I have been using Manjaro on my laptop for 6 months now, and everything has been working great until today.
Today I tried to connect the Bluetooth headphones I use every day, and they keep connecting and disconnecting from Bluetooth every few seconds. Even when they are connected, there is no sound!
Removing the headphones from the list of Bluetooth devices and reconnecting them did not change the situation. Restarting the computer did not help either.
Well, maybe you could tell us what happened today that didn’t also happen yesterday? What is different today? Did you install something? Did you decide to update today?
The point is that nothing happened today. I updated the system yesterday afternoon, but in the evening the headphones were working fine! Today I didn’t install or update anything.
KDE Plasma Version: 6.5.5
KDE Frameworks Version: 6.23.0
Qt Version: 6.10.2
Kernel Version: 6.18.12-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 12 Ă— AMD Ryzen 5 5600H with Radeon Graphics
Memory: 16 GiB of RAM (15.0 GiB usable)
Graphics Processor: AMD Radeon Graphics
Manufacturer: ASUSTeK COMPUTER INC.
Product Name: VivoBook_ASUSLaptop M1603QA_M1603QA
System Version: 1.0
It didn’t help. I removed the Bluetooth device and reconnected it, but nothing changed and it still doesn’t work.
It seems to be working, but somehow strangely… At first, it didn’t want to connect and gave an error. By the way, even when Bluetooth shows that it is connected, headphones do not always appear in the audio mixer.
And then the sound started to appear intermittently. And after 30 seconds of intermittent operation, the music plays normally.
I will monitor the situation and write back later or tomorrow!
Unfortunately, as soon as I closed the browser where the music was playing and started the film (SMPlayer), the sound disappeared and won’t work…
Yesterday, I tried again to boot Windows and check if the headphones worked there — as a result, they started glitching there too, but a system and driver update popped up! I updated everything and the headphones started working again in Windows 11.
Unfortunately, Windows messed up GRUB and Manjaro stopped booting… After spending two hours trying to restore GRUB (with no effect), I decided to reinstall Manjaro — it’s quicker and easier for me to do that.
After restarting the newly installed Manjaro and installing all the updates, the headphones are working without any problems!
I suppose that it was Windows that somehow affected the Bluetooth, but I cannot confirm this 100%!
At the moment, the problem has been resolved. Thanks everybody!
Reinstalling the OS is not recognised as a resolution to the issue raised. Never mark a solution unless a particular post has either solved the issue or led you to find a solution.
The marked solution has been removed.
If Windows Fast Startup is enabled, this is certainly possible – it is recommended to disable it from an administrative command prompt:
powercfg /h off
With Fast Startup enabled, Windows does not actually shut down; instead, it sleeps. When the computer subsequently wakes from the hibernation state, this gives the illusion of a faster startup and shutdown experience.
Fast Startupmust be disabled in a multiboot scenario.
