Hi everyone,
I’ve recently switched from Ubuntu to Manjaro, and so far, I’m enjoying the transition. However, I’m a at a bit of a loss when it comes to connecting my bluetooth headphones, Bose QuietComfort 35 II.
The first step, connecting, seems to go rather well. I tried using GNOME’s GUI and bluetoothctl
, and both are able to connect to my headphones - which also knows a connection has happened by telling me so. Additionally, the bluetooth menu lists the correct name and also that it’s a sound device.
However, the sound still comes from my normal speakers. I tried switching the output to the headphones, but neither GNOME’s output nor pavucontrol
lists any output devices that are related to my headphones, and so it seems that PulseAudio doesn’t recognise my headphones as audio devices. And yet, the bluetooth menu and bluetoothctl
specifically list it as such.
I’ve already tried searching for it online, but so far, it seems everyone is able to find their device under pavucontrol. Does anyone have any ideas on how to fix this?
For completeness, here’s some system info:
Output of inxi -Fazy
Kernel: 5.9.1-1-MANJARO x86_64 bits: 64 compiler: N/A
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=7b44a8fd-cf8e-44d4-ad1f-a3e60560f719 rw apparmor=1
security=apparmor resume=UUID=7f9bfb3b-6984-4be0-92a1-b9c3a16af59d
udev.log_priority=3
Desktop: GNOME 3.36.6 tk: GTK 3.24.23 wm: gnome-shell dm: GDM 3.36.3
Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: Z390 AORUS PRO v: N/A
serial: <filter>
Mobo: Gigabyte model: Z390 AORUS PRO-CF v: x.x serial: <filter>
UEFI: American Megatrends v: F11 date: 10/15/2019
ID-1: hidpp_battery_2 charge: N/A condition: N/A volts: 3.9/N/A
model: Logitech G703 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A
serial: <filter> status: Discharging
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse PID:0085
serial: N/A charge: 55% (should be ignored) rechargeable: yes
status: Discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard PID:0068
serial: N/A charge: 5% (should be ignored) rechargeable: yes
status: Discharging
Topology: 8-Core model: Intel Core i9-9900KF bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: C (12) microcode: D6
L2 cache: 16.0 MiB
bogomips: 115232
Speed: 800 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800 5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800
14: 800 15: 801 16: 800
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Device-1: NVIDIA TU104 [GeForce RTX 2080] vendor: Gigabyte driver: nvidia
v: 455.28 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1e82
Display: x11 server: X.org 1.20.9 compositor: gnome-shell driver: nvidia
resolution: <xdpyinfo missing>
OpenGL: renderer: GeForce RTX 2080/PCIe/SSE2 v: 4.6.0 NVIDIA 455.28
direct render: Yes
Device-1: Intel Cannon Lake PCH cAVS vendor: Gigabyte driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3
chip ID: 8086:a348
Device-2: NVIDIA TU104 HD Audio vendor: Gigabyte driver: snd_hda_intel
v: kernel bus ID: 01:00.1 chip ID: 10de:10f8
Sound Server: ALSA v: k5.9.1-1-MANJARO
Device-1: Intel Ethernet I219-V vendor: Gigabyte driver: e1000e v: kernel
port: efa0 bus ID: 00:1f.6 chip ID: 8086:15bc
IF-ID-1: vboxnet0 state: up speed: 10 Mbps duplex: full mac: <filter>
Local Storage: total: 2.73 TiB used: 2.09 TiB (76.5%)
ID-1: /dev/nvme0n1 vendor: Corsair model: Force MP600 size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4
serial: <filter> rev: EGFM11.3 scheme: GPT
ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 970 EVO Plus 250GB
size: 232.89 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 serial: <filter> rev: 2B2QEXM7 scheme: GPT
ID-3: /dev/sda vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s serial: <filter>
rev: 4B6Q scheme: GPT
ID-4: /dev/sdb vendor: Seagate model: ST2000LM015-2E8174 size: 1.82 TiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw size: 75.00 GiB size: 73.32 GiB (97.76%) used: 10.10 GiB (13.8%)
fs: ext4 dev: /dev/nvme1n1p2
ID-2: /home raw size: 150.00 GiB size: 146.65 GiB (97.76%)
used: 26.22 GiB (17.9%) fs: ext4 dev: /dev/nvme1n1p3
ID-1: swap-1 type: partition size: 7.78 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme1n1p4
System Temperatures: cpu: 50.0 C mobo: N/A gpu: nvidia temp: 59 C
Processes: 412 Uptime: 3h 24m Memory: 31.30 GiB used: 7.46 GiB (23.8%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1246 pacman: 1242
lib: 317 flatpak: 0 snap: 4 Shell: Bash v: 5.0.18 running in: tilix
inxi: 3.1.05
The output of pa-info | sed -e "s/$HOSTNAME/HOST/gI" -e "s/$USER/USER/gI"
________________
> pulseaudio_ps_do
gdm 1492 0.6 0.0 1021600 12820 ? S<sl 22:30 0:08 /usr/bin/pulseaudio --daemonize=no
USER 1809 0.0 0.0 1997060 13728 ? S<sl 22:30 0:00 /usr/bin/pulseaudio --daemonize=no
USER 5333 0.0 0.0 3076 844 pts/0 S+ 22:50 0:00 grep pulseaudio
________________
> which pulseaudio
/usr/bin/pulseaudio
________________
> pidof pulseaudio
1809 1492
________________
> pulseaudio --version
pulseaudio 13.0
________________
> pactl info
Server String: /run/user/1000/pulse/native
Library Protocol Version: 33
Server Protocol Version: 33
Is Local: yes
Client Index: 16
Tile Size: 65472
User Name: USER
Host Name: HOST
Server Name: pulseaudio
Server Version: 13.0
Default Sample Specification: s16le 2ch 44100Hz
Default Channel Map: front-left,front-right
Default Sink: alsa_output.pci-0000_00_1f.3.analog-stereo
Default Source: alsa_output.pci-0000_00_1f.3.analog-stereo.monitor
Cookie: 67dc:67d9
________________
> pactl list
Module #0
Argument:
Usage counter: n/a
Properties:
module.author = "Lennart Poettering"
module.description = "Automatically restore the volume/mute state of devices"
module.version = "13.0"
Module #1
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore the volume/mute/device state of streams"
Module #2
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore profile of cards"
Module #3
Argument:
Usage counter: n/a
Properties:
module.description = "Augment the property sets of streams with additional static information"
Module #4
Argument:
Usage counter: n/a
Properties:
module.author = "David Henningsson"
module.description = "Switches ports and profiles when devices are plugged/unplugged"
Module #5
Argument:
Usage counter: n/a
Properties:
module.description = "Detect available audio hardware and load matching drivers"
Module #6
Argument: device_id="1" name="pci-0000_01_00.1" card_name="alsa_card.pci-0000_01_00.1" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
Usage counter: 0
Properties:
module.description = "ALSA Card"
Module #7
Argument: device_id="0" name="pci-0000_00_1f.3" card_name="alsa_card.pci-0000_00_1f.3" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
Usage counter: 0
Properties:
Module #8
Argument: channels=2
Usage counter: n/a
Properties:
module.description = "Adds JACK sink/source ports when JACK is started"
Module #9
Argument:
Usage counter: n/a
Properties:
module.author = "Frédéric Dalleau, Pali Rohár"
module.description = "Policy module to make using bluetooth devices out-of-the-box easier"
Module #10
Argument:
Usage counter: n/a
Properties:
module.author = "João Paulo Rechi Vita"
module.description = "Detect available Bluetooth daemon and load the corresponding discovery module"
Module #11
Argument:
Usage counter: n/a
Properties:
module.description = "Detect available BlueZ 5 Bluetooth audio devices and load BlueZ 5 Bluetooth audio drivers"
Module #12
Argument:
Usage counter: n/a
Properties:
module.author = "Tanu Kaskinen"
module.description = "D-Bus interface"
Module #13
Argument:
Usage counter: n/a
Properties:
module.description = "Native protocol (UNIX sockets)"
Module #14
Argument:
Usage counter: n/a
Properties:
module.author = "Sylvain Baubeau"
module.description = "GSettings Adapter"
Module #15
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically restore the default sink and source"
Module #16
Argument:
Usage counter: n/a
Properties:
module.description = "When a sink/source is removed, try to move its streams to the default sink/source"
Module #17
Argument:
Usage counter: n/a
Properties:
module.author = "Colin Guthrie"
module.description = "Always keeps at least one sink loaded even if it's a null one"
Module #18
Argument:
Usage counter: n/a
Properties:
module.description = "Automatically set device of streams based on intended roles of devices"
Module #19
Argument:
Usage counter: n/a
Properties:
module.description = "Create a client for each ConsoleKit session of this user"
Module #20
Argument:
Usage counter: n/a
Properties:
module.description = "Create a client for each login session of this user"
Module #21
Argument:
Usage counter: n/a
Properties:
module.description = "Position event sounds between L and R depending on the position on screen of the widget triggering them."
