rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
3: hci1: Bluetooth
Soft blocked: no
Hard blocked: no
I did what you told me on the terminal, then I turned on two bluetooth speakers and one of them appeared in the bluesman and then disappeared.
the other speaker didn’t even appear.
after that i got nervous and uninstalled blueman and restarted the computer. then I tried for the bluetooth settings of the manjaro itself and none of the boxes appears.
inxi -Eazy
Device-1: Apple Bluetooth Host Controller type: USB driver: btusb v: 0.8
bus-ID: 1-1.1.3:8 chip-ID: 05ac:821a class-ID: fe01
Report: rfkill ID: hci1 rfk-id: 2 state: up address: see --recommends
Device-2: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) type: USB
driver: btusb v: 0.8 bus-ID: 2-1.2:4 chip-ID: 0a12:0001 class-ID: e001
Report: ID: hci0 rfk-id: 1 state: up address: N/A
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
2: hci1: Bluetooth
Soft blocked: no
Hard blocked: no
systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor>
Active: active (running) since Tue 2021-11-30 15:53:36 -03; 10min ago
Docs: man:bluetoothd(8)
Main PID: 11559 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 19078)
Memory: 904.0K
CPU: 159ms
CGroup: /system.slice/bluetooth.service
└─11559 /usr/lib/bluetooth/bluetoothd
nov 30 15:53:36 guOfMidNight bluetoothd[11559]: Starting SDP server
nov 30 15:53:36 guOfMidNight bluetoothd[11559]: Bluetooth management inte>
nov 30 15:53:36 guOfMidNight bluetoothd[11559]: Endpoint registered: send>
Because I once decided to open my macbook to change the thermal compound and let’s say that I thought I hadn’t reconnected the bluetooth and I was preoccupied.
I took out the adapter and it still doesn’t work.
I think there’s a demon inside this notebook.
I’m going to try to do just a few more tests and if it doesn’t work can I open a new topic or speak right here?
