: 8-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-9: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
Device-1: 9-1:2 info: ASRock LED Controller type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 26ce:01a2 class-ID: 0300
serial: <filter>
Hub-10: 10-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
System Temperatures: cpu: 42.2 C mobo: 31.5 C
GPU: device: amdgpu temp: 36.0 C device: amdgpu temp: 47.0 C mem: 61.0 C
fan: 0 watts: 34.00
Packages: 2125 pm: pacman pkgs: 2112 libs: 501 tools: pamac,yay pm: flatpak
pkgs: 13
1: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
2: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 463
1: cpu: 11.2% command: deemix started-by: elisa pid: 27280
mem: 468.5 MiB (1.5%)
2: cpu: 7.9% command: thumbnail.so started-by: kioworker pid: 28581
mem: 205.5 MiB (0.6%)
3: cpu: 6.2% command: konsole pid: 28535 mem: 244.4 MiB (0.7%)
4: cpu: 5.7% command: firefox pid: 16661 mem: 586.6 MiB (1.8%)
5: cpu: 5.0% command: firefox pid: 28278 mem: 308.3 MiB (0.9%)
Memory top: 5 of 463
1: mem: 1450.9 MiB (4.6%) command: pamac-manager pid: 27827 cpu: 2.7%
2: mem: 835.2 MiB (2.6%) command: firefox pid: 16540 cpu: 4.3%
3: mem: 736.8 MiB (2.3%) command: plasmashell pid: 2217 cpu: 0.7%
4: mem: 605.9 MiB (1.9%) command: krunner pid: 4766 cpu: 0.1%
5: mem: 586.6 MiB (1.8%) command: firefox pid: 16661 cpu: 5.7%
Processes: 463 Power: uptime: 2h 39m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.17 GiB services: org_kde_powerdevil,
tool: systemctl
Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.37 running-in: konsole inxi: 3.3.37
