Bluetooth headset is connected but the corresponding pipewire audio device is not available
My bluetooth headset is connected OK but there is no corresponding pipewire audio device available
bluetoothctl info [MAC]
Device [MAC] (random)
        Name: JBL Tune 520BT-LE
        Alias: JBL Tune 520BT-LE
        Paired: yes
        Bonded: yes
        Trusted: yes
        Blocked: no
        Connected: yes
        LegacyPairing: no
        CablePairing: no
Everything was OK before some Manjaro upgrade. There are no error messages in the system logs when the headset is conected. What else can I check?
Please post more information about system
inxi -SMAEz
and audio devices detected in pipewire-pulse
pactl list cards
Thanks,
> inxi -SMAEz
  Kernel: 6.6.99-1-MANJARO arch: x86_64 bits: 64
  Desktop: KDE Plasma v: 6.3.6 Distro: Manjaro Linux
  Type: Laptop System: HP product: HP ProBook 430 G6 v: N/A
    serial: <superuser required>
  Mobo: HP model: 8536 v: KBC Version 51.20.00 serial: <superuser required>
    UEFI: HP v: R71 Ver. 01.08.03 date: 07/17/2019
  Device-1: Intel Cannon Point-LP High Definition Audio driver: snd_hda_intel
  API: ALSA v: k6.6.99-1-MANJARO status: kernel-api
  Server-1: PipeWire v: 1.4.6 status: active
  Device-1: Realtek Bluetooth 4.2 Adapter driver: btusb type: USB
  Report: btmgmt ID: hci1 rfk-id: 3 state: down bt-service: enabled,running
    rfk-block: hardware: no software: yes address: N/A
> pactl list cards short
265     alsa_card.pci-0000_00_1f.3      alsa
266     alsa_card.platform-snd_aloop.0  alsa
When my bluetooth speakers (which work OK with my Manjaro) is connected, I can see third card in the list:
345     bluez_card.[MAC]    module-bluez5-device.c
But there is no third card in the list when the aforementioned BT headset is connected. The headset is working properly with any other system.
ArchWiki - Bluetooth headset - Troubleshooting - Connecting works but device does not show up in PulseAudio sinks
If the headphones connect successfully (which can be confirmed via bluetoothctl) but do not show up as an output sink in pavucontrol, you can try adding (or creating) the following policy to your Bluetooth configuration file /etc/bluetooth/audio.conf:
# /etc/bluetooth/audio.conf
[General]
Enable=Control,Gateway,Headset,Media,Sink,Socket,Source
Restart the bluetooth.service, then reconnect the headphones.
Some users report that this has solved their problem.
A post was split to a new topic: Bluetooth connected but no sound
