Bluetooth not working after update
I updated my system today (stable update). After restart, my system does not connect to bluetooth devices any more and I also cannot pair.
The GUI system settings show me “bluetooth is disabled” and clicking the enable button has no effect. It lets me however scan for available devices, but doesn’t find anything.
According to systemctl status bluetooth, the bluetooth service is running.
● bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
     Active: active (running) since Sat 2025-09-27 21:43:10 CEST; 29min ago
 Invocation: fd264bcfd1334d418322d208eb9c658b
       Docs: man:bluetoothd(8)
   Main PID: 986 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 8070)
     Memory: 2M
        CPU: 34ms
     CGroup: /system.slice/bluetooth.service
             └─986 /usr/lib/bluetooth/bluetoothd
Sep 27 21:43:10 Zipfam systemd[1]: Starting Bluetooth service...
Sep 27 21:43:10 Zipfam (uetoothd)[986]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Sep 27 21:43:10 Zipfam bluetoothd[986]: Bluetooth daemon 5.83
Sep 27 21:43:10 Zipfam systemd[1]: Started Bluetooth service.
Sep 27 21:43:10 Zipfam bluetoothd[986]: Starting SDP server
Sep 27 21:43:10 Zipfam bluetoothd[986]: Bluetooth management interface 1.21 initialized
I tried nevertheless systemctl stop bluetooth, systemctl start bluetooth. As expected, no effect. I see the warning about configuration directory, but have no idea where this configuration directory is located or which config would be correct.
rfkill list bluetooth shows no blocks:
0: tpacpi_bluetooth_sw: Bluetooth
        Soft blocked: no
        Hard blocked: no
2: hci0: Bluetooth
        Soft blocked: no
        Hard blocked: no
bluetoothctl list shows nothing as output.
Welcome to the Manjaro community @mba
Try doing a full shutdown, turn the power off for a minute or so, turn the power back on & restart your machine (aka as a “cold boot”).
I’m not sure why this happens, but occasionally after a system update which includes firmware updates, a cold boot is required.
If that does not work, more troubleshooting may be necessary. To do that, please read through the following pre-prepared instructions:
As a new or infrequent forum user, you are encouraged to take some time to familiarise yourself with Forum requirements; in particular, the many ways to use the forum to your benefit:
The Update Announcements contain a Known Issues and Solutions section and should generally be checked before posting a request for support.
inxi --filter --verbosity=8
inxi -zv8
I had several cold boots in the meanwhile, this did not resolve the problem.
The Stable Update Announcements have no known issue related to bluetooth. However, since my original post, someone reported the same problem.
The resources around bluetooth issues I found all recommend restarting bluetooth service using systemctl or unblocking with rfkill which does not resolve the problem in my case.
Output of inxi -zv8:
  Kernel: 5.15.193-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=9d529913-6d3a-4a50-b9d3-79dac61c5ab1 rw apparmor=1
    security=apparmor resume=UUID=50d3d022-4e76-41c4-aa3a-cd5e41fc2775
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
  Type: Laptop System: LENOVO product: 20YG005WGE v: ThinkPad E15 Gen 3
    serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: LENOVO model: 20YG005WGE serial: <filter>
    part-nu: LENOVO_MT_20YG_BU_Think_FM_ThinkPad E15 Gen 3
    uuid: 2f5f19cc-35f7-11b2-a85c-d8f6fe9997bc UEFI: LENOVO
    v: R1OET28W (1.07 ) date: 07/15/2021
  ID-1: BAT0 charge: 44.4 Wh (78.2%) condition: 56.8/57 Wh (99.7%)
    volts: 12.39 min: 11.52 model: SMP 5B11C732 type: Li-poly serial: <filter>
    charging: status: not charging control: start: 75% end: 80% cycles: 36
