Bluetooth don't work
How can I see if my headphones are visible?With a mobile phone android 9, the headphones are visible and work
sudo lshw | grep blu
                      capabilities: bluetooth usb-2.00
[manjaro manjaro]# systemctl status bluetooth
● bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
     Active: active (running) since Wed 2025-06-11 08:42:06 CDT; 16min ago
 Invocation: 7d7a6ea476634a9dba4b354236282fc8
       Docs: man:bluetoothd(8)
   Main PID: 3095 (bluetoothd)
     Status: "Running"
      Tasks: 1 (limit: 4644)
     Memory: 2.3M (peak: 2.7M)
        CPU: 105ms
     CGroup: /system.slice/bluetooth.service
             └─3095 /usr/lib/bluetooth/bluetoothd
Jun 11 08:44:54 manjaro bluetoothd[3095]: Endpoint registered: sender=:1.110 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Jun 11 08:44:54 manjaro bluetoothd[3095]: Endpoint registered: sender=:1.110 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Jun 11 08:44:54 manjaro bluetoothd[3095]: Endpoint registered: sender=:1.110 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Jun 11 08:44:54 manjaro bluetoothd[3095]: Endpoint registered: sender=:1.110 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Jun 11 08:44:54 manjaro bluetoothd[3095]: Endpoint registered: sender=:1.110 path=/MediaEndpoint/A2DPSource/faststream
Jun 11 08:44:54 manjaro bluetoothd[3095]: Endpoint registered: sender=:1.110 path=/MediaEndpoint/A2DPSource/faststream_duplex
Jun 11 08:44:54 manjaro bluetoothd[3095]: Endpoint registered: sender=:1.110 path=/MediaEndpoint/A2DPSink/opus_05
Jun 11 08:44:54 manjaro bluetoothd[3095]: Endpoint registered: sender=:1.110 path=/MediaEndpoint/A2DPSource/opus_05
Jun 11 08:44:54 manjaro bluetoothd[3095]: Endpoint registered: sender=:1.110 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Jun 11 08:44:54 manjaro bluetoothd[3095]: Endpoint registered: sender=:1.110 path=/MediaEndpoint/A2DPSource/opus_05_duplex
gnome-control-center bluetooth
09:16:22.5323 Gtk[ 5282]: WARNING: Unable to acquire session bus: Error spawning command line “dbus-launch --autolaunch=3272937d8164426bbe7fbad5e471a053 --binary-syntax --close-stderr”: Child process exited with code 1
09:16:23.1264 Bluetooth[ 5282]: WARNING: Failed to get session proxy: Error spawning command line “dbus-launch --autolaunch=3272937d8164426bbe7fbad5e471a053 --binary-syntax --close-stderr”: Child process exited with code 1
09:16:23.1470 GLib-GIO[ 5282]:CRITICAL: g_dbus_proxy_get_cached_property: assertion ‘G_IS_DBUS_PROXY (proxy)’ failed
09:16:23.1471 GLib[ 5282]:CRITICAL: g_variant_get_type: assertion ‘value != NULL’ failed
09:16:23.1471 GLib[ 5282]:CRITICAL: g_variant_type_is_subtype_of: assertion ‘g_variant_type_check (type)’ failed
09:16:23.1471 GLib[ 5282]:CRITICAL: g_variant_get_boolean: assertion ‘g_variant_is_of_type (value, G_VARIANT_TYPE_BOOLEAN)’ failed
09:16:23.1471 GLib-GIO[ 5282]:CRITICAL: g_dbus_proxy_get_cached_property: assertion ‘G_IS_DBUS_PROXY (proxy)’ failed
09:16:23.1472 GLib[ 5282]:CRITICAL: g_variant_get_boolean: assertion ‘g_variant_is_of_type (value, G_VARIANT_TYPE_BOOLEAN)’ failed
09:16:23.1472 GLib-GIO[ 5282]:CRITICAL: g_dbus_proxy_get_cached_property: assertion ‘G_IS_DBUS_PROXY (proxy)’ failed
09:16:23.1472 GLib[ 5282]:CRITICAL: g_variant_get_type: assertion ‘value != NULL’ failed
09:16:23.1472 GLib[ 5282]:CRITICAL: g_variant_type_is_subtype_of: assertion ‘g_variant_type_check (type)’ failed
09:16:23.1473 GLib-GIO[ 5282]:CRITICAL: g_dbus_proxy_get_cached_property: assertion ‘G_IS_DBUS_PROXY (proxy)’ failed
09:16:23.1473 GLib[ 5282]:CRITICAL: g_variant_get_type: assertion ‘value != NULL’ failed
09:16:23.1473 GLib[ 5282]:CRITICAL: g_variant_type_is_subtype_of: assertion ‘g_variant_type_check (type)’ failed
09:16:23.1473 GLib[ 5282]:CRITICAL: g_variant_get_boolean: assertion ‘g_variant_is_of_type (value, G_VARIANT_TYPE_BOOLEAN)’ failed
09:16:23.1475 GLib-GObject[ 5282]:CRITICAL: invalid (NULL) pointer instance
09:16:23.1475 GLib-GObject[ 5282]:CRITICAL: g_signal_connect_object: assertion ‘G_TYPE_CHECK_INSTANCE (instance)’ failed
09:16:23.1499 dconf[ 5282]: WARNING: failed to commit changes to dconf: Error spawning command line “dbus-launch --autolaunch=3272937d8164426bbe7fbad5e471a053 --binary-syntax --close-stderr”: Child process exited with code 1
MESA: error: Failed to attach to x11 shm
Moderator edit: Messages are merged. This is a forum, not a chat software. Make use of the edit button and read [HowTo] Request support Thanks.
Tomorrow I’ll try to install a hard drive with Ubuntu on this computer and connect Bluetooth
Mint 22 Mate:
hciconfig -a
hci0: Type: Primary Bus: USB
BD Address: 00:1F:81:00:00:01 ACL MTU: 339:6 SCO MTU: 180:1
UP RUNNING PSCAN ISCAN
RX bytes:561 acl:0 sco:0 events:32 errors:0
TX bytes:641 acl:0 sco:0 commands:31 errors:0
Features: 0xef 0x3e 0x09 0xf0 0x0b 0x08 0x00 0x80
Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
Link policy: RSWITCH HOLD SNIFF
Link mode: PERIPHERAL ACCEPT
Class: 0x7c0104
Service Classes: Rendering, Capturing, Object Transfer, Audio, Telephony
Device Class: Computer, Desktop workstation
HCI Version: 1.2 (0x2) Revision: 0x2
LMP Version: 1.2 (0x2) Subversion: 0x2
Manufacturer: Accel Semiconductor Ltd. (74)
On Mint 22 Mate It works automatically
And it’s interesting that the USB audio stick works on Manjaro, but the Bluetooth USB stick doesn’t.I’ll try it on EndeavourOS tomorrow
