I can’t get my bluetooth adapter get running. I have a Geekom Mini IT13 and bluetooth doesn’t run from the installed version also when booting from USB Stick with latest version of manjaro. I also tried several kernels from 5.1 to 6.8. I also cut the power off and resarted the computer after several minutes up to half a hour.
Any help is appreciated.
Here are the system messages.
The error message itself
sudo dmesg | grep hci0
[ 6.349916] Bluetooth: hci0: Opcode 0x0c03 failed: -110
[11969.490001] Bluetooth: hci0: Opcode 0x0c03 failed: -110
[11987.196327] Bluetooth: hci0: Opcode 0x0c03 failed: -110
System Info
inxi --full --admin --filter --width
Kernel: 6.6.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: root=UUID=439ce4c8-69f4-49b3-8294-2a3bab2eed24 rw quiet splash
resume=UUID=37402339-ef41-42e5-8a4f-39dc9bbbf083 udev.log_priority=3
initrd=boot\initramfs-6.6-x86_64.img
Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
v: 5.115.0 wm: kwin_wayland vt: 1 dm: 1: LightDM v: 1.32.0 note: stopped
2: SDDM Distro: Manjaro base: Arch Linux
Type: Desktop System: GEEKOM product: Mini IT13 v: N/A
serial: <superuser required>
Mobo: N/A model: N/A serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: 1.09
date: 11/10/2023
Device-1: hidpp_battery_0 model: Logitech K850 Performance Wireless Keyboard
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Device-2: hidpp_battery_1 model: Logitech M720 Triathlon Multi-Device Mouse
status: discharging
Info: model: 13th Gen Intel Core i9-13900H bits: 64 type: MST AMCP
arch: Raptor Lake gen: core 13 level: v3 note: check built: 2022+
process: Intel 7 (10nm) family: 6 model-id: 0xBA (186) stepping: 2
microcode: 0x4112
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 435 high: 831 min/max: 400/5200:5400:4100 scaling:
driver: intel_pstate governor: powersave cores: 1: 678 2: 400 3: 400 4: 400
5: 400 6: 400 7: 400 8: 831 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 bogomips: 119840
Type: reg_file_data_sampling status: Vulnerable: No microcode
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
Device-1: Intel Raptor Lake-P [Iris Xe Graphics] driver: i915 v: kernel
arch: Gen-13 process: Intel 7 (10nm) built: 2022+ ports: active: HDMI-A-1
empty: DP-1,DP-2,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:a7a0 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.12 with: Xwayland v: 23.2.6
compositor: kwin_wayland driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: 0
Monitor-1: HDMI-A-1 res: 3491x1964 size: N/A modes: N/A
device: 1 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-P)
device-ID: 8086:a7a0 memory: 30.38 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: N/A device: 0 type: integrated-gpu
name: Intel Graphics (RPL-P) driver: mesa intel v: 24.0.2-manjaro1.1
device-ID: 8086:a7a0 surfaces: xcb,xlib,wayland
Device-1: Intel Raptor Lake-P/U/H cAVS driver: snd_hda_intel v: kernel
alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:51ca
class-ID: 0403
Device-2: Texas Instruments PCM2902 Audio Codec
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-2:5 chip-ID: 08bb:2902 class-ID: 0300
API: ALSA v: k6.6.26-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
Device-1: MEDIATEK MT7922 802.11ax PCI Express Wireless Network Adapter
vendor: AzureWave driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 56:00.0 chip-ID: 14c3:7922 class-ID: 0280
Device-2: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 57:00.0 chip-ID: 8086:15f3
class-ID: 0200
IF: enp87s0 state: down mac: <filter>
Device-1: IMC Networks Wireless_Device driver: btusb v: 0.8 type: USB
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:4 chip-ID: 13d3:3585
Report: hciconfig ID: hci0 rfk-id: 2 state: down
bt-service: enabled,running rfk-block: hardware: no software: no
address: <filter>
Info: acl-mtu: 0:0 sco-mtu: 0:0 link-mode: peripheral accept
Local Storage: total: 1.86 TiB used: 117.43 GiB (6.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Lexar model: SSD NM7A1 2TB
size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 9742 temp: 36.9 C scheme: GPT
ID-1: / raw-size: 100 GiB size: 97.87 GiB (97.87%) used: 31.9 GiB (32.6%)
fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: /boot/efi raw-size: 37.79 GiB size: 37.78 GiB (99.98%)
used: 22.5 MiB (0.1%) fs: vfat dev: /dev/nvme0n1p5 maj-min: 259:5
ID-3: /home raw-size: 1.57 TiB size: 1.55 TiB (98.36%)
used: 85.51 GiB (5.4%) fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
ID-1: swap-1 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p6 maj-min: 259:6