  System RAM: total: 8 GiB available: 6.6 GiB used: 2.65 GiB (40.1%)
  Array-1: capacity: 64 GiB slots: 2 modules: 1 EC: None
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 8 GiB speed: 3200 MT/s volts: curr: 1.2 min: 1.2
    max: 1.2 width (bits): data: 64 total: 64 manufacturer: Samsung
    part-no: M471A1G44AB0-CWE serial: N/A
  Slot: 1 type: PCIe status: available info: J3600 length: short volts: 3.3
    bus-ID: 00:00.0
  Slot: 2 type: PCIe status: available info: J3605 length: short volts: 3.3
    bus-ID: 00:00.0
  Slot: 3 type: PCIe status: available info: J3700, M.2 length: short
    volts: 3.3 bus-ID: 00:00.0
  Slot: 4 type: PCIe status: available info: J3702, M.2 length: long
  Slot: 5 type: PCIe status: available info: J3703, M.2 length: long
  Slot: 6 type: PCIe status: available info: J4000 length: long volts: 3.3
    bus-ID: 00:00.0
  Info: model: AMD Ryzen 5 5500U with Radeon Graphics socket: FP6 bits: 64
    type: MT MCP arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
    process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
    microcode: 0x8608108
  Topology: cpus: 1x dies: 1 cores: 6 threads: 12 tpc: 2 smt: enabled cache:
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
    desc: 2x4 MiB
  Speed (MHz): avg: 1400 min/max: 1400/4056 boost: enabled
    base/boost: 2100/4050 scaling: driver: acpi-cpufreq governor: schedutil
    volts: 1.2 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 1400 4: 1400
    5: 1400 6: 1400 7: 1400 8: 1400 9: 1400 10: 1400 11: 1400 12: 1400
    bogomips: 50324
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb
    ibpb_exit_to_user ibrs ibs irperf lahf_lm lbrv lm mba mca mce misalignsse
    mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save
    nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rapl rdpid
    rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca
    smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock
    syscall tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif
    vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
    xsaveopt
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
  Type: spec_rstack_overflow mitigation: safe RET
    prctl and seccomp
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: Advanced Micro Devices [AMD/ATI] Lucienne vendor: Lenovo
    driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm
    built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s ports: active: DP-2,DP-4,eDP-1 empty: DP-1,DP-3,HDMI-A-1
    bus-ID: 05:00.0 chip-ID: 1002:164c class-ID: 0300 temp: 39.0 C
  Device-2: Logitech QuickCam Pro 9000 driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.3.3.3:8
    chip-ID: 046d:0990 class-ID: 0102 serial: <filter>
  Device-3: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 04f2:b6be
  Display: unspecified server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3000x2280 s-dpi: 96 s-size: 792x602mm (31.18x23.70")
    s-diag: 995mm (39.17")
  Monitor-1: DP-2 mapped: DisplayPort-1 pos: top-right model: HP LP2465
    serial: <filter> built: 2008 res: mode: 1920x1200 hz: 60 scale: 100% (1)
    dpi: 94 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.608
    blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 519x324mm (20.43x12.76") diag: 616mm (24.2") ratio: 16:10
    modes: 1920x1200, 1600x1200, 1680x1050, 1280x1024, 1280x960, 1152x864,
    1024x768, 832x624, 800x600, 640x480, 720x400
  Monitor-2: DP-4 mapped: DisplayPort-3 pos: top-left model: HP Z22i
    serial: <filter> built: 2014 res: mode: 1920x1080 hz: 60
    scale: 177% (0.5625) to: 1080x1920 dpi: 102 gamma: 1.2 chroma: red:
    x: 0.647 y: 0.337 green: x: 0.306 y: 0.635 blue: x: 0.145 y: 0.055 white:
    x: 0.314 y: 0.329 size: 477x268mm (18.78x10.55") diag: 547mm (21.5")
