Bluetooth is enabled and running but not working ?!
hi all, suddenly my bluetooth connections aren’t working
after some restarts and some commands found in here like
$ sudo systemctl stop bluetooth.service
$ sudo modprobe -rv btusb && sleep 10 && sudo modprobe -v btusb
$ sudo systemctl start bluetooth.service
with no results :weary:
I don´t know what else to do
some system info now:
status
═    ⇝ systemctl status bluetooth
● bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
     Active: active (running) since Fri 2025-07-11 15:38:27 -03; 51min ago
 Invocation: 9acf5a99849142859e775688a15fc2ec
       Docs: man:bluetoothd(8)
   Main PID: 9069 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 18990)
     Memory: 2M (peak: 2.5M)
        CPU: 51ms
     CGroup: /system.slice/bluetooth.service
             └─9069 /usr/lib/bluetooth/bluetoothd
jul 11 15:38:27 icarusdb systemd[1]: Starting Bluetooth service...
jul 11 15:38:27 icarusdb bluetoothd[9069]: Bluetooth daemon 5.83
jul 11 15:38:27 icarusdb systemd[1]: Started Bluetooth service.
jul 11 15:38:27 icarusdb bluetoothd[9069]: Starting SDP server
jul 11 15:38:27 icarusdb bluetoothd[9069]: Bluetooth management interface 1.22 initialized
journal
═    ⇝ journalctl -b 0 | grep bluetooth
jul 11 15:33:27 icarusdb NetworkManager[831]: <info>  [1752258807.9449] Loaded device plugin: NMBluezManager (/usr/lib/NetworkManager/1.52.0-1/libnm-device-plugin-bluetooth.so)
jul 11 15:36:02 icarusdb sudo[5043]:   mcrose : TTY=pts/0 ; PWD=/home/mcrose ; USER=root ; COMMAND=/usr/bin/systemctl status bluetooth
jul 11 15:36:34 icarusdb sudo[6040]:   mcrose : TTY=pts/1 ; PWD=/home/mcrose ; USER=root ; COMMAND=/usr/bin/systemctl stop bluetooth.service
jul 11 15:38:27 icarusdb sudo[9062]:   mcrose : TTY=pts/1 ; PWD=/home/mcrose ; USER=root ; COMMAND=/usr/bin/systemctl start bluetooth.service
rfill list
═    ⇝ rfkill list
0: acer-wireless: Wireless LAN
	Soft blocked: no
	Hard blocked: no
1: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
but in the gnome setting is disabled nor I can enable it
dmesg
╘═    ⇝ sudo dmesg | grep -i bluetooth
[  257.508240] Bluetooth: Core ver 2.22
[  257.508292] NET: Registered PF_BLUETOOTH protocol family
[  257.508294] Bluetooth: HCI device and connection manager initialized
[  257.508300] Bluetooth: HCI socket layer initialized
[  257.508303] Bluetooth: L2CAP socket layer initialized
[  257.508308] Bluetooth: SCO socket layer initialized
[  309.677156] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[  309.677162] Bluetooth: BNEP filters: protocol multicast
[  309.677168] Bluetooth: BNEP socket layer initialized
inxi
╘═    ⇝ inxi -b
  Host: icarusdb Kernel: 6.6.94-1-MANJARO arch: x86_64 bits: 64
  Desktop: GNOME v: 48.2 Distro: Manjaro Linux
  Type: Laptop System: Acer product: Aspire E5-575G v: V1.47
    serial: <superuser required>
  Mobo: Acer model: Ironman_SK v: V1.47 serial: <superuser required>
    UEFI: Insyde v: 1.47 date: 09/06/2018
  ID-1: BAT1 charge: 19.7 Wh (100.0%) condition: 19.7/61.0 Wh (32.3%)
  Info: dual core Intel Core i5-6200U [MT MCP] speed (MHz): avg: 500
    min/max: 400/2800
  Device-1: Intel Skylake GT2 [HD Graphics 520] driver: i915 v: kernel
  Device-2: NVIDIA GM107 [GeForce 940MX] driver: nvidia v: 575.64
  Device-3: Chicony HD WebCam driver: uvcvideo type: USB
  Display: wayland server: X.Org v: 24.1.8 with: Xwayland v: 24.1.8
    compositor: gnome-shell driver: X: loaded: modesetting,nvidia dri: iris
    gpu: i915 s-res: 5360x1440 resolution: 1: 3440x1440 2: 1920x1080
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.1.4-arch1.1
    renderer: Mesa Intel HD Graphics 520 (SKL GT2)
  Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
    x11: xdpyinfo,xprop
  Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
    driver: ath10k_pci
    driver: r8169
  Local Storage: total: 1.14 TiB used: 692.13 GiB (59.2%)
  Memory: total: 16 GiB available: 15.49 GiB used: 6.62 GiB (42.7%)
  Processes: 304 Uptime: 1h 7m Shell: Zsh inxi: 3.3.38
any ideas ?
How about the toggle? On Plasma it reassuringly says ‘Enabled’ for me.
	Soft blocked: no
	Hard blocked: no
	Soft blocked: no
	Hard blocked: no
Your bluetooth device disappeared from the system, as evident from above. A bluetooth device that’s present shows as follows
rfkill list
0: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
1: hci0: Bluetooth
	Soft blocked: yes
	Hard blocked: no
You should check if you have a physical switch for bluetooth in the form of a key combination or physical switch that turns it off or on. You might also want to check the BIOS if it is disabled there.
well, I rebooted and tried to get into the BIOS, but because I didn’t remember the password ( and I don´t remember set it :smiling_face_with_tear: ) I had to turn off my notebook
then turned on again… forgot the F2, got into the user login and… bluetooth was enabled again
╘═    ⇝ rfkill list
	Soft blocked: no
	Hard blocked: no
1: acer-bluetooth: Bluetooth
	Soft blocked: no
	Hard blocked: no
2: hci0: Bluetooth
	Soft blocked: no
	Hard blocked: no
3: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
I just mark my own answer as a solution, even though I wouldn’t figure it out without @braveheartleo suggestion :grinning: :+1:
I used to have that chip in my old Dell laptop.
No idea why, but only shutting down works when BlueTooth magically disappears like that. :man_shrugging:
Same happens with my trackpad — sometimes it stops working after the first suspend. In my case I use a workaround — modprobe to remove and re-add psmouse which brings it back and restores suspend thereafter.
I wonder if similar can be used for that Wifi module?
