Hello Manjaro,
I have a bluetooth headphones and I think I am using default bluetooth & pipewire configuration that comes with Manjaro Gnome.
The issue is:
I am having audio glitches while using bluetooth headphones.
Audio is getting faster and slower just a little bit. It is so small that I usually can’t recognize it while watching a movie. It is almost an invisible/inaudible glitch.
But while listening some music, it becomes audible. I can hear it from microtonal pitch changes during a song. I do love jazz, but this is too jazzy to listen ![]()
I tried different headsets, result is the same.
I am using 5GHz WiFi connection, so bluetooth-wifi signal interference is unlikely. Plus, I am having the same issue while WiFi is off.
I wan’t to solve this issue because right now it is almost impossible to listen some music using my computer.
Kernel: 5.15.25-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=9d1957cd-266f-4059-82dc-e93d466e28ed rw zswap.enabled=0 quiet
splash apparmor=1 security=apparmor
resume=UUID=c42d6251-2dbd-4a5d-b453-cb3ad5d93ccb udev.log_priority=3
Desktop: GNOME 41.4 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Laptop System: Apple product: MacBookAir6,2 v: 1.0
serial: <superuser required> Chassis: type: 10 v: Mac-7DF21CB3ED6977E5
Mobo: Apple model: Mac-7DF21CB3ED6977E5 v: MacBookAir6,2
serial: <superuser required> UEFI: Apple v: 122.0.0.0.0 date: 06/10/2020
ID-1: BAT0 charge: 30.4 Wh (87.1%) condition: 34.9/54.3 Wh (64.2%)
volts: 8.2 min: 7.6 model: SMP bq20z451 type: Li-ion serial: N/A
status: Full cycles: 2707
RAM: total: 3.77 GiB used: 3.05 GiB (80.7%)
RAM Report:
Info: model: Intel Core i5-4250U bits: 64 type: MT MCP arch: Haswell
family: 6 model-id: 0x45 (69) stepping: 1 microcode: 0x26
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1021 high: 1251 min/max: 800/2600 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 800 2: 1251 3: 1091
4: 945 bogomips: 15205
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xsave xsaveopt xtopology xtpr
Type: l1tf
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Apple driver: i915
v: kernel ports: active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:0a26 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.3 with: Xwayland v: 22.1.0
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: Apple Color LCD built: 2011 res: 1440x900 dpi: 128
gamma: 1.2 size: 286x179mm (11.3x7") diag: 337mm (13.3") ratio: 16:10
modes: 1440x900
Message: Wayland GBM/EGL data currently not available.
Device-1: Intel Haswell-ULT HD Audio vendor: Apple driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio driver: snd_hda_intel v: kernel
bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
Device-3: Broadcom 720p FaceTime HD Camera driver: facetimehd v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:1570
class-ID: 0480
Sound Server-1: ALSA v: k5.15.25-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.47 running: yes
Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter vendor: Apple
driver: wl v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14e4:43a0 class-ID: 0280
Device-1: Apple Bluetooth USB Host Controller type: USB driver: btusb v: 0.8
bus-ID: 1-3.3:6 chip-ID: 05ac:828f class-ID: fe01
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 113 GiB used: 63.02 GiB (55.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0128F size: 113 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: SSD
serial: <filter> rev: EA1Q scheme: GPT
ID-1: / raw-size: 104.4 GiB size: 102.2 GiB (97.89%) used: 63.02 GiB (61.7%)
fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 9d1957cd-266f-4059-82dc-e93d466e28ed
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: 7440-2579
ID-1: swap-1 type: partition size: 8.3 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3 label: swap
uuid: c42d6251-2dbd-4a5d-b453-cb3ad5d93ccb
ID-2: swap-2 type: zram size: 3.77 GiB used: 1.07 GiB (28.4%)
priority: 100 dev: /dev/zram0
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 9 rev: 2.0
Hub-2: 1-3:2
info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth) ports: 3
rev: 2.0 speed: 12 Mb/s power: 94mA chip-ID: 0a5c:4500 class-ID: 0900
Device-1: 1-3.3:6 info: Apple Bluetooth USB Host Controller
type: Bluetooth driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s
Device-2: 1-5:3 info: Apple Apple Internal Keyboard / Trackpad
type: HID,Keyboard,Mouse driver: apple,bcm5974,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 05ac:0291 class-ID: 0301
serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Device-1: 2-3:2 info: Apple Internal Memory Card Reader type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 896mA
chip-ID: 05ac:8406 class-ID: 0806 serial: <filter>
System Temperatures: cpu: 64.0 C mobo: N/A
Processes: 242 Uptime: 17h 46m wakeups: 58 Init: systemd v: 250
tool: systemctl Compilers: gcc: 11.2.0 Packages: 1355 pacman: 1327 lib: 327
flatpak: 28 Shell: Zsh v: 5.8.1 running-in: guake inxi: 3.3.13