    ratio: 16:9 modes: 1920x1080, 1680x1050, 1600x900, 1280x1024, 1440x900,
    1280x720, 1024x768, 800x600, 640x480, 720x400
  Monitor-3: eDP-1 mapped: eDP pos: primary,bottom-r
    model: ChiMei InnoLux 0x151e built: 2019 res: mode: 1920x1080 hz: 60
    scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red: x: 0.592 y: 0.349 green:
    x: 0.329 y: 0.557 blue: x: 0.153 y: 0.118 white: x: 0.314 y: 0.329
    size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720,
    device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.3-arch1.2
    renoir ACO DRM 3.42 5.15.193-1-MANJARO) device-ID: 1002:164c
    memory: 1000 MiB unified: no
  API: Vulkan v: 1.4.321 layers: 1 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RENOIR) driver: mesa radv v: 25.2.3-arch1.2
    device-ID: 1002:164c surfaces: N/A
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
    vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.1
    chip-ID: 1002:1637 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
    driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x pcie:
    gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s
    bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
    lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 05:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  Device-4: Lenovo ThinkPad USB-C Dock Gen2 USB Audio
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 1-1.3.3.2:7 chip-ID: 17ef:30d1 class-ID: 0300
    serial: <filter>
  Device-5: Logitech QuickCam Pro 9000 driver: snd-usb-audio,uvcvideo
  API: ALSA v: k5.15.193-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.8 status: n/a (root, process)
    with: pipewire-media-session status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active (root, process)
    with: pulseaudio-alsa type: plugin tools: pacat,pactl
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter
    vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:c822
    class-ID: 0280
  Device-3: Lenovo USB-C Dock Ethernet driver: r8152 type: USB rev: 3.0
    speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-1.1:3 chip-ID: 17ef:a387
    class-ID: 0000 serial: <filter>
  IF: enp5s0f3u1u1 state: down mac: <filter>
  Info: services: mld, NetworkManager, systemd-timesyncd, wpa_supplicant
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:3 chip-ID: 0bda:c123
  Report: btmgmt ID: hci0 rfk-id: 2 state: up address: N/A
  Local Storage: total: 1.4 TiB used: 632.83 GiB (44.2%)
  ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: SK Hynix model: HFM512GD3HX015N
    lanes: 4 tech: SSD serial: <filter> fw-rev: 41030C20 temp: 24.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 69d 19h cycles: 1,285
    read-units: 1,595,622 [816 GB] written-units: 1,417,559 [725 GB]
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
    SDBPNTY-1T00-1101 size: 953.87 GiB block-size: physical: 512 B
    fw-rev: 11190001 temp: 36.9 C scheme: GPT
  SMART: yes health: PASSED on: 24d 11h cycles: 1,293
    read-units: 230,252,353 [117 TB] written-units: 163,168,208 [83.5 TB]
  ID-1: / raw-size: 78.12 GiB size: 76.35 GiB (97.73%) used: 51.94 GiB (68.0%)
    fs: ext4 block-size: 4096 B dev: /dev/nvme1n1p2 maj-min: 259:2
    label: Manjaro uuid: 9d529913-6d3a-4a50-b9d3-79dac61c5ab1
    used: 324 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
    maj-min: 259:1 label: NO_LABEL uuid: 927B-0E23
  ID-3: /home raw-size: 858.85 GiB size: 844.29 GiB (98.31%)
    used: 580.89 GiB (68.8%) fs: ext4 block-size: 4096 B dev: /dev/nvme1n1p3
    maj-min: 259:3 label: HOME uuid: 24c2c7c5-389d-4fbc-8e57-78e358c4f781
  ID-1: swap-1 type: partition size: 16.6 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme1n1p4 maj-min: 259:4 label: SWAP
    uuid: 50d3d022-4e76-41c4-aa3a-cd5e41fc2775