System Temperatures: cpu: 46.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 32 GiB note: est. available: 31.11 GiB used: 9.11 GiB (29.3%)
Processes: 359 Power: uptime: 4h 39m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 12.43 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: pm: pacman pkgs: 1807 libs: 446 tools: pamac,yay pm: flatpak
pkgs: 0 Compilers: clang: 16.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9 default: Bash
v: 5.2.26 running-in: konsole inxi: 3.3.34
Kernel Ring Buffer Logs
[ 0.115918] #1 #3 #5 #7 #9 #11
[ 0.125819] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.207998] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS04._UPC], AE_ALREADY_EXISTS (20230628/dswload2-326)
[ 0.208004] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[ 0.208007] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS04._PLD], AE_ALREADY_EXISTS (20230628/dswload2-326)
[ 0.208009] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[ 0.208147] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS10._UPC], AE_ALREADY_EXISTS (20230628/dswload2-326)
[ 0.208150] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[ 0.208152] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS10._PLD], AE_ALREADY_EXISTS (20230628/dswload2-326)
[ 0.208154] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[ 0.259580] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 0.259584] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS01._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 0.259605] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 0.259607] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS02._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 0.259626] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 0.259629] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS03._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 0.259699] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 0.259701] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS05._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 0.269886] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 0.269889] ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS01._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 0.269976] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 0.269978] ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS02._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 0.270065] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 0.270067] ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS03._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 0.270152] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 0.270155] ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS04._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 0.510550] pci 0000:00:07.0: DPC: RP PIO log size 0 is invalid
[ 0.511549] pci 0000:00:07.3: DPC: RP PIO log size 0 is invalid
[ 0.550406] pnp 00:02: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[ 0.579743] hpet_acpi_add: no address or irqs in _CRS
[ 1.041442] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.041454] ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS01._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 1.041482] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.041489] ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS01._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 1.041515] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.041521] ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS02._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 1.041540] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.041544] ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS02._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 1.041564] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.041569] ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS03._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 1.041589] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.041594] ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS03._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 1.041612] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.041617] ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS04._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 1.041635] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.041639] ACPI Error: Aborting method \_SB.PC00.TXHC.RHUB.SS04._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 1.046103] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.046107] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS01._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 