Module #22
Argument:
Usage counter: n/a
Properties:
module.description = "Mute & cork streams with certain roles while others exist"
Module #23
Argument:
Usage counter: n/a
Properties:
module.description = "Detect when various filters are desirable"
Module #24
Argument:
Usage counter: n/a
Properties:
module.description = "Load filter sinks automatically when needed"
Module #25
Argument:
Usage counter: n/a
Properties:
module.author = "Michael Terry"
module.description = "When a sink/source is added, switch to it or conditionally switch to it"
Module #26
Argument: display=:1
Usage counter: n/a
Properties:
module.description = "X11 credential publisher"
Module #27
Argument: display=:1 session_manager=local/HOST:@/tmp/.ICE-unix/1811,unix/HOST:/tmp/.ICE-unix/1811
Usage counter: n/a
Properties:
module.description = "X11 session management"
Sink #0
State: IDLE
Description: Built-in Audio Analog Stereo
Driver: module-alsa-card.c
Owner Module: 7
Mute: no
Volume: front-left: 50580 / 77% / -6.75 dB, front-right: 49145 / 75% / -7.50 dB
balance -0.03
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: alsa_output.pci-0000_00_1f.3.analog-stereo.monitor
Latency: 1237346 usec, configured 2000000 usec
Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "ALC1220 Analog"
alsa.id = "ALC1220 Analog"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0x54430000 irq 157"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "a348"
device.product.name = "Cannon Lake PCH cAVS"
device.string = "front:0"
device.buffering.buffer_size = "352800"
device.buffering.fragment_size = "176400"
device.access_mode = "mmap+timer"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Built-in Audio Analog Stereo"
alsa.mixer_name = "Realtek ALC1220"
alsa.components = "HDA:10ec1220,1458a0c3,00100101"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
Ports:
analog-output-lineout: Line Out (priority: 9000, available)
analog-output-headphones: Headphones (priority: 9900, not available)
Active Port: analog-output-lineout
Formats:
pcm
Source #0
State: IDLE
Description: Monitor of Built-in Audio Analog Stereo
Owner Module: 7
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Monitor of Sink: alsa_output.pci-0000_00_1f.3.analog-stereo
Latency: 0 usec, configured 2000000 usec
Flags: DECIBEL_VOLUME LATENCY
Properties:
device.description = "Monitor of Built-in Audio Analog Stereo"
device.class = "monitor"
alsa.card = "0"
device.bus = "pci"
device.string = "0"
Formats:
pcm
Client #0
Driver: module-systemd-login.c
Owner Module: 20
Properties:
application.name = "Login Session 3"
systemd-login.session = "3"
Client #3
Driver: module-x11-xsmp.c
Owner Module: 27
Properties:
application.name = "XSMP Session on gnome-session as 10c2fb613e21d62670160443902454087800000018110061"
xsmp.vendor = "gnome-session"
xsmp.client.id = "10c2fb613e21d62670160443902454087800000018110061"
Client #4
Driver: protocol-native.c
Owner Module: 13
Properties:
application.name = "GNOME Shell Volume Control"
native-protocol.peer = "UNIX socket client"
native-protocol.version = "33"
application.id = "org.gnome.VolumeControl"
application.icon_name = "multimedia-volume-control"
application.version = "3.36.6"
application.process.id = "1825"
application.process.user = "USER"
application.process.host = "HOST"
application.process.binary = "gnome-shell"
application.language = "en_GB.UTF-8"
window.x11.display = ":1"
application.process.machine_id = "b145b4c7a0224d46af830d851fa82f82"
Client #5
Owner Module: 13
Properties:
application.name = "GNOME Volume Control Media Keys"
application.version = ""
application.process.id = "1989"
application.process.binary = "gsd-media-keys"
Client #6
Owner Module: 13
Properties:
application.name = "gsd-power"
window.x11.screen = "0"
application.process.id = "1991"
application.process.binary = "gsd-power"
Client #8
Owner Module: 13
Properties:
application.name = "Chrome input"
application.process.id = "2132"
application.process.binary = "pcloud"
Client #11
Owner Module: 13
Properties:
application.name = "Mutter"
Client #12
Owner Module: 13
Properties:
application.name = "Thunderbird"
application.icon_name = "thunderbird"
application.version = "68.12.0"
application.process.id = "3469"
application.process.binary = "thunderbird"
Client #13
Owner Module: 13
Properties:
application.name = "Firefox"
application.process.id = "2408"
application.process.binary = "firefox"
application.icon_name = "firefox"
Client #17
Owner Module: 13
Properties:
application.name = "pactl"
application.process.id = "5339"
application.process.binary = "pactl"
application.language = "C"
Sample #0
Volume: (invalid)
balance 0.00
Duration: 0.1s
Lazy: no
Filename: n/a
Properties:
media.role = "event"
event.description = "Bell event"
event.id = "bell-window-system"
media.name = "bell-window-system"
media.filename = "/usr/share//sounds/freedesktop/stereo/bell.oga"
Card #0
Owner Module: 6
Properties:
alsa.card = "1"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0x54080000 irq 17"
device.bus_path = "pci-0000:01:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1"
device.bus = "pci"
device.vendor.id = "10de"
device.vendor.name = "NVIDIA Corporation"
device.product.id = "10f8"
device.product.name = "TU104 HD Audio Controller"
device.string = "1"
device.description = "TU104 HD Audio Controller"
Profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-stereo-extra5: Digital Stereo (HDMI 6) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra5: Digital Surround 5.1 (HDMI 6) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra5: Digital Surround 7.1 (HDMI 6) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-stereo-extra6: Digital Stereo (HDMI 7) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra6: Digital Surround 5.1 (HDMI 7) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra6: Digital Surround 7.1 (HDMI 7) Output (sinks: 1, sources: 0, priority: 600, available: no)
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
Active Profile: off
Ports:
hdmi-output-0: HDMI / DisplayPort (priority: 5900, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo, output:hdmi-surround, output:hdmi-surround71
hdmi-output-1: HDMI / DisplayPort 2 (priority: 5800, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra1, output:hdmi-surround-extra1, output:hdmi-surround71-extra1
hdmi-output-2: HDMI / DisplayPort 3 (priority: 5700, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-surround-extra2, output:hdmi-surround71-extra2
hdmi-output-3: HDMI / DisplayPort 4 (priority: 5600, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-surround-extra3, output:hdmi-surround71-extra3
hdmi-output-4: HDMI / DisplayPort 5 (priority: 5500, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra4, output:hdmi-surround-extra4, output:hdmi-surround71-extra4
hdmi-output-5: HDMI / DisplayPort 6 (priority: 5400, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra5, output:hdmi-surround-extra5, output:hdmi-surround71-extra5
hdmi-output-6: HDMI / DisplayPort 7 (priority: 5300, latency offset: 0 usec, not available)
Properties:
Part of profile(s): output:hdmi-stereo-extra6, output:hdmi-surround-extra6, output:hdmi-surround71-extra6
Card #1
Owner Module: 7
Properties:
alsa.card = "0"
device.bus = "pci"
device.string = "0"
device.description = "Built-in Audio"
Profiles:
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: no)
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: yes)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: no)
output:analog-surround-21: Analog Surround 2.1 Output (sinks: 1, sources: 0, priority: 1300, available: yes)
output:analog-surround-21+input:analog-stereo: Analog Surround 2.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
