Hey everyone,
I come today to get some help with my bluetooth on a all in one mac computer.
I tried some solution found on this forum or in the net but not working.
I have these packages :
bluez-hid2hci
bluez-utils
blueman
When I launch blueman-manager I got this error :
marie@marie-pc ~$ blueman-manager
blueman-manager 01.08.02 ERROR Manager:137 on_dbus_name_appeared: Default adapter not found, trying first available.
blueman-manager 01.08.02 ERROR Manager:141 on_dbus_name_appeared: No adapter(s) found, exiting
When I use hciconfig I get nothing, I don’t know why.
marie@marie-pc ~$ systemctl status dbus-org.bluez.service 130 ↵
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Tue 2022-05-03 00:56:04 CEST; 20min ago
Docs: man:bluetoothd(8)
Main PID: 45974 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 4658)
Memory: 2.1M
CPU: 63ms
CGroup: /system.slice/bluetooth.service
└─45974 /usr/lib/bluetooth/bluetoothd
mai 03 00:56:03 marie-pc systemd[1]: Starting Bluetooth service...
mai 03 00:56:04 marie-pc bluetoothd[45974]: Bluetooth daemon 5.64
mai 03 00:56:04 marie-pc systemd[1]: Started Bluetooth service.
mai 03 00:56:04 marie-pc bluetoothd[45974]: Starting SDP server
mai 03 00:56:04 marie-pc bluetoothd[45974]: profiles/network/bnep.c:bnep_init() kernel lacks bnep-prot>
mai 03 00:56:04 marie-pc bluetoothd[45974]: src/plugin.c:plugin_init() System does not support network>
mai 03 00:56:04 marie-pc bluetoothd[45974]: Bluetooth management interface 1.21 initialized
The rfkill command return just my Wireless device.
marie@marie-pc ~$ sudo dmesg | grep 'blue' 1 ↵
[ 8888.173318] audit: type=1130 audit(1651532164.398:660): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 9028.959263] audit: type=1130 audit(1651532305.184:679): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 9074.978502] audit: type=1131 audit(1651532351.204:680): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=blueman-mechanism comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
marie@marie-pc ~$ inxi -bx 1 ↵
Host: marie-pc Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64
compiler: gcc v: 11.2.0 Desktop: i3 v: 4.20.1 Distro: Manjaro Linux
base: Arch Linux
Type: Desktop System: Apple product: iMac12,1 v: 1.0
serial: <superuser required>
Mobo: Apple model: Mac-942B5BF58194151B serial: <superuser required>
UEFI: Apple v: IM121.88Z.0047.B1F.1201241648 date: 01/24/12
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
charge: 55% (should be ignored) status: discharging
Info: quad core Intel Core i5-2400S [MCP] arch: Sandy Bridge speed (MHz):
avg: 1600 min/max: 1600/3300
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
driver: i915 v: kernel bus-ID: 00:02.0
Device-2: AMD Whistler [Radeon HD 6630M/6650M/6750M/7670M/7690M]
vendor: Apple driver: radeon v: kernel bus-ID: 01:00.0
Device-3: Apple FaceTime HD Camera (Built-in) type: USB driver: uvcvideo
bus-ID: 1-2:3
Display: x11 server: X.Org v: 21.1.3 driver: X:
loaded: modesetting,radeon gpu: radeon resolution: 1920x1080~60Hz
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
v: kernel port: N/A bus-ID: 02:00.0
Device-2: Qualcomm Atheros AR93xx Wireless Network Adapter
vendor: Apple AirPort Extreme driver: ath9k v: kernel bus-ID: 03:00.0
Local Storage: total: 523.56 GiB used: 80.93 GiB (15.5%)
Processes: 234 Uptime: 2h 58m Memory: 3.81 GiB used: 2.43 GiB (63.9%)
Init: systemd Compilers: gcc: 11.2.0 clang: 13.0.1 Packages: 1329
Shell: Zsh v: 5.8.1 inxi: 3.3.15
marie@marie-pc ~$ lsmod | grep bluetooth
bluetooth 749568 6
ecdh_generic 16384 1 bluetooth
crc16 16384 1 bluetooth
rfkill 32768 7 ath9k,bluetooth,cfg80211
I am actually on Manjaro I3 Testing Branch, I tried on XFCE too and not working.
Thank you for read.