1.046116] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.046118] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS01._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 1.046126] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.046128] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS02._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 1.046134] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.046136] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS02._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 1.046143] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.046145] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS03._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 1.046151] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.046155] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS03._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 1.046275] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.046278] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS05._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 1.046285] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.046288] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS05._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 1.052010] nvme nvme0: missing or invalid SUBNQN field.
[ 1.355452] ------------[ cut here ]------------
[ 1.355455] i915 0000:00:02.0: Port B asks to use VBT vswing/preemph tables
[ 1.355469] WARNING: CPU: 6 PID: 255 at drivers/gpu/drm/i915/display/intel_bios.c:2656 intel_bios_init+0x150d/0x1d20 [i915]
[ 1.355716] Modules linked in: i915(+) i2c_algo_bit sdhci_pci drm_buddy ttm cqhci sdhci intel_gtt nvme spi_intel_pci crc32c_intel mmc_core drm_display_helper spi_intel nvme_core xhci_pci xhci_pci_renesas cec nvme_common video wmi
[ 1.355730] CPU: 6 PID: 255 Comm: (udev-worker) Not tainted 6.6.26-1-MANJARO #1 810ec2d1597099b697461fea57746cd5c8b13c80
[ 1.355734] Hardware name: GEEKOM Mini IT13/Default string, BIOS 1.09 11/10/2023
[ 1.355736] RIP: 0010:intel_bios_init+0x150d/0x1d20 [i915]
[ 1.355939] Code: 49 8b 7c 24 08 48 8b 5f 50 48 85 db 75 03 48 8b 1f e8 17 e3 5f c3 89 e9 48 89 da 48 c7 c7 e0 90 77 c0 48 89 c6 e8 83 d5 d8 c2 <0f> 0b e9 56 fd ff ff 31 f6 48 85 db 74 04 48 8b 73 08 48 c7 c1 d8
[ 1.355941] RSP: 0018:ffffc90006fa3968 EFLAGS: 00010282
[ 1.355943] RAX: 0000000000000000 RBX: ffff8881030783f0 RCX: c0000000ffffdfff
[ 1.355945] RDX: 0000000000000000 RSI: 00000000ffffdfff RDI: 0000000000000001
[ 1.355946] RBP: 0000000000000042 R08: 0000000000000000 R09: ffffc90006fa37f0
[ 1.355948] R10: 0000000000000003 R11: ffff8888afbaa068 R12: ffff8881127e8000
[ 1.355949] R13: 0000000000000000 R14: 0000000000000001 R15: ffff8881137f88a0
[ 1.355950] FS: 00007fe7b9a8d540(0000) GS:ffff88888f780000(0000) knlGS:0000000000000000
[ 1.355952] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1.355953] CR2: 00007fe7ba6484d8 CR3: 000000010e8ea000 CR4: 0000000000f50ee0
[ 1.355955] PKRU: 55555554
[ 1.355957] Call Trace:
[ 1.355961] <TASK>
[ 1.355965] ? intel_bios_init+0x150d/0x1d20 [i915 4b00786c9bd3ba66599426eef2a64e2710fd3edc]
[ 1.356151] ? __warn+0x81/0x130
[ 1.356157] ? intel_bios_init+0x150d/0x1d20 [i915 4b00786c9bd3ba66599426eef2a64e2710fd3edc]
[ 1.356331] ? report_bug+0x171/0x1a0
[ 1.356334] ? prb_read_valid+0x1b/0x30
[ 1.356338] ? handle_bug+0x3c/0x80
[ 1.356343] ? exc_invalid_op+0x17/0x70
[ 1.356347] ? asm_exc_invalid_op+0x1a/0x20
[ 1.356351] ? intel_bios_init+0x150d/0x1d20 [i915 4b00786c9bd3ba66599426eef2a64e2710fd3edc]
[ 1.356549] ? intel_bios_init+0x150d/0x1d20 [i915 4b00786c9bd3ba66599426eef2a64e2710fd3edc]
[ 1.356702] ? drm_vblank_worker_init+0x6b/0x80
[ 1.356707] intel_display_driver_probe_noirq+0x39/0x270 [i915 4b00786c9bd3ba66599426eef2a64e2710fd3edc]
[ 1.356891] i915_driver_probe+0x6ae/0xb90 [i915 4b00786c9bd3ba66599426eef2a64e2710fd3edc]
[ 1.357040] local_pci_probe+0x42/0xa0
[ 1.357045] pci_device_probe+0xc1/0x260
[ 1.357048] ? sysfs_do_create_link_sd+0x6e/0xe0
[ 1.357052] really_probe+0x19b/0x3e0
[ 1.357055] ? __pfx___driver_attach+0x10/0x10
[ 1.357058] __driver_probe_device+0x78/0x160
[ 1.357060] driver_probe_device+0x1f/0x90
[ 1.357063] __driver_attach+0xd2/0x1c0
[ 1.357066] bus_for_each_dev+0x85/0xd0
[ 1.357068] bus_add_driver+0x116/0x220
[ 1.357071] driver_register+0x59/0x100
[ 1.357074] i915_init+0x22/0xc0 [i915 4b00786c9bd3ba66599426eef2a64e2710fd3edc]
[ 1.357238] ? __pfx_i915_init+0x10/0x10 [i915 4b00786c9bd3ba66599426eef2a64e2710fd3edc]
[ 1.357390] do_one_initcall+0x5a/0x320
