Hi there,
My Bluetooth keyboard randomly seems to fall asleep for about 10 seconds or so and then quickly does the last couple of keystrokes. This happens every few minutes.
I have also noticed that when the keyboard falls asleep, running the command lsusb gives no output until the keyboard works again. Also the entire problem seems to get better if the keyboard has been connected for longer. i.e. the interruptions are not as often then.
Originally I noticed these problems on Kubuntu after an update. Sadly switching to Manjaro has not fixed the problem.
If anyone would know a solution I would be very grateful!!
Cheers,
dayday
here are my system infos:
inxi --full --admin --verbosity=7 --filter --no-host
System: Kernel: 5.10.56-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=4c2e8cd5-51c7-4c44-81de-8832c7a73f00 rw
quiet apparmor=1 security=apparmor resume=UUID=82ad94cd-20eb-4dd2-94aa-a220d37f2ad2
udev.log_priority=3
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux
base: Arch Linux
Machine: Type: Laptop System: LENOVO product: 20BTS06G08 v: ThinkPad X1 Carbon 3rd serial: <filter> Chassis:
type: 10 serial: <filter>
Mobo: LENOVO model: 20BTS06G08 v: SDK0E50510 WIN serial: <filter> UEFI-[Legacy]: LENOVO
v: N14ET26W (1.04 ) date: 01/23/2015
Battery: ID-1: BAT0 charge: 44.9 Wh (100.0%) condition: 44.9/50.1 Wh (89.6%) volts: 17.1 min: 15.2
model: SMP 00HW003 type: Li-poly serial: <filter> status: Full
Memory: RAM: total: 7.46 GiB used: 3.91 GiB (52.5%)
CPU: Info: Dual Core model: Intel Core i7-5600U bits: 64 type: MT MCP arch: Broadwell family: 6
model-id: 3D (61) stepping: 4 microcode: 2F cache: L2: 4 MiB bogomips: 20761
Speed: 2595 MHz min/max: 500/3200 MHz Core speeds (MHz): 1: 2595 2: 2594 3: 2595 4: 2594
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2 bts
clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms
est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr hle ht ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat
pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good rtm sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
Type: spectre_v2
mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Graphics: Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:1616 class-ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus-ID: 2-8:4 chip-ID: 04f2:b45d
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: modesetting
alternate: fbdev,intel,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1921x2160 s-dpi: 96 s-size: 506x570mm (19.9x22.4") s-diag: 762mm (30")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 158 size: 309x173mm (12.2x6.8") diag: 354mm (13.9")
Monitor-2: HDMI-2 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
OpenGL: renderer: Mesa Intel HD Graphics 5500 (BDW GT2) v: 4.6 Mesa 21.1.6 direct render: Yes
Audio: Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:03.0
chip-ID: 8086:160c class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0 class-ID: 0403
Sound Server-1: ALSA v: k5.10.56-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Network: Device-1: Intel Ethernet I218-LM vendor: Lenovo driver: e1000e v: kernel port: 3080 bus-ID: 00:19.0
chip-ID: 8086:15a2 class-ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel port: efa0 bus-ID: 04:00.0
chip-ID: 8086:095b class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 2-7:3
chip-ID: 8087:0a2a class-ID: e001
Logical: Message: No logical block device data found.
RAID: Message: No RAID data found.
Drives: Local Storage: total: 238.47 GiB used: 59.25 GiB (24.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: MZNTE256HMHP-000L7 size: 238.47 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 8L6Q scheme: MBR
Partition: ID-1: / raw-size: 229.67 GiB size: 225 GiB (97.97%) used: 59.25 GiB (26.3%) fs: ext4 dev: /dev/sda1
maj-min: 8:1 label: N/A uuid: 4c2e8cd5-51c7-4c44-81de-8832c7a73f00
Swap: Kernel: swappiness: 60 (default) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda2
maj-min: 8:2 label: N/A uuid: 82ad94cd-20eb-4dd2-94aa-a220d37f2ad2
Unmounted: Message: No unmounted partitions found.
USB: Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 3 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002
Hub-2: 1-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0 speed: 480 Mb/s chip-ID: 8087:8001
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 11 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002
Device-1: 2-7:3 info: Intel Bluetooth wireless interface type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0a2a class-ID: e001
Device-2: 2-8:4 info: Chicony Integrated Camera type: Video driver: uvcvideo interfaces: 2 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 04f2:b45d class-ID: 0e02 serial: <filter>
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s chip-ID: 1d6b:0003
Sensors: System Temperatures: cpu: 55.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 3961
Info: Processes: 229 Uptime: 1m wakeups: 1 Init: systemd v: 248 tool: systemctl Compilers: gcc: 11.1.0
Packages: 1350 pacman: 1338 lib: 351 flatpak: 6 snap: 6 Shell: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.06
