Hello,
When I use High Fidelty Playback (A2DP) on my headset I only get audio output. When I use Handsfree headset unit (HFP) I get my microphone recording but no sound output comes from the headphones even when I set sound output to the headphones.
I have been able to use HFP with my headphones before when I had manjaro on my laptop and even though the audio was not clear, I was able to use both the microphone and headphone speaker.
Kernel: 5.10.61-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=6f0e6d25-04cf-4fda-aeb4-9ea63414a140 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel, plank
wm: xfwm 4.16.1 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux
base: Arch Linux
Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
Mobo: ASUSTeK model: PRIME B560M-A v: Rev 1.xx serial: <filter>
UEFI: American Megatrends v: 0820 date: 04/27/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Solar Keyboard K750
serial: <filter> charge: 100% rechargeable: yes status: Full
Device-2: hidpp_battery_1 model: Logitech Wireless Gaming Mouse
status: Discharging
Info: Quad Core model: Intel Core i3-10320 bits: 64 type: MT MCP
arch: Comet Lake family: 6 model-id: A5 (165) stepping: 3 microcode: EA
cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 60819
Speed: 800 MHz min/max: 800/4600 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800
Vulnerabilities: Type: itlb_multihit status: KVM: VMX unsupported
Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: eVga.com. driver: nvidia
v: 470.63.01 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1401 class-ID: 0300
Display: x11 server: X.Org 1.20.13 compositor: xfwm4 v: 4.16.1 driver:
loaded: nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 3968x1280 s-dpi: 96 s-size: 1050x339mm (41.3x13.3")
s-diag: 1103mm (43.4")
Monitor-1: DP-0 res: 1024x1280 hz: 60
Monitor-2: DP-3 res: 1920x1080 hz: 60 dpi: 93 size: 527x296mm (20.7x11.7")
diag: 604mm (23.8")
Monitor-3: DP-4 res: 1024x1280 hz: 60
OpenGL: renderer: NVIDIA GeForce GTX 960/PCIe/SSE2 v: 4.6.0 NVIDIA 470.63.01
direct render: Yes
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:f0c8 class-ID: 0403
Device-2: NVIDIA GM206 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fba
class-ID: 0403
Sound Server-1: ALSA v: k5.10.61-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: no
Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
port: efa0 bus-ID: 00:1f.6 chip-ID: 8086:15fa class-ID: 0200
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel port: 3000
bus-ID: 03:00.0 chip-ID: 8086:095a class-ID: 0280
bus-ID: 1-8:2 chip-ID: 8087:0a2a class-ID: e001
Local Storage: total: 931.52 GiB used: 29.06 GiB (3.1%)
model: WDS500G3X0C-00SJG0 size: 465.76 GiB block-size: physical: 4096 B
logical: 4096 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 111110WD temp: 56.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 20WD
scheme: GPT
ID-1: / raw-size: 465.46 GiB size: 457.08 GiB (98.20%)
used: 29.04 GiB (6.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.3 MiB (99.76%)
used: 25.4 MiB (8.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 48.0 C mobo: N/A gpu: nvidia temp: 60 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 7%
Processes: 247 Uptime: 11h 38m wakeups: 209 Memory: 15.49 GiB
used: 3.58 GiB (23.1%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1205 lib: 338 flatpak: 0 Shell: Bash v: 5.1.8
running-in: xfce4-terminal inxi: 3.3.06
