Hi,
I am trying to connect to my smart-phone from my manjaro desktop PC using bluetooth. Both, the cdl and the gui often return the following error when attempting to pair:
Failed to connect: org.bluez.Error.Failed br-connection-unknown
I installed the bluetooth software: pamac install manjaro-bluetooth
and set AutoEnable=true
in the configuration file.
Here is a summary of the commands + output I used:
(base) [dejhost@Workstation ~]$ bluetoothctl devices
Device 74:5C:4B:A3:A0:55 Jabra GN
bluetoothctl agent on
bluetoothctl scan on
[NEW] Device 7C:38:AD:5C:C5:D1 Galaxy S10
(base) [dejhost@Workstation ~]$ bluetoothctl pair 7C:38:AD:5C:C5:D1
Attempting to pair with 7C:38:AD:5C:C5:D1
[DEL] Device 4D:06:8D:4A:D2:12 4D-06-8D-4A-D2-12
[CHG] Device 7C:38:AD:5C:C5:D1 Connected: yes
My phone shows a passkey (which I confirm, though I cannot see a passkey on my desktop), and then the desktop says:
Failed to pair: org.bluez.Error.AuthenticationFailed
Where would I enter this passkey on the desktop? Any hint much appreciated!
Olli
22 August 2023 09:07
2
hello @dejhost
please post the output of the mandatory
first. this will give us infos about the used kernel, distro, hardware. otherwise it’s just digging in the dark.
(base) [dejhost@Workstation ~]$ inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 6.1.44-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=7c6ac262-7b71-4cba-b35c-72277acbafa9 rw quiet apparmor=1
security=apparmor udev.log_priority=3 nmi_watchdog=0
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: docker, xfce4-panel
wm: xfwm v: 4.18.0 vt: 2 dm: 1: GDM v: 44.1 2: LightDM v: 1.32.0
note: stopped Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Micro-Star product: MS-7B89 v: 1.0
serial: <superuser required>
Mobo: Micro-Star model: B450M MORTAR MAX (MS-7B89) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 2.70
date: 04/21/2020
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard ERGO K860
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 32 GiB available: 31.29 GiB used: 8.53 GiB (27.3%)
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 2505 high: 4251 min/max: 2200/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3599 2: 2200
3: 2200 4: 4251 5: 2185 6: 2057 7: 2090 8: 2200 9: 2200 10: 2200 11: 2200
12: 2200 13: 3621 14: 2057 15: 2200 16: 3800 17: 2200 18: 2200 19: 2200
20: 3599 21: 2075 22: 2200 23: 2200 24: 2200 bogomips: 182462
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spec_rstack_overflow mitigation: safe RET
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ASUSTeK driver: nvidia
v: 535.98 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-08) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 26:00.0 chip-ID: 10de:2484
class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.4:10
chip-ID: 046d:082d class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.1.2
compositor: xfwm v: 4.18.0 driver: X: loaded: nvidia gpu: nvidia
display-ID: :1.0 screens: 1
Screen-1: 0 s-res: 11520x2160 s-dpi: 96 s-size: 3048x572mm (120.00x22.52")
s-diag: 3101mm (122.09")
Monitor-1: DP-0 pos: primary,center res: 3840x2160 hz: 60 dpi: 163
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
Monitor-2: DP-2 pos: left res: 3840x2160 hz: 60 dpi: 163
Monitor-3: DP-4 pos: right res: 3840x2160 hz: 60 dpi: 163
API: OpenGL v: 4.6.0 NVIDIA 535.98 renderer: NVIDIA GeForce RTX
3070/PCIe/SSE2 direct-render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
link-max: gen: 4 speed: 16 GT/s bus-ID: 26:00.1 chip-ID: 10de:228b
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 28:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: GN Netcom Jabra SPEAK 510 driver: jabra,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.3:8
chip-ID: 0b0e:0420 class-ID: 0300 serial: <filter>
Device-4: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.1.44-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.77 status: off with: pipewire-media-session
status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-a88cee8f84e5 state: down mac: <filter>
