I noticed recently (probably since last update) that my laptop’s bluetooth turns on itself quite often, which tends to highly annoy me. After a few tests I found out that it happens when it wakes up from sleep, and after booting as well.
I don’t really know what info to provide, so let’s start with inxi:
I had thought of this solution but as you said it makes bluetooth completely unavaiable, which is quite unconvenient when I need to use it. Thanks anyway
# AutoEnable defines option to enable all controllers when they are found.
# This includes adapters present on start as well as adapters that are plugged
# in later on. Defaults to 'true'.
AutoEnable=false
It worked \m/ thanks a lot mate =)
For anyone who would read this thread, the line to modify was commented in my case, so mak sure to uncomment it (delete the “#” at its beginning)
