Usually my headphones reconnect after I take them out of their box. But not on Manjaro. I see that the Bluetooth manager “connects” to them but there is no audio connection to them.
Is there something I need to do first?
Kernel: 5.15.55-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=8d893b58-a86a-4225-b843-5e6e518b1056 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Acer model: Predator PO3-630 v: 1.0
serial: <superuser required> UEFI: American Megatrends v: R01-A1
date: 03/18/2021
RAM: total: 15.48 GiB used: 1.47 GiB (9.5%)
RAM Report:
Info: model: 11th Gen Intel Core i7-11700F bits: 64 type: MT MCP
arch: Rocket Lake gen: core 11 built: 2021+ process: Intel 14nm family: 6
model-id: 0xA7 (167) stepping: 1 microcode: 0x53
Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 900 high: 901 min/max: 800/4800:4900 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 901 3: 901 4: 900
5: 900 6: 900 7: 900 8: 900 9: 901 10: 900 11: 900 12: 901 13: 900 14: 901
15: 900 16: 901 bogomips: 79888
Flags: 3dnowprefetch abm acpi adx aperfmperf apic arat arch_capabilities
arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2 avx512_vnni
avx512_vpopcntdq avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi
avx512vl bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed
rdtscp rep_good sdbg sep sha_ni smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
tsc_known_freq umip vme vmx vnmi vpclmulqdq vpid x2apic xgetbv1 xsave
xsavec xsaveopt xsaves xtopology xtpr
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: NVIDIA GP107GL [Quadro P620] driver: nouveau v: kernel
non-free: 515.xx+ status: current (as of 2022-06) arch: Pascal
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: DP-4 empty: DP-1,DP-2,DP-3
bus-ID: 01:00.0 chip-ID: 10de:1cb6 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa gpu: nouveau display-ID: :0
screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
s-diag: 599mm (23.57")
Monitor-1: DP-4 model: Idek Iiyama X2485 serial: <filter> built: 2016
res: 1920x1200 hz: 60 dpi: 94 gamma: 1.2 size: 518x324mm (20.39x12.76")
diag: 611mm (24.1") ratio: 16:10 modes: max: 1920x1200 min: 720x400
OpenGL: renderer: NV137 v: 4.3 Mesa 22.1.3 direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Sound Server-1: ALSA v: k5.15.55-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.55 running: yes
Device-1: Intel Tiger Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:43f0 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
chip-ID: 10ec:2600 class-ID: 0200
bus-ID: 1-14:4 chip-ID: 8087:0026 class-ID: e001
Hardware-1: Intel Device driver: N/A v: N/A port: 5020 bus-ID: 00:17.0
chip-ID: 8086:43de rev: N/A class-ID: 0104
Local Storage: total: 476.94 GiB used: 9.43 GiB (2.0%)
model: PC SN530 SDBPNPZ-512G-1114 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: 21113000 temp: 40.9 C scheme: GPT
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 9.4 GiB (9.6%)
fs: ext4 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: 8d893b58-a86a-4225-b843-5e6e518b1056
used: 29 MiB (30.2%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: F2D0-01A7
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 499 MiB fs: ntfs
label: Wiederherstellung uuid: 920ECF5D0ECF394D
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 1024 KiB
fs: <superuser required> label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 15 MiB fs: <superuser required>
ID-4: /dev/nvme0n1p5 maj-min: 259:5 size: 376.34 GiB fs: ntfs label: N/A
uuid: 9E88D61F88D5F5AD
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Hub-2: 1-6:2 info: Hitachi ports: 4 rev: 2.0 speed: 480 Mb/s
chip-ID: 045b:0209 class-ID: 0900
Hub-3: 1-9:3 info: Alcor Micro USB Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 058f:6254 class-ID: 0900
Device-1: 1-9.4:5
info: Microsoft 2.4GHz Transceiver v8.0 used by mouse Wireless Desktop 900
type: Keyboard,Mouse,HID driver: hid-generic,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 100mA chip-ID: 045e:07b2 class-ID: 0300
Device-2: 1-14:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-4: 2-0:1 info: Super-speed hub ports: 5 rev: 3.1 speed: 20 Gb/s
System Temperatures: cpu: 38.0 C mobo: N/A gpu: nouveau temp: 49.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 2490
Processes: 324 Uptime: 4m wakeups: 0 Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 14.0.6 Packages: pacman: 1184
lib: 319 flatpak: 0 Shell: Zsh v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.19