output:analog-surround-40: Analog Surround 4.0 Output (sinks: 1, sources: 0, priority: 1200, available: yes)
output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: no)
output:analog-surround-41: Analog Surround 4.1 Output (sinks: 1, sources: 0, priority: 1300, available: yes)
output:analog-surround-41+input:analog-stereo: Analog Surround 4.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
output:analog-surround-50: Analog Surround 5.0 Output (sinks: 1, sources: 0, priority: 1200, available: yes)
output:analog-surround-50+input:analog-stereo: Analog Surround 5.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: no)
output:analog-surround-51: Analog Surround 5.1 Output (sinks: 1, sources: 0, priority: 1300, available: yes)
output:analog-surround-51+input:analog-stereo: Analog Surround 5.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
output:iec958-stereo: Digital Stereo (IEC958) Output (sinks: 1, sources: 0, priority: 5500, available: yes)
output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5565, available: no)
Active Profile: output:analog-stereo
Ports:
analog-input-front-mic: Front Microphone (priority: 8500, latency offset: 0 usec, not available)
Properties:
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21+input:analog-stereo, output:analog-surround-40+input:analog-stereo, output:analog-surround-41+input:analog-stereo, output:analog-surround-50+input:analog-stereo, output:analog-surround-51+input:analog-stereo, output:iec958-stereo+input:analog-stereo
analog-input-rear-mic: Rear Microphone (priority: 8200, latency offset: 0 usec, not available)
Properties:
analog-input-linein: Line In (priority: 8100, latency offset: 0 usec, not available)
analog-output-lineout: Line Out (priority: 9000, latency offset: 0 usec, available)
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21, output:analog-surround-21+input:analog-stereo, output:analog-surround-40, output:analog-surround-40+input:analog-stereo, output:analog-surround-41, output:analog-surround-41+input:analog-stereo, output:analog-surround-50, output:analog-surround-50+input:analog-stereo, output:analog-surround-51, output:analog-surround-51+input:analog-stereo
analog-output-headphones: Headphones (priority: 9900, latency offset: 0 usec, not available)
Properties:
iec958-stereo-output: Digital Output (S/PDIF) (priority: 0, latency offset: 0 usec)
Part of profile(s): output:iec958-stereo, output:iec958-stereo+input:analog-stereo
________________
> cat /etc/pulse/daemon.conf
# This file is part of PulseAudio.
# PulseAudio is free software; you can redistribute it and/or modify
# it under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# PulseAudio is distributed in the hope that it will be useful, but
# WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# General Public License for more details.
# You should have received a copy of the GNU Lesser General Public License
# along with PulseAudio; if not, see <http://www.gnu.org/licenses/>.
## Configuration file for the PulseAudio daemon. See pulse-daemon.conf(5) for
## more information. Default values are commented out. Use either ; or # for
## commenting.
; daemonize = no
; fail = yes
; allow-module-loading = yes
; allow-exit = yes
; use-pid-file = yes
; system-instance = no
; local-server-type = user
; enable-shm = yes
; enable-memfd = yes
; shm-size-bytes = 0 # setting this 0 will use the system-default, usually 64 MiB
; lock-memory = no
; cpu-limit = no
; high-priority = yes
; nice-level = -11
; realtime-scheduling = yes
; realtime-priority = 5
; exit-idle-time = 20
; scache-idle-time = 20
; dl-search-path = (depends on architecture)
; load-default-script-file = yes
; default-script-file = /etc/pulse/default.pa
; log-target = auto
; log-level = notice
; log-meta = no
; log-time = no
; log-backtrace = 0
; resample-method = speex-float-1
; avoid-resampling = false
; enable-remixing = yes
; remixing-use-all-sink-channels = yes
; enable-lfe-remixing = no
; lfe-crossover-freq = 0
flat-volumes = no
; flat-volumes = yes
; rlimit-fsize = -1
; rlimit-data = -1
; rlimit-stack = -1
; rlimit-core = -1
; rlimit-as = -1
; rlimit-rss = -1
; rlimit-nproc = -1
; rlimit-nofile = 256
; rlimit-memlock = -1
; rlimit-locks = -1
; rlimit-sigpending = -1
; rlimit-msgqueue = -1
; rlimit-nice = 31
; rlimit-rtprio = 9
; rlimit-rttime = 200000
; default-sample-format = s16le
; default-sample-rate = 44100
; alternate-sample-rate = 48000
; default-sample-channels = 2
; default-channel-map = front-left,front-right
; default-fragments = 4
; default-fragment-size-msec = 25
; enable-deferred-volume = yes
; deferred-volume-safety-margin-usec = 8000
; deferred-volume-extra-delay-usec = 0
________________
> cat /etc/pulse/client.conf
## Configuration file for PulseAudio clients. See pulse-client.conf(5) for
## commenting.
; default-sink =
; default-source =
; default-server =
; default-dbus-server =
autospawn = no
; autospawn = yes
; daemon-binary = /usr/bin/pulseaudio
; extra-arguments = --log-target=syslog
; cookie-file =
; enable-shm = yes
; auto-connect-localhost = no
; auto-connect-display = no
________________
> cat /etc/pulse/default.pa
#!/usr/bin/pulseaudio -nF
# PulseAudio is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as published by
# This startup script is used only if PulseAudio is started per-user
# (i.e. not in system mode)
.fail
### Automatically restore the volume of streams and devices
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
### Automatically augment property information from .desktop files
### stored in /usr/share/application
load-module module-augment-properties
### Should be after module-*-restore but before module-*-detect
load-module module-switch-on-port-available
### Load audio drivers statically
### (it's probably better to not load these drivers manually, but instead
### use module-udev-detect -- see below -- for doing this automatically)
#load-module module-alsa-sink
#load-module module-alsa-source device=hw:1,0
#load-module module-oss device="/dev/dsp" sink_name=output source_name=input
#load-module module-oss-mmap device="/dev/dsp" sink_name=output source_name=input
#load-module module-null-sink
#load-module module-pipe-sink
### Automatically load driver modules depending on the hardware available
.ifexists module-udev-detect.so
load-module module-udev-detect
.else
### Use the static hardware detection module (for systems that lack udev support)
load-module module-detect
.endif
### Automatically connect sink and source if JACK server is present
.ifexists module-jackdbus-detect.so
.nofail
load-module module-jackdbus-detect channels=2
.fail
.endif
### Automatically load driver modules for Bluetooth hardware
#.ifexists module-bluetooth-policy.so
load-module module-bluetooth-policy
#.endif
#.ifexists module-bluetooth-discover.so
load-module module-bluetooth-discover
#.endif
### Load several protocols
load-module module-dbus-protocol
.ifexists module-esound-protocol-unix.so
load-module module-esound-protocol-unix
.endif
load-module module-native-protocol-unix
### Network access (may be configured with paprefs, so leave this commented
### here if you plan to use paprefs)
#load-module module-esound-protocol-tcp
#load-module module-native-protocol-tcp
#load-module module-zeroconf-publish
### Load the RTP receiver module (also configured via paprefs, see above)
#load-module module-rtp-recv
### Load the RTP sender module (also configured via paprefs, see above)
#load-module module-null-sink sink_name=rtp format=s16be channels=2 rate=44100 sink_properties="device.description='RTP Multicast Sink'"
