That’s de issue: Bluetooth does not work with kernel 5.15.2-2, it worked with 5.14.18-1
In 5.15 I can’t activate it. In 5.14 it autostarts normally.
any suggestion?
Thank you so much
Hi, then stay back Linux Kernel 5.14, no need upgrade to 5.15.
If you need LTS (Long-term support) of kernel, then maybe take 5.10.
Thank you for your suggestion.
Maybe it will be fixed with next updates.
Pulling out the power cable (while the machine was running) fixed the issue for me.
Source: Bluetooth unavailable after updates - Reading Intel version information failed (-110)
