Bluetooth headphones have no sound
Bluetooth headphones have no sound? Anyone?
  Host: yoga Kernel: 6.1.11-1-MANJARO arch: x86_64 bits: 64
    Desktop: KDE Plasma v: 5.26.5 Distro: Manjaro Linux
  Device-1: Intel Ice Lake-LP Smart Sound Audio
    driver: sof-audio-pci-intel-icl
  Sound API: ALSA v: k6.1.11-1-MANJARO running: yes
  Sound Server-1: PulseAudio v: 16.1 running: yes
  Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
    driver: btusb
Assuming the headphones are connected properly and working you may just need to select them as sync device. You can do this through pasystray. Basically your just redirecting the output from your speakers to the headphones.
I used blueman-manager to remove device from paired devices, re-paired my headphones and now it works.
First time this happend after upgrade.