#load-module module-rtp-send source=rtp.monitor
### Load additional modules from GSettings. This can be configured with the paprefs tool.
### Please keep in mind that the modules configured by paprefs might conflict with manually
### loaded modules.
.ifexists module-gsettings.so
.nofail
load-module module-gsettings
.fail
.endif
### Automatically restore the default sink/source when changed by the user
### during runtime
### NOTE: This should be loaded as early as possible so that subsequent modules
### that look up the default sink/source get the right value
load-module module-default-device-restore
### Automatically move streams to the default sink if the sink they are
### connected to dies, similar for sources
load-module module-rescue-streams
### Make sure we always have a sink around, even if it is a null sink.
load-module module-always-sink
### Honour intended role device property
load-module module-intended-roles
### Automatically suspend sinks/sources that become idle for too long
# load-module module-suspend-on-idle
### If autoexit on idle is enabled we want to make sure we only quit
### when no local session needs us anymore.
.ifexists module-console-kit.so
load-module module-console-kit
.endif
.ifexists module-systemd-login.so
load-module module-systemd-login
.endif
### Enable positioned event sounds
load-module module-position-event-sounds
### Cork music/video streams when a phone stream is active
load-module module-role-cork
### Modules to allow autoloading of filters (such as echo cancellation)
### on demand. module-filter-heuristics tries to determine what filters
### make sense, and module-filter-apply does the heavy-lifting of
### loading modules and rerouting streams.
load-module module-filter-heuristics
load-module module-filter-apply
### Make some devices default
#set-default-sink output
#set-default-source input
# Automatically switch to newly-connected devices
load-module module-switch-on-connect
# or switch also to newly-connected virtual devices
load-module module-switch-on-connect ignore_virtual=no
________________
> cat /etc/pulse/system.pa
# This startup script is used only if PulseAudio is started in system
# mode.
.else
### Use the static hardware detection module (for systems that lack udev/hal support)
.endif
.endif
### during runtime
________________
> ls -alt /dev/snd/*
crw-rw----+ 1 root audio 116, 13 Nov 3 22:30 /dev/snd/pcmC0D1p
crw-rw----+ 1 root audio 116, 1 Nov 3 22:30 /dev/snd/seq
crw-rw----+ 1 root audio 116, 12 Nov 3 22:30 /dev/snd/pcmC0D0c
crw-rw----+ 1 root audio 116, 8 Nov 3 22:30 /dev/snd/pcmC1D12p
crw-rw----+ 1 root audio 116, 7 Nov 3 22:30 /dev/snd/pcmC1D11p
crw-rw----+ 1 root audio 116, 6 Nov 3 22:30 /dev/snd/pcmC1D10p
crw-rw----+ 1 root audio 116, 5 Nov 3 22:30 /dev/snd/pcmC1D9p
crw-rw----+ 1 root audio 116, 4 Nov 3 22:30 /dev/snd/pcmC1D8p
crw-rw----+ 1 root audio 116, 3 Nov 3 22:30 /dev/snd/pcmC1D7p
crw-rw----+ 1 root audio 116, 2 Nov 3 22:30 /dev/snd/pcmC1D3p
crw-rw----+ 1 root audio 116, 11 Nov 3 22:30 /dev/snd/pcmC0D0p
crw-rw----+ 1 root audio 116, 16 Nov 3 22:30 /dev/snd/controlC0
crw-rw----+ 1 root audio 116, 15 Nov 3 22:30 /dev/snd/hwC0D0
crw-rw----+ 1 root audio 116, 14 Nov 3 22:30 /dev/snd/pcmC0D2c
crw-rw----+ 1 root audio 116, 10 Nov 3 22:30 /dev/snd/controlC1
crw-rw----+ 1 root audio 116, 9 Nov 3 22:30 /dev/snd/hwC1D0
crw-rw----+ 1 root audio 116, 33 Nov 3 22:30 /dev/snd/timer
/dev/snd/by-path:
total 0
drwxr-xr-x 2 root root 80 Nov 3 22:30 .
lrwxrwxrwx 1 root root 12 Nov 3 22:30 pci-0000:00:1f.3 -> ../controlC0
drwxr-xr-x 3 root root 400 Nov 3 22:30 ..
lrwxrwxrwx 1 root root 12 Nov 3 22:30 pci-0000:01:00.1 -> ../controlC1
________________
> lsof /dev/snd/*
/usr/bin/pa-info: line 56: lsof: command not found
________________
> jacks_do
card=0
numid=41,iface=CARD,name='Front Headphone Jack'
; type=BOOLEAN,access=r-------,values=1
: values=off
numid=35,iface=CARD,name='Front Mic Jack'
: values=off
numid=37,iface=CARD,name='Line Jack'
: values=off
numid=40,iface=CARD,name='Line Out CLFE Jack'
: values=off
numid=38,iface=CARD,name='Line Out Front Jack'
: values=on
numid=39,iface=CARD,name='Line Out Surround Jack'
: values=off
numid=36,iface=CARD,name='Rear Mic Jack'
: values=off
numid=42,iface=CARD,name='SPDIF Phantom Jack'
: values=on
card=1
numid=25,iface=CARD,name='HDMI/DP,pcm=10 Jack'
: values=off
numid=31,iface=CARD,name='HDMI/DP,pcm=11 Jack'
: values=off
numid=37,iface=CARD,name='HDMI/DP,pcm=12 Jack'
: values=off
numid=1,iface=CARD,name='HDMI/DP,pcm=3 Jack'
: values=off
numid=7,iface=CARD,name='HDMI/DP,pcm=7 Jack'
: values=off
numid=13,iface=CARD,name='HDMI/DP,pcm=8 Jack'
: values=off
numid=19,iface=CARD,name='HDMI/DP,pcm=9 Jack'
: values=off
________________
> aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pipewire
PipeWire Sound Server
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PulseAudio Sound Server)
sysdefault:CARD=PCH
HDA Intel PCH, ALC1220 Analog
Default Audio Device
front:CARD=PCH,DEV=0
Front output / input
surround21:CARD=PCH,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=PCH,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=PCH,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=PCH,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=PCH,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=PCH,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=PCH,DEV=0
HDA Intel PCH, ALC1220 Digital
IEC958 (S/PDIF) Digital Audio Output
usbstream:CARD=PCH
HDA Intel PCH
USB Stream Output
hdmi:CARD=NVidia,DEV=0
HDA NVidia, HDMI 0
HDMI Audio Output
hdmi:CARD=NVidia,DEV=1
HDA NVidia, HDMI 1
HDMI Audio Output
hdmi:CARD=NVidia,DEV=2
HDA NVidia, HDMI 2
HDMI Audio Output
hdmi:CARD=NVidia,DEV=3
HDA NVidia, HDMI 3
HDMI Audio Output
hdmi:CARD=NVidia,DEV=4
HDA NVidia, HDMI 4
HDMI Audio Output
hdmi:CARD=NVidia,DEV=5
HDA NVidia, HDMI 5
HDMI Audio Output
hdmi:CARD=NVidia,DEV=6
HDA NVidia, HDMI 6
HDMI Audio Output
usbstream:CARD=NVidia
HDA NVidia
USB Stream Output
________________
> arecord -L
null
samplerate
speexrate
jack
oss
Open Sound System
pipewire
pulse
speex
upmix
vdownmix
default
sysdefault:CARD=PCH
usbstream:CARD=PCH
HDA Intel PCH
USB Stream Output
HDA NVidia
USB Stream Output
________________
> alsa_info_do
dmesg: read kernel buffer failed: Operation not permitted
upload=true&script=true&cardinfo=
!!ALSA Information Script v 0.4.65
!!Script ran on: Tue Nov 3 21:50:26 UTC 2020
!!Linux Distribution
ID_LIKE=arch
!!DMI Information
Manufacturer: Gigabyte Technology Co., Ltd.
