Hello,
once a minute I get LOG-Messages:
bluetoothd[1028]: src/profile.c:record_cb() Unable to get Hands-Free unit SDP record: Host is down
bluetoothd[1028]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
What is the reason and how can I stop that?
Thank you
Manfred
Hi @comparat,
From [SOLVED]Bluetoothd journal error message: Unable to get Hands-Free / Newbie Corner / Arch Linux Forums :
Do you have an actual problem or are you just wondering about the message? It simply can’t initialize the “old” hands-free protocol, which might be normal given that the HW seems to support aptx duplex and faststream. But still it’s kind of BT protocol “baseline” so it’s likely being probed anyway. I wouldn’t worry too much.
Thank you for your answer! I found that message too - but the many log messages bother me because, as a software developer, I constantly monitor the journal.
I also monitor the logs a loot, and I also have many warnings and some errors, but everything works, so I leave it and I suggest you do too.