IF-ID-2: br-a96c1ef81739 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
IF-ID-3: br-d5799e778888 state: down mac: <filter>
IF-ID-4: docker0 state: down mac: <filter>
IF-ID-5: veth9c54733 state: up speed: 10000 Mbps duplex: full mac: <filter>
IF-ID-6: vethd313693 state: up speed: 10000 Mbps duplex: full mac: <filter>
Device-1: Cambridge Silicon Radio Bluetooth Dongle (HCI mode) driver: btusb
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2.3:5
chip-ID: 0a12:0001 class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.0
lmp-v: 6 status: discoverable: yes pairing: yes class-ID: 7c0104
Local Storage: total: 3.57 TiB used: 486.6 GiB (13.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP510
size: 1.75 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: ECFM22.5 temp: 39.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 41.9 C
Optical-1: /dev/sr0 vendor: hp model: DVD-RAM GH82N rev: W204
dev-links: cdrom
ID-1: / raw-size: 1.33 TiB size: 1.31 TiB (98.35%) used: 486.57 GiB (36.4%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 7c6ac262-7b71-4cba-b35c-72277acbafa9
used: 29.6 MiB (30.9%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 9EFE-2CB7
ID-1: swap-1 type: file size: 38 GiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 529 MiB fs: ntfs label: Recovery
uuid: A644FDD844FDAB67
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 428.38 GiB fs: ntfs label: N/A
uuid: 24D4FF51D4FF23A8
Device-1: 1-4:2 info: eWBM Security Key(Goldengate G310) type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 311f:4a1a class-ID: 0300
serial: <filter>
Hub-4: 3-1:2 info: VIA Labs Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2811
Device-1: 3-1.1:4 info: Logitech Unifying Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c52b class-ID: 0300
Device-2: 3-1.2:6 info: Xenta 2.4G Mouse type: keyboard,mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 1d57:0001 class-ID: 0301
Device-3: 3-1.3:8 info: GN Netcom Jabra SPEAK 510 type: audio,HID
driver: jabra,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
Device-4: 3-1.4:10 info: Logitech HD Pro Webcam C920 type: video,audio
Hub-5: 3-2:3 info: VIA Labs Hub ports: 4 rev: 2.1
Device-1: 3-2.3:5 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: bluetooth driver: btusb interfaces: 2 rev: 2.0
Device-2: 3-2.4:7 info: Razer USA DeathAdder Elite type: mouse,keyboard
lanes: 1 mode: 1.1 power: 500mA chip-ID: 1532:005c class-ID: 0300
Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
System Temperatures: cpu: 53.1 C mobo: N/A gpu: nvidia temp: 48 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Processes: 486 Uptime: 55m wakeups: 5 Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7 Packages: 1931
pm: pacman pkgs: 1875 libs: 424 tools: pamac,yay pm: flatpak pkgs: 26
pm: snap pkgs: 30 Shell: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.29
Olli
22 August 2023 09:22
4
question: you’re running the actual kernel 6.xxx series. there are several issues already reported with networking. did this issue occured on former kernels in the past ?
welcome to the club: is this a dongle of the “hama” brand ?
you can try to install the depreceated “bluez-utils-compat” package that supports hci-modes not used in the actual bluez-utils package.
question:
what kind of bluetooth-devices do you wanna connect ? some esoteric devices ?
I am not using BT regularly. I remember that I connected my smartphone earlier, but this might be 2 years ago or so.
The dongle is an earlier version of this one here
Right now, I am testing connectivity with my Samsung GAlaxy S10 and a Zagg keyboard . My goal is to execute python script using a BT-remote control. So in the longrun, I could use s.th. like this . Let me know, if you have a recommendation for the hardware (avoid compatibility issues). A simple remote with a few simple buttons would do.
bluez was already installed. I tried using the GUI - and it works:
Thank you, Olli!
system
Closed
25 August 2023 01:41
6