Product Name: Z390 AORUS PRO
Product Version: Default string
Firmware Version: F11
Board Vendor: Gigabyte Technology Co., Ltd.
Board Name: Z390 AORUS PRO-CF
!!ACPI Device Status Information
/sys/bus/acpi/devices/ACPI000C:00/status 15
/sys/bus/acpi/devices/INT33A1:00/status 15
/sys/bus/acpi/devices/INT340E:00/status 15
/sys/bus/acpi/devices/INT3450:00/status 15
/sys/bus/acpi/devices/INT3F0D:00/status 15
/sys/bus/acpi/devices/LNXPOWER:00/status 15
/sys/bus/acpi/devices/LNXPOWER:01/status 1
/sys/bus/acpi/devices/LNXPOWER:02/status 1
/sys/bus/acpi/devices/LNXPOWER:03/status 1
/sys/bus/acpi/devices/LNXPOWER:04/status 1
/sys/bus/acpi/devices/PNP0103:00/status 15
/sys/bus/acpi/devices/PNP0C02:03/status 3
/sys/bus/acpi/devices/PNP0C02:05/status 3
/sys/bus/acpi/devices/PNP0C04:00/status 31
/sys/bus/acpi/devices/PNP0C0C:00/status 15
/sys/bus/acpi/devices/PNP0C0E:00/status 11
/sys/bus/acpi/devices/PNP0C0F:00/status 11
/sys/bus/acpi/devices/PNP0C0F:01/status 11
/sys/bus/acpi/devices/PNP0C0F:02/status 11
/sys/bus/acpi/devices/PNP0C0F:03/status 11
/sys/bus/acpi/devices/PNP0C0F:04/status 11
/sys/bus/acpi/devices/PNP0C0F:05/status 11
/sys/bus/acpi/devices/PNP0C0F:06/status 11
/sys/bus/acpi/devices/PNP0C0F:07/status 11
/sys/bus/acpi/devices/PNP0C14:04/status 11
/sys/bus/acpi/devices/PRP00001:00/status 11
!!Kernel Information
Kernel release: 5.9.1-1-MANJARO
Operating System: GNU/Linux
Architecture: x86_64
Processor: unknown
SMP Enabled: Yes
!!ALSA Version
Driver version: k5.9.1-1-MANJARO
Library version: 1.2.3.2
Utilities version: 1.2.3
!!Loaded ALSA modules
snd_hda_intel
snd_hda_intel
!!Sound Servers on this system
Pulseaudio:
Installed - Yes (/usr/bin/pulseaudio)
Running - Yes
Jack:
Installed - Yes (/usr/bin/jackd)
Running - No
!!Soundcards recognised by ALSA
0 [PCH ]: HDA-Intel - HDA Intel PCH
1 [NVidia ]: HDA-Intel - HDA NVidia
!!PCI Soundcards installed in the system
00:1f.3 Audio device [0403]: Intel Corporation Cannon Lake PCH cAVS [8086:a348] (rev 10)
DeviceName: Onboard - Sound
01:00.1 Audio device [0403]: NVIDIA Corporation TU104 HD Audio Controller [10de:10f8] (rev a1)
Subsystem: Gigabyte Technology Co., Ltd Device [1458:37c1]
!!Loaded sound module options
!!Module: snd_hda_intel
align_buffer_size : -1
bdl_pos_adj : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
beep_mode : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
dmic_detect : Y
enable : Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y,Y
enable_msi : -1
id : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
index : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
jackpoll_ms : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
model : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
patch : (null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null),(null)
pm_blacklist : Y
position_fix : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
power_save : 1
power_save_controller : Y
probe_mask : -1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1,-1
probe_only : 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
single_cmd : -1
snoop : -1
dmic_detect : Y
enable_msi : -1
pm_blacklist : Y
power_save : 1
single_cmd : -1
snoop : -1
!!HDA-Intel Codec information
--startcollapse--
Codec: Realtek ALC1220
Address: 0
AFG Function Id: 0x1 (unsol 1)
Vendor Id: 0x10ec1220
Subsystem Id: 0x1458a0c3
Revision Id: 0x100101
No Modem Function Group found
Default PCM:
rates [0x5f0]: 32000 44100 48000 88200 96000 192000
bits [0xe]: 16 20 24
formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
State of AFG node 0x01:
Power states: D0 D1 D2 D3 D3cold CLKSTOP EPSS
Power: setting=D0, actual=D0
GPIO: io=8, o=0, i=0, unsolicited=1, wake=0
IO[0]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[1]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[2]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[3]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[4]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[5]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[6]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
IO[7]: enable=0, dir=0, wake=0, sticky=0, data=0, unsol=0
Node 0x02 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Front Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=Out, idx=0, ofs=0
Device: name="ALC1220 Analog", type="Audio", device=0
Amp-Out caps: ofs=0x57, nsteps=0x57, stepsize=0x02, mute=0
Amp-Out vals: [0x4e 0x4d]
Converter: stream=1, channel=0
PCM:
rates [0x7e0]: 44100 48000 88200 96000 176400 192000
bits [0x1e]: 16 20 24 32
formats [0x1]: PCM
Power states: D0 D1 D2 D3 EPSS
Node 0x03 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Surround Playback Volume", index=0, device=0
Amp-Out vals: [0x4e 0x4e]
PCM:
formats [0x1]: PCM
Node 0x04 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Center Playback Volume", index=0, device=0
ControlAmp: chs=1, dir=Out, idx=0, ofs=0
Control: name="LFE Playback Volume", index=0, device=0
ControlAmp: chs=2, dir=Out, idx=0, ofs=0
PCM:
formats [0x1]: PCM
Node 0x05 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Control: name="Headphone Playback Volume", index=0, device=0
Amp-Out vals: [0x00 0x00]
PCM:
formats [0x1]: PCM
Node 0x06 [Audio Output] wcaps 0x611: Stereo Digital
Control: name="IEC958 Playback Con Mask", index=0, device=0
Control: name="IEC958 Playback Pro Mask", index=0, device=0
Control: name="IEC958 Playback Default", index=0, device=0
Control: name="IEC958 Playback Switch", index=0, device=0
Control: name="IEC958 Default PCM Playback Switch", index=0, device=0
Device: name="ALC1220 Digital", type="SPDIF", device=1
Converter: stream=2, channel=0
Digital:
Digital category: 0x0
IEC Coding Type: 0x0
PCM:
formats [0x1]: PCM
Node 0x07 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x08 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=0, ofs=0
Control: name="Capture Switch", index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x3f, stepsize=0x02, mute=1
Amp-In vals: [0x27 0x27]
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x23
Node 0x09 [Audio Input] wcaps 0x10051b: Stereo Amp-In
Control: name="Capture Volume", index=1, device=0
Control: name="Capture Switch", index=1, device=0
Device: name="ALC1220 Alt Analog", type="Audio", device=2
Amp-In vals: [0x80 0x80]
Converter: stream=0, channel=0
SDI-Select: 0
PCM:
formats [0x1]: PCM
Connection: 1
0x22
Node 0x0a [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x0b [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Control: name="Front Mic Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=1, ofs=0
Control: name="Front Mic Playback Switch", index=0, device=0
Control: name="Rear Mic Playback Volume", index=0, device=0
Control: name="Rear Mic Playback Switch", index=0, device=0
Control: name="Line Playback Volume", index=0, device=0
ControlAmp: chs=3, dir=In, idx=2, ofs=0
Control: name="Line Playback Switch", index=0, device=0
Amp-In caps: ofs=0x17, nsteps=0x1f, stepsize=0x05, mute=1
Amp-In vals: [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 8
