Bluetooth does not work on gnome
When I’m trying to turn bluetooth on in gnome settings nothing happens: it still says, that bluetooth turned off. I found out, that it was soft blocked on rfkill list, so I entered rfkill unblock bluetooth, now it says, that it is not blocked, but the probem persist.
I don’t know if it helps, but I installed manjaro using “manjaro architect” and choosed “custom desktop enviroment” (or something like this), so it possible, that I accidentally skipped important step during the installation.
My laptop is Xiaomi Mi Notebook Air 13.3
$ ~> inxi --admin --verbosity=7 --filter --no-host --width
  Kernel: 5.4.97-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
  root=UUID=91aa9b1d-d526-4210-9a7a-84aee6250a0a ro
  cryptdevice=UUID=7fc8779a-3b81-47bc-bc29-2dd7120938fd:cryptroot quiet
  udev.log_priority=3
  Desktop: GNOME 3.38.3 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
  Distro: Manjaro Linux
  Type: Laptop System: Timi product: TM1703 v: XMAKB3M0P160F serial: <filter>
  Mobo: Timi model: TM1703 v: XMAKB3M0P160F serial: <filter>
  UEFI [Legacy]: Insyde v: XMAKB3M0P160F date: 03/08/2019
  ID-1: BAT0 charge: 21.7 Wh condition: 30.7/40.1 Wh (76%) volts: 7.9/7.6
  model: SUNWODA R13B02W type: Li-ion serial: <filter> status: Discharging
  RAM: total: 7.69 GiB used: 3.42 GiB (44.5%)
  RAM Report: missing: Required program dmidecode not available
  Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP
  arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: A (10)
  microcode: E0 L2 cache: 8 MiB bogomips: 32012
  Speed: 800 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
  4: 800 5: 800 6: 800 7: 801 8: 800
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
  avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
  hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid invpcid_single lahf_lm lm
  mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat
  rdrand rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1
  xsaves xtopology xtpr
  Type: l1tf
  Device-1: Intel UHD Graphics 620 vendor: Xiaomi driver: i915 v: kernel
  bus ID: 00:02.0 chip ID: 8086:5917 class ID: 0300
  Device-2: NVIDIA GP108BM [GeForce MX250] vendor: Xiaomi driver: nvidia
  v: 460.39 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1d52
  class ID: 0302
  Device-3: Cheng Uei Precision Industry (Foxlink) XiaoMi USB 2.0 Webcam
  type: USB driver: uvcvideo bus ID: 1-5:2 chip ID: 05c8:03a2 class ID: 0e02
  Display: x11 server: X.org 1.20.10 compositor: gnome-shell driver:
  loaded: modesetting,nvidia alternate: fbdev,intel,nouveau,nv,vesa
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Xiaomi
  driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus ID: 00:1f.3
  chip ID: 8086:9d71 class ID: 0403
  Sound Server: ALSA v: k5.4.97-1-MANJARO
  Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: 3000
  bus ID: 02:00.0 chip ID: 8086:24fd class ID: 0280
  bus ID: 1-7:4 chip ID: 8087:0a2b class ID: e001
  Message: Required tool hciconfig not installed. Check --recommends
  Local Storage: total: 238.47 GiB used: 80.12 GiB (33.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB256HAHQ-00000
  size: 238.47 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
  lanes: 4 rotation: SSD serial: <filter> rev: EXD7201Q scheme: MBR
  ID-1: / raw size: 238.47 GiB size: 233.73 GiB (98.01%)
  used: 80.12 GiB (34.3%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
  mapped: cryptroot label: N/A uuid: N/A
  ID-1: swap-1 type: file size: 7.68 GiB used: 0 KiB (0.0%) priority: -2
  file: /swapfile
  Message: No Unmounted partitions found.
  Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 12 rev: 2.0
  speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
  Device-1: 1-5:2
  info: Cheng Uei Precision Industry (Foxlink) XiaoMi USB 2.0 Webcam
  type: Video driver: uvcvideo interfaces: 2 rev: 2.0 speed: 480 Mb/s
  Device-2: 1-6:3 info: Elan Micro ELAN:Fingerprint type: <vendor specific>
  driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s chip ID: 04f3:0c1a
  class ID: 0000
  Device-3: 1-7:4 info: Intel Bluetooth wireless interface type: Bluetooth
  driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0a2b
  class ID: e001
  Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 3.0 speed: 5 Gb/s
  chip ID: 1d6b:0003 class ID: 0900
  System Temperatures: cpu: 43.0 C mobo: 36.0 C
  Processes: 260 Uptime: 2d 5h 20m wakeups: 11 Init: systemd v: 247 Compilers:
  gcc: 10.2.0 clang: 11.0.1 Packages: pacman: 1150 lib: 365 Shell: fish
  v: 3.1.2 running in: gnome-terminal inxi: 3.3.01
$ ~> rfkill list
0: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
5: hci0: Bluetooth
	Soft blocked: no
	Hard blocked: no
$ ~> sudo systemctl status bluetooth
● bluetooth.service - Bluetooth service
     Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; disabled; vendor preset: disabled)
     Active: inactive (dead)
       Docs: man:bluetoothd(8)
$ ~> lsmod | grep blu
bluetooth             692224  5 btrtl,btintel,btbcm,btusb
ecdh_generic           16384  1 bluetooth
rfkill                 28672  7 bluetooth,cfg80211
crc16                  16384  2 bluetooth,ext4
I got no idea what’s wrong and will appreciate any help.
Try:
sudo systemctl enable bluetooth.service
sudo systemctl start bluetooth.service
Also, check if bluez and bluz-utils is installed, they provide the bluetooth protocol stack.
You can also try using bluetoothctl in the terminal to see if it works as well.
Thanks, everything start working! bluez and bluez-utils have been already installed.
