Hello! I am using a fresh install of Manjaro, and I got everything set up to know that bluetooth is not working. I launched blueman-manager in the terminal to find out what is wrong just to get these errors:
blueman-manager 20.19.05 ERROR Manager:118 on_dbus_name_appeared: Default adapter not found, trying first available.
blueman-manager 20.19.05 ERROR Manager:122 on_dbus_name_appeared: No adapter(s) found, exiting
Due to the error, I launched lspci and I got this:
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 08)
00:02.0 VGA compatible controller: Intel Corporation UHD Graphics 620 (rev 07)
00:04.0 Signal processing controller: Intel Corporation Xeon E3-1200 v5/E3-1500 v5/6th Gen Core Processor Thermal Subsystem (rev 08)
00:08.0 System peripheral: Intel Corporation Xeon E3-1200 v5/v6 / E3-1500 v5 / 6th/7th/8th Gen Core Processor Gaussian Mixture Model
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:14.2 Signal processing controller: Intel Corporation Sunrise Point-LP Thermal subsystem (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:17.0 RAID bus controller: Intel Corporation 82801 Mobile SATA Controller [RAID mode] (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #5 (rev f1)
00:1c.5 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #6 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point LPC Controller/eSPI Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
02:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8821CE 802.11ac PCIe Wireless Network Adapter
Some of you will be pointing out that I did not run inxi, so here is the output of that:
System: Kernel: 4.14.219-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-4.14-x86_64 root=UUID=56c10d28-81c7-49a9-bc86-dbb161fc6c71 rw quiet apparmor=1
Desktop: i3 4.19.1 info: i3bar dm: LightDM 1.30.0 Distro: Manjaro Linux
Machine: Type: Laptop System: HP product: HP Laptop 15-da0xxx v: Type1ProductConfigId serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: HP model: 84A6 v: 80.31 serial: <filter> UEFI: Insyde v: F.07 date: 11/21/2018
Battery: ID-1: BAT1 charge: 29.0 Wh condition: 36.8/41.0 Wh (90%) volts: 12.9/11.4 model: Hewlett-Packard PABAS0241231
type: Li-ion serial: <filter> status: Charging
CPU: Info: Quad Core model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 8E (142) stepping: A (10) microcode: E0 L2 cache: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 28808
Speed: 800 MHz min/max: 400/3400 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800 8: 800
Vulnerabilities: Type: itlb_multihit status: KVM: Vulnerable
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5917
class ID: 0300
Device-2: Cheng Uei Precision Industry (Foxlink) HP TrueVision HD Camera type: USB driver: uvcvideo bus ID: 1-5:2
chip ID: 05c8:03ba class ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: picom v: git-dac85 driver: loaded: intel unloaded: modesetting
alternate: fbdev,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0") s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: llvmpipe (LLVM 11.0.1 256 bits) v: 4.5 Mesa 20.3.4 compat-v: 3.1 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus ID: 00:1f.3 chip ID: 8086:9d71 class ID: 0403
Sound Server: ALSA v: k4.14.219-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169
v: 2.3LK-NAPI port: 4000 bus ID: 01:00.0 chip ID: 10ec:8168 class ID: 0200
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard driver: rtl8821ce v: N/A
modules: 8821ce port: 3000 bus ID: 02:00.0 chip ID: 10ec:c821 class ID: 0280
Bluetooth: Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8 bus ID: 1-6:3 chip ID: 0bda:b00a
class ID: e001 serial: <filter>
Message: Required tool hciconfig not installed. Check --recommends
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: 5060 bus ID: 00:17.0
chip ID: 8086.282a rev: 21
Drives: Local Storage: total: 931.51 GiB used: 9.55 GiB (1.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB block size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 1C scheme: GPT
Partition: ID-1: / raw size: 931.22 GiB size: 915.6 GiB (98.32%) used: 9.55 GiB (1.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%) used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1
maj-min: 8:1
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 44.0 C mobo: 29.8 C
Info: Processes: 193 Uptime: 26m wakeups: 1 Memory: 7.71 GiB used: 1.67 GiB (21.7%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: pacman: 1075 lib: 311 Shell: Bash v: 5.1.0 running in: urxvtd inxi: 3.3.01
I have no idea what is going on, please help!