0x18 0x19 0x1a 0x1b 0x1d 0x15 0x16 0x17
Node 0x0c [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Amp-In vals: [0x00 0x00] [0x80 0x80]
Connection: 2
0x02 0x0b
Node 0x0d [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x03 0x0b
Node 0x0e [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x04 0x0b
Node 0x0f [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x05 0x0b
Node 0x10 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x11 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x12 [Pin Complex] wcaps 0x40040b: Stereo Amp-In
Amp-In caps: ofs=0x00, nsteps=0x03, stepsize=0x27, mute=0
Pincap 0x00000020: IN
Pin Default 0x411111f0: [N/A] Speaker at Ext Rear
Conn = 1/8, Color = Black
DefAssociation = 0xf, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x00:
Node 0x13 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x14 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Front Playback Switch", index=0, device=0
Amp-Out caps: ofs=0x00, nsteps=0x00, stepsize=0x00, mute=1
Pincap 0x0001001c: OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x01014010: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Green
DefAssociation = 0x1, Sequence = 0x0
Pin-ctls: 0x40: OUT
Unsolicited: tag=05, enabled=1
Connection: 1
0x0c
Node 0x15 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Surround Playback Switch", index=0, device=0
Pincap 0x00000034: IN OUT Detect
Pin Default 0x01011012: [Jack] Line Out at Ext Rear
DefAssociation = 0x1, Sequence = 0x2
Pin-ctls: 0x40: OUT
Unsolicited: tag=06, enabled=1
Connection: 1
0x0d
Node 0x16 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Control: name="Center Playback Switch", index=0, device=0
Control: name="LFE Playback Switch", index=0, device=0
Pin Default 0x01016011: [Jack] Line Out at Ext Rear
Conn = 1/8, Color = Orange
DefAssociation = 0x1, Sequence = 0x1
Pin-ctls: 0x40: OUT
Unsolicited: tag=07, enabled=1
Connection: 1
0x0e
Node 0x17 [Pin Complex] wcaps 0x40058d: Stereo Amp-Out
Amp-Out vals: [0x80 0x80]
Pin Default 0x403fc500: [N/A] CD at Ext N/A
Conn = Other, Color = UNKNOWN
DefAssociation = 0x0, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x20: IN
Unsolicited: tag=00, enabled=0
Connection: 1
0x0f
Node 0x18 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Rear Mic Boost Volume", index=0, device=0
Pincap 0x00003734: IN OUT Detect
Vref caps: HIZ 50 GRD 80 100
Pin Default 0x01a19040: [Jack] Mic at Ext Rear
Conn = 1/8, Color = Pink
DefAssociation = 0x4, Sequence = 0x0
Pin-ctls: 0x24: IN VREF_80
Unsolicited: tag=03, enabled=1
Connection: 5
0x0c* 0x0d 0x0e 0x0f 0x26
Node 0x19 [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Front Mic Boost Volume", index=0, device=0
Pincap 0x0000373c: IN OUT HP Detect
Pin Default 0x02a19050: [Jack] Mic at Ext Front
DefAssociation = 0x5, Sequence = 0x0
Unsolicited: tag=02, enabled=1
Connection: 5
Node 0x1a [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Line Boost Volume", index=0, device=0
Pin Default 0x0181304f: [Jack] Line In at Ext Rear
Conn = 1/8, Color = Blue
DefAssociation = 0x4, Sequence = 0xf
Pin-ctls: 0x20: IN VREF_HIZ
Unsolicited: tag=04, enabled=1
Connection: 5
Node 0x1b [Pin Complex] wcaps 0x40058f: Stereo Amp-In Amp-Out
Control: name="Headphone Playback Switch", index=0, device=0
Pincap 0x0001373c: IN OUT HP EAPD Detect
EAPD 0x2: EAPD
Pin Default 0x02214020: [Jack] HP Out at Ext Front
DefAssociation = 0x2, Sequence = 0x0
Pin-ctls: 0xc0: OUT HP VREF_HIZ
Unsolicited: tag=01, enabled=1
Connection: 5
0x0c 0x0d 0x0e 0x0f* 0x26
Node 0x1c [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x1d [Pin Complex] wcaps 0x400400: Mono
Pin Default 0x40e8e669: [N/A] Reserved at Ext N/A
Conn = DIN, Color = White
DefAssociation = 0x6, Sequence = 0x9
Pin-ctls: 0x20: IN
Node 0x1e [Pin Complex] wcaps 0x400781: Stereo Digital
Pincap 0x00000010: OUT
Pin Default 0x01452130: [Jack] SPDIF Out at Ext Rear
Conn = Optical, Color = Grey
DefAssociation = 0x3, Sequence = 0x0
Misc = NO_PRESENCE
Pin-ctls: 0x40: OUT
Connection: 1
0x06
Node 0x1f [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x20 [Vendor Defined Widget] wcaps 0xf00040: Mono
Processing caps: benign=0, ncoeff=127
Node 0x21 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x22 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Amp-In vals: [0x80 0x80] [0x00 0x00] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80] [0x80 0x80]
Connection: 10
0x18 0x19 0x1a 0x1b 0x1d 0x15 0x16 0x17 0x12 0x0b
Node 0x23 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 10
Node 0x24 [Vendor Defined Widget] wcaps 0xf00000: Mono
Node 0x25 [Audio Output] wcaps 0x41d: Stereo Amp-Out
Amp-Out vals: [0x57 0x57]
PCM:
formats [0x1]: PCM
Node 0x26 [Audio Mixer] wcaps 0x20010b: Stereo Amp-In
Connection: 2
0x25 0x0b
Codec: Nvidia GPU 92 HDMI/DP
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x10de0092
Subsystem Id: 0x145837c1
Revision Id: 0x100100
Default PCM:
rates [0x0]:
bits [0x0]:
formats [0x0]:
Power states: D0 D1 D2 D3 CLKSTOP EPSS
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x04 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pincap 0x09000094: OUT Detect HBR HDMI DP
Pin Default 0x185600f0: [Jack] Digital Out at Int HDMI
Conn = Digital, Color = Unknown
Pin-ctls: 0x00:
Devices: 4
Dev 00: PD = 0, ELDV = 0, IA = 0
Dev 01: PD = 0, ELDV = 0, IA = 0
Dev 02: PD = 0, ELDV = 0, IA = 0
*Dev 03: PD = 0, ELDV = 0, IA = 0
Connection: 4
0x08* 0x09 0x0a 0x0b
Node 0x05 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Devices: 4
Connection: 4
Node 0x06 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Unsolicited: tag=09, enabled=1
Devices: 4
Connection: 4
Node 0x07 [Pin Complex] wcaps 0x407381: 8-Channels Digital CP
Pin-ctls: 0x00:
Unsolicited: tag=0d, enabled=1
Devices: 4
Connection: 4
Node 0x08 [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
rates [0x7f0]: 32000 44100 48000 88200 96000 176400 192000
formats [0x5]: PCM AC3
Node 0x09 [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x0a [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
Node 0x0b [Audio Output] wcaps 0x62b1: 8-Channels Digital Stripe
Digital:
PCM:
--endcollapse--
!!ALSA Device nodes
/dev/snd/by-path:
total 0
!!Aplay/Arecord output
APLAY
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC1220 Analog [ALC1220 Analog]
Subdevices: 0/1
Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 1: ALC1220 Digital [ALC1220 Digital]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
card 1: NVidia [HDA NVidia], device 12: HDMI 6 [HDMI 6]
Subdevices: 1/1
ARECORD
**** List of CAPTURE Hardware Devices ****
Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 2: ALC1220 Alt Analog [ALC1220 Alt Analog]
Subdevices: 1/1
!!Amixer output
!!-------Mixer controls for card PCH
Card hw:0 'PCH'/'HDA Intel PCH at 0x54430000 irq 157'
Mixer name : 'Realtek ALC1220'
Components : 'HDA:10ec1220,1458a0c3,00100101'
Controls : 47
Simple ctrls : 21
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 87
Mono: Playback 78 [90%] [-6.75dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 0 [0%] [-65.25dB] [off]