[ 1.357395] do_init_module+0x60/0x240
[ 1.357399] init_module_from_file+0x89/0xe0
[ 1.357404] idempotent_init_module+0x120/0x2b0
[ 1.357408] __x64_sys_finit_module+0x5e/0xb0
[ 1.357412] do_syscall_64+0x5a/0x80
[ 1.357416] ? ksys_lseek+0x69/0xb0
[ 1.357420] ? syscall_exit_to_user_mode+0x22/0x40
[ 1.357423] ? do_syscall_64+0x66/0x80
[ 1.357425] ? do_syscall_64+0x66/0x80
[ 1.357428] ? ksys_lseek+0x69/0xb0
[ 1.357431] ? syscall_exit_to_user_mode+0x22/0x40
[ 1.357434] ? do_syscall_64+0x66/0x80
[ 1.357436] ? do_syscall_64+0x66/0x80
[ 1.357438] entry_SYSCALL_64_after_hwframe+0x78/0xe2
[ 1.357441] RIP: 0033:0x7fe7ba56f88d
[ 1.357446] Code: ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 63 14 0d 00 f7 d8 64 89 01 48
[ 1.357447] RSP: 002b:00007fff5d3342b8 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
[ 1.357449] RAX: ffffffffffffffda RBX: 0000561acaf42e10 RCX: 00007fe7ba56f88d
[ 1.357450] RDX: 0000000000000000 RSI: 00007fe7ba684376 RDI: 0000000000000032
[ 1.357452] RBP: 00007fe7ba684376 R08: 0000000000000001 R09: fffffffffffffe88
[ 1.357453] R10: 0000000000000050 R11: 0000000000000246 R12: 0000000000020000
[ 1.357454] R13: 0000561acaf19f50 R14: 0000000000000000 R15: 0000561acaf44900
[ 1.357456] </TASK>
[ 1.357457] ---[ end trace 0000000000000000 ]---
[ 1.357458] ------------[ cut here ]------------
[ 1.357459] i915 0000:00:02.0: Port D asks to use VBT vswing/preemph tables
[ 1.357466] WARNING: CPU: 6 PID: 255 at drivers/gpu/drm/i915/display/intel_bios.c:2656 intel_bios_init+0x150d/0x1d20 [i915]
[ 1.357658] Modules linked in: i915(+) i2c_algo_bit sdhci_pci drm_buddy ttm cqhci sdhci intel_gtt nvme spi_intel_pci crc32c_intel mmc_core drm_display_helper spi_intel nvme_core xhci_pci xhci_pci_renesas cec nvme_common video wmi
[ 1.357669] CPU: 6 PID: 255 Comm: (udev-worker) Tainted: G W 6.6.26-1-MANJARO #1 810ec2d1597099b697461fea57746cd5c8b13c80
[ 1.357672] Hardware name: GEEKOM Mini IT13/Default string, BIOS 1.09 11/10/2023
[ 1.357673] RIP: 0010:intel_bios_init+0x150d/0x1d20 [i915]
[ 1.357843] Code: 49 8b 7c 24 08 48 8b 5f 50 48 85 db 75 03 48 8b 1f e8 17 e3 5f c3 89 e9 48 89 da 48 c7 c7 e0 90 77 c0 48 89 c6 e8 83 d5 d8 c2 <0f> 0b e9 56 fd ff ff 31 f6 48 85 db 74 04 48 8b 73 08 48 c7 c1 d8
[ 1.357844] RSP: 0018:ffffc90006fa3968 EFLAGS: 00010282
[ 1.357846] RAX: 0000000000000000 RBX: ffff8881030783f0 RCX: c0000000ffffdfff
[ 1.357847] RDX: 0000000000000000 RSI: 00000000ffffdfff RDI: 0000000000000001
[ 1.357848] RBP: 0000000000000044 R08: 0000000000000000 R09: ffffc90006fa37f0
[ 1.357849] R10: 0000000000000003 R11: ffff8888afbaa068 R12: ffff8881127e8000
[ 1.357850] R13: 0000000000000000 R14: 0000000000000001 R15: ffff8881137f8480
[ 1.357851] FS: 00007fe7b9a8d540(0000) GS:ffff88888f780000(0000) knlGS:0000000000000000
[ 1.357852] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1.357853] CR2: 00007fe7ba6484d8 CR3: 000000010e8ea000 CR4: 0000000000f50ee0
[ 1.357855] PKRU: 55555554
[ 1.357855] Call Trace:
[ 1.357856] <TASK>
[ 1.357857] ? intel_bios_init+0x150d/0x1d20 [i915 4b00786c9bd3ba66599426eef2a64e2710fd3edc]
[ 1.358017] ? __warn+0x81/0x130
[ 1.358020] ? intel_bios_init+0x150d/0x1d20 [i915 4b00786c9bd3ba66599426eef2a64e2710fd3edc]
[ 1.358169] ? report_bug+0x171/0x1a0
[ 1.358172] ? prb_read_valid+0x1b/0x30
[ 1.358174] ? handle_bug+0x3c/0x80
[ 1.358177] ? exc_invalid_op+0x17/0x70
[ 1.358181] ? asm_exc_invalid_op+0x1a/0x20
[ 1.358184] ? intel_bios_init+0x150d/0x1d20 [i915 4b00786c9bd3ba66599426eef2a64e2710fd3edc]
[ 1.358332] ? intel_bios_init+0x150d/0x1d20 [i915 4b00786c9bd3ba66599426eef2a64e2710fd3edc]
[ 1.358479] ? drm_vblank_worker_init+0x6b/0x80
[ 1.358482] intel_display_driver_probe_noirq+0x39/0x270 [i915 4b00786c9bd3ba66599426eef2a64e2710fd3edc]
[ 1.358654] i915_driver_probe+0x6ae/0xb90 [i915 4b00786c9bd3ba66599426eef2a64e2710fd3edc]
[ 1.358782] local_pci_probe+0x42/0xa0
[ 1.358786] pci_device_probe+0xc1/0x260
[ 1.358788] ? sysfs_do_create_link_sd+0x6e/0xe0
[ 1.358791] really_probe+0x19b/0x3e0
[ 1.358793] ? __pfx___driver_attach+0x10/0x10
[ 1.358796] __driver_probe_device+0x78/0x160
[ 1.358798] driver_probe_device+0x1f/0x90
[ 1.358801] __driver_attach+0xd2/0x1c0
[ 1.358803] bus_for_each_dev+0x85/0xd0
[ 1.358805] bus_add_driver+0x116/0x220
[ 1.358807] driver_register+0x59/0x100
[ 1.358810] i915_init+0x22/0xc0 [i915 4b00786c9bd3ba66599426eef2a64e2710fd3edc]
[ 1.358939] ? __pfx_i915_init+0x10/0x10 [i915 4b00786c9bd3ba66599426eef2a64e2710fd3edc]
[ 1.359062] do_one_initcall+0x5a/0x320
[ 1.359066] do_init_module+0x60/0x240
[ 1.359069] init_module_from_file+0x89/0xe0
[ 1.359073] idempotent_init_module+0x120/0x2b0
