It’s have been a week I’m trying to reach this purpose but I’m still unable to do it.
According to articles and solved issues, I uninstalled the pulseaudio
and installed pipewire
Now when I use HSP/HFP
mode audio quality is a little bit lower which is not a problem but microphone is completely noisy! I searched again and I found out that I should use mSBC
codec instead of CVSD
one but it is not currently supported and I should enable it.
Guides on Internet says I should edit bluez-monitor.conf
file but I couldn’t find it:
$ ls /etc/pipewire/media-session.d -a
. .. media-session.conf.backup
$ ls ~/.config/pipewire/
ls: cannot access '/home/milad/.config/pipewire/': No such file or directory
So where can I find defined codecs?
Update:
I followed this link and created file manually, but after restarting pipewire, there is still now support for mSBC
codec with HSP
/HFP