Front Right: Playback 0 [0%] [-65.25dB] [off]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Front',0
Mono:
Front Left: Playback 87 [100%] [0.00dB] [on]
Front Right: Playback 86 [99%] [-0.75dB] [on]
Simple mixer control 'Front Mic',0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 0 [0%] [-34.50dB] [off]
Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Front Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'Surround',0
Mono:
Front Right: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'Center',0
Mono: Playback 87 [100%] [0.00dB] [on]
Simple mixer control 'LFE',0
Simple mixer control 'Line',0
Mono:
Simple mixer control 'Line Boost',0
Limits: 0 - 3
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control 'IEC958 Default PCM',0
Mono: Playback [on]
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 63
Front Left: Capture 39 [62%] [12.00dB] [on]
Front Right: Capture 39 [62%] [12.00dB] [on]
Simple mixer control 'Capture',1
Front Left: Capture 0 [0%] [-17.25dB] [off]
Front Right: Capture 0 [0%] [-17.25dB] [off]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Enabled'
Simple mixer control 'Input Source',0
Capabilities: cenum
Items: 'Front Mic' 'Rear Mic' 'Line'
Item0: 'Front Mic'
Simple mixer control 'Input Source',1
Capabilities: cenum
Item0: 'Front Mic'
Simple mixer control 'Loopback Mixing',0
Capabilities: enum
Item0: 'Disabled'
Simple mixer control 'Rear Mic',0
Mono:
Simple mixer control 'Rear Mic Boost',0
Limits: 0 - 3
!!-------Mixer controls for card NVidia
Card hw:1 'NVidia'/'HDA NVidia at 0x54080000 irq 17'
Mixer name : 'Nvidia GPU 92 HDMI/DP'
Components : 'HDA:10de0092,145837c1,00100100'
Controls : 49
Simple ctrls : 7
Mono: Playback [on]
Simple mixer control 'IEC958',1
Mono: Playback [on]
Simple mixer control 'IEC958',2
Mono: Playback [on]
Simple mixer control 'IEC958',3
Mono: Playback [on]
Simple mixer control 'IEC958',4
Mono: Playback [on]
Simple mixer control 'IEC958',5
Mono: Playback [on]
Simple mixer control 'IEC958',6
Mono: Playback [on]
!!Alsactl output
--startcollapse--
state.PCH {
control.1 {
iface MIXER
name 'Front Playback Volume'
value.0 87
value.1 86
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 -75
control.2 {
iface MIXER
name 'Front Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.3 {
iface MIXER
name 'Surround Playback Volume'
value.0 87
value.1 87
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
dbvalue.1 0
control.4 {
iface MIXER
name 'Surround Playback Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.5 {
iface MIXER
name 'Center Playback Volume'
value 87
comment {
access 'read write'
type INTEGER
count 1
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
control.6 {
iface MIXER
name 'LFE Playback Volume'
value 87
comment {
access 'read write'
type INTEGER
count 1
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 0
control.7 {
iface MIXER
name 'Center Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.8 {
iface MIXER
name 'LFE Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.9 {
iface MIXER
name 'Headphone Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -6525
dbvalue.1 -6525
control.10 {
iface MIXER
name 'Headphone Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.11 {
iface MIXER
name 'Loopback Mixing'
value Disabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.12 {
iface MIXER
name 'Front Mic Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.13 {
iface MIXER
name 'Front Mic Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.14 {
iface MIXER
name 'Rear Mic Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.15 {
iface MIXER
name 'Rear Mic Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.16 {
iface MIXER
name 'Line Playback Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 31'
dbmin -3450
dbmax 1200
dbvalue.0 -3450
dbvalue.1 -3450
control.17 {
iface MIXER
name 'Line Playback Switch'
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.18 {
iface MIXER
name 'Auto-Mute Mode'
value Enabled
comment {
access 'read write'
type ENUMERATED
count 1
item.0 Disabled
item.1 Enabled
control.19 {
iface MIXER
name 'Input Source'
value 'Front Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Front Mic'
item.1 'Rear Mic'
item.2 Line
control.20 {
iface MIXER
name 'Input Source'
index 1
value 'Front Mic'
comment {
access 'read write'
type ENUMERATED
count 1
item.0 'Front Mic'
item.1 'Rear Mic'
item.2 Line
control.21 {
iface MIXER
name 'Capture Volume'
value.0 39
value.1 39
comment {
access 'read write'
type INTEGER
count 2
range '0 - 63'
dbmin -1725
dbmax 3000
dbvalue.0 1200
dbvalue.1 1200
control.22 {
iface MIXER
name 'Capture Switch'
value.0 true
value.1 true
comment {
access 'read write'
type BOOLEAN
count 2
control.23 {
iface MIXER
index 1
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 63'
dbmin -1725
dbmax 3000
dbvalue.0 -1725
dbvalue.1 -1725
control.24 {
iface MIXER
index 1
value.0 false
value.1 false
comment {
access 'read write'
type BOOLEAN
count 2
control.25 {
iface MIXER
name 'Front Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.26 {
iface MIXER
name 'Rear Mic Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.27 {
iface MIXER
name 'Line Boost Volume'
value.0 0
value.1 0
comment {
access 'read write'
type INTEGER
count 2
range '0 - 3'
dbmin 0
dbmax 3000
dbvalue.0 0
dbvalue.1 0
control.28 {
iface MIXER
name 'IEC958 Playback Con Mask'
value '0fff000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.29 {
iface MIXER
name 'IEC958 Playback Pro Mask'
value '0f00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access read
type IEC958
count 1
control.30 {
iface MIXER
name 'IEC958 Playback Default'
value '0400000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000'
comment {
access 'read write'
type IEC958
count 1
control.31 {
iface MIXER
name 'IEC958 Playback Switch'
value false
comment {
access 'read write'
type BOOLEAN
count 1
control.32 {
iface MIXER
name 'IEC958 Default PCM Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.33 {
iface MIXER
name 'Master Playback Volume'
value 78
comment {
access 'read write'
type INTEGER
count 1
range '0 - 87'
dbmin -6525
dbmax 0
dbvalue.0 -675
control.34 {
iface MIXER
name 'Master Playback Switch'
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.35 {
iface CARD
name 'Front Mic Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.36 {
iface CARD
name 'Rear Mic Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.37 {
iface CARD
name 'Line Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.38 {
iface CARD
name 'Line Out Front Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.39 {
iface CARD
name 'Line Out Surround Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.40 {
iface CARD
name 'Line Out CLFE Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.41 {
iface CARD
name 'Front Headphone Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.42 {
iface CARD
name 'SPDIF Phantom Jack'
value true
comment {
access read
type BOOLEAN
count 1
control.43 {
iface PCM
name 'Playback Channel Map'
value.0 3
value.1 4
value.2 0
value.3 0
