Hallo zusammen,
ich habe ein Jabra 85H Headset und kann es auch über Bluetooth verbinden, als Kopfhörer funktionieren die problemlos.
Nur scheint das Betriebssystem nicht das Mikrofon zu finden und bietet es auch nicht zur Auswahl an.
Manjaro aktueller Stand testing
KDE 5.20.2
Kernel 5.9.6
$ dmesg | grep -i bluetooth
[ 3.149674] Bluetooth: Core ver 2.22
[ 3.149690] Bluetooth: HCI device and connection manager initialized
[ 3.149694] Bluetooth: HCI socket layer initialized
[ 3.149696] Bluetooth: L2CAP socket layer initialized
[ 3.149702] Bluetooth: SCO socket layer initialized
[ 3.917008] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 3.917010] Bluetooth: BNEP filters: protocol multicast
[ 3.917014] Bluetooth: BNEP socket layer initialized
[ 22.448615] Bluetooth: RFCOMM TTY layer initialized
[ 22.448647] Bluetooth: RFCOMM socket layer initialized
[ 22.448673] Bluetooth: RFCOMM ver 1.11
$ systemctl status bluetooth
bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Fri 2020-11-13 14:21:31 CET; 43min ago
Docs: man:bluetoothd(8)
Main PID: 906 (bluetoothd)
Status: “Running”
Tasks: 1 (limit: 18522)
Memory: 3.4M
CGroup: /system.slice/bluetooth.service
└─906 /usr/lib/bluetooth/bluetoothd
Nov 13 14:21:31 k-xps139370 bluetoothd[906]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionLatency” in group “Controller”
Nov 13 14:21:31 k-xps139370 bluetoothd[906]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionSupervisionTimeout” in group “Controller”
Nov 13 14:21:31 k-xps139370 bluetoothd[906]: src/main.c:parse_controller_config() Key file does not have key “LEAutoconnecttimeout” in group “Controller”
Nov 13 14:21:31 k-xps139370 systemd[1]: Started Bluetooth service.
Nov 13 14:21:31 k-xps139370 bluetoothd[906]: Starting SDP server
Nov 13 14:21:31 k-xps139370 bluetoothd[906]: Bluetooth management interface 1.17 initialized
Nov 13 14:21:51 k-xps139370 bluetoothd[906]: Endpoint registered: sender=:1.49 path=/MediaEndpoint/A2DPSink/sbc
Nov 13 14:21:51 k-xps139370 bluetoothd[906]: Endpoint registered: sender=:1.49 path=/MediaEndpoint/A2DPSource/sbc
Nov 13 14:24:45 k-xps139370 bluetoothd[906]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to 70:BF:92:38:06:EF: Connection refused (111)
Nov 13 14:24:47 k-xps139370 bluetoothd[906]: /org/bluez/hci0/dev_70_BF_92_38_06_EF/sep1/fd0: fd(45) ready
Kann mir jemand bitte helfen ich komme nicht weiter?
Danke!
