Mein großer Rechner findet den TV und die Lautsprecher nicht.
dmesg | egrep -i bluetooth ✔
[ 5.925134] Bluetooth: Core ver 2.22
[ 5.925154] NET: Registered PF_BLUETOOTH protocol family
[ 5.925155] Bluetooth: HCI device and connection manager initialized
[ 5.925157] Bluetooth: HCI socket layer initialized
[ 5.925159] Bluetooth: L2CAP socket layer initialized
[ 5.925161] Bluetooth: SCO socket layer initialized
[ 6.048388] Bluetooth: hci0: unexpected event for opcode 0x0000
[ 6.084932] audit: type=1130 audit(1643502869.039:57): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=bluetooth comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[ 6.104274] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.104277] Bluetooth: BNEP filters: protocol multicast
[ 6.104280] Bluetooth: BNEP socket layer initialized
[ 9.415889] Bluetooth: RFCOMM TTY layer initialized
[ 9.415897] Bluetooth: RFCOMM socket layer initialized
[ 9.415901] Bluetooth: RFCOMM ver 1.11
Das Notebook findet es anstandslos.
Da fehlt aber die Zeile mit dem audit. Dafür ist eine Zeile mit usb 1-1-1 dabei.
Weiß wer Rat ?
rfkill list ✔
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
lsusb ✔
Bus 007 Device 002: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
systemctl status dbus-org.bluez.service 4 ✘
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Sun 2022-01-30 01:34:29 CET; 34min ago
Docs: man:bluetoothd(8)
Main PID: 1290 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 14243)
Memory: 2.3M
CPU: 50ms
CGroup: /system.slice/bluetooth.service
└─1290 /usr/lib/bluetooth/bluetoothd
Jan 30 01:38:40 weingeist-PC bluetoothd[1290]: src/adv_monitor.c:btd_adv_monitor_offload_supported() Manager is NULL, get offload support failed
Jan 30 01:38:41 weingeist-PC bluetoothd[1290]: src/adv_monitor.c:btd_adv_monitor_offload_supported() Manager is NULL, get offload support failed
Jan 30 01:38:42 weingeist-PC bluetoothd[1290]: src/adv_monitor.c:btd_adv_monitor_offload_supported() Manager is NULL, get offload support failed
Jan 30 01:38:43 weingeist-PC bluetoothd[1290]: src/adv_monitor.c:btd_adv_monitor_offload_supported() Manager is NULL, get offload support failed
Jan 30 01:38:44 weingeist-PC bluetoothd[1290]: src/adv_monitor.c:btd_adv_monitor_offload_supported() Manager is NULL, get offload support failed
Jan 30 01:38:45 weingeist-PC bluetoothd[1290]: src/adv_monitor.c:btd_adv_monitor_offload_supported() Manager is NULL, get offload support failed
systemctl status bluetooth.service ✔
Active: active (running) since Sun 2022-01-30 01:34:29 CET; 37min ago
Status: "Running"
Memory: 2.3M
CPU: 54ms
bluetoothctl show 1 ✘
Controller 00:02:72:D5:4A:3A (public)
Alias: weingeist-PC
Class: 0x007c0104
Powered: yes
Discoverable: no
DiscoverableTimeout: 0x000000b4
Pairable: yes
UUID: A/V Remote Control (0000110e-0000-1000-8000-00805f9b34fb)
UUID: PnP Information (00001200-0000-1000-8000-00805f9b34fb)
UUID: Message Access Server (00001132-0000-1000-8000-00805f9b34fb)
UUID: Audio Sink (0000110b-0000-1000-8000-00805f9b34fb)
UUID: Message Notification Se.. (00001133-0000-1000-8000-00805f9b34fb)
UUID: Phonebook Access Server (0000112f-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
UUID: OBEX Object Push (00001105-0000-1000-8000-00805f9b34fb)
UUID: IrMC Sync (00001104-0000-1000-8000-00805f9b34fb)
UUID: OBEX File Transfer (00001106-0000-1000-8000-00805f9b34fb)
UUID: Vendor specific (00005005-0000-1000-8000-0002ee000001)
UUID: Handsfree Audio Gateway (0000111f-0000-1000-8000-00805f9b34fb)
UUID: Audio Source (0000110a-0000-1000-8000-00805f9b34fb)
UUID: Headset (00001108-0000-1000-8000-00805f9b34fb)
Modalias: usb:v1D6Bp0246d053F
Discovering: yes
