I have a Logitech M337 Bluetooth Mouse and a Boat Rockerz 400 Bluetooth Headphone. The mouse works fine on its own, but when both devices are connected, the mouse lags significantly sometimes [Sometimes both the devices work fine, but sometimes the mouse starts to lag just after the headphone is connected, which adds to the confusion]. What should I do?
Inxi info:
Kernel: 5.15.25-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=d2bc7634-231f-4395-baf7-8bd03bd81f22 rw rootflags=subvol=@ quiet
apparmor=1 security=apparmor
resume=UUID=2a4fcd30-2c13-4af8-ac48-dcc594deb59a udev.log_priority=3
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP 250 G6 Notebook PC
v: Type1ProductConfigId serial: <superuser required> Chassis: type: 10
Mobo: HP model: 8328 v: 23.77 serial: <superuser required> UEFI: Insyde
v: F.68 date: 07/22/2021
ID-1: BAT1 charge: 40.9 Wh (100.0%) condition: 40.9/41.6 Wh (98.2%)
volts: 16.6 min: 14.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: Full
Device-1: hid-f4:73:35:1e:61:f1-battery
model: Bluetooth Mouse M336/M337/M535 serial: N/A charge: N/A
status: Discharging
Info: model: Intel Core i3-6006U bits: 64 type: MT MCP arch: Skylake
family: 6 model-id: 0x4E (78) stepping: 3 microcode: 0xEC
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2000 min/max: 400/2000 scaling: driver: intel_pstate
governor: powersave cores: 1: 2000 2: 2000 3: 2000 4: 2000 bogomips: 16006
Type: l1tf
Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Hewlett-Packard
driver: i915 v: kernel ports: active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: Sunplus Innovation HP TrueVision HD Camera type: USB
driver: uvcvideo bus-ID: 1-5:3 chip-ID: 1bcf:2c9b class-ID: 0e02
Display: x11 server: X.Org v: 1.21.1.3 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.2x8.0")
s-diag: 414mm (16.3")
Monitor-1: eDP-1 model: BOE Display built: 2015 res: 1366x768 hz: 60
dpi: 101 gamma: 1.2 size: 344x194mm (13.5x7.6") diag: 395mm (15.5")
ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.3.7
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d70 class-ID: 0403
Sound Server-1: ALSA v: k5.15.25-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 8086:24fb class-ID: 0280
IF-ID-1: virbr0 state: down mac: <filter>
Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 1-4:2 chip-ID: 8087:0aa7 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: <filter>
Local Storage: total: 1.13 TiB used: 43.04 GiB (3.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: A-Data model: SU630 size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: 3R17 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD10JPVX-60JC3T1 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter>
rev: 1A02 scheme: GPT
ID-1: / raw-size: 214.47 GiB size: 214.47 GiB (100.00%)
used: 43.04 GiB (20.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
used: 1.2 MiB (0.4%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 214.47 GiB size: 214.47 GiB (100.00%)
ID-4: /var/log raw-size: 214.47 GiB size: 214.47 GiB (100.00%)
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 55.0 C pch: 45.0 C mobo: 27.8 C
Processes: 283 Uptime: 33m wakeups: 9 Memory: 7.68 GiB
used: 3.82 GiB (49.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1852 pacman: 1833 lib: 414 flatpak: 19
Shell: Zsh v: 5.8.1 default: Bash v: 5.1.16 running-in: kitty inxi: 3.3.13