[ 1.359077] __x64_sys_finit_module+0x5e/0xb0
[ 1.359080] do_syscall_64+0x5a/0x80
[ 1.359082] ? ksys_lseek+0x69/0xb0
[ 1.359085] ? syscall_exit_to_user_mode+0x22/0x40
[ 1.359087] ? do_syscall_64+0x66/0x80
[ 1.359089] ? do_syscall_64+0x66/0x80
[ 1.359091] ? ksys_lseek+0x69/0xb0
[ 1.359094] ? syscall_exit_to_user_mode+0x22/0x40
[ 1.359097] ? do_syscall_64+0x66/0x80
[ 1.359098] ? do_syscall_64+0x66/0x80
[ 1.359100] entry_SYSCALL_64_after_hwframe+0x78/0xe2
[ 1.359103] RIP: 0033:0x7fe7ba56f88d
[ 1.359104] Code: ff c3 66 2e 0f 1f 84 00 00 00 00 00 90 f3 0f 1e fa 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 63 14 0d 00 f7 d8 64 89 01 48
[ 1.359105] RSP: 002b:00007fff5d3342b8 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
[ 1.359107] RAX: ffffffffffffffda RBX: 0000561acaf42e10 RCX: 00007fe7ba56f88d
[ 1.359108] RDX: 0000000000000000 RSI: 00007fe7ba684376 RDI: 0000000000000032
[ 1.359109] RBP: 00007fe7ba684376 R08: 0000000000000001 R09: fffffffffffffe88
[ 1.359110] R10: 0000000000000050 R11: 0000000000000246 R12: 0000000000020000
[ 1.359111] R13: 0000561acaf19f50 R14: 0000000000000000 R15: 0000561acaf44900
[ 1.359113] </TASK>
[ 1.359113] ---[ end trace 0000000000000000 ]---
[ 1.442848] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.442857] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS01._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 1.444451] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.444456] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS01._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 1.444488] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.444491] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS01._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 1.444515] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.444518] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS01._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 1.710972] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.710993] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS02._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 1.712341] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.712364] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS02._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 1.712450] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.712459] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS02._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 1.712503] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.712511] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS02._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 1.712557] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 1.712565] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS02._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 4.033211] intel-hid INTC1078:00: failed to enable HID power button
[ 4.195030] proc_thermal_pci 0000:00:04.0: error: proc_thermal_add, will continue
[ 9.735944] sddm-greeter[783]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[ 9.969716] block nvme0n1: No UUID available providing old NGUID
[ 73.123097] mt7921e 0000:56:00.0: not ready 65535ms after FLR; giving up
[ 79.006997] warning: `Qt bearer threa' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[ 4775.060356] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 4775.060379] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS02._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 4775.061874] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 4775.061904] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS02._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 4775.077395] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 4775.077408] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS02._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 4775.077459] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 4775.077465] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS02._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 4775.077508] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.UBTC.RUCC], AE_NOT_FOUND (20230628/psargs-330)
[ 4775.077513] ACPI Error: Aborting method \_SB.PC00.XHCI.RHUB.HS02._PLD due to previous error (AE_NOT_FOUND) (20230628/psparse-529)
[ 5791.466329] i915 0000:00:02.0: [drm] *ERROR* [CONNECTOR:236:HDMI-A-1] Failed to read TMDS config: -6
[10068.432663] xhci_hcd 0000:00:0d.0: xHC error in resume, USBSTS 0x401, Reinit
SystemD /Journal logs
[ 1.355961] <TASK>
[ 1.357456] </TASK>
[ 1.357856] <TASK>
[ 1.359113] </TASK>