  ID-1: /dev/nvme0n1p1 maj-min: 259:6 size: 260 MiB fs: vfat label: SYSTEM
    uuid: 9263-3402
  ID-2: /dev/nvme0n1p2 maj-min: 259:7 size: 16 MiB fs: N/A label: N/A
    uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:8 size: 475.69 GiB fs: bitlocker
    label: N/A uuid: dd18ce18-e734-4cec-8668-5ef7d31438f5
  ID-4: /dev/nvme0n1p4 maj-min: 259:9 size: 1000 MiB fs: ntfs
    label: WinRE_DRV uuid: 74E66653E66615A0
  Hub-2: 1-1:2 info: Lenovo USB2.0 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:a392
  Hub-3: 1-1.3:4 info: Lenovo USB2.0 Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 17ef:a394
  Hub-4: 1-1.3.3:5 info: Lenovo USB2.0 Hub ports: 4 rev: 2.0
    chip-ID: 17ef:a395 class-ID: 0900
  Device-1: 1-1.3.3.1:6 info: Lenovo 40AS type: billboard,HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 17ef:a38f class-ID: 0300
    serial: <filter>
  Device-2: 1-1.3.3.2:7 info: Lenovo ThinkPad USB-C Dock Gen2 USB Audio
    type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 30mA
    chip-ID: 17ef:30d1 class-ID: 0300 serial: <filter>
  Device-3: 1-1.3.3.3:8 info: Logitech QuickCam Pro 9000 type: video,audio
  Device-4: 1-3:3 info: Chicony Integrated Camera type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b6be class-ID: fe01
    serial: <filter>
  Hub-5: 2-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-6: 2-1:2 info: Lenovo USB3.1 Hub ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 17ef:a391
  Device-1: 2-1.1:3 info: Lenovo USB-C Dock Ethernet type: Network
    driver: r8152 interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s) lanes: 1
    mode: 3.2 gen-1x1 power: 288mA chip-ID: 17ef:a387 class-ID: 0000
    serial: <filter>
  Hub-7: 2-1.3:4 info: Lenovo USB3.1 Hub ports: 4 rev: 3.1
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 17ef:a393
  Hub-8: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-3:2 info: Synaptics type: <vendor specific> driver: N/A
    interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 100mA chip-ID: 06cb:00fd class-ID: ff00 serial: <filter>
  Device-2: 3-4:3 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
  Hub-9: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 45.0 C mobo: N/A gpu: amdgpu temp: 39.0 C
  Fan Speeds (rpm): fan-1: 0
  Packages: pm: pacman pkgs: 2030 libs: 483 tools: octopi,pamac,trizen
    pm: flatpak pkgs: 0
    1: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    2: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
    3: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    4: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    5: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    8: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 295
  1: cpu: 10.0% command: firefox pid: 2263 mem: 496.2 MiB (7.3%)
  2: cpu: 7.3% command: firefox pid: 2541 mem: 347.5 MiB (5.1%)
  3: cpu: 2.8% command: kwin_x11 pid: 1362 mem: 182.4 MiB (2.7%)
  4: cpu: 2.7% command: Xorg pid: 1123 mem: 115.1 MiB (1.7%)
  5: cpu: 1.2% command: plasmashell pid: 1422 mem: 415.5 MiB (6.1%)
  Memory top: 5 of 295
  1: mem: 496.2 MiB (7.3%) command: firefox pid: 2263 cpu: 10.0%
  2: mem: 415.5 MiB (6.1%) command: plasmashell pid: 1422 cpu: 1.2%
  3: mem: 347.5 MiB (5.1%) command: firefox pid: 2541 cpu: 7.3%
  4: mem: 291.0 MiB (4.3%) command: firefox pid: 2479 cpu: 0.8%
  5: mem: 264.9 MiB (3.9%) command: firefox pid: 2567 cpu: 0.4%
  Processes: 295 Power: uptime: 17m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 2.63 GiB services: org_kde_powerdevil,upowerd
  Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Sudo (sudo) v: 1.9.17p1
    default: Bash v: 5.3.3 running-in: konsole inxi: 3.3.39
Did the same as you and got the same result.
Have you tried other kernels, e.g. 6.12 LTS?
Kernel 6.12.48-1 LTS works. Thanks!
Same here!
@Wollie Thanks so much!
