I’ve been trying to get a headset working that previously connected as headphones but not as mic, and along the way I ran a system update and something went wrong but I can’t find what that something is.
Right now if I try to connect to Bluetooth, I get the error br-connection-canceled
and once I saw br-connection-unknown
. Also tried pairing as a new device but it won’t detect anything in pairing mode.
Have tried different kernels (4.19.x, 5.4.x, and currently 5.14.x) and tons of troubleshooting from similar issues, but I don’t know where to go from here.
Is it possible the update didn’t go properly, or maybe a bug in the update?
Help will be very much appreciated!
Further information:
lsusb | grep -i bluetooth
us 001 Device 004: ID 8087:0a2b Intel Corp. Bluetooth wireless interface
rfkill list all
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
systemctl status bluetooth
irish@irish-sager:~$ sudo systemctl status bluetooth
[sudo] password for irish:
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Fri 2021-12-17 17:04:10 CST; 2min 38s ago
Docs: man:bluetoothd(8)
Main PID: 994 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 19056)
Memory: 3.4M
CPU: 26ms
CGroup: /system.slice/bluetooth.service
└─994 /usr/lib/bluetooth/bluetoothd
Dec 17 17:04:10 irish-sager bluetoothd[994]: Bluetooth management interface 1.14 initialized
Dec 17 17:04:10 irish-sager bluetoothd[994]: src/adapter.c:reset_adv_monitors_complete() Failed to reset Adv Monitors: Unknown Command (0x01)
Dec 17 17:04:21 irish-sager bluetoothd[994]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSink/sbc
Dec 17 17:04:21 irish-sager bluetoothd[994]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSource/sbc
Dec 17 17:04:21 irish-sager bluetoothd[994]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSink/sbc_xq_453
Dec 17 17:04:21 irish-sager bluetoothd[994]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSource/sbc_xq_453
Dec 17 17:04:21 irish-sager bluetoothd[994]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSink/sbc_xq_512
Dec 17 17:04:21 irish-sager bluetoothd[994]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSource/sbc_xq_512
Dec 17 17:04:21 irish-sager bluetoothd[994]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSink/sbc_xq_552
Dec 17 17:04:21 irish-sager bluetoothd[994]: Endpoint registered: sender=:1.32 path=/MediaEndpoint/A2DPSource/sbc_xq_552
inxi -Fxz
Kernel: 5.14.21-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: KDE Plasma 5.23.4 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Notebook product: N85_N87,HJ,HJ1,HK1 v: N/A
serial: <superuser required>
Mobo: Notebook model: N85_N87,HJ,HJ1,HK1 serial: <superuser required>
UEFI: American Megatrends v: 1.05.22RLS1 date: 03/27/2018
ID-1: BAT0 charge: 26.3 Wh (100.0%) condition: 26.3/59.9 Wh (43.9%)
volts: 12.4 min: 11.1 model: Notebook BAT status: Full
Info: quad core model: Intel Core i7-7700HQ bits: 64 type: MT MCP
arch: Kaby Lake rev: 9 cache: L1: 256 KiB L2: 1024 KiB L3: 6 MiB
Speed (MHz): avg: 906 high: 949 min/max: 800/3800 cores: 1: 949 2: 900
3: 900 4: 900 5: 900 6: 900 7: 900 8: 900 bogomips: 44817
Device-1: Intel HD Graphics 630 vendor: CLEVO/KAPOK driver: i915 v: kernel
bus-ID: 00:02.0
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: CLEVO/KAPOK
driver: nvidia v: 470.86 bus-ID: 01:00.0
Device-3: Chicony Chicony USB 2.0 Camera type: USB driver: uvcvideo
bus-ID: 1-2:3
Display: x11 server: X.Org 1.21.1.2 driver: loaded: modesetting,nvidia
resolution: 1920x1080~60Hz
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 470.86 direct render: Yes
Device-1: Intel CM238 HD Audio vendor: CLEVO/KAPOK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 01:00.1
Sound Server-1: ALSA v: k5.14.21-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: no
vendor: CLEVO/KAPOK driver: r8169 v: kernel port: d000 bus-ID: 03:00.1
IF: enp3s0f1 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
bus-ID: 04:00.0
IF: wlp4s0 state: up mac: <filter>
bus-ID: 1-3:4
Report: rfkill ID: hci0 rfk-id: 3 state: up address: see --recommends
Local Storage: total: 1.16 TiB used: 562.48 GiB (47.5%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WDS256G1X0C-00ENX0
size: 238.47 GiB temp: 30.9 C
ID-2: /dev/sda vendor: Crucial model: CT1000MX500SSD1 size: 931.51 GiB
ID-3: /dev/sdb type: USB vendor: SanDisk model: Cruzer Glide
ID-1: / size: 202.36 GiB used: 34.01 GiB (16.8%) fs: ext4
dev: /dev/nvme0n1p3
ID-2: /boot/efi size: 2 GiB used: 288 KiB (0.0%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 915.89 GiB used: 528.47 GiB (57.7%) fs: ext4
dev: /dev/sda1
ID-1: swap-1 type: partition size: 29.8 GiB used: 0 KiB (0.0%)
dev: /dev/nvme0n1p2
System Temperatures: cpu: 39.0 C pch: 45.0 C mobo: N/A gpu: nvidia
temp: 45 C
Processes: 266 Uptime: 10h 44m Memory: 15.52 GiB used: 2.53 GiB (16.3%)
Init: systemd Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1496
Shell: Bash v: 5.1.12 inxi: 3.3.11```
