I am unable to activate Bluetooth on my laptop, and whenever I turn the laptop off, it shows the following error:
[FAILED] Failed to start Bluetooth service.
I tried the following, but it did not seem to work;
systemctl restart bluetoothd
Failed to restart bluetoothd.service: Unit bluetoothd.service not found.
I had a similar behaviour in the past, which seemed to be linked to the bluetooth quick connect gnome extension. Disabling that extension seemed to fix it, but now I don’t have that extension installed any more, so i don’t know if the errors are linked.
Here is my System Information:
✘ ~ inxi --admin --verbosity=7 --filter --width
Kernel: 5.15.28-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=e980b863-ca1f-4e22-bb6b-665a19ddff2d rw quiet apparmor=1
security=apparmor resume=UUID=3a5c48ea-fa12-4147-b57e-4dbdb9d07104
udev.log_priority=3
Desktop: GNOME v: 41.4 tk: GTK v: 3.24.33 wm: gnome-shell dm: GDM v: 41.3
Type: Laptop System: Timi product: TM1701 v: N/A
Mobo: Timi model: TM1701 v: MP serial: <superuser required> UEFI: INSYDE
v: XMAKB5R0P0502 date: 10/13/2017
ID-1: BAT0 charge: 21.5 Wh (52.1%) condition: 41.3/60.0 Wh (68.8%)
volts: 7.3 min: 7.6 model: SUNWODA R15B01W type: Li-ion serial: <filter>
status: discharging
RAM: total: 7.65 GiB used: 4.63 GiB (60.5%)
RAM Report:
Info: model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEC
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 712 high: 800 min/max: 400/4000 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 700 3: 700 4: 700
5: 700 6: 700 7: 700 8: 700 bogomips: 32012
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Xiaomi driver: i915 v: kernel
ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:5917 class-ID: 0300
Device-2: NVIDIA GP108M [GeForce MX150] vendor: Xiaomi Mi Notebook Pro
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 1
speed: 2.5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1d12 class-ID: 0302
Device-3: Chicony XiaoMi USB 2.0 Webcam type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 04f2:b59a class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.3 compositor: gnome-shell driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x0747 built: 2017 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.3.7
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Xiaomi
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.15.28-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.20 running: no
Sound Server-4: PulseAudio v: 15.0 running: yes
Sound Server-5: PipeWire v: 0.3.48 running: yes
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24fd class-ID: 0280
IF-ID-1: docker0 state: down mac: <filter>
bus-ID: 1-5:2 chip-ID: 8087:0a2b class-ID: e001
Report: bt-adapter note: tool can't run ID: hci0 rfk-id: 1 state: down
bt-service: enabled rfk-block: hardware: no software: no address: N/A
Local Storage: total: 704.24 GiB used: 376.43 GiB (53.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SanDisk model: Extreme Pro 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 101200RL temp: 44.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung
model: MZVLW256HEHP-00000 size: 238.47 GiB block-size: physical: 512 B
rev: CXB7401Q temp: 28.9 C scheme: GPT
ID-1: / raw-size: 456.66 GiB size: 448.5 GiB (98.21%)
used: 376.43 GiB (83.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: e980b863-ca1f-4e22-bb6b-665a19ddff2d
used: 316 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 592C-3652
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 3a5c48ea-fa12-4147-b57e-4dbdb9d07104
ID-1: /dev/nvme1n1p1 maj-min: 259:5 size: 499 MiB fs: ntfs label: N/A
uuid: A68E15988E15625B
ID-2: /dev/nvme1n1p2 maj-min: 259:6 size: 100 MiB fs: vfat label: N/A
uuid: A27D-5F71
ID-3: /dev/nvme1n1p3 maj-min: 259:7 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-4: /dev/nvme1n1p4 maj-min: 259:8 size: 237.87 GiB fs: ntfs label: N/A
uuid: 40AE7F22AE7F0FA0
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-5:2 info: Intel Bluetooth wireless interface type: Bluetooth
Device-2: 1-6:3 info: Chicony XiaoMi USB 2.0 Webcam type: Video
Device-3: 1-7:4 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
class-ID: ff00 serial: <filter>
Device-4: 1-8:5 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 04f3:0c1a class-ID: 0000
Device-5: 1-9:6 info: Areson Corp 2.4G Receiver type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 25a7:fa23 class-ID: 0301
Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 40.0 C pch: 33.0 C mobo: N/A
Processes: 315 Uptime: 18m wakeups: 2 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 2320 pacman: 2228 lib: 521
flatpak: 73 snap: 19 Shell: fish v: 3.3.1 default: Zsh v: 5.8.1
running-in: gjs inxi: 3.3.14