value.4 0
value.5 0
comment {
access read
type INTEGER
count 6
range '0 - 36'
control.44 {
iface PCM
name 'Capture Channel Map'
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.45 {
iface PCM
device 1
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.46 {
iface PCM
device 2
value.0 0
value.1 0
comment {
access read
type INTEGER
count 2
range '0 - 36'
control.47 {
iface MIXER
name 'PCM Playback Volume'
value.0 255
value.1 255
comment {
access 'read write user'
type INTEGER
count 2
range '0 - 255'
tlv '0000000100000008ffffec1400000014'
dbmin -5100
dbmax 0
dbvalue.0 0
dbvalue.1 0
state.NVidia {
control.1 {
iface CARD
name 'HDMI/DP,pcm=3 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.2 {
iface MIXER
comment {
access read
type IEC958
count 1
control.3 {
iface MIXER
comment {
access read
type IEC958
count 1
control.4 {
iface MIXER
comment {
access 'read write'
type IEC958
count 1
control.5 {
iface MIXER
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.6 {
iface PCM
device 3
name ELD
value ''
comment {
access 'read volatile'
type BYTES
count 0
control.7 {
iface CARD
name 'HDMI/DP,pcm=7 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.8 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.9 {
iface MIXER
index 1
comment {
access read
type IEC958
count 1
control.10 {
iface MIXER
index 1
comment {
access 'read write'
type IEC958
count 1
control.11 {
iface MIXER
index 1
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.12 {
iface PCM
device 7
name ELD
value ''
comment {
type BYTES
count 0
control.13 {
iface CARD
name 'HDMI/DP,pcm=8 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.14 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.15 {
iface MIXER
index 2
comment {
access read
type IEC958
count 1
control.16 {
iface MIXER
index 2
comment {
access 'read write'
type IEC958
count 1
control.17 {
iface MIXER
index 2
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.18 {
iface PCM
device 8
name ELD
value ''
comment {
type BYTES
count 0
control.19 {
iface CARD
name 'HDMI/DP,pcm=9 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.20 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.21 {
iface MIXER
index 3
comment {
access read
type IEC958
count 1
control.22 {
iface MIXER
index 3
comment {
access 'read write'
type IEC958
count 1
control.23 {
iface MIXER
index 3
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.24 {
iface PCM
device 9
name ELD
value ''
comment {
type BYTES
count 0
control.25 {
iface CARD
name 'HDMI/DP,pcm=10 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.26 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.27 {
iface MIXER
index 4
comment {
access read
type IEC958
count 1
control.28 {
iface MIXER
index 4
comment {
access 'read write'
type IEC958
count 1
control.29 {
iface MIXER
index 4
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.30 {
iface PCM
device 10
name ELD
value ''
comment {
type BYTES
count 0
control.31 {
iface CARD
name 'HDMI/DP,pcm=11 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.32 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.33 {
iface MIXER
index 5
comment {
access read
type IEC958
count 1
control.34 {
iface MIXER
index 5
comment {
access 'read write'
type IEC958
count 1
control.35 {
iface MIXER
index 5
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.36 {
iface PCM
device 11
name ELD
value ''
comment {
type BYTES
count 0
control.37 {
iface CARD
name 'HDMI/DP,pcm=12 Jack'
value false
comment {
access read
type BOOLEAN
count 1
control.38 {
iface MIXER
index 6
comment {
access read
type IEC958
count 1
control.39 {
iface MIXER
index 6
comment {
access read
type IEC958
count 1
control.40 {
iface MIXER
index 6
comment {
access 'read write'
type IEC958
count 1
control.41 {
iface MIXER
index 6
value true
comment {
access 'read write'
type BOOLEAN
count 1
control.42 {
iface PCM
device 12
name ELD
value ''
comment {
type BYTES
count 0
control.43 {
iface PCM
device 3
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.44 {
iface PCM
device 7
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.45 {
iface PCM
device 8
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.46 {
iface PCM
device 9
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.47 {
iface PCM
device 10
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.48 {
iface PCM
device 11
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
control.49 {
iface PCM
device 12
value.0 0
value.1 0
value.2 0
value.3 0
value.4 0
value.5 0
value.6 0
value.7 0
comment {
access 'read write'
type INTEGER
count 8
range '0 - 36'
--endcollapse--
!!All Loaded Modules
ac97_bus
aesni_intel
af_alg
agpgart
algif_hash
algif_skcipher
bluetooth
bnep
btbcm
btintel
btrtl
btusb
cec
cmac
cmdlinepart
coretemp
crc16
crc32_pclmul
crc32c_generic
crc32c_intel
crct10dif_pclmul
cryptd
crypto_simd
crypto_user
drm
drm_kms_helper
e1000e
ecc
ecdh_generic
ee1004
evdev
ext4
fat
fb_sys_fops
fuse
ghash_clmulni_intel
glue_helper
hid
hid_generic
hid_logitech_dj
hid_logitech_hidpp
i2c_i801
i2c_nvidia_gpu
i2c_smbus
iTCO_vendor_support
iTCO_wdt
input_leds
intel_cstate
intel_pch_thermal
intel_pmc_bxt
intel_powerclamp
intel_rapl_common
intel_rapl_msr
intel_spi
intel_spi_pci
intel_uncore
intel_wmi_thunderbolt
ip_tables
irqbypass
jbd2
joydev
kvm
kvm_intel
ledtrig_audio
loop
mac_hid
mbcache
mei
mei_hdcp
mei_me
mousedev
mtd
mxm_wmi
nls_cp437
nls_iso8859_1
nvidia
nvidia_drm
nvidia_modeset
ofpart
pcspkr
rapl
rc_core
rfcomm
rfkill
snd
snd_compress
snd_hda_codec
snd_hda_codec_generic
snd_hda_codec_hdmi
snd_hda_codec_realtek
snd_hda_core
snd_hda_ext_core
snd_hda_intel
snd_hrtimer
snd_hwdep
snd_intel_dspcfg
snd_pcm
snd_pcm_dmaengine
snd_seq
snd_seq_device
snd_seq_dummy
snd_soc_acpi
snd_soc_acpi_intel_match
snd_soc_core
snd_soc_hdac_hda
snd_soc_skl
snd_soc_sst_dsp
snd_soc_sst_ipc
snd_sof
snd_sof_intel_byt
snd_sof_intel_hda
snd_sof_intel_hda_common
snd_sof_intel_ipc
snd_sof_pci
snd_sof_xtensa_dsp
snd_timer
soundcore
spi_nor
squashfs
syscopyarea
sysfillrect
sysimgblt
typec
typec_ucsi
ucsi_ccg
uinput
usbhid
vboxdrv
vboxnetadp
vboxnetflt
vfat
wmi
wmi_bmof
x86_pkg_temp_thermal
x_tables
xhci_hcd
xhci_pci
!!Sysfs Files
/sys/class/sound/hwC0D0/init_pin_configs:
0x12 0x411111f0
0x14 0x01014010
0x15 0x01011012
0x16 0x01016011
0x17 0x403fc500
0x18 0x01a19040
0x19 0x02a19050
0x1a 0x0181304f
0x1b 0x02214020
0x1d 0x40e8e669
0x1e 0x01452130
/sys/class/sound/hwC0D0/driver_pin_configs:
/sys/class/sound/hwC0D0/user_pin_configs:
/sys/class/sound/hwC0D0/init_verbs:
/sys/class/sound/hwC0D0/hints:
/sys/class/sound/hwC1D0/init_pin_configs:
0x04 0x185600f0
0x05 0x185600f0
0x06 0x185600f0
0x07 0x185600f0
/sys/class/sound/hwC1D0/driver_pin_configs:
/sys/class/sound/hwC1D0/user_pin_configs:
/sys/class/sound/hwC1D0/init_verbs:
/sys/class/sound/hwC1D0/hints:
!!ALSA/HDA dmesg
Both of these commands were run with my headphones connected.
I should also note that it’s my first time posting here, so let me know if I’m doing something wrong or I need to provide more information.
Thanks!
Tim
EDIT: Now with complete ``inxi``` output
